Mirrors no longer fold when car locked
d*n
C?ID=165828
My A5 has just had a second hand CAN gateway fitted, with an extended CAN, during which my battery was disconnected and all my VAGCOM changes were reverted back to factory settings. I've recoded all the modules and everything works, except for some of the keyfob functionality:
1) the mirrors no longer fold when the car is locked. Strangely they close when I turn on the ignition, then fold out again.
The door controllers and central electric module long codes, before and after, are identical
There are no module errors
Module 46 (central electric) adaptation channel 01 has "folding mirrors installed and active" set
I retrofitted the mirrors about 8 months ago and both worked perfectly prior to the new gateway being installed. They fold with the driver door switch and the MMI option under central locking is selected. If I de-select the MMI option the mirrors no longer fold in and out when when the ignition is turned on (after the car is unlocked).
Has anyone come across this before?
I'm at a loss what to try next.
DrPeter
16.4905° S, 151.7375° W
Hi,
If I am not mistaken, these features you speak of are programed by the user and the instructions I believe were located in the owners manual.
- A similar feature/function for example.
drpeter
d*n
C?ID=165828
The mirrors should fold/retract when I lock the car and did before I installed the new CAN gateway.
They now fold/retract after I unlock the car and turn on the ignition! They then fold out again.
Its not a "setting the option in MMI" problem.
The door controller is processing the instruction to retract the mirrors to late. Could power to the door mirrors now be being switched off earlier than before?
d*n
C?ID=165828
Sure ... (I've removed some of the modules to fit in the 5000 character limit)
Tuesday,22,January,2013,17:46:46:15913
VCDS Version: 12.12.0.0
Data version: 20130910
Chassis Type: 8T (8T0)
Scan: 01 03 05 06 08 09 10 15 16 17 19 36 3C 42 46 47 52 53 55 56
          77
08-Auto HVAC -- Status: Status: OK 0000
   Part No SW: 8K0 907 289 C    HW: 8K0 907 289 C
   Component: BCM2.01       H38 0253
   Coding: 031000
   Shop #: WSC 06435 000 00000
   VCID: 397F137AB067BBD693D-806C
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H34 0050
   Subsystem 2 - Part No SW: 8K0 905 852 A    HW: 8K0 905 852 A
   Component: ELVAUDIB8  H33 0039
Address 06: Seat Mem. Pass (J521)       Labels: 8T0-959-760.clb
   Part No SW: 8T0 959 760 B    HW: 8T0 959 760 B
   Component: MEM-BFS       H09 0042
   Revision: AA000000    Serial number: 00001001032680
   Coding: 08217025002444111000
   Shop #: WSC 06325 000 00000
   VCID: 428D7496DDB1F80EC27-8017
   Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
   Component: BCM1 1.0      H21 0253
   Revision: 04021001    Serial number: 00000000037141
   Coding: 260050910014AF210709000000005D5D439D038800010141000000
   Shop #: WSC 39578 001 104857
   VCID: 2F6B2D227E2365663D9-807A
   Subsystem 1 - Part No SW: 8T2 955 119 B    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 190907  H11 0040
   Coding: 00FD11
   Component: RLS  H04 0002
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8T0 920 981 B    HW: 8T0 920 981 B
   Component: KOMBIINSTR.   H26 0212
   Revision: 00100000    Serial number: 71Y31G2A7
   Coding: 2F05010003002600010000
   VCID: 3B730972BA5B89C6811-806E
   Part No SW: 8T0 907 468 S    HW: 8T0 907 468 J
   Component: GW-BEM 6CAN   H06 0105
   Revision: HB600050    Serial number: 5000H09B1281DE
   Coding: 000003
   Shop #: WSC 06745 128 28888
   VCID: 51AF4BDA08D713964BD-8004
   Subsystem 1 - Part No SW: 8K0 915 181     HW: 8K0 915 181
   Component: J367-BDM  H06 0150
Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
   Component: MEM-FS        H09 0042
   Revision: AA000000    Serial number: 00001001033362
   Coding: 08297325002444111000
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8T0 959 793 J    HW: 8T0 959 793 D
   Component: TSG FA        H07 1301
   Coding: 011D02225201220102
   VCID: 50A94EDE03DD1A9E443-8005
   Revision: 00002001    Serial number: 0106082436
   Coding: 011F0680003904C0002000
   Component: DWA-Sensor  H02 0030
   Part No SW: 8T0 959 792 J    HW: 8T0 959 792 D
   Component: TSG BF        H07 1301
   Coding: 011D02225E01220100
   VCID: 4FAB4DA21EE305665D9-801A
Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
   Part No SW: 8T2 035 186 C    HW: 8T2 035 186 C
   Component: Concert3      H01 0210
   Revision: 00000003    Serial number: AUZ5Z6H1073986
   Coding: 000200820104CD00C7FBA70102
   Shop #: WSC 06325 123 12345
   VCID: 3879167E8B6DA2DE6C3-806D
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
What 5000 character limit? I just checked the setting where such a limit could be imposed and it's set to 0 which means there is no maximum number of characters per post here.
d*n
C?ID=165828
It appears the 5000 character limit applies only to PM's
