Hi all,
We currently have a 1997 Golf GTI 2.0 16v in the workshop with a faulty ABS controller.
Part number of the bad controller is 3A0 907 379E, Software Coding: 03704
The customer has provided us with a secondhand replacement controller 3A0 907 379A, Software Coding: 03604.
When we plug in this controller we get a control module incorrectly coded error. Entering the new coding has no effect.
As far as I know the controllers should be interchangeable because they both have the EDL function but I am open to correction on that.
First of all does anybody know if these controllers are interchangeable?
Secondly assuming they are then does anybody know if they require a login like the Bosch 5.3/5.5 before allowing coding? If so then can anyone shed any light on the procedure for generating the login?
Thanks in advance,
George
Friday,21,August,2015,12:38:11:36034
VCDS Version: Release 15.7.0 Running on Windows 8.1 x86
Address 03: ABS Brakes Labels: 3A0-907-379.lbl
Control Module Part Number: 3A0 907 379 E
Component and/or Version: ABS/EDS ITTAE 20 GI V00
Work Shop Code: WSC 00000
VCID: 2C57E3E7DC87F55EDA-4A84
35-00 - -
35-00 - -
Friday,21,August,2015,12:40:23:36034
Control Module Part Number: 3A0 907 379 A
Work Shop Code: WSC 66300
VCID: 285F1FF7C87FD97E3E-4A84
35-00 - -
Thanks in advance,
George
