P2413/009235 - Exhaust Gas Recirculation System - Performance Malfunction
mikeme
Alexandria/fairfax county VA
C?ID=99408
following up on this thread.
http://forums.tdiclub.com/showthread.php?p=4302223#post4302223
Default p2413 fix
I know this has been a more common issue with the CR Jettas but it happened to my Passat. I read all over the jetta side about this code with a/m air intakes. I got the same code with my stock air box, after further inspection the tube from the intake to the turbo had a crack in it. (for those that don't know, I rebuilt my Passat from a front end collision) The code is for EGR malfunction so I followed the flow chart in the Erwin service manual and it came back to a bad low pressure egr valve. I could not understand how this would cause this problem so I dug into the code a little more. This code is set when there are more than 4 fuel mass adaptions stored in the ECU. So I wondered if I could reset the fuel mass adaptions once I fixed the tube. Turns out in basic settings the first option was to reset fuel quantity, so I reset it. No more code. Erwin never mentioned this fix.
BTW: I waited to post this fix until my Readiness reset, so I would not make an A$$ of myself like I did with a previous post Now my code is off and my readiness has set. I hope this helps anyone else with this same problem.​
for this car:
 Thursday,20,August,2015,20:49:36:31289
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64(Parallels)
VCDS Version 15.7.0.1 (x64)
Data version: 20150729
Dealer/Shop Name: home
VIN: 3VWRL71K29M149332 License Plate:
Mileage: 218230km-135601mi Repair Order: home-3
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 65 72
VIN: 3VWRL71K29M149332 Mileage: 218230km-135601miles
Address 01: Engine (CBE) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 016 N HW: 03L 906 022 J
Component: R4 2,0L EDC G000SG 8680
Revision: 12H01--- Serial number: VWX7Z0I124P0FZ
Coding: 0050072
Shop #: WSC 00066 000 00000
VCID: 3D5FCDF4640B97D67D-8069
P2413 - 000 - Performance Malfunction - MIL ON
Fault Status: 11100000
Mileage: 218214 km
Voltage: 12.31 V
Torque: 0.0 Nm
Temperature: 89.1°C
Bin. Bits: 00000000
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 113B400D49260003880E02E7921B00423000
VCID: 74C928D0D7C1169E42-8021
02781 - ASR/ESP Button (E256)
Reset counter: 243
Mileage: 217556 km
Count: 12800
Count: 156
Count: 49408
Count: 2048
Part No SW: 1K0 820 047 JJ HW: 1K0 820 047 JJ
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000
VCID: 75CF15D41CBB0F9675-8021
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000009201851
Coding: 14018E234004150007140000001400000008730B5C000120000000000000
VCID: 3245EEC8AD5558AE90-8067
Component: Wischer 030309 021 0501
Coding: 00038805
Shop #: WSC 00066
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7I0529514
Coding: 0000100
VCID: 334BEBCC524F51A69B-8067
Reset counter: 182
Mileage: 188618 km
Time: 13:51:47
01304 - Radio
Fault Frequency: 40
Reset counter: 229
Mileage: 218013 km
Time: 15:22:51
Part No SW: 1K0 909 605 AC HW: 1K0 909 605 AC
Component: 21 AIRBAG VW8R 038 8600
Revision: 07038000 Serial number: 003E7M08V9U
Coding: 0012849
VCID: 6DFF3DB474EBC7568D-8039
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME46111037.
Subsystem 3 - Serial number: 6342MSME4200320C
Subsystem 4 - Serial number: 6351HSME1C0A71626
Subsystem 5 - Serial number: 6361HSME1C0A6B77M
Subsystem 6 - Serial number: 63727SME1C076600Z
Subsystem 7 - Serial number: 63827SME1B75252F9
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 055 0111
Coding: 0000131
VCID: 76CD12D801BD048E7C-8023
Component: E0221 002 0010
Part No SW: 1K0 920 974 N HW: 1K0 920 974 N
Component: KOMBIINSTRUMENT 3HL 2418
Revision: V0005000 Serial number: VWX7Z0I124P0FZ
Coding: 0023203
Shop #: WSC 00999 444 64523
VCID: 3957D9E47023ABF651-806D
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 050109F1000151
Coding: E9807F07001302001002
VCID: 3753DFDC4637BD86A7-8063
01304 - Radio
Reset counter: 182
Mileage: 188618 km
Time: 13:51:47
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0004
Revision: 00005000 Serial number: 1293324T3ZBT04
Coding: 0000003
Component: IMMO 3HL 2418
Shop #: WSC 06884 001 1048576
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000535689216
Coding: 0001205
VCID: 6FC327BC7EE73546BF-803B
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 70 2501
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2C79F0B08F710E5EDA-8079
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 DA HW: 1K0 959 433 DA
Component: KSG PQ35 RDK 052 0225
Revision: 00052000 Serial number: 00000000000000
Coding: 13900F880186281B0904058FB0880F0488DC00
VCID: 72C52EC86DD518AE50-8027
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 08112319255401
Coding: 0001204
VCID: 70C124C063D92ABEA6-8025
Address 56: Radio
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003776723
Coding: 0001168
Component: RDK 0453
Coding: 0100101
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003779358
Coding: 0001168
VCID: 77D31FDC06B77D8667-8023
End-------------------------(Elapsed Time: 01:25)--------------------------
any idea which basic setting or other would reset the suggested fuel mass flow?
mikeme
C?ID=99408
oops, can a moderator change the title of the first post and thread title to P2413? I must not have been awake yet yesterday morning.
mikeme
C?ID=99408
I have a similar car, and there is not a fuel mass adaptation listed.
any suggestions?
Gone But Not Forgotten
FYI Mike
The eeprom in this ecu tricore is buggy for such things as ADP lock up after a re-flash, learned value changes due to disruption or resets of DTC's and ADP's done out of sequence.
Me and Eric witnessed this repeatedly duplicated with the BDM.
Sometimes recoding the module helps also reset this in addition to DTC resets or ADP manually.
Don't worry you aren't the asshole here....... that's my job.
