2015 Audi S3 Sedan TPMS
fateTH
Canada
C?ID=243499
Hi everyone,
I have a 2015 Audi S3 Sedan, Canada spec, that I'm trying to enable the indirect TPMS.
Here is my auto scan:
Sunday,23,August,2015,14:36:38:02955
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
VIN: License Plate:
Mileage: 5008km-3111mi   Repair Order:
Chassis Type: FF (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 52 55
          5F 6C A5 A9
VIN: Mileage: 5008km-3111miles
Address 01: Engine (J623-CYFB)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 E    HW: 06K 907 425 E
   Revision: --H13---
   Coding: 0A1D00322466000E3004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V0906259E 001003
   ROD: EV_ECM20TFS0208V0906259E_AU37.rod
   VCID: 42A5BA1ED5845A2E00-8016
   Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4521
   Revision: 05853104    Serial number: TFK01502040143
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 1F63136A06B657C64F-804A
   Part No SW: 3Q0 907 379 R    HW: 3Q0 907 379 G
   Component: ESC           H42 0711
   Revision: 00000000    Serial number: 60325000000111
   Coding: 31FF6B9254210A700180030341C3698CD62A5080C08296B6184150880208
   VCID: 49B7AD32E8B28976C1-801C
   Revision: 00021000    Serial number: 0358587765
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: 3A55C2FEBD5412EE58-806E
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000565343
   Coding: 03000014010000000000000000001400
   VCID: 334BEFDA9A3EE3A69B-8066
   Part No SW: 5Q0 937 085 AC    HW: 5Q0 937 085 AC
   Component: BCM MQBAB HNA H18 0137
   Serial number: 01011503100728
   Coding: 04151C46C04106FD41C04004511807A00800000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 7AD502FEFDD4D2EE18-802E
   Slave 1:
   Component: WWS371 150208  042 0585
   Serial number:         150212145619
   Coding: 0A47F7
   Slave 2:
   Serial number: 23703699
   Coding: 00006C
   Slave 3:
   Serial number: 09 12 2014  00001112
   Serial number: 00000000000031795966
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST0004SWWO00000
   Coding: 101F00
204293 - Remote key 1
          B1479 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 231
                    Mileage: 4874 km
                    Date: 2015.08.19
                    Time: 15:38:47
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0051
   Revision: --------    Serial number: 39391503401199
   Coding: 0070150011
   ROD: EV_EPHVA18AU3700000_AU37.rod
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 N    HW: 5Q0 907 567 N
   Component: ACC3          H10 0400
   Serial number: 05021503031112
   Coding: 01261701FE0309
   ASAM Dataset: EV_ACCBoschMQB 001024
   ROD: EV_ACCBoschMQB_AU37.rod
   VCID: 46ADA60EF9AC660E2C-8012
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 E    HW: 8V0 907 376 E
   Component: DAEMPFUNGS-SG H09 0072
   Serial number:       310115015
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide_AU37.rod
   VCID: 43ABBF1ACA9E53260B-8016
   Serial number: 003GCR01ED77
   Coding: 9DCCFCC00000000050000000C04800000065
   VCID: 47B3AB0AFEA67F06D7-8012
   Seat belt tensioner; left:
   Serial number: 34178311B09021541043
   Coding: 333135
   Seat belt tensioner; right:
   Serial number: 34178312B09021541197
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 502 15
   Serial number: 357000000002FA39231H
   Subsystem 4 - Part No SW: -----------    HW: 480 000 502 15
   Serial number: 3580000000098A39231I
   Subsystem 5 - Part No SW: -----------    HW: 480 402 801 15
   Serial number: 3510002B31901D9473C+
   Subsystem 6 - Part No SW: -----------    HW: 480 400 302 15
   Serial number: 352000299196FF55F21I
   Subsystem 7 - Part No SW: -----------    HW: 480 400 801 15
   Serial number: 3550002991901DA283A4
   Subsystem 8 - Part No SW: -----------    HW: 480 400 801 15
   Serial number: 3560002991901DA4D0ED
   Part No SW: 8V0 953 521 ED    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 11021508490099
   Coding: E818
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 002170169B08883E56-8054
   Part No SW: 8V0 920 871 D    HW: 8V0 920 871 D
   Component: KOMBI         H02 4292
   Coding: 0B8D181B7E8800080281EA001800000000000000
   VCID: 3D5FC9E2AC7A25D67D-8068
   Revision: --------    Serial number: 07021510800817
   Coding: 0101000830085A005B00023C980B00000001010000000000000000000000
   ROD: EV_GatewConti.rod
   VCID: 72C52ADEA5A4AAAE50-8026
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 28 01 2015  C0081727
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Serial number: HA1-00009.01.15
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
   ROD: EV_AllWheelContrHA1VW37X_AU21.rod
   Revision: 00000000    Serial number: 15000028949002
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 3449ECC69F30E49E82-8060
Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Serial number: 0355726899
   Coding: 030211
   ROD: EV_LaneChangAssis_AU37.rod
   VCID: 3851D8F6835800FEAE-806C
   Lane Change Assistant 2:
   Serial number: 260115BAQ04018
   Coding: 005D1F204000048000000003
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Coding: 9102
   ROD: EV_SteerAssisMQB.rod
   VCID: 3753DBCA8E460F86A7-8062
   Serial number: 280115BAS00215
   Coding: 005D17204C00048000000003
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   VCID: 41A7B512D082413619-8014
   Component: AFS-ECU       H01 0091
   Coding: 0122000123200400
   VCID: 3FA3B3EAA67637C66F-806A
   Coding: E00100
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
   Component: LeiMo links  H01 7050
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
   Component: LeiMo rechts  H01 7050
   Coding: E00100
5544753 - LED Headlamp Power Output Stage; Right
          B149B 31 [008] - No Signal
                    Reset counter: 237
                    Mileage: 4959 km
                    Date: 2015.08.21
                    Time: 09:07:33
   Part No SW: 8V0 035 047 B    HW: 8V0 035 047 B
   Component: MU-H-NS-US    H43 0394
   Serial number: A052B0FB005021
   Coding: 017301020000000021220002041A00002F000224010001047E
   ROD: EV_MUHig6C3HBAS_AU37.rod
   Engine Control Module 2:
   Subsystem 1 - Part No SW: V03 959 800 SS    HW: -----------
   Component: NAR 2015  --- 0035
   Seat Adjustment Driver Side:
   Component: DU High  H49 0014
   Serial number: AUZ8Z9EY202JL4
   Sound System:
   Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
   Component: ControlUnit_H  H81 0816
   Serial number: C1000015121400040420
   Door Electronics Rear Left:
   Component: Gracenote  --- 3006
0020 - Tuner for Satelite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 159
                    Mileage: 4008 km
                    Date: 2015.07.23
                    Time: 14:25:45
Address 6C: Back-up Cam. (J772)       Labels: 5Q0-907-441.clb
   Coding: 027300010201000300
   ROD: EV_CamSysRearPANAAU914.rod
   VCID: 3041E0D66B28D8BEE6-8064
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0052
   Serial number: 00000280594
   Coding: 0100000000010303000500010100000100
   ROD: EV_MFKBoschAU370_AU37.rod
   VCID: 3B5BC7FAB26E2BE643-806E
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0012
   Serial number: 150131200042
   VCID: 7DDF09E2ECFAE5D63D-8028
End-------------------------(Elapsed Time: 04:15)--------------------------
I have read this thread http://forums.ross-tech.com/showthread.php?355-Security-Access-ABS-Module and this thread http://forums.ross-tech.com/showthread.php?1903-8V-A3-Tweaks&highlight=audi+tpms regarding the TPMS in the 8V Audi A3/S3s but their unaltered ABS module coding is slightly different than mine and I'm hesitant to make the changes suggested in those threads.
[table="width: 1000"]
[tr]
[td]My original code:[/td]
[td]31FF6B9254210A700180030341C3698CD62A5080C08296B6184150880208[/td]
[/tr]
[tr]
[td]User Veeeight's original code:[/td]
[td]30F193A254252A75017C070641C5690CC92A5480E08296F6F84150080608[/td]
[/tr]
[tr]
[td]Code change suggested by Sebastian to enable TPMS:[/td]
[td]30F193A254252A75017C070641C5690CC92A5480E08296F6F84150388608 [/td]
[/tr]
[/table]
It seems in Sebastian's suggestion to user Veeight, Byte 27's bit 4 and 5 were enabled and Byte 28's bit 7 was enabled to get activate TPMS. Can someone shed some light on whether I could emulate those bit changes to get TPMS?
To add to my confusion, I found an autoscan from user jster here: http://forums.ross-tech.com/showthread.php?3489-Auto-Scan-2015-Audi-A3 of a US spec Audi A3 sedan with standard TPMS.
His ABS long coding seems a lot more similar to mine but it doesn't match what was suggested by Sebastian in the other thread.
User jster's:
Address 03: ABS Brakes	Labels: None
	Revision: 00000000
	Coding: 13FF6A9234280A6E0177030381CC29C8562C5080C08194B4184150588208
	ROD: N/A
	VCID: 49D5CE27735D8A0346CD3D-801C
Mine:
Can any expert users or Ross-Tech employee offer some insight or advice regarding what correct coding to use? I would appreciate it very much!
m_bolc
San José, Costa Rica
C?ID=230356
Have a look here as well, I got it working on my 8V A3. I only changed two bits in the tail end of the long coding, as well as the 5F changes necessary for activation.
I see you already quoted my link in your message. From what I saw online while investigating the coding, TPMS is in those two bits I changed on my car. You won't see any change until you recode and restart your MMI unit.
fateTH
Canada
C?ID=243499
Solved
I found another scan of a 2015 S3 with similar specs to mine and determined the correct coding.
[table="width: 800"]
[tr]
[td]Original Code[/td]
[td] 31FF6B9254210A700180030341C3698CD62A5080C08296B6184150880208[/td]
[/tr]
[tr]
[td]New Code to enable TPMS[/td]
[td] 31FF6B9254210A700180030341C3698CD62A5080C08296B6184150D88208[/td]
[/tr]
[/table]
The rest of the process was the same as the other threads I quoted earlier.
m_bolc
C?ID=230356
FYI - I've found it is not very sensitive. The tire will be a good 5psi underinflated by the time it triggers the warning.
Andy
Sector 7G
HC424490
Out of curiosity, do you now have a TPMS reset choice in the display of the MIB?
m_bolc
C?ID=230356
Only if you change the appropriate adaptation in 5F.
