Missing Measuring Values for Reducing Agent for 2011 Audi Q7 TDI
venkatr
C?ID=255730
I just received my HEX-NET from Ross-Tech. I downloaded the VCDS 15.7 form Ross-Tech website.
The problem is that this version does not show in Adv. Meas. Values. I did try searching the blog and no updates.
Reducing agent fill level
Reducing agent tank fill level indicator; raw value
Sensor for reducing agent fill level; fill level
Status of a reducing agent warning-Bit 0 53
It only shows
Sensor for reducing agent fill level; voltage
Saturday,22,August,2015,20:24:05:65494
VCDS Version: 15.7.0.2 (x64)
Data version: 20150820
VIN: WA1LMAFE2BD000629   License Plate: AUDI_Q7
Mileage: 74050km-46012mi   Repair Order:
Chassis Type: FE (4F0)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 42 46 47 4C 4F 52 55 56
          5F 62 6C 6D 6F 72 76
VIN: WA1LMAFE2BD000629   Mileage: 74050km-46012miles
Address 01: Engine (J623-CATA)       Labels: 059-907-401-V2.clb
   Part No SW: 4L2 910 401     HW: 4L0 907 401 D
   Component: 3.0TDI EDC17  H16 0005
   Revision: 54H16---    Serial number:
   Coding: 2A2A4012252600050000
   Shop #: WSC 58959 000 1048576
   ASAM Dataset: EV_ECM30TDI0114L2910401 001005
   ROD: EV_ECM30TDI0114L2910401.rod
   VCID: E1DAEC5BF0B6FC36BA-80B4
Address 02: Auto Trans (J217)       Labels: 0C8-927-750.clb
   Part No SW: 0C8 927 750 S    HW: 0C8 927 750 S
   Component: AL1000 AISIN  001 1785
   Coding: 001378
   Shop #: WSC 58764 000 1048576
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: EV_TCMAL991031_AU56.rod
   VCID: BC647D2F3794F1DEC9-80E8
Address 03: ABS Brakes        Labels: 4L0-910-517-V2.clb
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 0099473
   Shop #: WSC 31414 790 00001
   VCID: B474550FD7C4399E01-80E0
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
   Component: FBSAUDIC6 ELV   H05 0130
   Revision: 00H05000    Serial number: 10602901600455
   Coding: 0000131
   Shop #: WSC 25161 444 999999
   VCID: A552B84B6C1E501686-80F0
   Subsystem 1 - Part No: 4F0 910 132 J
   Component: FBSAUDIC6 EZS   H03 0020
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H01 0054
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AE
   Component: KLIMA 4 ZONEN H13 0050
   Revision: 00---021    Serial number: 00000000238880
   Coding: 0002A036
   VCID: A552B84BAC1E501686-80F0
   Part No SW: 4F0 910 279 AD    HW: 4F0 907 279 D
   Component: ILM Fahrer      H28 0360
   Coding: 0039123
   VCID: EBC68E73CA7AA66610-80BE
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H17 0100
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                    Reset counter: 132
                    Mileage: 74048 km
                    Date: 2015.08.22
                    Time: 16:40:00
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH43 0230
   Revision: 07H43000    Serial number: 0038QD09G50.
   Coding: 0014131
   VCID: AB464E730AFA666650-80FE
   Subsystem 1 - Part No: 4L0 910 339 A
   Component: BF-Gewichtsens. H03 0030
   Subsystem 2 - Serial number: 6332QSME4B570708H
   Subsystem 3 - Serial number: 6342QSME4B572600B
   Subsystem 4 - Serial number: 6352QSME115853224
   Subsystem 5 - Serial number: 6362QSME156356026
   Subsystem 6 - Serial number: 63734SME3C610A14
   Subsystem 7 - Serial number: 63834SME33612C0A$
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90026101500196
   Coding: 0002042
   VCID: A74EB24316124206B4-80F2
   Component: E0221           H02 0100
Address 17: Instruments (J285)       Labels: 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 984 A    HW: 4L0 920 984 A
   Component: KOMBIINSTR.   H10 0208
   Revision: 00000000    Serial number: FDE06066A
   Coding: 8BD664040100CF05020201
   VCID: B17A5C1BE8D60CB66A-80E4
Address 19: CAN Gateway (J533)       Labels: 4F0-907-468.clb
   Part No SW: 4F0 907 468 P    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0047
   Revision: LB200032    Serial number: 3200L10526801A
   Coding: 00C303
   VCID: BC647D2F3F94F1DEC9-80E8
   Component: J367-BDM  H07 0125
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AA
   Revision: 00---010    Serial number: 00000000237427
   Coding: 0000006
   VCID: E8CCF17FDB8C8D7E7D-80BC
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0064
   Revision: AA000000    Serial number: 00001010170704
   Coding: 00581300000011110000
   VCID: B2785317EDD037AE13-80E6
Address 42: Door Elect, Driver (J386)       Labels: 4F0-959-793.clb
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0357
   Revision:             Serial number: 0004000051273
   Coding: 011F07205E40440004
   VCID: C88C11FF7B4CAD7E5D-809C
Address 46: Central Conv.        Labels: 4L0-910-289.lbl
   Part No SW: 4L0 910 289 H    HW: 4L0 907 289 H
   Component: Komfortgeraet   H10 0110
   Revision: 0110 ---    Serial number: 01309362320000
   Coding: 3569693
   VCID: B572680BDCBE209636-80E0
   Part No SW: 4L0 035 223 G    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H03 0040
   Revision: CH003000    Serial number: 00000000004791
   VCID: A650BF47D1185B0E8F-80F2
            000 -  -  - Intermittent
                    Reset counter: 132
                    Mileage: 74049 km
                    Date: 2015.08.22
                    Time: 14:23:15
                    Bin. Bits: 00000001
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H03 0110
   Revision: 00000276    Serial number: 00002760016301
   Coding: 0758477
   VCID: A356A653622AAE26E8-80F6
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000068877
   Coding: 0012001
   VCID: DEA0D7A709C8C3CE87-808A
Address 52: Door Elect, Pass. (J387)       Labels: 4F0-959-792.clb
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0357
   Revision:             Serial number: 0004000047117
   VCID: C78E12C37652A20654-8092
   Part No: 8P0 907 357 H
   Coding: 0000007
   VCID: BF9E0A23EE82EAC6EC-80EA
   Part No SW: 4G0 035 082     HW: 4G0 035 082
   Component: Radio U SIRIU H51 0052
   Revision: AB001007    Serial number: 471F%0A7505796
   Coding: 020007010000000000
   VCID: DDA2D0ABC4CED8D69E-8088
   Part No SW: 4L0 035 664 B    HW: 4L0 035 664 A
   Component: H-BN-NA       H49 0116
   Revision: --------    Serial number: 489F70A7535189
   Coding: 010200060004E3EF41000305EF6300030000
   VCID: AA484B77C5007F6EAB-80FE
   Subsystem 1 - Part No: 8R0 060 884 P
   Component: NAR 2010  0407
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H42 0094
   Subsystem 3 - Part No SW: 4L0 910 609     HW: 4L0 919 611 B
   Component: E0380 Bedient  H05 0060
   Component: CD-Database  1886
Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0357
   Revision:             Serial number: 0004000045515
   Coding: 010E07204040230004
   VCID: C6901FC77158BB0EAF-8092
   Revision: --H04---    Serial number: 525PA8-J0541KR
   Coding: 1021201
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Component: ValeoHeckdeckel H55 0500
   Revision: --H55001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: ECC48D6FCF74A15E19-80B8
   Subsystem 3 - Serial number: RD11.06.10--H55001001A0051ÿ
   Subsystem 4 - Serial number: 1A0051ÿ
Address 6F: Centr. Conv. II        Labels: None
   Part No HW: 4L0 907 290 A
   Revision: AAH05061    Serial number: 105280161-----
   VCID: D5B2C88B3CFE0096D6-8080
Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
   Component: TSG HR        H11 0357
   Revision:             Serial number: 0004000045513
   Part No SW: 4L0 910 283 C    HW: 4L0 919 283 C
   Component: Parkhilfe 8-Kan H02 0500
   Revision: 00H02000    Serial number: 12631015802498
   Coding: 0221266
   VCID: AA484B7705007F6EAB-80FE
End-------------------------(Elapsed Time: 03:31)--------------------------
I perform a reset on SCR lock and reset learning value on reducing Tank under basic setting. I have seen in the forums that they have a tank level measurements by percent. The distance went from 3400km to what is shown in the output below (~25,000km). Please see the measuring values that I saw for the reducing agent under engine. Yesterday I just filled about 1 gallon after the oil change (last week). I know the reducing tank is full as it was up to the neck and overflowed (witnessed a visible level). I am not even sure if I had reset my add blue warning since I did not see this time as the dealer just a few months back had filled it for me for free. I am not even sure if I had reset my add blue warning since I did not see this time as the dealer just a few months back had filled it for me for free. It would be nice if the information is available:
Output file
Saturday,22,August,2015,20:19:32:65494
Mileage: 46018 miles   Repair Order:
                Address 01: Engine  (4L2 910 401 )
20:18:45
  425   Remaining engine starts until reducing agent deficiency-Bit 0 00011001
  426   Remaining vehicle distance until reducing agent deficiency 24950.00 km
  433   Sensor for reducing agent fill level; voltage 1891.4 mV
  434   Sensor for reducing agent tank temperature; temperature 30.9 °C
  435   Sensor for reducing agent tank temperature; voltage 840.6 mV
  475   Status of reduction agent level OK
  507   Used reducing agent since last service 88444.212 g
Please help as I need to understand the level in the AdBlue tank. New to the game.
Million Thanks
Sure it would be nice if fill level was available in some format other than the raw mV from, but we can only tell you what the ECU knows, and with UDS, what VW/Audi admit to it knowing in the data that defines how diagnostics are done with that ECU.
Got a link? I'm guessing that was a different generation of ECU that didn't use the UDS protocol.
venkatr
C?ID=255730
Uwe,
See posts on this link - first post that this was available and the older versions of VCDS seem to have this for the Q7 2010 and 2011 which i believe is the exact same. The first post also indicates they received the MVB from Ross tech
http://forums.ross-tech.com/showthread.php?1287-AdBlue-Adaptation
Nope, this has nothing to do with VCDS versions. None of the ECUs posted in that thread use the UDS protocol for diagnostics, whereas yours does.
