Car: 2017 VW Jetta
Mileage: 105k km (65k miles)
Engine: 1.4 TSI / Engine family EA211 / Engine variant CZTA
The car started having random misfires on all cylinders (about 2-5 misfires per cylinder every 5 minutes).
I noticed these items when using VCDS. I am not sure if they are relevant:
I also tried the following tests:
I will appreciate any advices & suggestions! Thank you!
The following is a VCDS autoscan of the car:
- VCDS reports “Leakage air” of 1.8kg/hr
- I tried performing a "fuel pressure test". The fuel pressure at idle was 12.6 MPa. About 20 minutes after turning off the engine, the fuel pressure maxed at 16.4 MPa.
Per my understanding, the fuel pressure was expected to double? - Long term fuel trim is +7% at idle. It drops to zero at higher RPMs
- There are no error codes present other than "Engine misfire on cylinder 1". The car got a blinking engine light as a result of that.
- Checked timing chain stretch adjustment: it's less than 2degrees
- I checked "Camshaft phase position" it was less than 1degree
- Tried cleaning VVT camshaft solenoids. They seem to work fine.
- Checked battery voltage (12.7V engine off / 13.7V idling)
- Replaced Spark Plugs
- Replaced air filter
- Cleaned MAF
- Replaced oil & filter (5W40)
- Tried "italian tuneup": Driving the car at 3-4k RPMs for 30 minutes
Thursday,10,August,2023,20:30:10:30954
VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4
VIN: 3VWDB7AJ6HM279729 License Plate:
Mileage: 109090km-67785mi Repair Order:
Chassis Type: AJ-VW36 (7E0)
Scan: 01 02 03 04 05 08 09 15 17 19 25 2B 3C 44 5F 75
VIN: 3VWDB7AJ6HM279729 Mileage: 109090km-67785miles
Address 01: Engine (J623-CZTA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 023 AL HW: 04E 907 309 AP
Component: R4 1.4l TFS H22 3669
Revision: X5H22--- CVN: 3BBC5B28
Coding: 011A0012232400001000
Shop #: WSC 00066 790 00017
ASAM Dataset: EV_ECM14TFS01104E906023AL 005004
ROD: EV_ECM14TFS01104E906023AL.rod
VCID: 6A8DCD324CF867FAB1F-803E
VINID: 0E69D448745A1987421C91C2246391823A
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 749 AA HW: 09G 927 749
Component: AISIN AG6 G3 129 3128
CVN: 56A8984D
Coding: 010200000C000000000000000000000000000000
ASAM Dataset: EV_TCMAQ250031 002009
ROD: EV_TCMAQ250031_002_VW36.rod
VCID: 78A9E77A0254C56A37B-802C
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
Coding: A14B400C49290003851202E6922200412010F01A
Shop #: WSC 00066 000 00000
VCID: 75B7EE4E15C6B8022CD-8020
Part No SW: 5K0 959 434 G HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1305
Revision: 00092000 Serial number: 0417798439 Dataset Number: V03935236HT 0001
Coding: 032C0C
Shop #: WSC 00066 000 00178
VCID: 392F227E79DE1C62085-806C
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 DA HW: 5C0 820 047 DA
Component: J301 Klimaanlage 0211
Revision: 2001401S Serial number: 00000003639407
VCID: 629DA512B8483FBA79F-8036
03984 - Left front heated seat
Fault Status: 00111011
Reset counter: 34
Mileage: 98717 km
Date: 2017.04.01
Time: 08:52:03
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 190 B HW: 7E0 937 190
Component: BCM PQ25 Max3 H81 0744
Revision: B8081001 Serial number: 88007245165712
Coding: 7B994B9A28230F0008392080240884C54BC672FE600151F0B0A050032844
Shop #: WSC 01799 002 104857
VCID: 2B0308368302BEF28A9-807E
Subsystem 1 - Part No SW: 6R0 959 801 DF HW: 6R0 959 801 DF Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 022 1467
Serial number: 14102743161011203741
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 DJ HW: 6R0 959 802 DJ Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 022 1467
Serial number: 14202742161017064728
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 A HW: 6R0 959 591 D
Component: J245 PS41.402 H03 0004
Serial number: 0000FST001696DZ00000
Coding: 180000
Subsystem 4 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A
Serial number: 2291607454400845AD2B
Coding: 280000
Subsystem 5 - Part No SW: 6R0 959 811 T HW: 6R0 959 811 T
Component: J388__TSG_HL 022 1467
Serial number: 14102745161015064543
Subsystem 6 - Part No SW: 6R0 959 812 T HW: 6R0 959 812 T
Component: J389__TSG_HR 022 1467
Serial number: 14102744161015181106
Address 15: Airbags (J234) Labels:* 561-959-655.clb
Part No SW: 561 959 655 HW: 561 959 655
Component: AirbagVW11 008 0210
Serial number: 003RXM094J7 Dataset Number: 5C6003V____ 0017
Coding: 8CCCF000000000005000001AC20800000065
ASAM Dataset: EV_AirbaVW11SMEVW411 001002
ROD: EV_AirbaVW11SMEVW411.rod
VCID: 6393A016ABD236B2729-8036
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000005YM8UG
Coding: 303146
Subsystem 2 - Part No SW: ----------- HW: 480 001 009 16
Serial number: 35700000000AF829DD10
Subsystem 3 - Part No SW: ----------- HW: 480 001 009 16
Serial number: 358000000001E829DD1Y
Subsystem 4 - Part No SW: ----------- HW: 480 021 309 16
Component: SideSensor_Dr 000 0148
Serial number: 3510001A72319DB1A483
Subsystem 5 - Part No SW: ----------- HW: 480 020 609 16
Component: SideSensor_Pr 000 0148
Serial number: 3520001B72285311F37X
Subsystem 6 - Part No SW: ----------- HW: 480 020 710 16
Component: FrontSensor_D 000 0189
Serial number: 3550001A92285325341P
Subsystem 7 - Part No SW: ----------- HW: 480 020 710 16
Component: FrontSensor_P 000 0189
Serial number: 3560001A9228532535D$
Part No SW: 5C6 920 976 D HW: 5C6 920 976 D
Component: KOMBI H02 1104
Coding: 221A010000
Shop #: WSC 00066 790 00320
VCID: 333310565BB2E632C29-8066
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 190
Component: GW-K-CAN TP20 H81 0744
Revision: B8081001
Coding: 102201
VCID: 6889B73A527455EAA7B-803C
Component: IMMO H02 1104
Coding: 000007
Part No SW: 5K0 905 861 D HW: 5K0 905 861 D
Component: ELV-PQ35 H22 0240
Revision: 00000000 Serial number: 16000162853005
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 313F1A5EA1AED422B05-8064
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0417777367 Dataset Number: 5G9764V____ 0027
Coding: 01011101
Shop #: WSC 00066 790 00178
ROD: EV_HREntryHella_VW32.rod
VCID: 3C213B6A76EC294A133-8068
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0417063190
Coding: 010111
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 305 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 392F227E755E1C62085-806C
Part No SW: 5C0 035 200 C HW: 5C0 035 200 C
Component: MU-S-S-US H32 0363
Serial number: VWZAZ2U1607789 Dataset Number: V03935263MC 0001
Coding: 02630100AA00000051220001001808009F0100D40020010002
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 1577CECE35061802CCD-8040
B11CF 53 [009] - Deactivated
Reset counter: 251
Mileage: 98004 km
Date: 2022.10.18
Time: 12:11:08
Voltage terminal 30: 14.0 V
SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
SDARS_tuner_status_2-Audio Signal: Not available
SDARS_tuner_status_2-Antenna current: 0 mA
SDARS_tuner_status_2-Reception quality: No_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 00
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 00
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 020 0160
Serial number: 000003554140555 Dataset Number: V03935214WB 0001
Coding: 02630102C21632107F1606C00000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_OCULow 002010
ROD: EV_OCULow_002.rod
VCID: 1471B3CA3EFC010ABB3-8040
End----------(Elapsed Time: 01:29, VBatt start/end: 14.0V/13.8V)-----------
