Program a new BCM
jonatangallegos
California, USA
C?ID=519009
i have a new body control module and i need to program it to the car i am wondering if we can do it or i have to take it to the dealer
Thursday,10,August,2023,11:13:35:10129
VCDS Version: 23.3.1.0
VIN: 3VWTZ7AJ9AM635961   License Plate:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 56 62 65
          72 77
VIN: 3VWTZ7AJ9AM635961   Mileage: 215870km-134135miles
03-ABS Brakes -- Status: Cannot be reached 1100
2E-Media Player 3 -- Status: Cannot be reached 1100
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 AG    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9970
   Revision: G6H03---    Serial number:
   Coding: 0000075
   Shop #: WSC 22596 444 105191
   VCID: 73EFA58C1292B90BC6-8026
   VINID: 0E69E4A8745A2517460C524604B1A37E8E
14 Faults Found:
000262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
               P0106 - 000 - Implausible Signal - Intermittent
                    Fault Frequency: 51
                    Mileage: 207005 km
                    Date: 2028.10.15
                    Time: 11:34:18
                    RPM: 1819 /min
                    Load: 15.7 %
                    Speed: 86.0 km/h
                    Temperature: 82.0°C
                    Temperature: 36.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.351 V
012408 - Throttle Control
               P3078 - 000 - Airflow at Idle too Low
                    Mileage: 210572 km
                    Date: 2023.08.30
                    Time: 06:10:46
                    RPM: 1351 /min
                    Load: 16.5 %
                    Speed: 49.0 km/h
                    Temperature: 82.0°C
                    Temperature: 23.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.224 V
008584 - Bank 1; System too Rich at Idle
               P2188 - 000 -  - Intermittent
                    Mileage: 214230 km
                    Date: 2023.12.12
                    Time: 23:43:33
                    RPM: 1885 /min
                    Load: 16.5 %
                    Speed: 88.0 km/h
                    Temperature: 82.0°C
                    Temperature: 51.0°C
                    Voltage: 14.224 V
001384 - Cruise Control Switch (E45)
               P0568 - 000 - Implausible Signal
                    Mileage: 215481 km
                    Date: 2024.04.23
                    Time: 04:11:02
                    RPM: 1368 /min
                    Load: 32.1 %
                    Temperature: 10.0°C
                    Temperature: 10.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.224 V
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 000 -
                    Mileage: 215481 km
                    Date: 2024.04.23
                    Time: 04:11:02
                    RPM: 1368 /min
                    Load: 32.1 %
                    Temperature: 10.0°C
                    Temperature: 10.0°C
                    Voltage: 14.224 V
               U0155 - 000 -  - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 53.0°C
                    Temperature: 29.0°C
                    Voltage: 12.192 V
049682 - Steering Column Control Module
               U0212 - 000 - No Communications - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 53.0°C
                    Temperature: 29.0°C
                    Voltage: 12.192 V
049508 - No Communications with HVAC Control Module (J301)
               U0164 - 000 -  - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 53.0°C
                    Temperature: 29.0°C
                    Voltage: 12.192 V
049478 - No Communication with Diagnostic Gateway
               U0146 - 000 -  - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 53.0°C
                    Temperature: 29.0°C
                    Voltage: 12.192 V
005488 - Engine Start Blocked by Immobilizer
               P1570 - 000 -  - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    RPM: 1271 /min
                    Load: 28.6 %
                    Temperature: 54.0°C
                    Temperature: 29.0°C
                    Voltage: 13.589 V
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 71.0°C
                    Temperature: 33.0°C
                    Voltage: 12.573 V
053286 - Please Check Fault Codes in Transmission Control Module
               U1026 - 000 -  - Intermittent
                    Mileage: 215817 km
                    Date: 2024.05.13
                    Time: 21:35:39
                    Temperature: 71.0°C
                    Temperature: 33.0°C
                    Voltage: 12.446 V
005668 - MIL Request Signal Active (Check TCM for errors too!)
               P1624 - 000 -  - Intermittent
                    Mileage: 215817 km
                    Date: 2024.05.13
                    Time: 21:35:49
                    RPM: 1677 /min
                    Load: 23.9 %
                    Temperature: 71.0°C
                    Temperature: 32.0°C
                    Voltage: 14.224 V
049441 - No Communication with ABS Brake Control Module
               U0121 - 000 -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 215872 km
                    Date: 2024.05.28
                    Time: 23:24:31
                    Temperature: 11.0°C
                    Temperature: 10.0°C
                    Voltage: 15.494 V
   Part No SW: 09G 927 750 HG    HW: 09G 927 750 HG
   Component: AQ 250 6F           1631
   Revision: 00H76000    Serial number:
   Coding: 0000840
   Shop #: WSC 00066 000 00000
   VCID: 7DFB83B424D6FF7BA0-8028
Address 03: ABS Brakes
   Part No SW: 3C8 907 336 N    HW: 3C8 907 336 N
   Component: Climatic      H13 0203
   Revision: 00008001
   Coding: 0000000000
   Shop #: WSC 00066 000 00187
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 387552A083741A5333-806C
   Part No SW: 5K0 937 085 C    HW: 5K0 937 085 C
   Component: BCM PQ35 B++  008 3019
   Revision: BI008001
   Coding: 6D380E1F902F3EC480080001400000C401000086435D8D60648020000000
   VCID: 336F658C9212F90B06-8066
30 Faults Found:
                    Fault Status: 00101011
                    Reset counter: 114
                    Mileage: 215855 km
                    Date: 2024.05.14
                    Time: 00:14:34
                        Term 15 Off
                    Voltage: 12.65 V
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 76
                    Mileage: 215872 km
                    Date: 2024.05.28
                    Time: 23:25:12
                    Voltage: 13.20 V
                    Fault Status: 00101001
                    Reset counter: 114
                    Mileage: 215855 km
                    Date: 2024.05.14
                    Time: 00:08:23
                        Term 15 Off
                    Voltage: 12.70 V
00927 - Terminal 30 (Right)
                    Reset counter: 112
                    Mileage: 215767 km
                    Date: 2024.05.08
                    Time: 13:46:55
                        Term 15 Off
                    Voltage: 12.60 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 74
                    Mileage: 215817 km
                    Date: 2024.05.13
                    Time: 21:39:53
                    Voltage: 13.65 V
                    Fault Status: 00101010
                    Reset counter: 112
                    Mileage: 215766 km
                    Date: 2024.05.08
                    Time: 02:59:11
                    Voltage: 13.80 V
00984 - Left Tail Light (M4)
                    Reset counter: 74
                    Mileage: 215817 km
                    Date: 2024.05.13
                    Time: 21:39:53
                    Voltage: 13.65 V
00985 - Right Tail Light (M2)
                    Reset counter: 112
                    Mileage: 215766 km
                    Date: 2024.05.08
                    Time: 02:59:11
                    Voltage: 13.75 V
                    Reset counter: 112
                    Mileage: 215766 km
                    Date: 2024.05.08
                    Time: 02:59:11
                    Voltage: 13.75 V
                    Reset counter: 74
                    Mileage: 215817 km
                    Date: 2024.05.13
                    Time: 21:39:57
                    Voltage: 13.50 V
                    Reset counter: 114
                    Mileage: 215817 km
                    Date: 2024.05.13
                    Time: 21:33:02
                    Voltage: 14.25 V
                    Reset counter: 74
                    Mileage: 215817 km
                    Date: 2024.05.13
                    Time: 21:36:10
                    Voltage: 14.20 V
01495 - Bulb for High-Beams; Left (M30)
                    Reset counter: 74
                    Mileage: 215817 km
                    Date: 2024.05.13
                    Time: 21:39:52
                    Voltage: 13.70 V
                    Reset counter: 112
                    Mileage: 215766 km
                    Date: 2024.05.08
                    Time: 02:59:11
                    Voltage: 13.45 V
                    Reset counter: 112
                    Mileage: 215766 km
                    Date: 2024.05.08
                    Time: 02:59:11
                    Voltage: 13.45 V
01501 - Bulb for Blinkers; Rear Left (M6)
                    Reset counter: 112
                    Mileage: 215766 km
                    Date: 2024.05.08
                    Time: 03:10:11
                    Voltage: 13.85 V
                    Reset counter: 112
                    Mileage: 215766 km
                    Date: 2024.05.08
                    Time: 02:59:11
                    Voltage: 13.70 V
                    Reset counter: 115
                    Mileage: 215817 km
                    Date: 2024.05.13
                    Time: 21:39:52
                    Voltage: 13.90 V
01516 - Terminal 30; Left
                    Reset counter: 74
                    Mileage: 215817 km
                    Date: 2024.05.13
                    Time: 21:36:07
                    Voltage: 14.15 V
                    Reset counter: 74
                    Mileage: 215817 km
                    Date: 2024.05.13
                    Time: 21:39:52
                    Voltage: 13.90 V
                    Reset counter: 112
                    Mileage: 215766 km
                    Date: 2024.05.08
                    Time: 02:59:11
                    Voltage: 13.50 V
01800 - Light Switch (E1)
                    Reset counter: 114
                    Mileage: 215855 km
                    Date: 2024.05.14
                    Time: 00:08:23
                        Term 15 Off
                    Voltage: 12.70 V
02092 - Enabling Heated Seat
                    Reset counter: 114
                    Mileage: 215817 km
                    Date: 2024.05.13
                    Time: 21:33:58
                    Voltage: 14.20 V
02391 - Terminal 30 Reference
                    Reset counter: 112
                    Mileage: 215649 km
                    Date: 2024.05.07
                    Time: 13:38:49
                    Voltage: 14.40 V
                    Reset counter: 112
                    Mileage: 215766 km
                    Date: 2024.05.08
                    Time: 02:59:11
                    Voltage: 13.65 V
                    Reset counter: 74
                    Mileage: 215817 km
                    Date: 2024.05.13
                    Time: 21:39:52
                    Voltage: 13.75 V
                    Reset counter: 74
                    Mileage: 215817 km
                    Date: 2024.05.13
                    Time: 21:36:07
                    Voltage: 14.20 V
                    Reset counter: 112
                    Mileage: 215766 km
                    Date: 2024.05.08
                    Time: 02:59:15
                    Voltage: 13.95 V
                    Reset counter: 114
                    Mileage: 215855 km
                    Date: 2024.05.14
                    Time: 00:08:23
                        Term 15 Off
                    Voltage: 12.70 V
                    Reset counter: 114
                    Mileage: 215855 km
                    Date: 2024.05.14
                    Time: 00:08:23
                        Term 15 Off
                    Voltage: 12.70 V
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   019 0706
   Serial number: 003C4D07GPGA   Dataset Number: 1KM003v__B_ 0027
   Coding: 00003044
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 397357A4B87E035BCC-806C
   Subsystem 1 - Part No SW: 1KM 959 339     HW: 1KM 959 339
   Component: BF-Gewichtss.  007 0001
   Serial number: ---0000R--0004WT2800
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME0C15044CZZZV
   Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME3A0F354CZZZ3
   Serial number: 3511HSME490F641DZZZX
   Serial number: 3521HSME7B0A5A1DZZZ$
   Serial number: 35527SME1E10701CZZZC
   Serial number: 35627SME4321701CZZZ7
12656896 - No Communication with ABS Brake Control Module
          U0121 00 [009] - -
                    Reset counter: 76
                    Mileage: 215872 km
                    Date: 2023.08.10
                    Time: 02:34:28
9482752 - Seat Occupied Recognition
          B10B2 00 [137] - Function Restriction due to Missing Message(s)
                    Reset counter: 76
                    Mileage: 215872 km
                    Date: 2023.08.10
                    Time: 02:34:44
   Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
   Component: J0527           053 0111
   Coding: 0001034
   VCID: 0201F0485D288083DD-8056
00895 - Cruise Control Switch (E45)
            014 - Defective
   Part No SW: 5K0 920 970 K    HW: 5K0 920 970 K
   Component: KOMBI         H08 0021
   Revision: V0008011    Serial number:
   Coding: 270F00
   Shop #: WSC 00066 000 00150
   ASAM Dataset: EV_KombiUDSMM9RM10 A04010
   ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
   VCID: 36695C988960EC2321-8062
12656896 - Function Restricted due to Missing Message(s)
          U1111 00 [137] - -
                    Reset counter: 76
                    Mileage: 215872 km
                    Date: 2023.08.10
                    Time: 02:34:28
   Part No SW: 1K0 907 530 AB    HW: 1K0 907 951
   Component: J533  Gateway   H06 0081
   Revision:   H06 01    Serial number: 300909F1001315
   Coding: ED807F07001613002002
   VCID: 67D7C1DC564A45AB6A-8032
                    Reset counter: 76
                    Mileage: 215872 km
                    Date: 2023.08.10
                    Time: 02:34:30
                    Reset counter: 76
                    Mileage: 215872 km
                    Date: 2023.08.10
                    Time: 02:34:33
03272 - Control Module for Audio Interface
                    Reset counter: 76
                    Mileage: 215872 km
                    Date: 2023.08.10
                    Time: 02:34:33
Address 1C: Position Sensing
   Component: IMMO          H08 0021
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01010
Address 2E: Media Player 3
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 70     2901
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 2F6769FCBE3ADDEB62-807A
                    Fault Status: 11100100
                    Reset counter: 76
                    Mileage: 215872 km
                    Date: 2023.08.10
                    Time: 02:34:28
                    Voltage: 12.25 V
                        DU
                    Temperature: 28.0°C
                    Speed: 50.0 km/h
                    Speed: 50.0 km/h
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Component: EZE_2         H06 0081
   Coding: 050B0500
   VCID: 66C9CCD891405CA351-8032
   Component: J245EE19SKB12  H01 0220
   Component: J394EE19SKB12  H01 0220
Address 52: Door Elect, Pass.
   Part No SW: 5ND 035 190 B    HW: 5ND 035 190 B
   Component: RCD510USBRVC  003 0003
   Revision: -----001    Serial number: VWZ4Z3R8157913
   Coding: 01000424040010
   Shop #: WSC 79107 000 00000
   VCID: 3B7F4DACBA42314BDE-806E
Address 62: Door, Rear Left
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Component: RDK           008 0817
   Coding: 018705
Address 72: Door, Rear Right
Address 77: Telephone
End-------------------------(Elapsed Time: 03:13)--------------------------
2kaa52
Ceska Republica, Praha
C?ID=319193
If you have the coding from old bcm you can do it by yourself
jonatangallegos
California, USA
C?ID=519009
Really New ? Or used from wrecked Car ?
what happened with the old one the moonroof stayed open and the module got wet i found some corrosion in the module and windows dont work wiper stays on and the car wont start because i guess immobilizer runs through it the car runs but u have to apply power directly to the starter
