2006 air suspension on Treg won’t calibrate.
Captftl
Northern California, USA
C?ID=538557
I’ll try and make this short. Bought car 6 months ago and air suspension didn’t work. Replaced all 4 shocks, compressor control module and started working. Worked great. 2 weeks later blew one of the airbags and replaced but had hard time getting to work properly but eventually it did. 4 days ago blew another air bag. (Faulty bag). Put all back together and car now has 6” degree difference in height on passenger side. (Front and rear now) Bled down axles but when I went to refill could only get 5.84 bar pressure on front axel rear went up to 10 bar but I brought down level. Took for test drive and it pumped up left side of car again. Went into to measuring blocks and under Absolute Height
LF 147.3 RF 98.0
LR 150. RR 70.0
Tried calibrating but VCDS would not allow me to enter any measurement more than 1mm. LF was 497 and I tried to enter 517 but it would only “allow” me to enter 498? Don’t understand?
Only fault code I’m showing is 01437 and I can’t delete it. I need a bit of help on this one. Never had problem with rear until this
Hi and welcome. Please post an Auto-Scan for better context.
There has to be a physical reason for it to be that far out of whack. Are you sure all the height sensors are installed correctly and functioning properly?
Captftl
C?ID=538557
I will post an auto scan a little later this afternoon. It’s just wierd right front and rear are down equally. Left side of car looks like in off-road and right side looks like regular mode. Only thing I did was replace air shock. Just looked at linkage and looks correct. Will pull tires later and double check all linkages and do an auto scan.
If you're going to pull tires, you'll presumably be using a jack or lift. Watch the the values from the height sensors as you raise and lower the vehicle to verify that they are changing as expected.
Captftl
C?ID=538557
I am having trouble with module 34 as posted last week and was going to add to that but it has disappeared? Am enclosing auto scan too. Per your advise I manually went in and raised car and seems to almost be working correctly but slightly front end high. Went to adaptions logged in but due to ongoing fault code I can’t delete will not allow me to adjust heights. Won’t accept inputs and I’m sure it’s because of fault code. How due I eliminate fault code so I can set heights?
Saturday,12,August,2023,18:10:41:40022
VCDS Version: 23.3.1.0 (x64)  HEX-NET2 CB: 0.4631.5
VIN: WVGPT77L96D023501   License Plate:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGPT77L96D023501   Mileage: 224440km-139460miles
   Part No SW: 070 906 016 CQ    HW: 028 101 196 2
   Component: V10 5,0L EDCG001AGMª9805
   Revision: --H01---    Serial number: VWZ3Z0E6430509
   Coding: 0060575
   Shop #: WSC 08681 666 30085
   VCID: 6194CB274D506F62605-5160
   VINID: 9E65E09071DC24650008314004181C103D
006407 - Engine Databus
               P1907 - 000 - ECU<->ECU Communications Fault - Intermittent
                    Mileage: 224279 km
                    Voltage: 11.93 V
                    Bin. Bits: 00001000
                    Torque: 323.9 Nm
                    Torque: 0.0 Nm
013111 - Engine-Engine Databus
               P3337 - 000 - Implausible Message - Intermittent
                    Mileage: 224279 km
                    Voltage: 12.08 V
                    Bin. Bits: 00001000
                    (no units): 0.0
                    (no units): 0.0
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No SW: 09D 927 750 DP    HW: 09D 927 750 DP
   Component: AL 750 6A           1032
   Revision: 00H37000    Serial number:
   Coding: 0004216
   VCID: 7F506D5FDBE4B992761-513C
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 G
   Component: ESP ALLRAD MK25     0203
   Coding: 0022786
   Shop #: WSC 31414 000 00000
   VCID: 3D2C575791686B8224D-5160
00814 - Solenoid for Brake Pressure (N247)
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: 7L0 909 137 A    HW: 5WK 485 02
   Component: 29 Kessy            6700
   Revision: 67005715    Serial number: VWZ3Z0E6430509
   Coding: 0147688
   VCID: 31347B675D309FE2B05-5160
            013 - Check DTC Memory
Address 06: Seat Mem. Pass        Labels: None
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   VCID: 77A0857FF3D481D23E1-5160
Address 08: Auto HVAC        Labels: 7L6-907-044.clb
   Part No: 7L6 907 044 AD
   Component: CLIMAtronic 2+2     4326
   Coding: 0020030
   Shop #: WSC 31414 790 00001
   VCID: 76BE887BF4DEF8DA257-5160
   Subsystem 1 - Part No: 7L6 907 049 E
   Component: CLIMAtronic FOND    0400
12 Faults Found:
02379 - Positioning Motor for Left Side Vent (V299)
02380 - Positioning Motor for Right Side Vent (V300)
00898 - Control Circuit A/C compressor
02599 - Rear Left Temperature Flap Motor (V313)
02597 - Rear Left Upper Body Vent Motor (V315)
00064 - Left B-pillar/Footwell Shut-Off Flap Motor (V212)
00362 - Rear Left Air Flap Motor (V239)
02600 - Rear Right Temperature Flap Motor (V314)
02598 - Rear Right Upper Body Vent Motor (V316)
00057 - Right B-pillar/Footwell Shut-Off Flap Motor (V211)
00363 - Rear Right Air Flap Motor (V240)
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 N
   Component:                     3003
   Coding: 0111839
   Shop #: WSC 27606 002 1048576
   VCID: 47C035BFC3B431528E1-5160
00070 - Starting Battery Voltage
Address 11: Engine II        Labels: Redir Fail!
   Component: V10 5,0L EDCG001AGSª9805
   Coding: 0060575
005227 - Particulate Filter Bank 2
               P146B - 000 - Temperature Rise too Low - Intermittent
                    Fault Status: 00110000
                    Mileage: 223032 km
                    RPM: 1785 /min
                    Speed: 107.1 km/h
                    (no units): 0.44
                    (no units): 0.06
                    (no units): 434.0
                    Temperature: 26.1°C
                    Duty Cycle: 6.7 %
   Part No: 3D0 909 601 H
   Component: 05 Airbag 8.4E++H01 0562
   Revision: BB38727     Serial number: 0006733:
   Coding: 0012341
   VCID: 280296036EEADE2A67B-5160
   Subsystem 1 - Part No: 7L0 959 339 C
   Component: BF-Gewichtsens. 006 0008
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 J
   Coding: 0000232
   VCID: 46DE38BBC4BE285A757-5160
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 981 R
   Component: KOMBIINSTRUMENT RB8 3211
   Coding: 0007231
   Shop #: WSC 22979 444 82785
   VCID: 48C23683CEAA3E2A87B-5160
00464 - Control Module with Display for Radio and Navigation (J503)
Address 18: Aux. Heat        Labels: 7L6-819-008.clb
   Part No: 7L6 815 071 D
   Component: Standheizung E1MAC
   Coding: 0000100
   VCID: 3338716FA72CADF2C29-5160
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70B2BE6396BAD6EAFFB-5160
00908 - Control Module for Wiper Motor
00484 - Vehicle Position Recognition Control Module (J603)
01308 - Control Module for Roof Electronics (J528)
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No: 7L6 919 879 A
   Component: JCI PathPoint       2200
   VCID: 45DC3FB7F9B823427CD-5160
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0122
   VCID: 7F506D5FDBE4B992761-5160
   Subsystem 1 - Part No: 0AD 927 755 BE
No Faults Found
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  0001
   Coding: 0000003
   VCID: 669ED83BA47E085A957-5160
Address 32: Differential Locks        Labels: None
   Part No: 0AC 927 771 C
   Component: SG-Quersperre       5020
   VCID: 38224643BE4A4EAAF7B-5160
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 F
   Component: LUFTFDR.-CDC- 3C3P1 3081
   Coding: 0015521
   Shop #: WSC 22158 444 179297
   VCID: 363E487BB45EB8DAE57-5160
01437 - Control Position not Learned
01400 - Suspension Level Control
01781 - Vehicle Extremely Un-Level
Address 46: Central Conv.        Labels: 7L0-959-933.clb
   Part No: 7L0 959 933 J
   Component:    HSG              5115
   Coding: 0000085
   VCID: 43D821AFF78C1D72529-4B1E
   Subsystem 1 - Part No: 7L0 959 701 H
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 H
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 D
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 D
   Component: Tuersteuergeraet HR 0201
00927 - Terminal 30 (Right)
01516 - Terminal 30; Left
00926 - Terminal 30
00896 - Trunk Lock Unit (F256)
Address 47: Sound System        Labels:
   VCID: 55FCEFF70C0893C20CD-5160
   Note: Excessive Comm Errors
Address 65: Tire Pressure        Labels:. 7L6-907-273.lbl
   Part No: 7L6 907 273 B
   Component: Reifendruckueberw.  0053
   Coding: 0211390
   Shop #: WSC 19124 444 83960
   VCID: 3720457FB35441D2FE1-5160
01507 - Initialization Not Successful
            000 - - - Intermittent - MIL ON
            004 - No Signal/Communication - Intermittent - MIL ON
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L0 955 119 K
   Component: Front Wiper         4027
   Coding: 0000341
   Shop #: WSC 31414 000 376832
   VCID: 3C2A5A538A72628A133-5160
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     140906 020 0105
   Coding: 00208933
   Shop #: WSC 31414
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
   Component: ANHAENGERELEKTRONIK 8854
   Coding: 0000002
   Part No SW: 7L6 907 441     HW: 7L6 907 441
   Component: J772__Rearview      0051
   Revision: 00H07000    Serial number:    PA8 J580714
   Coding: 0000101
   VCID: 72B6B46B98B6E4FA09F-5160
02283 - Video Connection to Output [End Unit]
                    Fault Status: 00101011
                    Reset counter: 141
                        Reverse ON
                    Count: 4
Address 6E: Ctrl Head Roof        Labels: None
   Part No: 7L6 919 044 N
   Component: DACHDISPLAY         0539
   Revision: 00800539    Serial number: 2009289.07
   VCID: 42D624ABE896147A59F-5160
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
   VCID: 39244347854057A2085-5160
00434 - Left Front Inner Parking Aid Sensor (G332)
            006 - Short to Plus
End----------(Elapsed Time: 09:05, VBatt start/end: 13.2V/
Nope. It was just a few pages back, in Car Repair Support. I'll merge...
