Hello everyone
Please help me determine the correct Steering Assist coding.
The car was rear-ended and is being repaired. Among other things, the Steering Assist electronics were damaged with which there was no communication.
Replaced with a functional one with the same numbers, but there is probably incorrect coding because the steering wheel turns with resistance.
Thank you in advance for your help.
I am attaching the full AutoScan.
Thursday,27,July,2023,16:52:56:57922
VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4
VIN: WA1LHAF77KD025676 License Plate:
Chassis Type: F7-AU73 (80A)
Scan: 01 02 03 08 09 15 16 17 19 28 29 36 39 3C 42 44 46 47 50 52
5F 69 6C 6D 75 81 A5 BB BC CA CF D6 D7
VIN: WA1LHAF77KD025676 Mileage: 79639km-49485miles
3C-Lane Change -- Status: Cannot be reached 0100
50-Seat Adj. 3rd row -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: Cannot be reached 0100
Address 01: Engine (J623-CYMC) Labels: None
Part No SW: 4M0 906 259 L HW: 06L 907 425 C
Component: R4 2.0l TFSI H15 0002
Revision: --H15--- CVN: 0B0F3F35
Coding: 2A2A00322536010E34280000000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM20TFS0204M0906259L 001003
ROD: EV_ECM20TFS0204M0906259L.rod
VCID: 3C21263BC6E583CA133-8068
VINID: 9D105C6115871DB500085187184E11FAFB
26388 - Lane change assistant control module
U1045 00 [039] - No communication
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:00
Engine RPM: 1275.50 /min
Normed load value: 16.1 %
Coolant temperature: 53 °C
Intake air temperature: 23 °C
Voltage terminal 30: 14.609 V
LF_MVB_PDU_INTC_DIAG_7: 20480
LF_MVB_PDU_INTC_DIAG_8: 199
LF_MVB_PDU_INTC_DIAG_9: 64896
LF_MVB_PDU_INTC_DIAG_10: 0
LF_MVB_BUS_INTC_DIAG: 256
Readiness: 1110 0101
Part No SW: 4M0 927 158 K HW: 0D5 927 156 H
Component: 0D5 20TSIUSA H05 1004
Revision: --H05--- CVN: 33D8EFA8
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011_AU49.rod
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-PRE-V1.clb
Part No SW: 4M0 907 379 T HW: 4M0 907 379 T
Component: ESP9 Premium H14 0861
Dataset Number: 4M0909504R 0003 CVN: 0C38D2B4
Coding: 28AA409C30A40A9B91A4589800835292E5369A14020C50891A004A49A76C59
ROD: EV_ESP9BOSCHCMP_004_AU49.rod
VCID: 48C94AEB823DDF6A87B-801C
451328 - Databus
U1121 00 [047] - Missing Message
[ComScl:_Signal_Group_SG_RCTA_01_-_Timeout_error]
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:00
93 00 00 00 CA 24 00 00 00 00
Unlearning counter according OBD-OBD unlearning counter: 28
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 4M0 820 043 AB HW: 4M0 820 043 AB
Component: Klima Zone 4 H52 0112
Coding: 640809015548001110680280800000000000000000000000000000000000
ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
ROD: EV_AirCondiFrontBHTCAU736.rod
VCID: 6597A35F15EFE2029CD-8030
Subsystem 1 - Part No SW: 4M1 820 021 B HW: 4M1 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000003096545
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: 37609D5900PAG0MUFU02
459027 - Databus
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:05
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W0 907 063 DG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0313
Dataset Number: 4M0909514AB 0061
Coding: 07500363E0081CCD0517871558BE9CB911033D01900000000000000020001A0108630122025709
ASAM Dataset: EV_BCM1BOSCHAU736 019008
ROD: EV_BCM1BOSCHAU736_019.rod
VCID: 03539DC7FB9B3C32129-8056
Subsystem 1 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 21730872X81A955547A0
Coding: 02006E
Subsystem 2 - Part No SW: 4M0 941 531 AG HW: 4M0 941 531 AG
Component: E1 - LDS H06 0008
Serial number: 13 11 2018 01724061
Subsystem 3 - Part No SW: 4N0 907 410 B HW: 4M0 907 410 A
Component: USHL5 H10 0100
Serial number: 0000009600368Z01WL02
Coding: 350000
Garage door opener control head:
Subsystem 4 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20181115182645 00767
Subsystem 5 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE106091823610458
Interior Light Module:
Subsystem 6 - Part No SW: 4M0 947 135 DM HW: 4M0 947 135 DM
Component: Dachmodul H42 0413
Serial number: Q00664275
Coding: 0D0305
Subsystem 7 - Part No SW: 80A 907 705 HW: 80A 907 705
Component: J866-EVLS-SG H03 0100
Serial number: WA135364000058979383
Coding: 0A0100
Subsystem 8 - Part No SW: 4M0 925 301 K HW: 4M0 925 301 K
Component: SL-Q7NF/AU736 H10 0013
Serial number: 00000000000000237626
Subsystem 9 - Part No SW: 4N0 963 575 HW: 4N0 963 575
Component: V512 LLR1SLvL H01 0012
Serial number: Q98AI25701078
Subsystem 10 - Part No SW: 4N0 963 575 HW: 4N0 963 575
Component: V514 LLR1SKvL H01 0012
Serial number: Q98AI33060696
Subsystem 11 - Part No SW: 4N0 963 575 HW: 4N0 963 575
Component: V516 LLR1SLvR H01 0012
Serial number: Q98AI33080787
Subsystem 12 - Part No SW: 4N0 963 575 HW: 4N0 963 575
Component: V518 LLR1SKvR H01 0012
Serial number: Q98AI33070971
65915 - Databus
[Side assist control module: no signal/communication]
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:49:59
average_Voltage_terminals: 14.70 V
Outside air temperature sensor-Outside air temperature on CAN: 23.00 °C
interior_temperature: 28.00 °C
Vehicle speed: 0.00 km/h
65940 - Control Module for Wiper Motor
U10A3 00 [009] - No Communications
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:00
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 4M0 959 655 L HW: 4M0 959 655 L
Component: Airbag10.44 H02 0108
Serial number: 003YS000PU5$ Dataset Number: 4M0909602AM 0002
Coding: AECCFCC000800000A0F00033D24C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006.rod
VCID: 44D15EDBBE15FB0A6B3-8010
Right seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2040
Serial number: 4M0857706AA325S01218
Coding: 88001B
Subsystem 2 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J18000APP340C
Subsystem 3 - Part No SW: ----------- HW: 442 061 411 18
Serial number: 3577Y00A32B891B434D6
Subsystem 4 - Part No SW: ----------- HW: 442 061 411 18
Serial number: 3587Y00C32D4F28100D1
Subsystem 5 - Part No SW: ----------- HW: 442 0B1 011 18
Serial number: 35177009B2E13361512
Subsystem 6 - Part No SW: ----------- HW: 442 0B1 011 18
Serial number: 35277009B2E1336150F8
Subsystem 7 - Part No SW: ----------- HW: 442 0C0 511 18
Component: FrontSensor_D 1C5 014A
Serial number: 3557500AD2D4F4D1D16Y
Subsystem 8 - Part No SW: ----------- HW: 442 0C0 511 18
Component: FrontSensor_P 1C5 014A
Serial number: 3567500BF2D63976422K
9 Faults Found:
B1006 1B [137] - Resistance Too High
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:02
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
B1009 1B [137] - Resistance Too High
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:03
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
B1008 1B [137] - Resistance Too High
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:03
9442075 - Driver's Belt Force Limiter Igniter
B1013 1B [137] - Resistance Too High
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:03
9440539 - Driver's Safety Belt Tensioner Igniter 2
B100D 1B [137] - Resistance Too High
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:03
1050624 - Databus
[NWD: 0x322 PCR_01 Timeout]
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:01
1056768 - Databus
[NWD: 0x17F PCR_02 Timeout]
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:01
12680704 - No Communication with Control Module for Seat Belt Tensioner; Front Left
U017E 00 [009] - -
[ECU for Pretensioner left no communication]
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:02
1062656 - Databus
[NWD: 0x189 SWA_Header Timeout]
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:01
Part No SW: 4N0 907 129 K HW: 4N0 907 129 K
Component: Lenks.Modul H03 0005
VCID: 392F3F2FC9D7B6E2085-806C
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 4M0 920 890 D HW: 4M0 920 890 D
Component: FBenUSA H20 0416
Coding: 09E600C12888CF05022369601800200008000000
ASAM Dataset: EV_DashBoardAU736 001032
ROD: EV_DashBoardAU736_AU73.rod
VCID: 313F070F11A77EA2B05-8064
16776982 - Databus
[SWA_01 communication error can_error_timeout]
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:49:59
Part No SW: 80A 907 468 C HW: 80A 907 468 A
Component: Gateway H05 0207
Serial number: 1HF03022208401 Dataset Number: 4M0909515Q 0092
Coding: 030100010000064029070000005900324C1A0007100000000175078E10000000
GVL: 01503C0408000000C0DC08008002C800100C2000000000000000000000000100
ASAM Dataset: EV_Gatew31xAU65x 003170
ROD: EV_Gatew31xAU65x_AU49.rod
VCID: 2E051C730099615AAD7-807A
Subsystem 1 - Part No SW: 4M0 951 523 A HW: 4M0 951 523 A
Component: J453 MFL H06 0004
Serial number: 20181203095428 30516
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 3549779804
131662 - Lane change assistant control module
U1045 00 [009] - No communication
[Timeout_Node_0x4E_DiagAdress_3C_MRR_HR]
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:01
131722 - Control Module 2 for Lane Change Assistance
U10A5 00 [009] - No Communications
[Timeout_Node_0x8A_DiagAdress_CF_MRR_HL]
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:01
Address 28: HVAC, Rear (E265) Labels:* None
Part No SW: 4M0 919 158 D HW: 4M0 919 158 D
Component: Klima Zone 2 H52 0103
Coding: 000000000000000100800080000000000000000000000000000000000000
ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
ROD: EV_AirCondiFondBHTCAU736.rod
VCID: 36353413F8C9599AE57-8062
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AC HW: 4M0 907 397 C
Component: LCM_MLBevoH05 0024
VCID: 78A9FA2BB25D6FEA37B-802C
Part No SW: 4M4 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0044
Serial number: 00000357251361 Dataset Number: 4M0909856D 0024
Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
VCID: 79AFFF2F895776E2485-802C
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Address 3C: Lane Change
Part No SW: 4M0 959 793 H HW: 4M0 959 793 F
Component: TSG FS 005 0130
Serial number: 0000357574455 Dataset Number: 4M0909872J 0035
Coding: 005F8B005E00108000012030
VCID: 43D35DC7BB1BFC32529-8016
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:03
524420 - Databus
[Message SWA_01 missing]
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:03
Part No SW: 4N0 909 144 D HW: 4N0 909 144 A
Component: EPS_MLBEVO2BS H20 0504
Dataset Number: 4M8909852E 0003
Coding: B2000101000100
Shop #: WSC 00022 000 00000
ASAM Dataset: EV_EPSVWBSAU426 009015
ROD: EV_EPSVWBSAU426_009.rod
3149825 - Databus
[COMI_TIMEOUT_ACC10]
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:00
FreezeFrame_mw_120C_Timeout-Engine RPM: 0.00 /min
FreezeFrame_mw_120C_Timeout-System status: 0
FreezeFrame_mw_120C_Timeout-Terminal 30 power supply: 14.79 V
FreezeFrame_mw_120C_Timeout-Terminal 15 status measured: On
FreezeFrame_mw_120C_Timeout-Engine steering torque sensor: average value: 0.00 Nm
FreezeFrame_mw_120C_Timeout-Terminal 15 resulting: On
FreezeFrame_mw_120C_Timeout-Terminal 15 status signal: On
FreezeFrame_mw_120C_Timeout-Steering pinion angle: offset corrected: -0.44 °
FreezeFrame_mw_120C_Timeout-ARA_signal_red_cyclic: 00
FreezeFrame_mw_120C_Timeout-PLA_signal_red_cyclic: 00
FreezeFrame_mw_120C_Timeout-SCU state: System OK
FreezeFrame_mw_120C_Timeout-Steering_angle_sender_status: System OK
1052420 - Internal Temperature Measurement
U1409 00 [137] - Implausible Signal
[STMP_DIAGMOTORGRADIENT]
Mileage: 53569 km
Date: 2023.02.20
Time: 15:06:22
FreezeFrame_mw_1317_temperature-DBC_Temp_Switch: 00
FreezeFrame_mw_1317_temperature-etmp_eadc_Dbc_Temp: 00 00
FreezeFrame_mw_1317_temperature-etmp_eadc_Motor_Temp: 00 00
FreezeFrame_mw_1317_temperature-Grad_Integ_DBC: 0.00 °C
FreezeFrame_mw_1317_temperature-Grad_Integ_Motor: 7.16 °C
FreezeFrame_mw_1317_temperature-Motor_Temp_State: 00
FreezeFrame_mw_1317_temperature-Motor_Temp_Switch: 00
FreezeFrame_mw_1317_temperature-Shutoff_Crosscheck: 00
FreezeFrame_mw_1317_temperature-Temp_Mosfet_VH: 0.00 °C
FreezeFrame_mw_1317_temperature-Temp_Mosfet_VPh_Sw: 0.00 °C
FreezeFrame_mw_1317_temperature-Temperature_rotor: 13.72 °C
FreezeFrame_mw_1317_temperature-Temperature_stator: 14.16 °C
Part No SW: 8W0 907 064 GD HW: 8W0 907 064 DD
Component: BCM2 MLBevo 025 0424
Dataset Number: 4M0909501M 0070
Coding: 01341E00492100C0650BA0006C01580203024000810004502F0400000F04803F001E0001000010
ASAM Dataset: EV_BCM2HellaAU736 016016
ROD: EV_BCM2HellaAU736_016_AU49.rod
VCID: 04519EDBFE953B0A2B3-8050
Subsystem 1 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000267131
65541 - Terminal 30
U140A 00 [009] - Open Circuit
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:00
Supply voltages-Terminal 30 power supply: 0.272 V
Supply voltages-Supply voltage Terminal 30 - 2: 15.000 V
Supply voltages-Supply voltage Terminal 30 - 3: 14.973 V
general_additional_freeze_frame-terminal_control_intern_status: 1B 02 0A 90 00 E0
defect_fusi_voltage_error_freeze_frame: 00000000 00000000 00000000 00000000
618241 - Luggage Compartment Lighting
B1215 13 [009] - Open Circuit
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:49:59
Supply voltages-Supply voltage Terminal 30 - 3: 15.000 V
light_freeze_frame: 11111111 11111111 11111111 11111111
65669 - Control Module for Rear Lid Opening
U1152 00 [009] - No Communications
[Control module for tailgate spoiler opening: no communication]
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:49:59
Supply voltages-Supply voltage Terminal 30 - 2: 14.986 V
Supply voltages-Supply voltage Terminal 30 - 3: 14.959 V
65650 - Rear Lid Closed Sensor 1
B146D 15 [009] - Open or Short to Plus
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:58
Supply voltages-Supply voltage Terminal 30 - 2: 14.973 V
65651 - Rear Lid Closed Sensor 2
B146E 15 [009] - Open or Short to Plus
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:58
Part No SW: 4M0 035 223 C HW: 4M0 035 223
Component: MIB2_amp_PD H03 0440
Serial number: 00000000136992 Dataset Number: 4M1909510E 0012
Coding: 0135060A008AF53AAF0000010000
ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
VCID: 2313FD475B5BDC32329-8076
Address 50: Seat Adj. 3rd row (J857) Labels:* None
Part No SW: 4M1 959 760 G HW: 4M1 959 760 G
Component: MEM-SR3 008 0016
Serial number: 00000357135384 Dataset Number: 4M0909467C 0016
Coding: FF041020F1000000000F000000000900000021210900000000000000440000
ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
VCID: 3D272B3FDDFF8AC224D-8068
524317 - Motor for Seat Backrest Adjustment; Right
B1598 54 [041] - Missing Calibration / Basic Setting
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:49:58
524344 - Indicator Light 1 for Seat Backrest Adjustmemt; Left
B1607 13 [041] - Open Circuit
Fault Frequency: 112
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:49:59
524345 - Indicator Light 1 for Seat Backrest Adjustmemt; Right
B1610 13 [041] - Open Circuit
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:49:59
524348 - Indicator Light 2 for Seat Backrest Adjustmemt; Left
B1608 13 [040] - Open Circuit
Fault Frequency: 8
Reset counter: 57
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:51
Part No SW: 4M0 959 792 H HW: 4M0 959 792 F
Component: TSG BFS 009 0130
Serial number: 0000358503898 Dataset Number: 4M0909873J 0035
VCID: 42DD58C3A401F53A59F-8016
524420 - Databus
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:03
Address 5F: Information Electr. (J794) Labels:* 4M0-035-MIB-HGH2.clb
Part No SW: 4M1 035 880 C HW: 4M1 035 880
Component: MU-P-LNS-US 035 1316
Serial number: A724L0JB089689 Dataset Number: 4M0909545Q 0048
Coding: 013706020000000051220002041A00332F001BE401700904FE
Shop #: WSC 46762 002 1048576
VCID: 2D071B7F0D9F1A4294D-8078
Subsystem 1 - Part No SW: V03 959 802 DL HW: -----------
Component: NAR 2019 --- 0069
Multimedia System 1:
Subsystem 2 - Part No SW: 4M0 919 605 HW: 4M0 919 605
Component: AU536_DU_HIGH H43 0008
Serial number: AUZ8Z9JJ4082SZ
Subsystem 3 - Part No SW: 4M0 919 615 M HW: 4M0 919 615 M
Component: ControlUnit_P H15 0306
Serial number: 03121800000000000081
Compact disc data bank:
Component: Gracenote2 --- 3013
3073 - Cellular Antenna
B1053 13 [009] - Open Circuit
[GSM/UMTS aerial - open circuit]
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:02
Voltage terminal 30: 14.8 V
3086 - Antenna for Telephone Mount
B1564 01 [009] - Electrical Failure
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:00
Status of telephone-Antenna diagnostic: OK
Status of telephone-Telephone baseplate diagnostic: not connected
Status of telephone-Handset in handset holder (cradle): not selected
Status of telephone-Handset holder (cradle): not connected
7194 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Side assist (0x1A) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:03
BAP-BAP_Function_ID: 02
Part No SW: 4M0 907 383 E HW: 4M0 907 383
Component: Anhaenger H27 0253
Revision: 9C001003 Serial number: 0500663181 Dataset Number: 4M0909527C 0024
Coding: 0210000200000000
VCID: 34310E1BEEB54B8ADB3-8060
Part No SW: 4M0 907 428 F HW: 4M0 907 428
Component: Areaview 2 H13 0318
Serial number: C854607JG074485 Dataset Number: 4M1909460J 0024
Coding: 02350602BB0FA10038004004
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
ROD: EV_CamSysRVAV2CE2MLBEv_005_AU49.rod
VCID: 3537331FE5CF5282ECD-8060
Part No SW: 8W8 959 107 D HW: 8W8 959 107
Component: HDSG-Modul H13 0170
Revision: -------- Serial number: A2-C744-8781-0 Dataset Number: 4M0909541H 0027
Coding: 00B0
ROD: EV_DeckLidCONTIAU736_AU37.rod
VCID: 4ACD70E39C312D7A91F-801E
Part No SW: 4K1 035 283 A HW: 4K1 035 283 A
Component: ConBox H08 0100
Serial number: 005CCA12F040229 Dataset Number: 4M0909612C 0012
Coding: 01C020FE4040800000
ASAM Dataset: EV_ConBoxAU651 001004
ROD: EV_ConBoxAU651_001_AU49.rod
VCID: 2615E4532869291A557-8072
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4M1 713 041 H HW: 4M1 713 041 G
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 18111649976493
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 2A0D10633C710D7A71F-807E
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 4M0 907 217 F HW: 4M0 907 217 E
Component: BVS H17 0052
Dataset Number: 4M0909466M 0045
Coding: 0407030600000201022023A3A50000B400F0C020C000
ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
1122656 - Databus
[TIMEOUT_SWA_Objekt_01_02]
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:49:59
Control Module temperature: 43 °C
Voltage terminal 15: 14.90 V
1123714 - Databus
[Airbag_01_AB_Systemfehler]
Reset counter: 17
Mileage: 79639 km
Date: 2023.07.27
Time: 10:50:07
Voltage terminal 15: 14.80 V
Part No SW: 4M0 959 795 H HW: 4M0 959 795 F
Component: TSG HFS 005 0130
Serial number: 0000355734533 Dataset Number: 4M0909897J 0035
Coding: 004F8B000000108040002020
ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
VCID: 45D743DFB52FC2027CD-8010
Component: TSG HBFS 005 0130
Serial number: 0000355733864 Dataset Number: 4M0909896J 0035
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Part No SW: 4M0 907 594 G HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Dataset Number: 4M0909469G 0015
Coding: 2A8000053602
ROD: EV_SunRoofCONTIAU736_006.rod
VCID: 3A2D2023CCD1BDFA01F-806E
Address CF: Lane Chge Asst 2
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
Dataset Number: 4M0909471D 0012
ROD: EV_LEDModLeftMELCOAU736_AU73.rod
VCID: 1675D4939809B99AC57-8042
Address D7: Light Ctrl Right 2
End-----(Elapsed Time: 02:37, VBatt start/end: 14.8V/0.0V. VIgn 0.0V)------
