8V A3 2.0TQ, I done messed up, plugged in different cluster
Tophergrace3
Ohio, USA
C?ID=327943
Hi Dana,
Thanks for the reply, i've done the basic settings in a parking lot 4 different times i'll go try it again and see if i can get it to cooperate.
   #22
The coding in addresses 03 and 44 looks good so give the Basic Settings in 03-ABS here a shot:
Hopefully that gets you down DTCs only for TPMS and G85. If so, the Steering Angle Sensor Calibration should be possible.
   #23
Tophergrace3
Ohio, USA
C?ID=327943
ok great, the tutorial i was following didn't have the options i was shown in my vagcom, I have to let me laptop recharge and then i'll head back out and try again
Thanks for your help
   #24
Tophergrace3
Ohio, USA
C?ID=327943
Got most of them to go away but cannot get rid of EPB code 32951, i've started/stop lining in basic settings 3 times, manually set/released the epb and the light is still there. as long as cruise works and no other lights i'm happy enough.
   #25
OK, if that doesn't clear up over the weekend run and post another scan so we can try to get to the bottom of it.
Tophergrace3
Ohio, USA
C?ID=327943
Dana, Thanks so much for the correct mk7/mqb links, that got me situated. I guess i don't know how to search the website correctly yet :/
That said here's my latest autoscan, i still have an epc light and parking brake code i cannot shake out. Everything works correctly but the light is still there
Saturday,11,November,2023,12:03:30:48330
VCDS Version: 23.11.0.0 (x64)  HEX-NET CB: 0.4643.4
VIN: WAUBFGFF9F1096075   License Plate:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 3C 42 44 52 55 5F 6C BB BC
VIN: WAUBFGFF9F1096075   Mileage: 95836km-59549miles
Address 01: Engine (J623-CNTC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 9C0 BB0 1    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---    CVN: 3FCF1B67
   Coding: 0A1D00324426000F2000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0205G09C0BB01 001003
   ROD: EV_ECM20TFS0205G09C0BB01.rod
   VCID: 3D32D41AACCD6479E8-8068
   VINID: 9D19525975962560402460071409323C8D
20638 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
          P0036 00 [10101111] - Malfunction / Open Circuit
                    Mileage: 95672 km
                    Date: 2023.11.08
                    Time: 23:00:53
                    Engine RPM: 806.00 /min
                    Normed load value: 18.0 %
                    Coolant temperature: 87 °C
                    Intake air temperature: 38 °C
                    Voltage terminal 30: 14.082 V
                    Engine: operating status: IS
                    ECU_STATE: SYN_ENG_IGK_ON
                    T_ES: 0 min
                    T_AST_SAE: 2 s
                    Lambda probe heater: resistance: bank 1: probe 2: 65535 Ohm
                    TEG_DYN_LS_DOWN[1]: 363.5375 °C
                    VLS_DOWN_SAE[1]: 1.275 V
15255 - Secondary Air Injection System Valve (N112)
          P0413 00 [11101101] - Open Circuit
                    Mileage: 95672 km
                    Date: 2023.11.08
                    Time: 23:00:52
                    Engine RPM: 801.75 /min
                    Normed load value: 16.1 %
                    Voltage terminal 30: 14.140 V
                    STATE_LS_SAE[1]: OL_INTR
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 28 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.958 V
                    FAC_TPS_1_SAE: 12.109375 %
                    FUP_H_SAE: 3530.0 kPa
Readiness: 1010 1101
   Part No SW: 0D9 300 012 K    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4513
   Revision: 03253104    Serial number: TFK01412040741 CVN: 0000B51C
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1E703396010B1F61D1-804A
   Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
   Component: ESC           H42 0610
   Revision: 00000000    Serial number: 63304000002085
   Coding: 13FF6A9234290A720177030781C829C8562C5080C08194B4024100588208
   VCID: 48DCB5CEF30F31D14B-801C
32951 - Control Module for Electronic Parking Brake
          C10E2 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 84
                    Date: 2023.11.08
                    Time: 23:11:48
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000522022
   Coding: 03000014010000000000000000001400
   VCID: 3326F2229A89A2090E-8066
   Humidity sensor: exterior:
   Serial number: 0A780267000000000001
328965 - Motor for Front Air Distribution Flap
          B1091 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 84
                    Mileage: 95672 km
                    Date: 2023.11.08
                    Time: 23:05:30
                    Voltage terminal 30: 14.5 V
                    Inside temperature: 30.0 °C
                    Outside temperature: 14.5 °C
                    Front air distribution flap: actual value: 1.5 %
                    Front air distribution flap: actual value: 928
                    Air distribution door front - Specified value: 928
329988 - Motor for Defroster Flap
          B1090 71 [00001001] - Actuator Stuck
                    Reset counter: 84
                    Mileage: 95672 km
                    Date: 2023.11.08
                    Time: 23:05:33
                    Defrost door - Specified value: 30
                    Defroster flap: actual value: 99.0 %
                    Defroster flap: actual value: 929
   Part No SW: 5Q0 937 085 AB    HW: 5Q0 937 085 AB
   Component: BCM MQBAB MNA H18 0137
   Serial number: 01011434200748 Dataset Number: 8V0909514K  0081
   Coding: 04141A46C04122F541C04004511007000000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 79BA000AF865985984-802C
   Component: WWS371 141202  042 0585
   Serial number:         141206191541
   Coding: 0A47F7
   Serial number: 23529381
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
   Serial number: 02 10 2014  00000277
   Serial number: 00000000000031391394
   Sunroof control module:
   Component: J245 PS73.404  H02 0003
   Serial number: 0000FST00026MNH00000
   Coding: 101F00
204290 - Remote key 1
          B1479 18 [00001001] - Current Too Low
                    Reset counter: 84
                    Mileage: 95672 km
                    Date: 2023.11.08
                    Time: 23:19:04
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 12.3 V
   Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0051
   Revision: --------    Serial number: 39391433503482 Dataset Number: 8V0909526D  0040
   Coding: 0010150011
   ROD: EV_EPHVA18AU3700000_VW26.rod
   VCID: 42C8A7E6D5331B8195-8016
   Serial number: 003GCR0128ZI Dataset Number: 8V0909602F  0004
   VCID: 47DEB6F2FE113EA942-8012
   Left seat belt tensioner:
   Serial number: 34178311B15121470525
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34178312B15121440613
   Coding: 333135
   Serial number: 6940000Y1400019JKC0X
   Coding: 303139
   Subsystem 4 - Part No SW: -----------    HW: 480 002 811 14
   Serial number: 357000000000A2597117
   Subsystem 5 - Part No SW: -----------    HW: 480 002 811 14
   Serial number: 358000000004F159711G
   Subsystem 6 - Part No SW: -----------    HW: 480 402 811 14
   Serial number: 3510002B518B3A7260F4
   Subsystem 7 - Part No SW: -----------    HW: 480 402 811 14
   Serial number: 3520002A118B3A72C15/
   Subsystem 8 - Part No SW: -----------    HW: 480 400 210 14
   Serial number: 3550002C1175A925732-
   Subsystem 9 - Part No SW: -----------    HW: 480 400 210 14
   Serial number: 3560002C9175A925123$
   Part No SW: 8V0 953 521 CB    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 04121408490707
   Coding: A018
   ROD: EV_SMLSKLOMQB_017.rod
   VCID: 7CB4191EF757AD719F-8028
   Part No SW: 8V0 920 960 H    HW: 8V0 920 960 H
   Component: KOMBI         H01 4291
   Coding: 03F518092B88D7050208EA001800000000000000
   VCID: 40CCADEEDB3F099183-8014
   Revision: --------    Serial number: 03121410800916 Dataset Number: 8V0909515F  0060
   Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
   GVL: 01D43C0000000000404C10000002C80000000000000000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 72A83726A513EB01C5-8026
   Generator:
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Serial number: HA1-00006.11.14 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
   VCID: 46C0BBF6F91B27A1B9-8012
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Serial number: 0352947253 Dataset Number: 8V0909535D  0032
   Coding: 030211
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 383CC50E83EF41513B-806C
   Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0353528586
   Coding: 030211
   Part No SW: 5Q0 959 393 D    HW: 5Q0 959 393 B
   Serial number: 151214BLF02432 Dataset Number: 8V0909872F  0032
   Coding: 00100F204000048000000002
   Component: EPS_MQB_ZFLS  126 1061
   Dataset Number: 8V0909852K  0022
   Coding: 0102
   VCID: 43C6A2E2CA2912899E-8016
   Part No SW: 5Q0 959 392 D    HW: 5Q0 959 392 B
   Serial number: 261114BKQ0023A Dataset Number: 8V0909873F  0032
   Coding: 001007204000048000000002
   VCID: 3FCEAE12A6C17669FA-806A
   Revision: --------    Serial number: -------------- Dataset Number: 8V0909865L  0038
   Coding: 012A000101000000
   VCID: 75A20C3AD47DFC39E0-8020
5276949 - Positioning Motor for Headlight Range Left
          C1085 15 [10001001] - Open or Short to Plus
                    Reset counter: 84
                    Mileage: 95672 km
                    Date: 2023.11.08
                    Time: 23:00:51
5277205 - Positioning Motor for Headlight Range Right
          C1086 15 [10001001] - Open or Short to Plus
                    Reset counter: 84
                    Mileage: 95672 km
                    Date: 2023.11.08
                    Time: 23:00:51
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 844     HW: 8V0 035 844
   Component: MU-S-S-US     013 0626
   Serial number: A7A01012140609 Dataset Number: 8V1909545D  0041
   Coding: 01730100FF0A000021220001001A00002F0001040100010006
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE.rod
   VCID: 76A00B36C97BF721E9-8022
   Multimedia System 1:
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9EY3087KN
   Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Component: ControlUnit_B  H41 0054
   Serial number: C1000024101400040089
          U1014 00 [00001001] - -
                    Reset counter: 84
                    Mileage: 95672 km
                    Date: 2023.11.08
                    Time: 23:04:30
                    Voltage terminal 30: 14.2 V
                    Reset counter: 84
                    Mileage: 95672 km
                    Date: 2023.11.08
                    Time: 23:04:31
                    Voltage terminal 30: 14.3 V
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
   Dataset Number: 8V0909460C  0017
   Coding: 027300010201000300
   ROD: EV_2CamSysRearPASE.rod
   VCID: 302CFD2E6B9F991173-8064
   Part No SW: 5Q0 959 395 D    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0028
   Serial number: 091214BL70623A Dataset Number: 8V0909897D  0018
   Coding: 000007204000048000000002
   Component: TSG HBFS      020 0028
   Serial number: 091214BL706231 Dataset Number: 8V0909896D  0018
65592 - Interior Switch for Central Locking
          B1230 29 [00001000] - Signal Implausible
                    Reset counter: 126
                    Mileage: 95781 km
                    Date: 2023.11.09
                    Time: 03:52:58
End----------(Elapsed Time: 01:43, VBatt start/end: 12.1V/12.1V)-----------
Hmm, this
32951 - Control Module for Electronic Parking Brake​
C10E2 54 [10001001] - Missing Calibration / Basic Setting​
MIL ON - Confirmed - Tested Since Memory Clear​
Should be as simple as the opening and closing you were doing last week. Please try this:
Battery charger connected​
Parking brake off​
Connect to 03-ABS
Basic Settings > [*IDE03331-ENG114972*] Start lining change mode [Go]​
Make note of the response. For instance; Not Running versus Finished Correctly​
[Stop]​
Exit Basic Settings at this point and check Fault Codes to see if there's one for Lining Change Mode. There should be since it would be in the middle of a service action.​
Basic Settings > [*IDE03330-ENG114972*] End lining change mode [Go]​
Note the response before using [Stop]​
Exit the controller, foot on brake pedal, turn the EPB on and back off two full cycles and then re-check for fault codes.​
   #28
Tophergrace3
Ohio, USA
C?ID=327943
Dana,
Thanks again, I tried exactly this and i'm still getting a 32951 code. Everything is working perfectly but i'm getting the code
Saturday,18,November,2023,15:15:54:48330
VCDS Version: Release 23.11.0 (x64) Running on Windows 10 x64
                Address 03: ABS Brakes       Labels: 5Q0-907-379-IPB-V1.clb
Control Module Part Number: 3Q0 907 379 Q    HW: 3Q0 907 379 F
  Component and/or Version: ESC           H42 0610
           Software Coding: 13FF6A9234290A720177030781C829C8562C5080C08194B4024100588208
            Work Shop Code: WSC 06385 790 00016
              ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036 (AU37)
Fault Codes have been Erased
                    Reset counter: 92
                    Date: 2023.11.18
                    Time: 15:15:28
Is there not a basic setting for parking brake?
There is:
IDE05335-ENG114972 -- Electro-mechanical parking brake function test
But I'm not sure what's involved with that one in this module.
There is:
Good call. That may do it. That isn't usually needed but I'd go with the same general prerequisites.
