8V A3 2.0TQ, I done messed up, plugged in different cluster
Tophergrace3
Ohio, USA
C?ID=327943
1ST I READ UWE'S THREAD AND TRIED TO GIVE ALL THE INFO I CAN IF THERE'S ANYTHING ELSE LET ME KNOW AND I'LL SCAN THE CAR AGAIN.
i have a 2015 audi a3 2.0t quattro, i plugged in a used rs3 cluster and now i don't have abs, awd, traction control, cruise etc.
VIN-WAUBFGFF9F1096075
ENGINE- 2.0T CNTC
TRANS- 6-SPEED DSG
Monday,31,July,2023,11:07:55:48330
VCDS Version: 23.3.0.0 (x64)  HEX-NET CB: 0.4631.4
VIN: WAUBFGFF9F1096075   License Plate:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 3C 42 44 52 55 5F 6C BB BC
VIN: WAUBFGFF9F1096075   Mileage: 95248km-59184miles
Address 01: Engine (J623-CNTC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 9C0 BB0 1    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---    CVN: 206287B7
   Coding: 0A1D00324426000F2000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0205G09C0BB01 001003
   ROD: EV_ECM20TFS0205G09C0BB01.rod
   VCID: 3D32D41AACCD647BE8-8068
   VINID: 9D19525975962560402460071409323C8D
20638 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
          P0036 00 [047] - Malfunction / Open Circuit
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 21:39:12
                    Engine RPM: 0.00 /min
                    Coolant temperature: 55 °C
                    Intake air temperature: 47 °C
                    Voltage terminal 30: 12.109 V
                    Engine: operating status: ES
                    ECU_STATE: ENG_STOP
                    T_ES: 83 min
                    T_AST_SAE: 0 s
                    Lambda probe heater: resistance: bank 1: probe 2: 65535 Ohm
                    TEG_DYN_LS_DOWN[1]: 135.2875 °C
                    VLS_DOWN_SAE[1]: 1.275 V
20662 - Oxygen (Lambda) Sensor B1 S1
          P0131 00 [040] - Signal too Low
                    Fault Frequency: 14
                    Mileage: 94937 km
                    Date: 2023.05.21
                    Time: 16:02:51
                    Engine RPM: 1128.00 /min
                    Normed load value: 32.2 %
                    Coolant temperature: 37 °C
                    Intake air temperature: 34 °C
                    Voltage terminal 30: 14.472 V
                    Unlearning counter according OBD: 36
                    Engine: operating status: IS
                    ECU_STATE: SYN_ENG_IGK_ON
                    T_ES: 0 min
                    T_AST_SAE: 4 s
                    TTIP_MES_LS_UP[1]: 648.4375 °C
                    TEG_DYN_LS_UP[1]: 279.5375 °C
                    Lambda probes actual: bank1: 0.6787
15255 - Secondary Air Injection System Valve (N112)
          P0413 00 [237] - Open Circuit
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 21:40:37
                    Engine RPM: 909.00 /min
                    Normed load value: 21.6 %
                    Intake air temperature: 45 °C
                    Voltage terminal 30: 11.894 V
                    STATE_LS_SAE[1]: OL_CDN
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 36 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 13.281250 %
                    FUP_H_SAE: 9670.0 kPa
17178 - Implausible Data Received from ESP Control Module
          U0416 00 [109] - -
                    Mileage: 94720 km
                    Date: 2023.02.06
                    Time: 00:32:46
                    Engine RPM: 1055.50 /min
                    Normed load value: 51.4 %
                    Coolant temperature: 77 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 12.148 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
19875 - No Communication with ABS Brake Control Module
          U0121 00 [175] - -
          [Lost Communication WithAnti-Lock Brake System (ABS) Control Module]
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 21:39:09
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 57.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 83 min
                    Cruise control switch actuation-Main switch: Not operated
                    Cruise control switch actuation-Set: Not operated
                    Cruise control switch actuation-Resume: Not operated
                    Cruise control switch actuation-Accelerate: Not operated
                    Cruise control switch actuation-DELAY: Not operated
                    Cruise control switch actuation-Cancel: Not operated
                    Cruise control switch actuation-Main switch hardware: operated
                    Cruise control switch actuation-Limit button: Not operated
                    Cruise control switch actuation-Main switch CAN: operated
                    Cruise control switch actuation-Large increment: Not operated
                    T_AST_SAE: 0 s
15271 - EVAP System
          P0456 00 [104] - Very Small Leak Detected
                    Mileage: 94931 km
                    Date: 2023.05.18
                    Time: 16:29:55
                    Engine RPM: 1084.00 /min
                    Normed load value: 36.1 %
                    Vehicle speed: 7 km/h
                    Coolant temperature: 21 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 14.355 V
                    Unlearning counter according OBD: 28
                    T_AST_SAE: 17 s
                    MAP_MES_SAE: 60 kPa
                    FAC_TPS_1_SAE: 16.406250 %
                    FUP_H_SAE: 5960.0 kPa
Readiness: 0000 1001
   Part No SW: 0D9 300 012 K    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4513
   Revision: 03253104    Serial number: TFK01412040741 CVN: 0000B51C
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1E703396010B1F63D1-804A
          P1734 00 [002] - -
21221 - No Communications with Parking Brake Control Module
          U0128 00 [011] - -
                    Fault Frequency: 182
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 21:39:09
   Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
   Component: ESC           H42 0610
   Revision: 00000000    Serial number: 63304000002085
   VCID: 48DCB5CEF30F31D34B-801C
10 Faults Found:
0195 - Control module not coded
          U1013 00 [137] - -
          [ECU marked as Not Configured because vehicle ID is invalid]
                    Reset counter: 219
                    Date: 2023.02.01
                    Time: 21:34:49
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 219
                    Date: 2023.02.01
                    Time: 21:34:49
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 219
                    Date: 2023.02.01
                    Time: 21:34:49
0279 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 219
                    Date: 2023.02.01
                    Time: 21:34:49
0295 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 219
                    Date: 2023.02.01
                    Time: 21:34:49
8286 - Databus
          [FCAN: MO_Timeout_ESP signal is invalid]
                    Fault Frequency: 150
                    Reset counter: 37
                    Date: 2023.02.01
                    Time: 21:34:49
8292 - Control Module Incorrectly Coded
          U1014 00 [137] - -
          [FCAN: 4 wheel driven is not coded but Allrad_03 message is received]
                    Reset counter: 219
                    Date: 2023.02.01
                    Time: 21:34:49
8306 - Databus
          U1122 00 [137] - Implausible Message
          [FCAN: Unplausible VIN number]
                    Reset counter: 219
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 21:34:54
8314 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [009] - -
          [FCAN: Coding of ESP and TSK does not fit together]
                    Reset counter: 37
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 21:34:52
32848 - Control Module for Electric Parking Brake
          C10E2 F1 [137] - Switches/Motors Detected
                    Reset counter: 219
                    Date: 2023.02.01
                    Time: 21:34:49
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000522022
   Coding: 03000014010000000000000000001400
   VCID: 3326F2229A89A20B0E-8066
   Humidity sensor: exterior:
   Serial number: 0A780267000000000001
65544 - Button(s) or Switch(es) in Operating Device
          B1312 07 [008] - Mechanical Failure
                    Reset counter: 72
                    Mileage: 95216 km
                    Date: 2023.07.22
                    Time: 17:20:50
                    Voltage terminal 30: 12.6 V
                    Outside temperature: 26.5 °C
                    Pressing a button-Defrost: Not operated
                    Pressing a button-Recirculating air: Not operated
                    Pressing a button-Rear window defogger: Not operated
                    Pressing a button-AC: Not operated
                    Pressing a button-Left heated seat: Not operated
                    Pressing a button-Right heated seat: Not operated
                    Pressing a button-OFF: Not operated
                    Pressing a button-AUTO: Not operated
                    Pressing a button-Footwell air distribution: Not operated
                    Pressing a button-Upper body vent air distribution: operated
                    Pressing a button-Air distribution up: Not operated
                    Pressing a button-Left head area heater: Not operated
                    Pressing a button-Right head area heater: Not operated
328963 - Motor for Front Air Distribution Flap
          B1091 13 [008] - Open Circuit
                    Reset counter: 77
                    Mileage: 95248 km
                    Date: 2023.07.31
                    Time: 10:49:17
                    Voltage terminal 30: 13.8 V
                    Inside temperature: 25.8 °C
                    Outside temperature: 23 °C
                    Front air distribution flap: actual value: 768
                    Front air distribution flap: actual value: 1.5 %
                    Air distribution door front - Specified value: 416
328965 - Motor for Front Air Distribution Flap
          B1091 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 219
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 20:43:31
                    Voltage terminal 30: 12.0 V
                    Inside temperature: 17.8 °C
                    Outside temperature: 5.5 °C
                    Air distribution door front - Specified value: 928
329987 - Motor for Defroster Flap
          B1090 13 [008] - Open Circuit
                    Reset counter: 70
                    Mileage: 94799 km
                    Date: 2023.04.02
                    Time: 01:04:15
                    Voltage terminal 30: 14.5 V
                    Inside temperature: 27.0 °C
                    Outside temperature: 11 °C
                    Defrost door - Specified value: 30
                    Defroster flap: actual value: 768
                    Defroster flap: actual value: 99.0 %
329988 - Motor for Defroster Flap
          B1090 71 [009] - Actuator Stuck
                    Fault Frequency: 29
                    Reset counter: 30
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 20:43:34
                    Defrost door - Specified value: 257
   Part No SW: 5Q0 937 085 AB    HW: 5Q0 937 085 AB
   Component: BCM MQBAB MNA H18 0137
   Serial number: 01011434200748 Dataset Number: 8V0909514K  0081
   Coding: 04141A46C04122F541C04004511007000000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 79BA000AF865985B84-802C
   Component: WWS371 141202  042 0585
   Serial number:         141206191541
   Coding: 0A47F7
   Serial number: 23529381
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
   Serial number: 02 10 2014  00000277
   Serial number: 00000000000031391394
   Sunroof control module:
   Component: J245 PS73.404  H02 0003
   Serial number: 0000FST00026MNH00000
   Coding: 101F00
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 225
                    Mileage: 94750 km
                    Date: 2023.02.24
                    Time: 22:33:19
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: OFF
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 12.6 V
                    Outside temperature: 7.5 °C
   Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0051
   Revision: --------    Serial number: 39391433503482 Dataset Number: 8V0909526D  0040
   Coding: 0010150011
   VCID: 42C8A7E6D5331B8395-8016
12658704 - Databus
          [Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
                    Reset counter: 219
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 20:43:32
13637426 - Databus
                    Reset counter: 219
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 20:43:32
   Serial number: 003GCR0128ZI Dataset Number: 8V0909602F  0004
   VCID: 47DEB6F2FE113EAB42-8012
   Left seat belt tensioner:
   Serial number: 34178311B15121470525
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34178312B15121440613
   Coding: 333135
   Serial number: 6940000Y1400019JKC0X
   Coding: 303139
   Subsystem 4 - Part No SW: -----------    HW: 480 002 811 14
   Serial number: 357000000000A2597117
   Subsystem 5 - Part No SW: -----------    HW: 480 002 811 14
   Serial number: 358000000004F159711G
   Subsystem 6 - Part No SW: -----------    HW: 480 402 811 14
   Serial number: 3510002B518B3A7260F4
   Subsystem 7 - Part No SW: -----------    HW: 480 402 811 14
   Serial number: 3520002A118B3A72C15/
   Subsystem 8 - Part No SW: -----------    HW: 480 400 210 14
   Serial number: 3550002C1175A925732-
   Subsystem 9 - Part No SW: -----------    HW: 480 400 210 14
   Serial number: 3560002C9175A925123$
          B13BC F2 [137] - No function
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 20:43:32
1049093 - Databus
          [NWD: 0x101 ESP_02 error value ESP_Querbeschleunigung]
                    Reset counter: 37
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 20:43:35
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 219
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 20:43:32
1049094 - Databus
          [NWD: 0x101 ESP_02 error value ESP_Laengsbeschleunigung]
                    Reset counter: 219
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 20:43:35
1049095 - Databus
          [NWD: 0x101 ESP_02 error value ESP_Gierrate]
                    Reset counter: 37
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 20:43:35
   Part No SW: 8V0 953 521 CB    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 04121408490707
   Coding: A018
   ROD: EV_SMLSKLOMQB_017.rod
   VCID: 7CB4191EF757AD739F-8028
   Part No SW: 8V0 920 960 H    HW: 8V0 920 960 H
   Component: KOMBI         H01 4291
   Coding: 03F518092B88D7050208EA001800000000000000
   VCID: 40CCADEEDB3F099383-8014
16776967 - Databus
          [EPB_02 keine Kommunikation]
                    Reset counter: 219
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 20:43:31
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 219
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 20:43:31
   Revision: --------    Serial number: 03121410800916 Dataset Number: 8V0909515F  0060
   Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
   GVL: 01D43C0000000000404C10000002C80000000000000000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 72A83726A513EB03C5-8026
   Generator:
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Serial number: HA1-00006.11.14 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
   VCID: 46C0BBF6F91B27A3B9-8012
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Serial number: 0352947253 Dataset Number: 8V0909535D  0032
   Coding: 030211
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 383CC50E83EF41533B-806C
   Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0353528586
   Coding: 030211
   Part No SW: 5Q0 959 393 D    HW: 5Q0 959 393 B
   Serial number: 151214BLF02432 Dataset Number: 8V0909872F  0032
   Coding: 00100F204000048000000002
   Component: EPS_MQB_ZFLS  126 1061
   Dataset Number: 8V0909852K  0022
   Coding: 0102
   VCID: 43C6A2E2CA29128B9E-8016
15873 - Steering angle sensor
                    Reset counter: 219
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 20:43:32
                    Motor status: 00
                    Supply voltage: 12.00 V
                    Temperature: 23.0 °C
                    KFC: 3E
                    KFA: 00 01
                    Freeze frame conditions: 5F
                    uioUdNotFilt_xdu16: 11.94 V
                    uAdSensI_SwitchedKl30_xdu16: 11.94 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
19204 - Databus
          [ESP_02 Botschaft - SNA_Check]
                    Reset counter: 37
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 21:40:36
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 11.75 V
                    Temperature: 22.0 °C
                    KFC: 4B
                    KFA: 00 04
                    Freeze frame conditions: 7F
   Part No SW: 5Q0 959 392 D    HW: 5Q0 959 392 B
   Serial number: 261114BKQ0023A Dataset Number: 8V0909873F  0032
   Coding: 001007204000048000000002
   VCID: 3FCEAE12A6C1766BFA-806A
   Revision: --------    Serial number: -------------- Dataset Number: 8V0909865L  0038
   Coding: 012A000101000000
   VCID: 75A20C3AD47DFC3BE0-8020
5276949 - Positioning Motor for Headlight Range Left
          C1085 15 [137] - Open or Short to Plus
                    Fault Frequency: 42
                    Reset counter: 37
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 20:43:34
5277205 - Positioning Motor for Headlight Range Right
          C1086 15 [137] - Open or Short to Plus
                    Reset counter: 219
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 20:43:34
13705992 - Databus
          [LWI_01: Fehlerwert im Signal LWI_Lenkradwinkel]
                    Fault Frequency: 181
                    Reset counter: 37
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 20:43:31
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 844     HW: 8V0 035 844
   Component: MU-S-S-US     013 0626
   Serial number: A7A01012140609 Dataset Number: 8V1909545D  0041
   Coding: 01730100FF0A000021220001001A00002F0001040100010006
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE.rod
   VCID: 76A00B36C97BF723E9-8022
   Multimedia System 1:
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9EY3087KN
   Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Component: ControlUnit_B  H41 0054
   Serial number: C1000024101400040089
          U1014 00 [009] - -
                    Reset counter: 219
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 20:43:32
                    Voltage terminal 30: 12.1 V
          B11CF 53 [009] - Deactivated
                    Reset counter: 219
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 20:43:33
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
   Dataset Number: 8V0909460C  0017
   Coding: 027300010201000300
   ROD: EV_2CamSysRearPASE.rod
   VCID: 302CFD2E6B9F991373-8064
9529428 - Steering angle sensor
                    Reset counter: 219
                    Mileage: 94717 km
                    Date: 2023.02.01
                    Time: 20:43:32
                    passive
   Part No SW: 5Q0 959 395 D    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0028
   Serial number: 091214BL70623A Dataset Number: 8V0909897D  0018
   Coding: 000007204000048000000002
   Component: TSG HBFS      020 0028
   Serial number: 091214BL706231 Dataset Number: 8V0909896D  0018
End----------(Elapsed Time: 01:41, VBatt start/end: 12.3V/12.3V)-----------
ABS ADVANCED I.D.
Monday,31,July,2023,11:16:33:48330
VCDS Version: Release 23.3.0 (x64)
Control Module Part Number: 3Q0 907 379 Q
  Component and/or Version: ESC           H42 0610
           Software Coding: 000000000000000000000000000000000000000000000000000000000000
            Work Shop Code: WSC 06385
Advanced Identification/FAZIT
     Identification: TT1-09I
     Revision: 00000000
     Date: 26.11.14
     Manufacturer number: 0303
     Test stand number: 0825
Flash Status
     Programming Attempts(application): 0/0
     Flash Date: 00.01.01
Misc.
     Hardware number: 3Q0 907 379 F
     Workshop System Name: J104
     Equipment/PR Code: FFFFFFFFFFFFFFFFFFFFFFFF
     Dataset Number: -----------
     Dataset Version: ----
     ASAM Dataset Revision: 034036
VCDS Info:
ENGINE ADVANCED I.D.
Monday,31,July,2023,11:19:54:48330
                Address 01: Engine
Control Module Part Number: 5G0 9C0 BB0 1
  Component and/or Version: 2.0l R4 TFSI  H13 0001
           Software Coding: 0A1D00324426000F2000
     Identification: SME-RBG
     Revision: --H13---
     Date: 11.12.14
     Manufacturer number: 2017
     Test stand number: 0430
Flash Status
     Programming Attempts(application): 4/4/3/4/5
     Successful Attempts(application): 4/4/3/4/5
     Programming Status: 00000000
     Flash Date: 00.00.00
Software
     HiSpd Net: 01.12.01
Misc.
     Hardware number: 06K 907 425 B
     Workshop System Name: J623
     ASAM Dataset Revision: 001003
Car Info
     Chassis Number: WAUBFGFF9F1096075
     Engine code: CNTC
VCDS Info:
       Labels: 06K-907-425-V1.clb
       Readiness: No script available
IMMOBILIZER ADVANCED I.D.
NO RESPONSE FROM CONTROLLER
AUTO TRANS ADVANCE I.D.
Monday,31,July,2023,11:27:20:48330
Control Module Part Number: 0D9 300 012 K
  Component and/or Version: DQ250-6A MQB  H53 4513
           Software Coding: 0014
            Work Shop Code: WSC 04742
     Identification: TFK-053
     Revision: 03253104
     Date: 04.12.14
     Manufacturer number: 80A6
     Test stand number: 0741
Flash Status
     Programming Attempts(application): 1/4/5
Misc.
     Hardware number: 02E 927 770 AQ
     Workshop System Name: J743
     ASAM Dataset Revision: 001001
Car Info
VCDS Info:
Dr Sheldon
Windsor UK
C?ID=334979
Have you plugged the original back in ??
Plugs back in properly ??
Bent any pins doing so ??
etz2k
C?ID=69430
@Tophergrace3 have you made a autoscan, before you decided to play a bit with different clusters?
Tophergrace3
Ohio, USA
C?ID=327943
i thought i had but i only saved this somehow. Also i thought it would be plug and play (i'm unsticking myself from the 90's)
Sunday,10,October,2021,14:41:35:48330
VCDS Version: 21.9.0.2 (x64) HEX-NET CB: 0.4555.4
VIN: WAUBFGFF9F1096075 License Plate: A3
Mileage: 92734km-57622mi Repair Order:
UDS Adaptation Channel (16B): ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16
Stored value not active
Tophergrace3
Ohio, USA
C?ID=327943
Yes, original is in the car, it wouldn't start with the other cluster in the car
Yes, it plugged back in very smoothly
No, plugs, both male and female, are straight
Tophergrace3
Ohio, USA
C?ID=327943
thanks Uwe i didn't know those where available, i have quite a few but this is the oldest one
Monday,27,September,2021,12:24:15:48330
VIN: WAUBFGFF9F1096075   Mileage: 92515km-57486miles
Address 01: Engine (J623-CNTC)       Labels: None
   Revision: --H13---    CVN: BEA3F5CA
   VCID: 3D32D41AACCD64616A-8068
   Revision: 03253104    Serial number: TFK01412040741 CVN: 00003FED
   VCID: 1E703396010B1F7953-804A
8 Faults Found:
21153 - Gear 1
          P072C 00 [002] - Not Selectable
21154 - Gear 2
          P072D 00 [002] - Not Selectable
21155 - Gear 3
          P072E 00 [002] - Not Selectable
21159 - Gear R
          P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
          P174A 00 [002] - Electrical malfunction
10732 - Valve 3 in Transmission Part 2
          P174E 00 [002] - Electrical malfunction
10906 - Cooling Oil Valve
          P179D 00 [002] - Electrical Malfunction
          P1734 00 [002] - -
   Coding: 13FF6A9234290A720177030781C829C8562C5080C08194B4024100588208
   VCID: 48DCB5CEF30F31C9C9-801C
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 119
                    Mileage: 89464 km
                    Date: 2021.02.18
                    Time: 13:28:58
   VCID: 3326F2229A89A2118C-8066
                    Fault Frequency: 20
                    Reset counter: 42
                    Mileage: 92203 km
                    Date: 2021.08.23
                    Time: 16:37:50
                    Voltage terminal 30: 14.4 V
                    Outside temperature: 30 °C
                    Pressing a button-Upper body vent air distribution: Not operated
                    Reset counter: 46
                    Mileage: 92151 km
                    Date: 2021.08.09
                    Time: 21:03:01
                    Voltage terminal 30: 12.3 V
                    Inside temperature: 35.0 °C
                    Outside temperature: 26 °C
                    Front air distribution flap: actual value: 2.0 %
                    Air distribution door front - Specified value: 91
                    Reset counter: 42
                    Mileage: 89001 km
                    Date: 2020.12.18
                    Time: 13:14:50
                    Voltage terminal 30: 13.7 V
                    Inside temperature: 10.4 °C
                    Outside temperature: 2 °C
                    Front air distribution flap: actual value: 0.0 %
                    Air distribution door front - Specified value: 926
                    Reset counter: 45
                    Mileage: 90592 km
                    Date: 2021.05.11
                    Time: 20:03:54
                    Voltage terminal 30: 14.1 V
                    Inside temperature: 34.8 °C
                    Outside temperature: 17.5 °C
                    Defroster flap: actual value: 929
                    Fault Frequency: 22
                    Reset counter: 7
                    Mileage: 89001 km
                    Date: 2020.12.18
                    Time: 13:16:34
                    Voltage terminal 30: 14.6 V
                    Inside temperature: 10.6 °C
                    Outside temperature: 2.5 °C
                    Defroster flap: actual value: 930
1048836 - Blower Output Reduction due to Energy Management
          B10CE 00 [008] - -
                    Reset counter: 21
                    Mileage: 91862 km
                    Date: 2021.07.14
                    Time: 19:50:07
                    Voltage terminal 30: 11.6 V
                    Blower reduction: No switch-off: no reduction
   VCID: 79BA000AF865984106-802C
   Coding: 0A47F7
   Coding: 00006C
   Coding: 101F00
   Coding: 0010150011
   VCID: 42C8A7E6D5331B9917-8016
   VCID: 47DEB6F2FE113EB1C0-8012
   Coding: 333135
   Coding: 333135
   Coding: 303139
   Coding: A018
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 7CB4191EF757AD691D-8028
   VCID: 40CCADEEDB3F098901-8014
   VCID: 72A83726A513EB1947-8026
   Generator:
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 05 12 2014  C0016392
   Coding: 0001
   VCID: 46C0BBF6F91B27B93B-8012
   Coding: 030211
   VCID: 383CC50E83EF4149B9-806C
   Coding: 030211
   Coding: 0102
   VCID: 43C6A2E2CA2912911C-8016
   VCID: 3FCEAE12A6C1767178-806A
   VCID: 75A20C3AD47DFC2162-8020
                    Fault Frequency: 25
                    Reset counter: 10
                    Mileage: 91598 km
                    Date: 2021.06.11
                    Time: 12:55:32
                    Fault Frequency: 24
                    Reset counter: 10
                    Mileage: 91598 km
                    Date: 2021.06.11
                    Time: 12:02:42
   VCID: 76A00B36C97BF7396B-8022
          U1014 00 [009] - -
                    Reset counter: 42
                    Mileage: 89001 km
                    Date: 2020.12.18
                    Time: 13:14:50
                    Voltage terminal 30: 13.6 V
                    Reset counter: 42
                    Mileage: 89001 km
                    Date: 2020.12.18
                    Time: 13:14:52
   VCID: 302CFD2E6B9F9909F1-8064
End----------(Elapsed Time: 01:41, VBatt start/end: 14.0V/14.0V)-----------
Tophergrace3
Ohio, USA
C?ID=327943
5. Read the wiki's and other sites
vis4vag is a tool that's available free of charge for VCDS users who have current interfaces.
Wiki http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Brake_Electronics_(MK60EC1)
System function test http://wiki.ross-tech.com/wiki/index.php/ESP_System_Function_Test
Steering rack end stops http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Assist#Steering_Limit_Stop_Adaptation
Good news!! i have awd again!! GTI life was getting old, i didn't realize how much i used awd until i lost it
I still have a few dash lights;tpms,steering wheel!,EPC,CEL (orange) and TC
Tophergrace3
Ohio, USA
C?ID=327943
Thursday,03,August,2023,18:23:29:48330
VCDS Version: 23.3.1.0 (x64)  HEX-NET CB: 0.4631.4
VIN: WAUBFGFF9F1096075   License Plate: A3 SCAN AWD FIXED
Mileage: 95258km-59190mi   Repair Order:
VIN: WAUBFGFF9F1096075   Mileage: 95258km-59190miles
   VCID: 3D32D41AACCD647BE0-8068
                    Mileage: 95252 km
                    Date: 2023.08.02
                    Time: 18:35:27
                    Voltage terminal 30: 11.855 V
                    ECU_STATE: ENG_STOP
                    T_ES: 19 min
                    T_AST_SAE: 0 s
                    TEG_DYN_LS_DOWN[1]: 289.7875 °C
          P0131 00 [039] - Signal too Low
                    Mileage: 95258 km
                    Date: 2023.08.03
                    Time: 18:20:48
                    Engine RPM: 1213.50 /min
                    Normed load value: 29.4 %
                    Coolant temperature: 26 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 14.531 V
                    T_ES: 0 min
                    T_AST_SAE: 4 s
                    TTIP_MES_LS_UP[1]: 647.9375 °C
                    TEG_DYN_LS_UP[1]: 319.8500 °C
                    Lambda probes actual: bank1: 0.6797
          P0413 00 [175] - Open Circuit
                    Mileage: 95252 km
                    Date: 2023.08.02
                    Time: 18:36:41
                    Engine RPM: 759.75 /min
                    Normed load value: 15.7 %
                    Coolant temperature: 76 °C
                    Voltage terminal 30: 11.699 V
                    STATE_LS_SAE[1]: OL_INTR
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 29 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.251 V
                    FAC_TPS_1_SAE: 11.718750 %
                    FUP_H_SAE: 9810.0 kPa
          U0416 00 [047] - -
                    Mileage: 95252 km
                    Date: 2023.08.02
                    Time: 20:02:06
                    Engine RPM: 1123.50 /min
                    Normed load value: 45.1 %
                    Coolant temperature: 62 °C
                    Intake air temperature: 55 °C
                    Voltage terminal 30: 11.464 V
Readiness: 0010 1101
   VCID: 1E703396010B1F63D9-804A
   VCID: 48DCB5CEF30F31D343-801C
                    Reset counter: 39
                    Date: 2023.08.02
                    Time: 18:35:23
                    Reset counter: 39
                    Date: 2023.08.02
                    Time: 18:35:23
                    Reset counter: 39
                    Date: 2023.08.02
                    Time: 18:35:23
                    Reset counter: 39
                    Date: 2023.08.02
                    Time: 18:35:23
16413 - Display for Tire Pressure Monitoring
          C1146 02 [137] - Signal Failure
                    Reset counter: 39
                    Mileage: 95252 km
                    Date: 2023.08.02
                    Time: 18:35:32
33000 - Longitudinal Acceleration
          C10B1 29 [137] - Signal Implausible
          [IPB-Sensor: Longitudinal acceleration sensor failure]
                    Reset counter: 39
                    Date: 2023.08.02
                    Time: 18:35:23
   VCID: 3326F2229A89A20B06-8066
                    Reset counter: 39
                    Mileage: 95252 km
                    Date: 2023.08.02
                    Time: 18:35:22
                    Voltage terminal 30: 11.9 V
                    Inside temperature: 36.4 °C
                    Air distribution door front - Specified value: 927
                    Reset counter: 39
                    Mileage: 95252 km
                    Date: 2023.08.02
                    Time: 18:35:36
                    Voltage terminal 30: 11.8 V
                    Inside temperature: 36.6 °C
   VCID: 79BA000AF865985B8C-802C
   Coding: 0A47F7
   Coding: 00006C
   Coding: 101F00
                    Reset counter: 39
                    Mileage: 95252 km
                    Date: 2023.08.02
                    Time: 19:48:35
                    CAN-Bus_aktiv: OFF
                    OFF: operated
                    last_wakeup: Pin A32 Heckdeckel Softtouch TasterPin
                    Voltage: 12.3 V
   Coding: 0010150011
   VCID: 42C8A7E6D5331B839D-8016
13637426 - Databus
                    Reset counter: 39
                    Mileage: 95252 km
                    Date: 2023.08.02
                    Time: 18:35:22
   VCID: 47DEB6F2FE113EAB4A-8012
   Coding: 333135
   Coding: 333135
   Coding: 303139
1050117 - Databus
                    Reset counter: 39
                    Mileage: 95252 km
                    Date: 2023.08.02
                    Time: 18:35:23
1049094 - Databus
                    Reset counter: 39
                    Mileage: 95252 km
                    Date: 2023.08.02
                    Time: 18:35:25
   Coding: A018
   VCID: 7CB4191EF757AD7397-8028
   VCID: 40CCADEEDB3F09938B-8014
   VCID: 72A83726A513EB03CD-8026
   Generator:
   Coding: 0001
   VCID: 46C0BBF6F91B27A3B1-8012
   Coding: 030211
   VCID: 383CC50E83EF415333-806C
   Coding: 030211
   Coding: 0102
   VCID: 43C6A2E2CA29128B96-8016
19204 - Databus
                    Mileage: 95252 km
                    Date: 2023.08.02
                    Time: 18:35:22
                    Motor status: 00
                    Temperature: 59.0 °C
                    KFC: 4B
                    KFA: 00 04
                    uioUdNotFilt_xdu16: 11.91 V
                    uAdSensI_SwitchedKl30_xdu16: 11.91 V
                    Reset counter: 39
                    Mileage: 95252 km
                    Date: 2023.08.02
                    Time: 18:35:22
                    Motor status: 00
                    KFC: 3E
                    KFA: 00 01
                    uioUdNotFilt_xdu16: 11.75 V
                    uAdSensI_SwitchedKl30_xdu16: 11.74 V
   VCID: 3FCEAE12A6C1766BF2-806A
   VCID: 75A20C3AD47DFC3BE8-8020
                    Reset counter: 39
                    Mileage: 95252 km
                    Date: 2023.08.02
                    Time: 20:02:06
                    Reset counter: 39
                    Mileage: 95252 km
                    Date: 2023.08.02
                    Time: 18:35:25
13705992 - Databus
                    Mileage: 95252 km
                    Date: 2023.08.02
                    Time: 18:35:22
   VCID: 76A00B36C97BF723E1-8022
          U1014 00 [009] - -
                    Reset counter: 39
                    Mileage: 95252 km
                    Date: 2023.08.02
                    Time: 18:35:22
                    Reset counter: 39
                    Mileage: 95252 km
                    Date: 2023.08.02
                    Time: 18:35:23
   VCID: 302CFD2E6B9F99137B-8064
                    Reset counter: 39
                    Mileage: 95252 km
                    Date: 2023.08.02
                    Time: 18:35:22
                    passive
End----------(Elapsed Time: 01:42, VBatt start/end: 14.6V/13.9V)-----------
Looks like you have some Basic Settings to be done in 03-ABS and 44-Steering, and an oxygen sensor heating circuit to fix.
Tophergrace3
Ohio, USA
C?ID=327943
I'm in VCDS trying to do my basic settings and i cannot get things to cooperate.
Monday,06,November,2023,15:58:50:48330
VCDS Version: Release 23.11.0 (x64) Running on Windows 10 x64
                Address 44: Steering Assist       Labels: 5Q0-909-144.clb
Control Module Part Number: 5Q0 909 144 R    HW: 5Q0 909 144 R
  Component and/or Version: EPS_MQB_ZFLS  126 1061
           Software Coding: 0002
            Work Shop Code: WSC 06385 790 00016
              ASAM Dataset: EV_SteerAssisMQB 012140 (AU37)
                      VCID: 43C6A2E2CA2912899E-8016
          B1168 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 83
                    Mileage: 95667 km
                    Date: 2023.11.05
                    Time: 15:36:28
                    Motor status: 01
                    Supply voltage: 14.00 V
                    Temperature: 44.0 °C
                    KFC: 3E
                    KFA: 00 01
                    uioUdNotFilt_xdu16: 13.97 V
                    uAdSensI_SwitchedKl30_xdu16: 13.96 V
19204 - Databus
                    Reset counter: 83
                    Mileage: 95667 km
                    Date: 2023.11.05
                    Time: 15:36:28
                    Motor status: 01
                    KFC: 4B
                    KFA: 00 04
                    uioUdNotFilt_xdu16: 14.16 V
                    uAdSensI_SwitchedKl30_xdu16: 14.16 V
Monday,06,November,2023,15:59:19:48330
                Address 03: ABS Brakes       Labels: 5Q0-907-379-IPB-V1.clb
Control Module Part Number: 3Q0 907 379 Q    HW: 3Q0 907 379 F
           Software Coding: 13FF6A9234290A720177030781C829C8562C5080C08194B4024100588208
              ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036 (AU37)
                      VCID: 48DCB5CEF30F31D14B-801C
          C1017 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 83
                    Date: 2023.11.05
                    Time: 15:15:31
          C1079 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 83
                    Date: 2023.11.05
                    Time: 15:15:31
          C107A 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 83
                    Date: 2023.11.05
                    Time: 15:15:31
          B1168 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 83
                    Date: 2023.11.05
                    Time: 15:15:31
          C1146 02 [00001001] - Signal Failure
                    Reset counter: 83
                    Mileage: 95667 km
                    Date: 2023.11.05
                    Time: 15:15:40
          C10B1 29 [10001001] - Signal Implausible
                    Reset counter: 83
                    Date: 2023.11.05
                    Time: 15:15:31
Been here?
Tophergrace3
Ohio, USA
C?ID=327943
I haven't been there yet but that's definitely helpful, i tried for almost 3 hours today
Hoping my o2 circuit won't interfere with a steering re-calibration
Again, thanks UWE
Tophergrace3
Ohio, USA
C?ID=327943
Friday,10,November,2023,09:41:06:48330
VCDS Version: 23.11.0.0 (x64)  HEX-NET CB: 0.4643.4
VIN: WAUBFGFF9F1096075   Mileage: 95670km-59446miles
   Revision: --H13---    CVN: 3FCF1B67
   VCID: 3D32D41AACCD6479E8-8068
          P0036 00 [00100111] - Malfunction / Open Circuit
                    Mileage: 95670 km
                    Date: 2023.11.08
                    Time: 15:52:05
                    Engine RPM: 840.50 /min
                    Normed load value: 22.4 %
                    Coolant temperature: 50 °C
                    Intake air temperature: 12 °C
                    T_ES: 0 min
                    T_AST_SAE: 2 s
                    TEG_DYN_LS_DOWN[1]: 318.6625 °C
          P0413 00 [01100101] - Open Circuit
                    Mileage: 95670 km
                    Date: 2023.11.08
                    Time: 15:52:03
                    Engine RPM: 812.50 /min
                    Normed load value: 21.2 %
                    Coolant temperature: 49 °C
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 30 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.987 V
                    FAC_TPS_1_SAE: 12.500000 %
                    FUP_H_SAE: 4690.0 kPa
17178 - Databus
          U1123 00 [00100111] - Received Error Message
                    Mileage: 95670 km
                    Date: 2023.11.08
                    Time: 15:54:44
                    Coolant temperature: 61 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 12.519 V
Readiness: 1110 1101
   VCID: 1E703396010B1F61D1-804A
          P1734 00 [00000010] - -
8 Faults Found:
                    Reset counter: 83
                    Date: 2023.11.08
                    Time: 15:52:00
                    Reset counter: 83
                    Date: 2023.11.08
                    Time: 15:52:00
                    Reset counter: 83
                    Date: 2023.11.08
                    Time: 15:52:00
          B1168 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 123
                    Mileage: 95670 km
                    Date: 2023.11.08
                    Time: 15:54:00
0297 - Steering angle sensor
          B1168 16 [10001001] - Voltage Too Low
                    Reset counter: 83
                    Mileage: 95670 km
                    Date: 2023.11.08
                    Time: 15:54:00
8277 - Databus
          [FCAN: EPS_DSR_Status signal is invalid]
                    Reset counter: 83
                    Date: 2023.11.08
                    Time: 15:52:00
          C1146 02 [10001001] - Signal Failure
                    Reset counter: 83
                    Mileage: 95670 km
                    Date: 2023.11.08
                    Time: 15:52:09
                    Reset counter: 83
                    Date: 2023.11.08
                    Time: 15:52:00
   VCID: 3326F2229A89A2090E-8066
          B1091 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 83
                    Mileage: 95670 km
                    Date: 2023.11.08
                    Time: 15:51:59
                    Inside temperature: 7.6 °C
                    Outside temperature: 9 °C
                    Front air distribution flap: actual value: 928
          B1090 71 [00001001] - Actuator Stuck
                    Reset counter: 83
                    Mileage: 95670 km
                    Date: 2023.11.08
                    Time: 15:52:00
                    Defroster flap: actual value: 928
   VCID: 79BA000AF865985984-802C
   Coding: 0A47F7
   Coding: 00006C
   Coding: 101F00
   Coding: 0010150011
   ROD: EV_EPHVA18AU3700000_VW26.rod
   VCID: 42C8A7E6D5331B8195-8016
13637426 - Databus
                    Reset counter: 83
                    Mileage: 95670 km
                    Date: 2023.11.08
                    Time: 15:51:59
   VCID: 47DEB6F2FE113EA942-8012
   Coding: 333135
   Coding: 333135
   Coding: 303139
1050117 - Databus
                    Reset counter: 83
                    Mileage: 95670 km
                    Date: 2023.11.08
                    Time: 15:54:00
1049094 - Databus
                    Reset counter: 83
                    Mileage: 95670 km
                    Date: 2023.11.08
                    Time: 15:52:03
   Coding: A018
   VCID: 7CB4191EF757AD719F-8028
   VCID: 40CCADEEDB3F099183-8014
   VCID: 72A83726A513EB01C5-8026
   Generator:
   Coding: 0001
   VCID: 46C0BBF6F91B27A1B9-8012
   Coding: 030211
   VCID: 383CC50E83EF41513B-806C
   Coding: 030211
   Coding: 0102
16387 - Steering End Stops Not Learned
          C10AC F0 [00001001] - Unknown Error Elaboration
          [Endanschläge nicht korrekt eingelernt Beide Endanschläge nicht eingelernt]
                    Reset counter: 83
                    Mileage: 95670 km
                    Date: 2023.11.08
                    Time: 15:51:59
                    Motor status: 01
                    Supply voltage: 14.25 V
                    Temperature: 18.0 °C
                    KFC: 40
                    KFA: 00 03
                    Rotorlagesensorspannung AMR Sinus: 2.634 V
                    Rotorlagesensorspannung AMR Kosinus: 11.959 V
                    Rotorlagesensorspannung AMR Sinus 2: 2.634 V
                    Rotorlagesensorspannung AMR Cosinus 2: 8.736 V
                    Rotorlagesensorspannung Hall 1: 0.0 V
                    Rotorlagesensorspannung Hall 2: 0.0 V
                    Aktueller Sinus-Offset für ASIC: -0.0 mV
                    Aktueller Cosinus-Offset für ASIC: 0.0 mV
                    aktuelle Sinusverstärkung für ASIC: 0.161
19204 - Databus
                    Reset counter: 83
                    Mileage: 95670 km
                    Date: 2023.11.08
                    Time: 15:51:59
                    Motor status: 01
                    KFC: 4B
                    KFA: 00 04
                    uioUdNotFilt_xdu16: 14.45 V
                    uAdSensI_SwitchedKl30_xdu16: 14.46 V
16131 - Steering Angle Sensor
          B1168 F2 [00001001] - Not Initialized
                    Reset counter: 83
                    Mileage: 95670 km
                    Date: 2023.11.08
                    Time: 15:54:00
                    Motor status: 01
                    Temperature: 19.0 °C
                    KFC: 3F
                    KFA: 00 03
                    uioUdNotFilt_xdu16: 14.39 V
                    uAdSensI_SwitchedKl30_xdu16: 14.38 V
   VCID: 3FCEAE12A6C17669FA-806A
   VCID: 75A20C3AD47DFC39E0-8020
          C1085 15 [10001001] - Open or Short to Plus
                    Reset counter: 83
                    Mileage: 95670 km
                    Date: 2023.11.08
                    Time: 15:52:03
          C1086 15 [10001001] - Open or Short to Plus
                    Reset counter: 83
                    Mileage: 95670 km
                    Date: 2023.11.08
                    Time: 15:52:03
   VCID: 76A00B36C97BF721E9-8022
          U1014 00 [00001001] - -
                    Reset counter: 83
                    Mileage: 95670 km
                    Date: 2023.11.08
                    Time: 15:51:59
                    Reset counter: 83
                    Mileage: 95670 km
                    Date: 2023.11.08
                    Time: 15:52:00
   VCID: 302CFD2E6B9F991173-8064
                    Reset counter: 83
                    Mileage: 95670 km
                    Date: 2023.11.08
                    Time: 15:54:00
                    passive
End----(Elapsed Time: 01:42, VBatt start/end: 12.3V/12.0V. VIgn 11.9V)-----
Hi Chris,
I'm looking over the emailed scan but we break for lunch soon. I'll report back in forum with any suggestions however all of the Missing Calibration / Basic Setting DTCs in 03-ABS need to be resolved before the steering rack is going to cooperate.
