Resolved Hello, First time post.
Resolved
Rich from South Mountain
Myersville, MD, USA
C?ID=381807
2015 Passat TDI SE, 116K. Car runs fine. I have multiple dash indicators... Steering assist, ERROR: airbag, stabilization control (ESC), TPMS, cruise is inop. Scan says right rear speed sensor has multiple codes. Sensor will be here tomorrow. Been working on cars for 45 years. Former avionics technician on large transport category aircraft. Comfortable with all types electronic test equipment. Survived with a simple OBDII code reader until now. Not familiar with VCDS but I'm guessing it will come with time. I was able to clear everything using the factory setting reset but all the errors and warnings came back. From what I can see, I need an airbag module, abs control module, and cruise control module. abs module looks to be almost impossible to access. Any secret on R&R the abs module greatly appreciated. Difficult to understand how all these electronic modules would fail at once.
Also parts prices for new parts are almost unaffordable. I'd rather not purchase used. I'm good with rebuilt/remanufactured. Any assistance greatly appreciated. Scan below. Thank you. Rich
Sunday,30,July,2023,15:29:17:27397
VCDS Version: 23.3.1.0  HEX-V2 CB: 0.4631.4
VIN: 1VWBV7A3XFC095621   License Plate:
Chassis Type: A3-VW41 (7N0)
          75 77
VIN: 1VWBV7A3XFC095621   Mileage: 187110km-116264miles
Address 01: Engine (J623-CVCA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 016 D    HW: 04L 907 309 K
   Component: R4 2.0l TDI   H20 9466
   Revision: 8AH20---    CVN: C3699F2538D3FF82B866C2AD
   Coding: 011D0012032410080000
   Shop #: WSC 09146 444 00000
   ASAM Dataset: EV_ECM20TDI01104L997016D 004002
   ROD: EV_ECM20TDI01104L997016D.rod
   VCID: 34311C263EBDDFFADB3-8060
   VINID: 0669D2987443A164C0245182048D5EBB92
17158 - Databus
          U1123 00 [047] - Received Error Message
                    Fault Frequency: 11
                    Mileage: 186875 km
                    Date: 2023.07.23
                    Time: 00:26:56
                    Engine RPM: 830.00 /min
                    Normed load value: 30.2 %
                    Coolant temperature: 44 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 13.920 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
                    Acceleration: 0.000 m/s²
   Part No SW: 02E 300 061 T    HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4518
   Revision: 05653104    Serial number: 00001501262681
   Shop #: WSC 09003 957 00200
   VCID: 2517F16289E7B6725CD-8070
18255 - Please check DTC Memory of ABS Controller
            P1847 - 000 -  - Intermittent
                    Fault Frequency: 20
                    Reset counter: 1
                    Mileage: 186905 km
                    Date: 2017.12.15
                    Time: 00:48:42
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: C54BC0F5492B00FFA31103E6921A0042A1100012
   VCID: 04518CE62E1DAF7A2B3-8050
03842 - RPM Sensor Rear Right: Incorrect Signal
                    Reset counter: 182
                    Mileage: 186875 km
                    Date: 2017.12.13
                    Time: 00:26:57
                    Count: 7
                    Count: 12
                    Count: 12800
                    Count: 87
                    Count: 49664
                    Count: 511
                    Fault Status: 00100011
                    Reset counter: 149
                    Mileage: 186875 km
                    Date: 2017.12.14
                    Time: 04:33:05
                    Count: 1090
                    Count: 4608
                    Count: 83
                    Count: 49990
                    Count: 254
                    Reset counter: 147
                    Mileage: 186875 km
                    Date: 2017.12.13
                    Time: 00:25:55
                    Count: 2
                    Count: 12
                    Count: 12800
                    Count: 16390
                    Count: 49664
                    Count: 511
                    Fault Status: 01101100
                    Reset counter: 149
                    Mileage: 186875 km
                    Count: 3
                    Count: 12
                    Count: 4096
                    Count: 4199
                    Count: 45824
                    Count: 510
   Part No SW: 561 907 426 J    HW: 561 907 426 J
   Component: AC Manuell    H02 0404
   Revision: 00001K01
   Coding: 0010001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 221DEA7E9449414A39F-8076
   Part No SW: 5K0 937 085 AB    HW: 5K0 937 085 AB
   Component: BCM PQ35 B+   122 0174
   Revision: BH122001
   Coding: EF200E1B802B2AD4098800010600044800F1A08640801520648060000C70
   Shop #: WSC 20487 002 1048576
   VCID: 73B3DF3A7BB398C2029-8026
   Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
   Component: AirbagVW10    500 0975
   Serial number: 003LZD06GFN3   Dataset Number: 560003v__A_ 0135
   Coding: 00004D53
   Shop #: WSC 19001 002 1048576
   ASAM Dataset: EV_AirbaVW10SMEVW360 001030
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 72BDDA3E042991CA09F-8026
   Serial number: 6940000Y150001BX900R
   Coding: 303044
   Serial number: 3572MSME26606A4EZZZ+
   Serial number: 3582MSME77616A4EZZZ6
   Serial number: 3516KSME4B546635ZZZX
   Serial number: 3526KSME161F6635ZZZX
   Serial number: 3556LSME77336634ZZZX
   Serial number: 3566LSME77016B34ZZZY
          B10B3 00 [008] - Function Restriction due to Implausible Message(s)
                    Fault Frequency: 15
                    Reset counter: 189
                    Mileage: 186875 km
                    Date: 2023.07.24
                    Time: 04:28:41
   Part No SW: 1K5 953 521 BM    HW: 5K0 953 569 AE
   Component: LENKS.MODUL   016 0162
   Revision: FF010042    Serial number: 20150312201200
   Coding: 088A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79AFED12595FE292485-802C
   Component: E221__MFL-8LP  H07 0023
   Serial number: 00000000000001044865
   Coding: E20000
   Part No SW: 561 920 970 G    HW: 561 920 970 G
   Component: KOMBI         H05 0813
   Coding: 231E01
   VCID: 1E65DE8EA03165AA1D7-804A
   Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1653
   Revision:   H55       Serial number: 19041503000264
   Coding: 461000
   VCID: 005980F63A05B35A0FB-8054
Address 1C: Position Sensing
   Component: IMMO          H05 0813
   VCID: 6A8DC25E2CF9590AB1F-803E
Address 2E: Media Player 3
   Revision: 13110009    Serial number: 0009529342
   Coding: 0404B5
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BE3979AF3A330823A9-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14202630150417192330
   Coding: 800000
          B11EC 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 181
                    Mileage: 186875 km
                    Date: 2023.07.23
                    Time: 00:25:54
131584 - Motor for Rear Window Regulator
          B11EE 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 182
                    Mileage: 186875 km
                    Date: 2023.07.23
                    Time: 00:25:55
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 215    3501
   Revision: 00H22000
   VCID: 392F2D12155F2292085-806C
                    Fault Status: 00101101
                    Fault Frequency: 23
                    Reset counter: 189
                    Mileage: 187118 km
                    Date: 2017.12.20
                    Time: 03:19:53
                    Voltage: 12.38 V
                        DD
                    Temperature: 28.0°C
   Component: EZE_2         H55 1653
   Coding: 01030108
   VCID: 6FBBD34A179BBC22E61-803A
   Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
   Component: J245 P05 9BA3  H08 0005
   Serial number: 53388786011432000446
   Coding: 181100
   Component: Analoguhr  009 0005
   Revision: 15110009    Serial number: 0009434366
   Coding: 0404B4
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CE19486F6AD37BA333-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14102631150417104502
   Coding: 800000
                    Reset counter: 181
                    Mileage: 186875 km
                    Date: 2023.07.23
                    Time: 00:25:54
                    Reset counter: 182
                    Mileage: 186875 km
                    Date: 2023.07.23
                    Time: 00:25:55
   Part No SW: 1K0 035 188 F    HW: 1K0 035 188 F
   Component: Radio Prem-8  H08 0009
   Revision: -----13S    Serial number: VWZ4Z7R3700731
   Coding: 0100044004000B
   VCID: 2B03075AE30380028A9-807E
                    Reset counter: 141
                    Mileage: 186875 km
                    Date: 2017.12.13
                    Time: 00:25:53
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0156
   Serial number: 000003554140534 Dataset Number: 561098V____ 0017
   Coding: 02140102C21632007F1606C00000
   ASAM Dataset: EV_OCULow 002009
   ROD: EV_OCULow_002.rod
   VCID: 1471BCA65EFD3FFABB3-8040
   Part No SW: 5N0 035 729 E    HW: 5N0 035 729 E
   Component: TELEFON       H07 0593
   Revision: 1B001001    Serial number: 00007670129636 Dataset Number: 5N0035729E  0001
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: 323D1A3EC4A9D1CAC9F-8066
End----------(Elapsed Time: 01:07, VBatt start/end: 12.3V/12.3V)-----------
Hi and welcome.
Why do you think you need an ABS module? All the faults in that module point at the right rear wheel speed sensor. A problem with the wheel speed sensor will trigger a cascade of faults in other module because they all get data from the ABS. Now whether this is actually a bad wheel speed sensor, or a problem with the pulse-ring at the wheel, or even the wheel bearing, is difficult to determine remotely.
Head for Measuring Blocks in the ABS and observe (or log) all four wheel speeds. When driving in a straight line, they should all be the same. My guess is the right rear one will be off from the rest (if it works at all).
There is no "Cruise Control Module". Cruise is all done between the 16-Steering Wheel and 01-Engine. However, it won't work while the ABS is unhappy.
The Airbag module seems to have an issue with the passenger seat occupancy module in the passenger seat. Check the electrical connections to that module before throwing any parts at this.
Because that's unlikely to be what's going on here. ;)
Myersville, MD, USA
C?ID=381807
I was thinking the sensor might be pushing though to the other faults, but was too pessimistic. I did reseat the abs module connecter. Passenger seat airbag light does cycle off and on when occupied. I will reseat connectors. Thank you very much for the reply.
wiw
C?ID=542818
Had this on my MK7 golf. Cluster went haywire and lost all the same systems (less the lane as it's not fitted)
Faulty speed sensor as Uwe pointed to.
Myersville, MD, USA
C?ID=381807
Finally installed the sensor. Took forever to arrive. It park, easuring blocks for the other wheels show zero, right rear fluctuates all over the place. When I drive, it goes to 40 kph and stops. Other 3 reflect the speed of the car. With the fluctuations at idle, would seem to point to wiring, not the bearing or the pulse ring. Although corrosion on the ring could cause readings to fluctuate at idle. Could be some real crap on the ring.
Dr Sheldon
Windsor UK
C?ID=334979
I have had mental health issues solving these..
When it is Right Rear it is always the Bearing / Phase Wheel - and always Right Rear !!! - Rarely the Sensor
It must be a conspiracy as the Ford Fiesta is the Same ?
MVB's For all 4 wheel speed sensors and Graph them !!! - Will stick out like a sore thumb
Myersville, MD, USA
C?ID=381807
Thanks Doc. I have fond memories of Skulthorpe Weathersfield and Lakenheath! It was obvious viewing the measuring blocks. I'm giving the pulse/tone ring a try. Although if I have the rear disassembled - I think I'll replace the wheel bearing.
Dr Sheldon
Windsor UK
C?ID=334979
Lakenheath!
Been there !!
Myersville, MD, USA
C?ID=381807
Hello, Replaced the sensor. Tried to find the pulse/tone wheel but was unable. Ordered bearing. Good price at online. New bearing came with a new tone wheel. New bearing installed. Measuring blocks still shows right rear oscillating with a variety of readings, should be zero in park. The other 3 show 0 kph in park. Seems like this could be a wiring or connector issue between the right rear sensor and where ever it goes to the ABS module.
Myersville, MD, USA
C?ID=381807
Long delay in repair due to broken laptop. Followed wiring from sensor from wheel well to rear seat. Harness follows beneath the bottom door jambs. Removed trim to passenger front seat. No change when moving harness. Removed the battery and cleaned terminals. Removed battery ground and reconnected. Reading changed to constant 2kph when stopped. After test drive, fluctuations returned. Decided to swap sensor with the left rear. Error swapped sides so new received sensor is faulty. Carparts.com is replacing sensor. Will troubleshoot AIRBAG error next. Will start with reseating airbag component connecters.
Larry Manton
C?ID=112505
Yeah that makes it tough, a lot of that as of late.
