VW UP airbag issues
Millers Motors
Launceston, Cornwall, UK
C?ID=167727
Hi all looking for some help please, the bodyshop next door to my workshop has a 2013 VW up in that had set off the air bags, they replaced with second hand units but the codes coming up are as follows
Thursday,20,August,2015,14:36:58:22373
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
VIN: WVWZZZAAZDD114965   License Plate: WA13 XGR
Mileage: 38710km-24053mi   Repair Order:
Chassis Type: AA (6N0)
Scan: 01 03 09 15 17 19 25 44 56
VIN: WVWZZZAAZDD114965   Mileage: 38710km-24053miles
Address 01: Engine (------CHYA)       Labels: 04C-906-020-CHY.clb
   Part No SW: 04C 906 020     HW: 04C 907 309
   Component: 1.0l R3 MPI   H01 4402
   Revision: U7H01---    Serial number:
   Coding: 00110010000400000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM10MPI01104C906020 001011
   ROD: EV_ECM10MPI01104C906020.rod
   VCID: 58B9D4FB23440EFE4E-800C
4675 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [032] - -
                    Mileage: 38712 km
                    Date: 2015.05.22
                    Time: 19:37:14
4715 - No Communication with Instrument Cluster
          U0155 00 [032] - -
4629 - ECM Power Relay Load Circuit
          P068A 00 [039] - Opens Too Early
   Part No SW: 1S0 614 117 L    HW: 1S0 614 117 L
   Component: EBC 460 MABS  H09 0012
   Serial number: A007K91
   Coding: 11BF247189AE00F5880324FB91AE0080580100
   ASAM Dataset: EV_Brake1ABSMP1TRWVW120 012031
   ROD: EV_Brake1ABSMP1TRWVW120.rod
   VCID: 3461404B9F6C0A9E82-8060
0020 - Rear Right Wheel Speed Sensor
          C101D 29 [008] - Signal Implausible
                    Reset counter: 221
                    Mileage: 38712 km
                    Date: 2015.05.22
                    Time: 19:37:14
0276 - Databus
                    Reset counter: 222
0279 - Databus
                    Reset counter: 222
0283 - Databus
                    Reset counter: 222
0318 - Databus
                    Reset counter: 222
Address 09: Cent. Elect. (J519)       Labels: 1S0-937-08x-09.clb
   Part No SW: 1S0 937 086 B    HW: 1S0 937 086 B
   Component: PQ25 BCM      H30 0555
   Revision: -A------    Serial number: --------------
   Coding: 64B8290000010000000008042C28AC800040400C60020000200000400000
   VCID: 377B7747861AE186A7-8062
   Part No SW: 1S0 959 655 B    HW: 1S0 959 655 B
   Component: VW10Airbag00R H02 0006
   Revision: --------    Serial number: 003MY0035C3$
   Coding: 000000000000000000000000000000003052
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
   ROD: EV_AirbaVW10BPAVN750_SE12.rod
   VCID: 3D77656FAC26CBD67D-8068
   Serial number: 349  RB4000000000005
   Serial number: 350  RB400000000000/
   Serial number: 3555NRB400M52L7AAOLX
9443146 - Driver's Side Airbag Crash Sensor
          B1017 4A [137] - Incorrect component(s) installed
                    Mileage: 38717 km
                    Date: 2015.08.19
                    Time: 23:26:35
9443091 - Driver's Side Airbag Crash Sensor
          B1017 13 [137] - Open Circuit
                    Mileage: 38717 km
                    Date: 2015.08.19
                    Time: 23:26:39
9451082 - Crash sensor side airbag; passenger side
          B1036 4A [137] - Incorrect component(s) installed
                    Mileage: 38717 km
                    Date: 2015.08.19
                    Time: 23:26:35
9451027 - Crash sensor side airbag; passenger side
          B1036 13 [137] - Open Circuit
                    Mileage: 38717 km
                    Date: 2015.08.19
                    Time: 23:26:39
Address 17: Instruments (J285)       Labels: 1Sx-920-xxx-17.clb
   Part No SW: 1S0 920 960 K    HW: 1S0 920 960 K
   Component: KOMBI         H21 0105
   Revision: X0021008    Serial number: 00000000000000
   Coding: 414200
   ASAM Dataset: EV_KombiUDSMM9RM10 A04712
   ROD: EV_KombiUDSMM9RM10_SE12.rod
   VCID: 397F717FB80EF7F651-806C
13635840 - Supply voltage
                    Reset counter: 222
                    Mileage: 38714 km
                    Date: 2015.07.26
                    Time: 21:17:44
          U1400 00 [008] - -
                    Reset counter: 222
                    Mileage: 38714 km
                    Date: 2015.07.26
                    Time: 21:17:31
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 1S0 937 086 B
   Component: GW-K-CAN TP20 H30 0555
   Revision: -A------
   Coding: 001100
   VCID: 70E98C5BA3F476BEA6-8024
                    Reset counter: 248
                    Mileage: 38717 km
                    Date: 2015.08.19
                    Time: 23:28:33
   Part No SW: 5K0 953 234     HW: 1S0 920 960 K
   Component: IMMO          H21 0105
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   ROD: EV_ImmoUDSMM9RM10_SE12.rod
   VCID: 6ADD9E338D288C6EE8-803E
Address 44: Steering Assist (J792)       Labels: 1Sx-909-144-44.clb
   Part No SW: 1S2 909 144 L    HW: 1S2 909 144 G
   Component: EPS_ECU       H45 1503
   Coding: 0001000001010000
   ASAM Dataset: EV_SteerAssisNSK 009004
   ROD: EV_SteerAssisNSK_SE12.rod
0101 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 222
0067 - Terminal 30
          U140A 00 [008] - Open Circuit
                    Reset counter: 9
0196 - Supply voltage
                    Reset counter: 222
   Part No SW: 1S0 035 156     HW: 1S0 035 156
   Component: Radio         567 5541
   Revision: AA001001    Serial number: VWZ8Z1N1080544
   Coding: 0000020001
   VCID: 68D9E43B9B24BE7EFE-803C
                    Fault Status: 00110010
                    Reset counter: 222
End-------------------------(Elapsed Time: 01:28)--------------------------
Now the other codes are all battery disconnected related but i would like an opinion on the Airbag fault codes, i think faulty parts have been fitted but before i speak to the pain shop owner what are your thoughts on it?
I also think faulty (or incorrect) parts have been fitted, and the likelihood of this is greatly increased since the parts are "second hand". In any case, Ross-Tech strongly frowns on installing used airbag components and will not assist customers who are "fixing" cars that way. It is in fact illegal in many places, and there are good reasons for that.
Millers Motors
C?ID=167727
Totally agree Uwe, ive left it in the bodyshop hands, tbh not something i wanna get involved with
