A8 led matrix
vioelectric
Romania
C?ID=11248
Hi. I've done this retrofit and have issue with matrix basic setting. Anyone know how to make this basic settings with VCDS? I send car to dealer but they couldn't do it also. Also I have dtc about no comunication between gateway and adress 55. I connect module to can extended as in Elsa wiring. Any help is welcome. Thank you.
Tuesday,04,August,2015,16:31:57:42648
VCDS Version: 15.7.0.1
Data version: 20150729
VIN: WAUZZZ4H5DN027234   License Plate:
Mileage: 92339km-57376mi   Repair Order:
Chassis Type: 4H (4H0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 20 28 34 36 3B 42 46 47
          48 52 53 55 56 57 5B 5F 62 6C 6D 6F 72 81 85 88 89 8A 8D 8E
          8F 90
VIN: WAUZZZ4H5DN027234   Mileage: 92339km-57376miles
48-Seat, Rear, DS -- Status: OK 0000
55-Headlight Range -- Status: Cannot be reached 0100
5B-Seat,Rear,PS -- Status: OK 0000
6F-Centr. Conv. II -- Status: Malfunction 0010
85-On Board Cam. -- Status: Malfunction 0010
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
Address 01: Engine (J623-CDTA)       Labels: 059-907-401-V2.clb
   Part No SW: 4H0 907 401     HW: 4G0 907 401
   Component: 3.0TDI EDC17  H40 0006
   Revision: 53H40---
   Coding: 0A2A4012052601020000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TDI0114H0907401 001012
   ROD: EV_ECM30TDI0114H0907401.rod
   VCID: E1C3BA52F0EFB236B9-80B4
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 4H1 927 158 BG    HW: 0BK 927 156 AG
   Component: 0BK 30 TDIRdW H16 1005
   Revision: --H16---
   ASAM Dataset: EV_TCMALX51011 002018
   ROD: EV_TCMALX51011_AU64.rod
   VCID: F6E9F90E4961258EFC-80A2
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 D    HW: 4H0 907 379 D
   Component: ESP PREMIUM   H10 0352
   Coding: 60E5E30006A7C700E300
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremi 005013
   ROD: EV_ESPPremi_AU64.rod
   VCID: B36F001A1A9370A61B-80E6
   Part No SW: 4H0 907 064 CB    HW: 4H0 907 064 CB
   Component: BCM2 2.0      H33 0433
   Coding: 01A73046000000000000
   Shop #: WSC 02313 785 00200
   VCID: EBDFD87A0A23E86613-80BE
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-BFS       H08 0153
   Revision: AA000000    Serial number: 00000051862550
   Coding: 0018B60000047201000001010101112131313333283333
   VCID: B46D0306179D779E02-80E0
Address 08: Auto HVAC (J255)       Labels: 4H0-820-043.clb
   Part No SW: 4H0 820 043 K    HW: 4H0 820 043 K
   Component: Klima 4 Zonen H20 0130
   Coding: 360102BE3C
   ASAM Dataset: EV_AirCondiFront 001050
   ROD: EV_AirCondiFront_AU64.rod
   VCID: A855E776D355037EBE-80FC
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001521967
   Coding: 0105001440349FE18B810007A0001800009CC3080E000101800008546F01
   Shop #: WSC 17000 111 123456
   VCID: EFE7CC6A3E3B14463F-80BA
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 130120  H35 0080
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Coding: 025523
   Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
   Component: E1 - LDS  H07 0044
   Component: EVLS-SG  H08 0300
   Coding: 020300
                    Reset counter: 143
                    Mileage: 92339 km
                    Date: 2015.08.04
                    Time: 15:43:00
Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061306000814
   Coding: A8030E
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000.rod
   VCID: F1E3CA12200F02B629-80A4
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00C4N5$
   Coding: 30314246323430303032554A304C34483053
   ROD: EV_AirbaAU10BPAAU64X_AU64.rod
   VCID: B669390E09E1658E3C-80E2
   Serial number: 3575HRB400K50EV48A32
   Serial number: 3585HRB401650E6E7PVH
   Serial number: 3515JRB401050ET871IT
   Serial number: 3525JRB401050ET8PHQT
   Serial number: 3554VRB400C50DEOA9LQ
   Serial number: 3564VRB401A50DEOOPUM
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Revision: --------    Serial number: 90815MB10000P
   Coding: 0000B4
   VCID: B777340A06EB9C8627-80E2
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Component: E221 - MFL  H08 0009
02795 - Steering Wheel Vibration Motor (V331)
                    Fault Status: 01101100
                    Reset counter: 143
                    Mileage: 92339 km
                    Date: 2015.08.04
                    Time: 15:43:34
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4H0 920 900 M    HW: 4H0 920 900 M
   Component: TDieRDW------ H50 0515
   Revision: 34081076    Serial number: 658230213592002
   Coding: 13A60800534400080D0000
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K.rod
   VCID: AD5B1662FCB726564D-80F8
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
   Component: Analoguhr D4  H05 0225
   Serial number: 2130221005358
   Part No SW: 4H0 907 468 AC    HW: 4H0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000000839508
   Coding: 00CD077D00
   ASAM Dataset: EV_GatewPkoUDS 001018
   ROD: EV_GatewPkoUDS.rod
   VCID: F2E1C51E250939AED0-80A6
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 00000000004971005640
   Voltage stabilizer:
5013 - Headlight Range Control Module
          U101E 00 [009] - No Communication
                    Reset counter: 143
                    Mileage: 92339 km
                    Date: 2015.08.04
                    Time: 15:43:39
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 8K0 857 511 F    HW: 8K0 857 511 A
   Component: FLA           H04 0020
   Revision: AA001002
   Coding: 04018B6B74745D545420363E00
Address 28: HVAC, Rear (E265)       Labels: None
   Part No SW: 4H0 919 158 K    HW: 4H0 919 158 K
   Component: Klima Fond    H16 0121
   Coding: 2000000000
   ASAM Dataset: EV_AirCondiHeck 001039
   ROD: EV_AirCondiHeck_AU64.rod
   VCID: B875373603F593FE2E-80EC
Address 34: Level Control (J197)       Labels: 4G0-907-553.clb
   Part No SW: 4H0 907 553 E    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H17 0099
   Coding: 008000
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_AU64.rod
   VCID: AE59116EF1B15D4E74-80FA
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000051862551
   Coding: 0018B78000857201020001010101112131313333203333
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
   Component: SARA 6D       H02 0056
   Revision: --------    Serial number: EJ1BPA7700KWCT
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2_AU57.rod
   VCID: B777340A0EEB9C8627-80E2
   Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
   Component: TSG FA        H06 0273
   Revision: --------    Serial number: 0000053461567
   Coding: 011F12005E0062C202083006
   Shop #: WSC 02312 785 00200
   VCID: C89547F67B15E37E5E-809C
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0300722738
   Coding: 011A062000B93584B320C7C40A01010F0000000000000000000000000000
   Subsystem 1 - Part No: 4H0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
   Component: J245 PS50.030  H07 0006
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 947 135 G    HW: 4H0 947 135 G
   Component: Dachelektroni  H13 0080
   Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS010  H05 0005
   Revision: CJ007001    Serial number: 00000000036215
   Coding: 030000
   VCID: 9D3BC6A28417D6D6DD-80C8
Address 48: Seat, Rear, DS (J876)       Labels: None
   Part No SW: 4H0 959 860     HW: 4H0 959 860
   Component: MEM-FS-Fond   H06 0155
   Revision: AA000000    Serial number: 00000049984493
   Coding: 001892800000700D0A00392038193A2039203B3B202020
   VCID: F1E3CA12280F02B629-80A4
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H06 0273
   Revision: --------    Serial number: 0000051657748
   VCID: BC7D2B263FCDBFDECA-80E8
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000605748
   ROD: EV_ParkiBrake_AU48.rod
   VCID: AB5F187AC2A3286653-80FE
Address 55: Headlight Range (J745)       Labels: 4H4-907-357.clb
   Part No SW: 4H4 907 357 B    HW: 7P6 907 357 B
   Component: MxB-ECU       H01 0049
   Coding: 02F2022022130200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 004002
   ROD: EV_HeadlRegulAUDIMXBAU64X_AU57.rod
   VCID: B1630A12E08F42B669-80E4
   Subsystem 1 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7540
   Coding: E00300
   Subsystem 2 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7540
   Coding: E00300
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0021
   Coding: E00300
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0021
   Coding: E00300
13706045 - Databus
          U1121 00 [137] - Missing Message
                    Reset counter: 143
                    Mileage: 92339 km
                    Date: 2015.08.04
                    Time: 16:00:42
13705479 - Databus
                    Reset counter: 143
                    Mileage: 92339 km
                    Date: 2015.08.04
                    Time: 16:00:43
5350720 - Left Matrix High Beam
          C1175 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 143
                    Mileage: 92339 km
                    Date: 2015.08.04
                    Time: 16:00:44
5350976 - Right Matrix High Beam
          C1176 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 143
                    Mileage: 92339 km
                    Date: 2015.08.04
                    Time: 16:00:44
Address 56: Radio (R)       Labels: None
   Part No SW: 4H0 035 053 G    HW: 4H0 035 053
   Component: Radio U Basic H60 0121
   Revision: AB001007    Serial number: 228B%0D7517739
   Coding: 010003010000000001
   VCID: A34FF05AA273E026EB-80F6
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 4G0 919 129 C    HW: 4G0 919 129
   Component: NGTV-DVB      H04 0690
   Revision: R0043000    Serial number: 06801300290401
   Coding: 01000000
   VCID: AD5B1662F4B726564D-80F8
Address 5B: Seat,Rear,PS (J877)       Labels: None
   Component: MEM-BFS-Fond  H06 0155
   Revision: AA000000    Serial number: 00000049984635
   Coding: 001896800000700D0A00392038193A2039203B3B382020
   Part No SW: 4H0 035 666 L    HW: 4H0 035 666 N
   Component: H-BN-EU       H45 0637
   Revision: --------    Serial number: 178B.0D7503573
   Coding: 020100000001F1EF4DB08B1E00000003E80101020000000000
   VCID: B261051EED8979AE10-80E6
   Subsystem 1 - Part No: 8R0 060 884 AR
   Component: ECE 2013  1505
   Subsystem 2 - Part No SW: 4H0 919 604 G    HW: 4H0 919 604 G
   Component: DU8 D4 SV NB  H48 0021
   Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
   Component: E380 BDT D4  H09 0065
   Component: CD-Database  4949
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H06 0273
   Revision: --------    Serial number: 0000053533987
   Coding: 010F1200420062C202083006
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4H0 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H06---    Serial number: 525 PA8J31D0PO
   Coding: 1080003
   VCID: A649E94E1141150E8C-80F2
Address 6D: Trunk Elect. (----)       Labels: None
   Part No SW: 4H0 959 107 AB    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0043
   Revision: 10011001    Serial number: 047300072
   Coding: 0210044000
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: EED9D16E31311D4E34-80BA
Address 6F: Centr. Conv. II (J773)       Labels: None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000099047
   Coding: 200000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: E3CFB05AEAF3A026AB-80B6
0006 - Front Left Footwell Lighting  Color 2
          B111D 01 [009] - Electrical Failure
                    Reset counter: 143
                    Mileage: 92339 km
                    Date: 2015.08.04
                    Time: 15:43:39
   Component: TSG HR        H06 0273
   Revision: --------    Serial number: 0000053533835
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H08 0083
   Revision: 0L0D5015    Serial number: SN130131  1406
   ROD: EV_GSM2x3Mono.rod
Address 85: On Board Cam. (J852)       Labels: None
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H25 0038
   Coding: E1040000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: A649E94ED941150E8C-80F2
0721 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 143
                    Mileage: 92339 km
                    Date: 2015.08.04
                    Time: 15:43:33
Address 88: Multicont. Seat Driver (J873)       Labels: None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00010370250602
   Coding: 662FF2
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: AF670C6AF6BB54467F-80FA
Address 89: Multicont. Seat Pass. (J872)       Labels: None
   Serial number: 00010370185302
   Coding: 262FF2
Address 8A: Multicont. Seat Rear,DS (J875)       Labels: None
   Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
   Component: IVB           H08 0042
   Serial number: 00010050298201
   Coding: 202F00
   ASAM Dataset: EV_IVBDriveSideRear 001003
Address 8D: Multicont. Seat Rear,PS (J874)       Labels: None
   Serial number: 00010050299901
   Coding: 202F00
   ASAM Dataset: EV_IVBPasseSideRear 001003
Address 8E: Image Processing (J851)       Labels: 4G0-907-107.clb
   Part No SW: 4G0 907 107 E    HW: 4H0 907 107
   Component: BV-SG         H31 0041
   Serial number: 005000122802137
   Coding: 0220AB001111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 00060000031F030000030801424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: B261051EE58979AE10-80E6
End-------------------------(Elapsed Time: 07:39)--------------------------
maniken
Lithuania
C?ID=229989
hello.what kind of headlights you had before?
vioelectric
Romania
C?ID=11248
Full led headlights.
maniken
Lithuania
C?ID=229989
ok so:full led headlight are without can,you have conected pin 1 and 2(can low,can high)from headlights to j745 range control unit to pin t26a/4 and t26a/5,when you must connect external can, from range control unit j745 t26a/2 ant t26a/3 to connection 3 in main wiring harness or to TV1/TV2(wiring junciotn for can).i think you have done this already yes?:) know problems can be in gateway wiring,have you check it?gateway j533 must be conected to tv1/tv2.so from j533(gateway) t32f/2 and t32f/18 must be conected to tv1/tv2 t46/19L and t46/19h,have you check it?
maniken
Lithuania
C?ID=229989
olso check convience can from 09 bcm (j519) to Wiring junction for convenience CAN and from Wiring junction for convenience CAN to gateway
vioelectric
Romania
C?ID=11248
Hi. Wiring is ok, I dont know why gateway and 09 bcm say that can't comunicate with adress 55, even if I can make diag on adress 55.
Do you know procedure for making basic setting for matrix module? VCDS ask for 1 to 3 digit number in matrix basic setting menu.
Thank you.
Mrclopec
Nipomo, CA
C?ID=149231
There was a changeover in 2013 on how the A8 headlights were wired. The changeover was between August and September of 2013. I have a question about the range control module (J745) you have in your vehicle. The module for the LED matrix is different than the one for standard LED headlights, however LED headlights on an A8 manufactured up to August 2013 did not use one. Did you have a range and cornering control module in your car before your retrofit?
You need to clear up the communication issue with 55 before you can do the basic settings. Work on fixing the communication error first.
maniken
Lithuania
C?ID=229989
check pins 32f2 and 32f18 in gateway,maybe yours gateway not suporting external can and and this pins is not existing.
vioelectric
Romania
C?ID=11248
Mrclopec you are right, original headlight were drivin by BCM on LIN-bus. Control unit 55 I installed is from a working car, do you know other way to register in gateway except in instalation list? Maybe I need to change gateway?
maniken Wiring is ok, can extended exist on car because other control unit are connected to that bus and they comunicate with gteway, only my control unit on adress 55 is not able to comunicate with gateway.But as before, I can make diag on adress 55 with no problem, so wiring and gateway should be ok.
Thank you.
Mrclopec
Nipomo, CA
C?ID=149231
Look in your 09-Central Elec...The error code there is it cant communicate with 55-Headlight Range (J431). You have a J745 now. I suspect your 09-Central Elec. Needs to be coded differently as it is looking for a headlight range module for Non-Matrix headlights.
maniken
Lithuania
C?ID=229989
problem with coding 09 bcm is posibble,but why cangateway have same error?if yours wiring is 100% correctly cangateway must see range control unit.second question:we have 2 kinds of "matrix" headlights.1st type is just facelift full lead headlights.2cond type real matrix full led headlights wich have 3controll units,wich kind you have?
Mrclopec
Nipomo, CA
C?ID=149231
Many of the modules in the vehicle talk to each other. If you have a communication error in one, it may show up in others as well. I suspect your communication error is with the system looking for a J431 when you have a J745. This is supported by the fact that you can communicate and read the 55 with you cable, but the rest of the system is having a hard time talking to it. This is just a theory...but its where I would start first.
vioelectric
Romania
C?ID=11248
Mrclopec error on BCM appear after I code BCM similar to a car that had matrix led from factory. With original codding , BCM search for LIN slave's. In cangateway didn't find way to distinquish between j431 and j745, only checkbox for adress 55 in instalation list.
maniken I think it's a real matrix, if you see in scan I've posted there are 2 subsystem for each side. 7PP 941 472 G and 4H0 941 329 A.
I found in adaptation option to enable matrix led for showroom purpose. When I set to active, led's for high beam are working.
vioelectric
Romania
C?ID=11248
BCM, gateway and j745 from a car that has matrix system from factory
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.clb
Part No SW: 4H0 907 063 AG HW: 4H0 907 063 AG
Component: BCM1 2.0 H20 0242
Revision: 14020001 Serial number: 00000058734001
Coding: 0105001440349FE2C9014084A0001800009CC3082E080201800008946101170000400019010000
VCID: 6DDA0D6CB44C4549B59-8038
Component: WWS641 140122 H36 0090
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
Component: G397_RLFS H06 0002
Coding: 02004E
Subsystem 3 - Part No SW: 4H0 941 531 G HW: 4H0 941 531 G
Component: E1 - LDS H01 0044
Coding: 020300
Part No SW: 4H0 907 468 AE HW: 4H0 907 468 AC
Component: J533--Gateway H13 0050
Revision: -------- Serial number: 00000001276158
Coding: 80CD077D00
ASAM Dataset: EV_GatewPkoUDS 001019
ROD: EV_GatewPKOUDS_AU57.rod
VCID: 74EC1808DF6694817A7-8021
Serial number: 51042739101911783069
Voltage stabilizer:
Component: MxB-ECU 001 0049
Coding: 02F20220221B0200
ROD: EV_HeadlRegulAUDIMXBAU64X_AU64.rod
VCID: 3162D11C60F4E1A9D11-8064
Subsystem 1 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F
Component: LED LeiMo li. H07 7530
Coding: E00300
Subsystem 2 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F
Component: LED LeiMo re. H07 7530
Coding: E00300
Coding: E00300
Coding: E00300
Mrclopec
Nipomo, CA
C?ID=149231
The 09-Central Elec. Control module in that scan is for a MY15 forward. I noticed your car is a 2013. May be a software situation or your BCM doesn't support Matrix.
maniken
Lithuania
C?ID=229989
different codings yours Coding: 02F2022022130200 from another car Coding: 02F20220221B0200
maniken
Lithuania
C?ID=229989
also different units Subsystem 1 - Part No SW: 7PP 941 472 F yours with G.Etka shows me only with J
vioelectric
Romania
C?ID=11248
I tried bouth codding on 55, but gateway still gives dtc about no com with mxb unit. From a friend from dealer I understend that you need to confirm the instalation list, somekind of activation. Do you know something about this? Tried all menu in vcds but can't find anything. Maybe cangateway with index AC doesn't have support for j745?
About subsystem i think they should work. If i set to active showroom mode, led from main beam are working.
maniken
Lithuania
C?ID=229989
i have done few bmw f01 full led retrofit,there 100% gateway must be changed.in vag group i have change gateways only then was no extrended can outputs.
maniken
Lithuania
C?ID=229989
hi man,have you done it?
