Lamborghini URUS Chassis control SA code/login?
Ziddywerks
Northern NJ USA
C?ID=208579
Hey guys Curious if anyone here has SA code for chassis control module 74. I need to perform adaption and SA is required. I have tried 31564 and get error 37, I have also tried 20103 and get error 35. See attached log this vehicle was in accident and I need to adapt suspension.
Saturday,15,July,2023,10:33:30:47988
VCDS Version: 23.3.1.0 (x64)  HEX-NET CB: 0.4631.4
VIN:                       License Plate: URUS
Mileage: 19426km-12070mi   Repair Order:
Chassis Type: ZL-LB63 (4K0)
Scan: 01 02 03 06 09 13 15 16 17 19 2B 32 36 3C 42 44 46 47 52 5F
          61 65 6D 74 75 81 82 A5 A9 BB BC C4 CA CB CF D4 D5 D6 D7 DB
          DC DE
VIN:                  Mileage: 19426km-12070miles
74-Chassis Control -- Status: Malfunction 0010
81-Gear Shift -- Status: Malfunction 0010
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: Malfunction 0010
D4-Roll Control 1 -- Status: OK 0000
D5-Roll Control 2 -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: Malfunction 0010
DC-Frt Corner Rdar 2 -- Status: Malfunction 0010
Address 01: Engine (------DHUA)       Labels: None
   Part No SW: 4ML 907 589 G    HW: 0P2 907 309 A
   Component: V8 4.0l TFS   H31 0001
   Revision: 72H31000    CVN: 89758A34
   Coding: 2E2A001225E6050D74040000000000000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM40TFS0114ML907589G 002001
   ROD: EV_ECM40TFS0114ML907589G.rod
   VCID: 5AF853135DA40D43E5-800E
   VINID: AA04A5441A9C11C711009044246A5FDB19
34393 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [175] - -
          [Checking coding/versions ofcontrol modules in drivetrain]
                    Fault Frequency: 11
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:50
                    Engine RPM: 0.00 /min
                    Coolant temperature: 27 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 12.780 V
                    Engine status: COENG_READY
Readiness: 0010 0101
   Part No SW: 4ML 927 158 A    HW: 0D6 927 156 J
   Component: 0D6  40TSIUSA H05 1002
   Revision: --H05---    CVN: A2ABC1D3
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002015
   ROD: EV_TCMALX52011_VW53.rod
   VCID: 4ED0AF43116C51E309-801A
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
   Part No SW: 4M6 907 379 AC    HW: 4M6 907 379
   Component: ESP9 Premium  H06 0856
   Dataset Number: 4ML909504F  0003 CVN: A93D387C
   Coding: 52BE6AB130A20B9F939F4C955C8616E2E53AC94A560CD0C9323A6847A75C93
   ROD: EV_ESP9BOSCHCMP_004_VW53.rod
   VCID: 7EB03F83E14C0163B9-802A
15383808 - Databus
          U1123 00 [040] - Received Error Message
          [HAL_Status_is_"Lenkungsausfall"_and_rear_wheel_steering_angle_is_correct]
                    Fault Frequency: 26
                    Mileage: 19411 km
                    Date: 2023.06.13
                    Time: 16:34:01
                    88 40 00 04 89 24 00 00 00 00
                    Unlearning counter according OBD-OBD unlearning counter: 28
0298 - Control Module for Suspension
          U122B 00 [040] - Implausible Message
          [Signal_FDR_Sollgiermom_Vorsteuerung_TV_Error(1023)_or_Invalid(1021.1022)_or_PDU_FDR_05_not_received_correctly(combination_of_Timeout:_CS:_AC]
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:19:23
                    81 00 00 00 42 24 00 00 00 00
                    Unlearning counter according OBD-OBD unlearning counter: 27
0297 - Databus
          [Signal_FDR_Sollgiermom_Vorsteuerung_TV_-Error(1023)]
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:50
                    80 00 00 00 C2 24 00 00 00 00
13773569 - Control Module for Suspension
          [Signal_FDR_TV_SollRadDiff_Moment_error_(4095)_or_PDU_FDR_02_not_received_correctly_(combination_of_Timeout:_CS:_AC)]
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:19:23
12853509 - Databus
          [Signal_FDR_TV_SollRadDiff_Moment_error_(4095)]
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:50
0327 - Implausible Data Received from Suspension Control Module
          U042B 00 [040] - -
          [Signal_AFR_Fehlers_faulty(1.2:3]
                    Mileage: 19414 km
                    Date: 2023.06.14
                    Time: 12:31:06
                    83 00 00 31 89 24 00 00 00 00
   Part No SW: 4M6 959 760 B    HW: 4M6 959 760 B
   Component: MEM-BFS       009 0044
   Serial number: 00000404069471 Dataset Number: V03935298MN 0151
   Coding: 001C12400001BCA14863010101010000810000070700878700000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_LB63.rod
   VCID: 3D32F88FACCADA7BE0-8068
   Valve block 1 in front seat passenger side:
   Subsystem 1 - Part No SW: 4M0 907 182     HW: 4M0 907 182
   Component: N477 VB1 BFSv  H06 0030
   Serial number: SJ80012701204025802B
   Coding: BF2F00
   Valve block 2 in front seat passenger side:
   Subsystem 2 - Part No SW: 4M0 907 182 A    HW: 4M0 907 182 A
   Component: N478 VB2 BFSv  H06 0030
   Serial number: SJ80010202201147002C
9655636 - Motor for Seat Fore/Aft Adjustment
          B1355 54 [041] - Missing Calibration / Basic Setting
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:37
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 KE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0691
   Dataset Number: V03935302CL 0353
   Coding: 07500363E06910CD070E57191CEE9C70030B37110406009701000600020016010863000A0012080000000303004100180802000044010104000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016.rod
   VCID: 7BB63697F25E144B9E-802E
   Subsystem 1 - Part No SW: 4M8 955 119     HW: 4N1 955 119
   Component: J400FRWISCH  052 0997
   Serial number: 904753F0301916101952
   Coding: 7DC727
   Serial number: 24308086X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4N1 941 501 C    HW: 4N1 941 501 C
   Component: E1 - LTM  H09 0086
   Serial number: 21S18.02.2000692355
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600373Z00Z302
   Coding: 250000
   Subsystem 5 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE120121923610058
   Coding: 030000
   Interior Light Module:
   Subsystem 6 - Part No SW: 4ML 947 135 B    HW: 4ML 947 135
   Component: J528-Dachele  H14 0150
   Serial number: Q00853116
   Subsystem 7 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA141354000081756600
   Coding: 020100
   Subsystem 8 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V512 LLR1SLvL  H01 0012
   Serial number: Q98BK008A9170
   Subsystem 9 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V514 LLR1SKvL  H01 0012
   Serial number: Q98BK008A9184
   Subsystem 10 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V516 LLR1SLvR  H01 0012
   Serial number: Q98BK008A9204
   Subsystem 11 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V518 LLR1SKvR  H01 0012
   Serial number: Q98BK008A9153
65896 - Databus
          [Automatic high beam assist control module: high beam assist error value]
                    Fault Frequency: 17
                    Reset counter: 42
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 16:09:03
                    average_Voltage_terminals: 13.50 V
                    Outside air temperature sensor-Outside air temperature on CAN: 25.00 °C
                    interior_temperature: 27.50 °C
                    Vehicle speed: 3.67 km/h
67155 - Position Sensor in Left Center Vent
          B10E1 01 [008] - Electrical Failure
                    Reset counter: 42
                    Mileage: 19421 km
                    Date: 2023.06.16
                    Time: 07:46:57
                    average_Voltage_terminals: 12.90 V
                    Outside air temperature sensor-Outside air temperature on CAN: 22.50 °C
                    interior_temperature: 25.50 °C
                    Vehicle speed: 0.00 km/h
                    Terminal activation-Terminal 75 status: OFF
                    Terminal activation-Terminal 15 status signal: OFF
                    Terminal activation-Terminal 15 via CAN: OFF
                    System run time-Engine running time: 65535 s
                    System run time-Terminal 15 on: 0 s
67156 - Position Sensor in Right Center Vent
          B10E2 01 [008] - Electrical Failure
                    Reset counter: 42
                    Mileage: 19421 km
                    Date: 2023.06.16
                    Time: 07:46:57
262473 - Bulb 1 for Ambient Lighting of Dashboard
          U1358 00 [009] - No Communication
          [Ambient lighting I-panel: RGB slave 1: no signal/communication]
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:48
                    average_Voltage_terminals: 12.70 V
                    Outside air temperature sensor-Outside air temperature on CAN: 25.50 °C
                    interior_temperature: 27.00 °C
   Part No SW: 4ML 907 561 B    HW: 4ML 907 561
   Component: LRR4R         H04 0332
   Coding: 00000000000000000000000000000018000000000000003000
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_VW53.rod
   VCID: 4BD6A657E27E64CB6E-801E
13 Faults Found:
0258 - Sensor for Automatic Distance Regulation
          C110B 54 [009] - Missing Calibration / Basic Setting
          [FAULT_ALIGNMENT_NEVER_DONE]
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:38
                    Control Module temperature: 51 °C
                    Voltage terminal 15: 12.6 V
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s²
                    Adaptive distance regulation: status: ACC_reversible_error
                    Steering_angle-Data: 5.700 °
                    Yaw_rate-Data: 0.000 rad/s
                    adjustment_calculation: OFF
                    Misalignment angle: horiz: 0.000 °
                    Misalignment angle: horiz: fast algorithm: 0.000 °
                    Congestion pilot: status: OFF
                    Outside temperature: 25.50 °C
                    Sensor blindness: radar: no blindness detected
2333 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING_FER]
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:38
1121 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING_FRONTCAMERA]
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:38
1119 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING_HAL]
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:38
2361 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING_IPA_APS]
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:38
1228 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING_REARRADAR]
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:38
0256 - Data Set Implausible
          B2012 00 [009] - -
          [FAULT_DIA_DATASET_IMPLAUSIBLE]
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:38
0257 - invalid data record
          B2005 00 [009] - -
          [FAULT_DIA_DATASET_INVALID]
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:38
1811 - Control module not coded
          U1013 00 [009] - -
          [FAULT_ECU_NO_CODING]
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:38
2143 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_ENGINE_PLAUS_FAIL]
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:38
15361024 - Component Protection
          U1101 00 [009] - Active
          [FAULT_THP_EC_OTHER_ERROR]
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:38
13697024 - Component Protection
          U1100 00 [009] - No Basic Setting
          [FAULT_THP_START_KEY]
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:38
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:38
   Part No SW: 4N0 959 655 N    HW: 4N0 959 655 N
   Component: AirbagVW31    H15 2720
   Serial number: 003YXM00BXBI Dataset Number: 4ML909602R  0001
   Coding: AEFCFCC000C00000A054003FF20D410000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   VCID: 47DE9A67FE1680AB4A-8012
   Left seat belt tensioner:
   Serial number: 00AI2020042631000000
   Coding: 02F001
   Right seat belt tensioner:
   Serial number: 00AI2020034465700000
   Coding: 02F001
   Component: BF-Gewichtss.  H12 0022
   Serial number: IBH0000D19000CDGC10.
   Coding: 303132
   Subsystem 4 - Part No SW: -----------    HW: 480 000 502 20
   Serial number: 35700000000E7BF8254
   Subsystem 5 - Part No SW: -----------    HW: 480 000 502 20
   Serial number: 3580000000039180844A
   Subsystem 6 - Part No SW: -----------    HW: 480 030 602 20
   Serial number: 351002C04CA112905AB2
   Subsystem 7 - Part No SW: -----------    HW: 480 030 602 20
   Serial number: 352002C048649E00FB8H
   Subsystem 8 - Part No SW: -----------    HW: 480 032 201 20
   Serial number: 355002C0471342508A4W
   Subsystem 9 - Part No SW: -----------    HW: 480 032 201 20
   Serial number: 356002C004C3BDB00E5F
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 10 - Part No SW: -----------    HW: 480 030 602 20
   Component: SideSens_B_Df  002 0149
   Serial number: I0P002C04CA8DA60DE0I
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 11 - Part No SW: -----------    HW: 480 030 602 20
   Component: SideSens_B_Pf  002 0149
   Serial number: I0Q002C048655180CBE3
8 Faults Found:
1073925 - Databus
          [NWD: 0xTBD MRR_VL_SensorHeader error value MRR_VL_Fehler]
                    Reset counter: 2
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:37
1074181 - Databus
          [NWD: 0xTBD MRR_VR_SensorHeader error value MRR_VR_Fehler]
                    Reset counter: 2
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:37
9437723 - Igniter for Passenger's Airbag
          B1002 1B [137] - Resistance Too High
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:38
9437979 - Igniter 2  for Passenger's Airbag
          B1003 1B [137] - Resistance Too High
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:38
9572123 - Ignitor for Passenger Airbag Release Valve
          B120F 1B [137] - Resistance Too High
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:38
9440539 - Driver's Safety Belt Tensioner Igniter 2
          B100D 1B [137] - Resistance Too High
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:38
9441306 - Rear; passenger's side; side-airbag igniter
          B1010 1A [137] - Resistance Too Low
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:38
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [137] - Resistance Too High
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:38
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 4ML 907 129 C    HW: 4ML 907 129 C
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 4CD4A54BE77063F367-8018
   Part No SW: 4ML 920 890 A    HW: 4ML 920 890 A
   Component: FBenUSAACC--- H12 0209
   Dataset Number: V03935293KH 0010
   Coding: 8B4F06E17FB8D7050285FF64B8C0481008003000
   ROD: EV_DashBoardAU65X_001_LB63.rod
   VCID: 4AD8A353ED047DC355-801E
16776985 - Databus
          [QSP_03 communication error can_error_timeout]
                    Fault Frequency: 8
                    Reset counter: 42
                    Mileage: 19411 km
                    Date: 2023.06.13
                    Time: 16:32:23
16777089 - Databus
          [ACC_12 communication error can_error_timeout]
                    Fault Frequency: 14
                    Reset counter: 42
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 16:08:42
   Part No SW: 4K0 907 468 Q    HW: 4K0 907 468 C
   Component: Gateway       H06 0272
   Serial number: 1AF02121294001 Dataset Number: 4ML909515G  0005
   Coding: 0301000500080F4054370000005901B0FC9A000FAC000000097F078E10000000
   GVL: F1593C580800020002FC88008100C800110C0070000000000000000000000100
   ASAM Dataset: EV_Gatew31xAU65x 003190
   ROD: EV_Gatew31xAU65x_AU58.rod
   VCID: 42C88B73D534A5839D-8016
   Subsystem 1 - Part No SW: 4ML 951 523 A    HW: 4ML 951 523 A
   Component: J453 MFL  H07 0004
   Serial number: 20190618113519 31214
   Subsystem 2 - Part No SW: 9Y0 915 105 R    HW: 9Y0 915 105 R
   Component: 12V_LiIon_BMS  H10 1010
   Serial number: LGCKOR190422C1LF0155
8519692 - Unknown Error Code
          P1D6C 00 [008] - -
          [12V_LiIon_Battery_Diagnostic_System_Monitoring_Defect]
                    Fault Frequency: 92
                    Reset counter: 42
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:36:42
                    Lithium ions starter battery-Battery: fault status: No malfunction
                    Lithium ions starter battery-Battery cut-out element: fault status: No malfunction
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Electric_current_Upper_Limit_Value_Exceeded]
                    Reset counter: 42
                    Mileage: 19422 km
                    Date: 2023.06.27
                    Time: 09:31:00
                    EM_vehicle_state: 00 00
                    Total static current-current total quiescent current: 95 mA
                    Total static current-Total time quiescent current exceeded: 1.0 H
          [KS_Active_1]
                    Fault Frequency: 55
                    Reset counter: 2
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:37
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 19000354231010
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 3424DDAB9F801B331F-8060
Address 32: Differential Locks (J187)       Labels: None
   Part No SW: 8W0 907 163     HW: 8W0 907 163
   Component: QSP QCU Gen2  H08 0060
   Revision: 5WK12700    Serial number: 605007311201707
   Coding: 0500
   ASAM Dataset: EV_TVDCQSP22 001008
   ROD: EV_TVDCQSP22.rod
   VCID: 79BA2C9FF862265B8C-802C
   Serial number: 00000404074612 Dataset Number: V03935298MP 0151
   Coding: 001C12400001BCA14863010101010000810000070700878700000000004000
   ROD: EV_SCMDriveSideCONTIAU736_LB63.rod
   Valve block 1 in front seat driver side:
   Component: N475 VB1 FSv  H06 0030
   Serial number: SJ80011801204025860D
   Coding: BF2F00
   Valve block 2 in front seat driver side:
   Component: N476 VB2 FSv  H06 0030
   Serial number: SJ800120012011470027
   Part No SW: 4N0 907 566 F    HW: 4N0 907 566 A
   Component: MRR_HR H12 0266
   Dataset Number: V03935278EY 0001
   Coding: 0FFC00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651.rod
   VCID: 393AEC9FB8E2E65BCC-806C
   Part No SW: 4M1 959 793 J    HW: 4M1 959 793 D
   Component: TSG FS002 0425
   Serial number: YE007SL519358 Dataset Number: V03935301LK 0102
   Coding: 001DDB435E001482A009A430
   ROD: EV_DCU2DriveSideMAXHKLO_AU58.rod
   VCID: 46C09763F91C99A3B1-8012
196661 - Motor for Window Regulator
          B1487 13 [008] - Open Circuit
                    Reset counter: 42
                    Mileage: 19425 km
                    Date: 2023.07.07
                    Time: 20:10:18
          B1487 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 42
                    Mileage: 19425 km
                    Date: 2023.07.07
                    Time: 20:10:18
196883 - Function Lighting for Central Locking
          B1783 01 [009] - Electrical Failure
                    Reset counter: 2
                    Mileage: 19421 km
                    Date: 2023.06.16
                    Time: 09:58:25
   Dataset Number: 4ML909852B  0001
   Coding: B2000101000100
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 3228DBB3659415030D-8066
   Part No SW: 8W1 907 064 AH    HW: 8W1 907 064 H
   Component: BCM2 MLBevo   044 0542
   Dataset Number: V03935285NF 0105
   Coding: 0134000049A302C0650BA0046E01080203000000810405502F0400200F04823F001E0101010001
   ASAM Dataset: EV_BCM2HellaAU736 017017
   ROD: EV_BCM2HellaAU736_017_AU49.rod
   VCID: 03464E778AAE6C8BD6-8056
   ID - sensor:
   Subsystem 1 - Part No SW: 4ML 959 754 L    HW: 4ML 959 754 L
   Component: ID-Geber  H11 0233
   Serial number: 3620000049406016
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000048085632
131120 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 2
                    Mileage: 19422 km
                    Date: 2023.06.18
                    Time: 17:45:38
                    Supply voltages-Terminal 30 power supply: 13.302 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 13.288 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 13.288 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 12 04 98
                    key_error_freeze_frame: 01001111 11111111 11111111 11111111
   Part No SW: 4N0 035 466 C    HW: 4N0 035 466
   Component: A2PA-3-AU     H01 0033
   Revision: --02S---    Serial number: 2880045656 Dataset Number: V03935245CC 0009
   Coding: 0836060000A2AAAAAAAAA0010000
   ASAM Dataset: EV_AMPMst24C1Gen2pBAO 001002
   ROD: EV_AMPMst24C1Gen2pBAO.rod
   VCID: 2D12C8CF7CAA4AFB50-8078
0512 - Front Left Bass Speaker
          B105F 13 [008] - Open Circuit
                    Reset counter: 41
                    Mileage: 19411 km
                    Date: 2023.06.13
                    Time: 17:19:28
                    Voltage terminal 30: 13.7 V
0527 - Subwoofer
          B106C 13 [009] - Open Circuit
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:41
                    Voltage terminal 30: 13.0 V
1611 - Positioning Motor for Tweeter; Front Left
          B1692 07 [008] - Mechanical Failure
                    Reset counter: 42
                    Mileage: 19421 km
                    Date: 2023.06.16
                    Time: 09:48:32
1612 - Positioning Motor for Tweeter; Front Left
          B1692 29 [008] - Signal Implausible
                    Reset counter: 42
                    Mileage: 19421 km
                    Date: 2023.06.16
                    Time: 09:48:32
   Part No SW: 4M1 959 792 J    HW: 4M1 959 792 D
   Component: TSG BFS002 0425
   Serial number: YE007SLD10525 Dataset Number: V03935301LL 0003
   ROD: EV_DCU2PasseSideMAXHKLO_AU58.rod
   VCID: 45C2906FC41A92BBB8-8010
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4ML 035 084 D    HW: 4ML 035 084 D
   Component: MU-H-LNS-US   055 2712
   Dataset Number: V03935316LX 0001
   Coding: 0935060200000000C1220002061C00302F0000E4017009048E
   ROD: EV_MUHigGen2pALPI_VW53.rod
   Subsystem 1 - Part No: V03 959 805 EA
   Component: MIB2P_NA_Q120  0446
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4ML 919 605 L    HW: 4ML 919 605 F
   Component: DU LB536 Top  H31 0053
   Serial number: INX00105121900200008
   Compact disc data bank:
   Component: Gracenote2  3008
   Volume Control 1:
   Subsystem 4 - Part No SW: 4ML 919 616 A    HW: 4ML 919 616
   Serial number: 00004420000000775004
   Multimedia System 5:
   Subsystem 5 - Part No SW: 4N0 919 603 L    HW: 4N0 919 603 F
   Component: DU AU651 Bot  H32 0053
   Serial number: INX00104111900170337
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 052000072819013
          B11CF 53 [009] - Deactivated
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:46
                    Voltage terminal 30: 12.8 V
                    Satellite radio tuner status-Antenna current: 107 mA
                    Satellite radio tuner status-Reception quality: weak_signal
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 0C
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 0C
1654 - External Optical Drive  (USB)
          U1303 00 [009] - No Communication
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:52
Address 61: Battery Regul. (J1120)       Labels: None
   Part No SW: 4M0 915 169 F    HW: 4M0 915 169 E
   Component: BMS_48V_SCAP  H07 0114
   Serial number: 200340017780111
   ASAM Dataset: EV_SCAP0213061 001004
   ROD: EV_SCAP0213061.rod
   VCID: 3620E7A389FC092321-8062
Address 65: Tire Pressure (J502)       Labels: 4M0-907-273.clb
   Part No SW: 4M0 907 273 B    HW: 4M0 907 273 B
   Component: RDKHUFAU736   H05 0010
   Serial number: 40000000055258 Dataset Number: V03935260SQ 0003
   ROD: EV_RDKHUFAU736.rod
   VCID: 2F2ED2C776A638EB62-807A
8398082 - Tire Pressure Sensor(s)
          C111A 31 [009] - No Signal
                    Reset counter: 2
                    Mileage: 19419 km
                    Date: 2023.06.14
                    Time: 12:39:53
                    Expanded ambient data 6-Vehicle speed: 25.93 km/h
                    Expanded ambient data 6-Outside temperature: 20.00 °C
                    Tire pressure sensor 01-Manufacturer code: 0
                    Tire pressure sensor 01-Sensor identification number (sensor ID): Not available
                    Tire pressure sensor 01-Wheel position: Unknown
                    Tire pressure sensor 01-CURRENT pressure: 0.00 bar
                    Tire pressure sensor 01-CURRENT temperature: -40 °C
                    Tire pressure sensor 01-SPECIFIED pressure: 0.00 bar
                    Tire pressure sensor 01-Warning pressure: 0.00 bar
   Part No SW: 4M0 959 107 D    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C737-6252-4 Dataset Number: V03935292TT 0050
   Coding: 2530
   ROD: EV_DeckLidCONTIAU736_VW38.rod
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4M8 907 777 CA    HW: 4M8 907 777 C
   Component: Fahrwerk-SG   H52 2135
   Serial number: 1602201208  Dataset Number: V03935294VM 0007
   Coding: 36606848FA40
   ASAM Dataset: EV_ChassContrContiAU651 002016
   ROD: EV_ChassContrContiAU651_002.rod
   VCID: 02484B7395B46583DD-8056
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130877702
   Coding: 303030
32776 - Sensor for Ride-Height
          C1048 07 [008] - Mechanical Failure
                    Reset counter: 42
                    Mileage: 19414 km
                    Date: 2023.06.14
                    Time: 12:31:06
                    Internal DTC: 262
196609 - Basic Setting of Deflected Position not Performed
          C10C5 00 [137] - -
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:36
                    Internal DTC: 837
   Part No SW: 9Y0 035 283 F    HW: 9Y0 035 283 C
   Component: ConBox        H10 0314
   Serial number: 005CCA1BF121191 Dataset Number: 4ML909612C  0013
   Coding: 09C0E0FFC040800000
   ROD: EV_ConBoxAU651_002.rod
458759 - Control Module Incorrectly Coded
          U1014 00 [008] - -
          [ECU_coded_wrong]
                    Mileage: 19421 km
                    Date: 2023.06.14
                    Time: 16:28:15
   Part No SW: 4ML 713 120 F    HW: 4ML 713 120 F
   Component: GSM-LL        H11 0090
   Revision: 0L005012    Serial number: 19120957299323
   ASAM Dataset: EV_GSMChariLB636 001009
   ROD: EV_GSMChariLB636.rod
   VCID: 41CA847FD032BE9B84-8014
67097 - Control module
          B2001 00 [008] - Incorrect software version
          [Control moduleIncorrect software version]
                    Reset counter: 42
                    Mileage: 19412 km
                    Date: 2023.06.14
                    Time: 12:26:22
                    Voltage terminal 30: 0.0 V
                    Selec. range display: spec. val.: Init
                    Selector lever position: Initialization
                    Standard_FreezeFrame_Extended_Temperature_CAN: 00
                    Standard_FreezeFrame_Extended_Temperature_Celsius: -50.0 °C
                    System run time: 0 s
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 4ML 919 617     HW: 4ML 919 617
   Component: HeadupDisplay H04 1818
   Coding: 470040
   ASAM Dataset: EV_HeadUpDisplAU65X 001009
   ROD: EV_HeadUpDisplAU65X.rod
   VCID: 0E506F43D1EC11E349-805A
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* 4N0-907-107-V2.clb
   Part No SW: 4KE 907 107 AR    HW: 4N0 907 107 H
   Component: zFAS Var C    H09 0295
   Dataset Number: V03935295UN 0009
   Coding: 020888000000000000FBD60000B0C50C1B1F520000000000000000000094D401011BA0000000000000000080000000000000000000000000F980400000000000000072040000009000800080000000000080400000E0
   ASAM Dataset: EV_ZFASAU516 001007
   ROD: EV_ZFASAU516_001.rod
   VCID: 0F6E7247D6E618EB42-805A
17 Faults Found:
2117665 - Internal Fault
          B200F F9 [008] - Unknown Error Elaboration
          [Internal PCB Temperature Sensor not readable]
                    Reset counter: 42
                    Mileage: 19423 km
                    Date: 2023.06.29
                    Time: 07:43:35
                    Platform_zFAS_Error_Handler_Master-ErrorHandlerMaster: 00 00 DA 10 00 00 00 00 00 00 00 00 00 00 00 00
                    Platform_zFAS_Error_Handler_SSH-ErrorHandlerSSH: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                    Platform_zFAS_Internal_Power_Supplies-Aurix 1V3: 1345 mV
                    Platform_zFAS_Internal_Power_Supplies-Aurix 3V3: 3293 mV
                    Platform_zFAS_Internal_Power_Supplies-AVDD HDMI PLL: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-AVDD PLL: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-KL30_LOCAL_VM: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-KL30_MAIN_VM: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-MIB_ADC_IN: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-MIB_SW_LOGO_FRONT: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-MIB_SW_LOGO_REAR: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-PEX VDD: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-Power Good MAX20024: not OK
                    Platform_zFAS_Internal_Power_Supplies-Power Good SYS_1V1: not OK
                    Platform_zFAS_Internal_Power_Supplies-Power Good SYS_1V2: not OK
                    Platform_zFAS_Internal_Power_Supplies-Power Good VDD_CAM_PG: not OK
                    Platform_zFAS_Internal_Power_Supplies-Power Good VDD_CORE: not OK
                    Platform_zFAS_Internal_Power_Supplies-Power Good VDD_CPU: not OK
                    Platform_zFAS_Internal_Power_Supplies-Power Good VDD_DDR_FPGA: not OK
                    Platform_zFAS_Internal_Power_Supplies-Power Good VDD_GPU: not OK
                    Platform_zFAS_Internal_Power_Supplies-Power Good VTT_DDR3_PG: not OK
                    Platform_zFAS_Internal_Power_Supplies-Qualifier AURIX_1V3: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier AURIX_3V3: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier AVDD_HDMI_PLL: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier AVDD_PLL: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier KL30_LOCAL_VM: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier KL30_MAIN_VM: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier MIB_ADC_IN: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier MIB_SW_LOGO_FRONT: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier MIB_SW_LOGO_REAR: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier PEX_VDD: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier SPKR_DIAG: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier SUP_LIN_FRNT: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier SUP_LIN_REAR: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier SUPPLY_LIN_FRNT_P: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier SUPPLY_LIN_REAR_P: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier SYS_1V1: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier SYS_1V2: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier SYS_2V5: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier SYS_5V: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier SYS_9V: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier TV1: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier TV1_VCC: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier TV2: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier TV2_VCC: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier TV3: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier TV3_VCC: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier TV4: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier TV4_VCC: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier US_SPEAKER_FRONT: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier US_SPEAKER_REAR: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VBAT_MAIN: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VCC_CAM: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_1V1: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_1V2: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_1V8: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_3V3: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_CORE: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_CPU: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_DDR: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_DDR_FPGA: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_DDR_HS: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_GPU: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_RTC: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDDIO_SYS: not_available
                    Platform_zFAS_Internal_Power_Supplies-SPKR_DIAG: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-SUP_LIN_FRNT: 13037 mV
                    Platform_zFAS_Internal_Power_Supplies-SUP_LIN_REAR: 13066 mV
                    Platform_zFAS_Internal_Power_Supplies-SUPPLY_LIN_FRNT_P: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-SUPPLY_LIN_REAR_P: 75 mV
                    Platform_zFAS_Internal_Power_Supplies-Sys 1V2: 1201 mV
                    Platform_zFAS_Internal_Power_Supplies-Sys 2V5: 2502 mV
                    Platform_zFAS_Internal_Power_Supplies-Sys 5V: 5101 mV
                    Platform_zFAS_Internal_Power_Supplies-SYS_1V1: 1096 mV
                    Platform_zFAS_Internal_Power_Supplies-SYS_9V: 13084 mV
                    Platform_zFAS_Internal_Power_Supplies-TV1_ISENSE: 351 mV
                    Platform_zFAS_Internal_Power_Supplies-TV1_VCC: 8372 mV
                    Platform_zFAS_Internal_Power_Supplies-TV2: 344 mV
                    Platform_zFAS_Internal_Power_Supplies-TV2_VCC: 8335 mV
                    Platform_zFAS_Internal_Power_Supplies-TV3: 352 mV
                    Platform_zFAS_Internal_Power_Supplies-TV3_VCC: 8313 mV
                    Platform_zFAS_Internal_Power_Supplies-TV4: 360 mV
                    Platform_zFAS_Internal_Power_Supplies-TV4_VCC: 8357 mV
                    Platform_zFAS_Internal_Power_Supplies-US_SPEAKER_FRONT: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-US_SPEAKER_REAR: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-VBAT_MAIN: 13051 mV
                    Platform_zFAS_Internal_Power_Supplies-VCC_CAM: 8854 mV
                    Platform_zFAS_Internal_Power_Supplies-VDD 1V1: 1094 mV
                    Platform_zFAS_Internal_Power_Supplies-VDD 1V2: 1201 mV
                    Platform_zFAS_Internal_Power_Supplies-VDD 1V8: 1796 mV
                    Platform_zFAS_Internal_Power_Supplies-VDD 3V3: 3276 mV
                    Platform_zFAS_Internal_Power_Supplies-VDD Core: 1042 mV
                    Platform_zFAS_Internal_Power_Supplies-VDD CPU: 924 mV
                    Platform_zFAS_Internal_Power_Supplies-VDD GPU: 906 mV
                    Platform_zFAS_Internal_Power_Supplies-VDD_DDR: 1352 mV
                    Platform_zFAS_Internal_Power_Supplies-VDD_DDR_FPGA: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-VDD_DDR_HS: 1051 mV
                    Platform_zFAS_Internal_Power_Supplies-VDDIO_SYS: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-VDDRTC: 998 mV
2114637 - Databus
          [LRR1_SensorHeader_LRR1_Fehler]
                    Fault Frequency: 59
                    Reset counter: 2
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 16:08:43
2114642 - Databus
          [MRR_VL_SensorHeader_MRR_VL_Fehler]
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:36
2114643 - Databus
          [MRR_VR_SensorHeader_MRR_VR_Fehler]
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:36
221189 - Front Camera for Driver Assist Systems
          C12B3 FA [008] - Communication Error
                    Fault Frequency: 11
                    Reset counter: 42
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 16:08:54
                    Control Module temperature-Printed circuit: 33 °C
                    Control Module temperature-Average temperature: -50 °C
                    Control Module temperature-Application service computer: 37 °C
                    Control Module temperature-Sensor service computer: 33 °C
                    Control Module temperature-Environment recognition service computer: 42 °C
221244 - Front Camera for Driver-Assist Systems
          C12B3 17 [008] - Voltage Too High
                    Reset counter: 42
                    Mileage: 19423 km
                    Date: 2023.07.03
                    Time: 07:09:51
                    Front camera: temperature: 37 °C
221245 - Front Camera for Driver-Assist Systems
          C12B3 16 [008] - Voltage Too Low
                    Reset counter: 42
                    Mileage: 19423 km
                    Date: 2023.07.03
                    Time: 07:09:51
221246 - Front Camera for Driver-Assist Systems
          C12B3 98 [008] - Component or System over Temperature
                    Reset counter: 42
                    Mileage: 19423 km
                    Date: 2023.07.03
                    Time: 07:09:44
                    Front camera: temperature: 36 °C
221247 - Front Camera for Driver Assist Systems
          C12B3 F9 [008] - Temperature too Low
                    Reset counter: 42
                    Mileage: 19423 km
                    Date: 2023.07.03
                    Time: 07:09:44
221255 - Windscreen Heater for Front Sensors
          B11CE 15 [008] - Open or Short to Plus
                    Reset counter: 42
                    Mileage: 19423 km
                    Date: 2023.07.03
                    Time: 07:09:44
                    Window defogger for front sensor system-Outside air temperature too low: No
                    Window defogger for front sensor system-Status: Malfunction
                    Window defogger for front sensor system-Crash signal: not active
                    Window defogger for front sensor system-Heating time exceeded: No
                    Window defogger for front sensor system-Current power consumption: 0.00 A
                    Window defogger for front sensor system-Actuator test: not active
                    Window defogger for front sensor system-Request due to blinding: no request
                    Window defogger for front sensor system-initial heating: not active
                    Window defogger for front sensor system-Camera temperature too high: No
                    Window defogger for front sensor system-System/voltage fault: No malfunction
                    Window defogger for front sensor system-Windshield heating malfunction: not active
                    Window defogger for front sensor system-preventive heating: not active
221257 - Windscreen Heater for Front Sensors
          B11CE 11 [008] - Short to Ground
                    Reset counter: 42
                    Mileage: 19423 km
                    Date: 2023.07.03
                    Time: 07:09:44
221281 - Control Module for Driver Assist Systems
          C12D5 FA [008] - Image Processor does not Repsond.
                    Reset counter: 42
                    Mileage: 19423 km
                    Date: 2023.07.03
                    Time: 07:08:52
                    EyeQ error source: General malfunction
12290 - TopView Image Processing
          B188F F0 [009] - Calintration of Software Failed
                    Fault Frequency: 17
                    Reset counter: 2
                    Mileage: 19411 km
                    Date: 2023.06.13
                    Time: 17:19:26
                    TVIP_SW_Error: 66 3B E7 27 00 00 00 00
233523 - Parking Sensor(s); Front
          B10FC F0 [008] - Function Limitation due to External Factors
          [Geber für Einparkhilfe vorne - Funktionseinschränkung durch Umwelteinflüsse]
                    Reset counter: 42
                    Mileage: 19421 km
                    Date: 2023.06.14
                    Time: 14:37:32
233524 - Side Front Left Parking Aid Sensor
          B10F6 31 [009] - No Signal
                    Fault Frequency: 60
                    Reset counter: 2
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:42
4107 - Databus
          [reversibler_Fehler_im_ACC_System]
                    Fault Frequency: 65
                    Reset counter: 2
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:36
65540 - Following-Distance Warning (High)
          C12DA F0 [009] - Status Feedback for HMI Implausible
                    Fault Frequency: 60
                    Reset counter: 2
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:39
                    Profile master status distance warning high-Nominal status: OFF
                    Profile master status distance warning high-Actual status:: Initialization
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 4ML 907 159 C    HW: 4K0 907 159
   Component: SAS-GEN 2.5   H08 0005
   Serial number: 200116203627
   VCID: 4FEEB247166658EB02-801A
   Part No SW: 4M1 959 795 J    HW: 4M1 959 795 D
   Component: TSG HFS004 0425
   Serial number: YE007SLK15778 Dataset Number: V03935301LM 0102
   Coding: 000DDB4300001482E008A020
   VCID: 48DC995BF3088FD343-801C
   Component: TSG HBFS004 0425
   Serial number: YE007SLK18265 Dataset Number: V03935301LN 0102
Address C4: DC/DC Converter (A7)       Labels: None
   Part No SW: 4K0 959 682     HW: 4K0 959 682
   Component: DCDC_GEN_2 H20 0307
   Serial number: DC20072000035 Dataset Number: 4ML909475H  0002
   ASAM Dataset: EV_DCDC48VFLEXAU581 004001
   ROD: EV_DCDC48VFLEXAU581_004_VW38.rod
   VCID: 76A027A3C97C4923E1-8022
   Dataset Number: V03935270WZ 0003
   Coding: 228040363602
   VCID: 75A220AFD47A423BE8-8020
Address CB: Rear Axle Steering (J1019)       Labels:* None
   Part No SW: 4M0 909 145 AA    HW: 4M0 909 145 E
   Component: HAL_MLBevoH08 0698
   Revision: --------    Serial number: CCC_098_B_1122_ Dataset Number: 4ML909904B  0001
   Coding: 06200200
   ASAM Dataset: EV_RearAxleSteerZFAU736 010018
   ROD: EV_RearAxleSteerZFAU736_010_VW53.rod
   VCID: 6FAE12C7B62678EB22-803A
0163 - Data set not compatible
          B2027 00 [137] - -
          [KFC_DATENSATZ_UNPLAUSIBEL]
                    Reset counter: 0
                    Mileage: 19392 km
                    Date: 2022.05.25
                    Time: 14:47:21
                    Expanded ambient data 1-Terminal 75 status: 0
                    Expanded ambient data 1-Internal voltage supply 5V: 3.75 V
                    Expanded ambient data 1-Vehicle speed: 0.00 km/h
                    Expanded ambient data 1-Steering angle sensor: -800.00 °
                    Expanded ambient data 1-Internal malfunction: 10
                    Expanded ambient data 1-Target angle: -8.19 °
                    Expanded ambient data 1-Terminal 15 signal: 1
                    Expanded ambient data 1-Power reduction: 100 %
                    Expanded ambient data 1-Restart: 0
                    Expanded ambient data 1-Terminal 30 voltage filtered: 14.41 V
                    Expanded ambient data 1-Power reduction due to overvoltage: 100 %
                    Expanded ambient data 1-Power reduction due to undervoltage: 100 %
                    Expanded ambient data 1-Internal voltage supply 1.2V: 1.20 V
                    Expanded ambient data 1-Current_system_status: 12
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H12 0266
   Dataset Number: V03935278F  0001
   Coding: 0FFC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651.rod
Address D4: Roll Control 1 (----)       Labels: None
   Part No SW: 971 907 156 Q    HW: 971 907 156 L
   Component: EAWSH17 0113
   Serial number: 00120200108145 Dataset Number: V03935269VH 0004
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_EAWSSchaeFront 008001
   ROD: EV_EAWSSchaeRear_VW53.rod
   VCID: 2E10CFC371AC31E369-807A
Address D5: Roll Control 2 (----)       Labels: None
   Serial number: 00120200109095 Dataset Number: V03935269VJ 0004
   Shop #: WSC 20970 1007 10866
   ASAM Dataset: EV_EAWSSchaeRear 008001
   ROD: EV_EAWSSchaeRear_LB63.rod
   Part No SW: 4K0 941 591 BC    HW: 4K0 941 591 B
   Component: LMS_MLBevo    H11 0031
   Dataset Number: V03935282BB 0012
   ROD: EV_LMSLeftHELLAAU58X.rod
   VCID: 71AA14BFA0126E1B34-8024
   Dataset Number: V03935282BC 0012
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4N0 907 669 F    HW: 4N0 907 669 A
   Component: MRR_VR H12 0266
   Dataset Number: 4M8909482C  0011
   Coding: 001000
   Shop #: WSC 31414 042 00001
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
   ROD: EV_FrontCorneRadarS1AU651.rod
          [Component protection is active]
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:36
                    Control Module temperature: 65 °C
                    Voltage terminal 30: Measuring value not available
                    Terminal 15 status: On
                    Voltage terminal 15: 12.60 V
                    Register_check_info-Register_check_info_parameter: 0
                    C1_critical_signals_info-C1_critical_signals_info_parameter: 0
                    C2_critical_signals_info-C2_critical_signals_info_parameter: 0
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H12 0266
   Dataset Number: 4M8909483C  0012
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
   ROD: EV_FrontCorneRadarS2AU651.rod
                    Reset counter: 1
                    Mileage: 19411 km
                    Date: 2023.06.12
                    Time: 15:17:36
                    Control Module temperature: 66 °C
                    Voltage terminal 15: 12.50 V
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502 B    HW: 4N0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 800000
   VCID: 23062EF72A6E8C8BF6-8076
End----------(Elapsed Time: 02:51, VBatt start/end: 13.4V/13.4V)-----------
Ziddywerks
Northern NJ USA
C?ID=208579
Error 37 supposedly pertains to invalid key being entered and need to wait with ignition on however IDE00323 shows 0 which would mean i should be good. Any ideas?
NEtech
Denmark
C?ID=56995
Can you tell which IDE adaptation channel it is, where VCDS show an SA is needed?
To me it looks like fix Ride-Height Sensor and make a full calibration, where SA is not needed.
wojciech300
Poland
C?ID=147841
Try 24085
AINils
Germany (AIB)
C?ID=56975
Fully agreee with you, first of all the mechanical fault should be fixed and then Adaption of suspension shoulöd be done.
Ziddywerks
Northern NJ USA
C?ID=208579
Mechanical faults are solved. However Left rear is sitting low and suspension is in service mode. Due to lack to deflection adaption. Which requires the vehicle to be up on the lift with wheels off the ground. All criteria are met however without login I cannot perform the deflection adaption.
Ziddywerks
Northern NJ USA
C?ID=208579
Here is an test video, for a complete procedure for ASAM EV_ChassContrContiAU426.
We have not tried it for ASAM EV_ChassContrContiAU651 yet.
I have tried it 4 times with VCDS.
Urus is essentially a SQ8 same platform and drivetrains and so on. I will give it a shot. Is there any potential hazards as to trying to do that sequence? Or will it either do it or not? I was trying to perform deflection adaption but kept getting SA needed or login to perform that adaption.
DrPeter
16.4905° S, 151.7375° W
The only documented Security Access code for the J775 found in the Lamborghini Urus is [20103].
- This code will enable both the calibration and the drain/fill functions.
You may just need to wait with the key on with a battery maintainer for a while, until the controller will allow you access.
Hope this helps,
drpeter
Feedback is limited but considering you already have the Basic Setting of Deflected Position not Performed -and- you know the e-tron 55, Q7 and Q8 models based on dealer level experience I would try it. I do not believe it will make things worse.
Ziddywerks
Northern NJ USA
C?ID=208579
Hope this helps,
drpeter
put in 20103 and got Error 35 every time. However I will try the video with sequence above and see what happens. Ideally I need to grab my other laptop with ODIS on it so I can see what it will do with that as well. I will keep you guys posted.
wojciech300
Poland
C?ID=147841
Did u try 24085 ? I saw that is used in Q8 for example to some 2E UDS
<ADJUST_CALIBRATION_DATA LOGIN_IND="" LOGIN="24085" ZDC_VERSION="0004" ZDC_NAME="4M8909576F" MODE_FRAGMENT="PKZZ_0001" RDI="0x0600" SID="2E" DIAGNOSTIC_ADDRESS="0074">385C5848F800</ADJUST_CALIBRATION_DATA>
<ADJUST_CALIBRATION_DATA LOGIN_IND="" LOGIN="24085" ZDC_VERSION="0004" ZDC_NAME="4M8909576F" MODE_FRAGMENT="PKZZ_0002" RDI="0x454D" SID="2E" DIAGNOSTIC_ADDRESS="0074">5F</ADJUST_CALIBRATION_DATA>
I agree. If a SA code would be needed 20103 doesn't work on many of these #74 units. 24085 is accepted by my 2022 e-tron 55 but I have NOT attempted calibration on that car. (My house garage rack arms are too short to hit the lift points but I'm working on that)
Ziddywerks
Northern NJ USA
C?ID=208579
I haven't tried that one. I will give it shot and see what happens. Would it be possible to compile a database of SA somewhere for future use as VCDS does not always give you a SA for most newer vehicles.
The closest thing we have at present isn't real new but:
Although that's Golf 7 based specific many of the SA codes carry over to other platforms. For instance 20103 is the most universal SA code in reasonably modern cars .... however 24085 is not. That particular thread won't help in all cases but it is handy.
Ziddywerks
Northern NJ USA
C?ID=208579
Perfect thank you bookmarked, good to have just in case. That being said I mostly use ODIS but in rare cases I do grab my VCDS as things like coding are so much easier to deal with using VCDS. I will try to log my ODIS session to see if the log from ODIS does show the login code in the background.
AINils
Germany (AIB)
C?ID=56975
Tried a SQ8 remote from a swiss customer today, but didn't have success. Got some error after starting sequence from @NEtech, but it seems car (ECU) had some issue so Workshop need to fix that first.
@Dana @NEtech will send you a trace log and Scans from Q7 last week. Just forget to send you these files
Ziddywerks
Northern NJ USA
C?ID=208579
Ok guys so an update. Login 24085 is indeed the correct login for chassis control module 74. I still was not able to run the adaptions or basic settings on this vehicle. I have no codes stored in the chassis module other than the deflection no basic setting performed code. However I cannot perform this as I get error conditions not met or sequence. The only thing I did notice while checking thing was that the module itself does not see a voltage for terminal15 when looking at advanced measured values but does see battery voltage terminal 30. It looks like terminal 15 comes directly from J393. I think maybe this is my issue? Or perhaps another module. This one is driving me crazy for sure as all the sensor height in terms of readings were close roughly 2mm apart. Fronts were around 450mm and rears around 447mm give or take 2mm between left and right.
The thing that sucks is that this module is buried in front of the center console, I think I may have to pull it to check to see whats going on. I did try to do thing using my ODIS today also and kept getting this error that the raw hex data for the calibration could not be written into the module but gave no further explanation. I am starting to wonder if CP in a different module would affect this since a fair majority of modules talk to each other for various functions and systems. I think Im gonna need to check some wires unless anyone has any other ideas.
  • Informative
Ziddywerks
Northern NJ USA
C?ID=208579
ODIS wasnt of much help. Error received but also didn't show the login code at all as you can see here in red. It looks like it doesn't like the deflected value possibly from one sensor possibly according to the raw hex data but i could be mistaken. However I don't know why it would fail to write the values in unless they are perhaps out of range.
Action:  Message
[en-GB]
Login successful
int_jobstatus = 1.
(080045218154a76e).(GUIDC712AB9DE40E4B3A902FF1DBE8981885)
Test step: [en-GB]Basic setting learn values
(080045218154a76e).(GUID7BA33F486AB3446398F05C41E0DC21B8)
Control module communication (UDS):
Control module: Chassis control (LL_ChassContrUDS)
Job status: OKAY
-Service: SinglJob_ChangDiagnSessi
Request parameters:
Name
Value
VW - diagnostic mode
Response parameters:
Name
Value
/OPA_JobStatuCode
/OPA_JobStatuInfor
Job Completed With out Errors
/OPA_NegatRespoInfor/Param_Avail
FALSE
/OPA_NegatRespoInfor/Param_NegatRespoCode
unknown NRC
/OPA_NegatRespoInfor/Param_NegatRespoPDU
Job status: ERROR_NACK
-Service: DiagnServi_RoutiContrStartBasicSetti
Request parameters:
Name
Value
Param_RoutiIdent
Adapting with deflected wheels
Option 1
with wheels
Name
Value
Conditions not correct
/Param_NegatRespoCodeValue
34
/Param_NegatRespoServiIdent
127
/Param_RequeServiIdent
31
Test step: [en-GB]Read and Write Rebound Values
(080045218154a76e).(GUID4C7B29E939214659B14931C1B3EA24D1)
Job status: OKAY
-Service: DiagnServi_ReadDataByIdentCalibData (Raw values, height sensors when deflected)
Request parameters:
Name
Value
Param_RecorDataIdent
Name
Value
/Param_DataRecor/Param_FrontLeftVehicLevelSen
deLearnValueRebouPosit
0.0 %
/Param_DataRecor/Param_FrontRightVehicLevelSe
ndeLearnValueRebouPosit
0.0 %
/Param_DataRecor/Param_RearLeftVehicLevelSend
0.0 %
/Param_DataRecor/Param_RearRightVehicLevelSen
0.0 %
/Param_MatchRecorDataIdent
45 2D
/Param_RecorDataIdent
Raw_values_of_level_sensors_in_rebounded_position
/Param_RespoServiId
98
Action:  Message
[en-GB]
Initial values of the adaptions/calibrations
(452D , 0x2E)
Front Left = 0.0
Front Right = 0.0
Rear Left = 0.0
Rear Right = 0.0
The next command will reset the raw values.
(0x31, 0x0517)
Press  to continue
(080045218154a76e).(GUIDBBAA623EDFF94163905543A051694FE5)
Job status: OKAY
Request parameters:
Name
Value
Param_RoutiIdent
Reset raw values of height sensors when deflected
Name
Value
/Param_RespoServiId
113
/Param_RoutiContrType
Start Routine
/Param_RoutiIdent
05 17
Job status: OKAY
-Service: DiagnServi_RoutiContrRequeRoutiResulBasicSetti
Request parameters:
Name
Value
Param_RoutiIdent
Name
Value
/Param_MatchRoutiIdent
05 17
/Param_RespoServiId
113
Request Routine Results
/Param_RoutiIdent
Reset_of_raw_values_of_level_sensors_in_rebounded_position
/Param_RoutiStatuRecor/Param_RoutiResul
Correct Results
/Param_RoutiStatuRecor/Param_RoutiStatu
Routine Not Active
Or Finished Correctly
Action:  Message
[en-GB]The Basic setting adaption height sensors pull stop - learn values is in progress.
Please wait ...
Basic Settings results
Correct Results
Unknown status
Routine Not Active Or Finished Correctly
Correct result
(080045218154a76e).(GUIDF184DF0D63864D42B79AEC825F82965E)
Job status: OKAY
-Service: DiagnServi_RoutiContrStopBasicSetti
Request parameters:
Name
Value
Param_RoutiIdent
Reset raw values o
f height sensors w
hen deflected
Name
Value
/Param_RespoServiId
113
Stop Routine
/Param_RoutiIdent
05 17
Job status: OKAY
-Service: DiagnServi_ReadDataByIdentMeasuValue (Vehicle level sensor, raw value)
Request parameters:
Name
Value
Vehicle level sens
or, raw value
Name
Value
/Param_DataRecor/Param_ActuaRawValueLevelSens
oFrontLeft
76.51 %
oFrontRight
16.57 %
oRearLeft
77.39 %
oRearRight
27.2 %
45 06
Vehicle_level_send
er_raw_value
/Param_RespoServiId
98
Action:  Message
[en-GB]
Measured values of the rebound values
before re-adapted
Front Left = 76.5
Front Right = 16.6
Rear Left = 77.4
Rear Right = 27.2
Press  to continue
(080045218154a76e).(GUIDE87988CF46014E2688B7E2228D5A5F81)
Action:  Message
[en-GB]
Attempting log in into Chassis control unit -J775
Waiting...
This is required to re-write the previous values
to the adaptions channel .
0x2E, 452D
(080045218154a76e).(GUIDBFDBF5F868454070BBF0834A8B494C5B)
Job status: OKAY
-Service: SinglJob_SecurAcces
Request parameters:
Name
Value
IPA_SecurMetho
Login
IPA_SecurCode
Name
Value
/OPA_JobComplStatu
Job completed succ
essfully
/OPA_JobMessa[0]/Param_Messa/Case_Stati/Param
_Messa
SecurityAccess gra
nted
/OPA_JobMessa[0]/Param_MessaType
static
/OPA_JobMessa[1]/Param_Messa/Case_Dynam/Param
_Messa
Job runtime: 0:00:
00.054
/OPA_JobMessa[1]/Param_MessaType
dynamic
FALSE
unknown NRC
Action:  Message
[en-GB]The following values are now 'adapted' to
0x452D
Front Left = 76.5
Front Right = 16.6
Rear Left = 77.4
Rear Right = 27.2
Press  to continue
(080045218154a76e).(GUID60DDBA7CF26E40D48E00BAEAFC79929B)
-Service: DiagnServi_WriteDataByIdentCalibData (Raw values, height sensors when deflected)
Request parameters:
Name
Value
Raw values, height
sensors when defl
ected
Left front level ctrl sys sensor, adaptation
value (deflected)
76.51 %
Right front level ctrl sys sensor, adaptation
value (deflected)
16.57 %
Left rear level ctrl sys sensor, adaptation v
alue (deflected)
77.39 %
Right rear level ctrl sys sensor, adaptation
value (deflected)
27.2 %
Name
Value
Conditions not cor
rect
34
127
2E
Action:  Message
[en-GB]
Write calibration of raw data failed '0x452D' failed
Press  to continue
(080045218154a76e).(GUID3874687AD3E54599B2B35293D0DF373A)
