Retrofitted R-wheel, Remove DTC for heater?
sers77
Norway
C?ID=26140
Can`t figure out how to remove DTC after removing OEM wheel with heater and now R-wheel without..
Button for heater is also removed, by gear leaver.
MIB activation of heater is also removed..
Saturday,15,July,2023,15:56:42:54229
VCDS Version: 23.3.1.0 (x64)  HEX-NET2 CB: 0.4631.5
VIN: WVWZZZ3CZHE001852   License Plate: R-WHEEL
Mileage: 64684km-40192mi   Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 22 2B 36 3C 42 44
          47 52 55 5F 65 69 6C 6D 82 A5 BB BC CA CF
VIN: WVWZZZ3CZHE001852   Mileage: 64684km-40192miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 3G0 906 259 C    HW: 06K 907 425 E
   Revision: --H13---    CVN: D23059F8
   Coding: 0A25003A2476050B3000
   Shop #: WSC 05311 115 00301
   ASAM Dataset: EV_ECM20TFS0203G0906259C 001004
   ROD: EV_ECM20TFS0203G0906259_VW48.rod
   VCID: AC0AEACA16868A3A033-80F8
   VINID: 9E69EAAAA0D3A9854000120508B720BCF2
Readiness: 0010 0001
   Part No SW: 0DL 300 011 C    HW: 0BH 927 711 F
   Component: GSG DQ500     H10 5210
   Revision: 00H10V01    CVN: 5DC370A3
   VCID: A80216DA027EA61AE7B-80FC
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.lbl
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 61446000001800
   Coding: 40EC6A8F54201B6D477F170541C56902562AD8E2E882967FB84250886AA902
   Shop #: WSC 00015 115 00001
   ROD: EV_Brake1UDSContiMK100IPB_035_VW48.rod
   VCID: FBA81996A368DD82DA9-80AE
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0404956416 Dataset Number: V03935240UV 0001
   Coding: 0F20100F07
   Shop #: WSC 99999 999 83333
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   ROD: EV_KessyHellaMQBAB.rod
   VCID: BC2ADA8AE6E61ABA933-80E8
   Part No SW: 5G0 907 044 BQ    HW: 5G0 907 044 BQ
   Component: Climatronic   H04 1601
   Revision: 00001K10
   Coding: 1202001410410101111550401210192A
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   VCID: F7A005A69F40F9E2BE1-80A2
   Air quality sensor:
   Humidity sensor: exterior:
   Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 032 0246
   Revision: --------    Serial number: 865823051600NZ Dataset Number: V03935267Q  0001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 865E7862E8AA906AB57-80D2
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    160507  042 0607
   Serial number:         160517074744
   Coding: 0B4DFC
   Component: RLHS  042 0105
   Serial number: S2Y16M05D13H12M54S41
   Coding: 06A8DD
   Subsystem 3 - Part No SW: 3G0 941 633 R    HW: 3G0 941 633 R
   Serial number: 15 02 2016  10000322
   Humidity sensor: interior:
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH08 0050
   Serial number: 000150057321331 Dataset Number: V03935341UY 0001
   Coding: 0A71267A51
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   VCID: D1F49B3E516487D2505-8084
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 R    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0771
   Dataset Number: V12345678AA V315
   Coding: 331D7FDBDFFFC429979F8264835086000000000000B9C00002
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ACCBOSCHVW416 003014
   ROD: EV_ACCBOSCHVW416_003_VW41.rod
   VCID: C6DEB862A82A506AF57-8092
   Part No SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0130
   Serial number: 19021641350042 Dataset Number: V03935232RZ 0001
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: B924C39EE9D42F92885-80EC
   Part No SW: 3Q0 959 655 BA    HW: 3Q0 959 655 BA
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003SSP9PRPWU Dataset Number: 3G0003V____ 0036
   Coding: 98FCC0C0008000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: FEAE1082B07AC8AAFD7-80AA
   Left seat belt tensioner:
   Serial number: 3G1857705G0134Q00930
   Coding: 80000D
   Right seat belt tensioner:
   Serial number: 3G1857706G0134Q01520
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 002 704 16
   Serial number: 3576U000000B15BCE91T
   Subsystem 4 - Part No SW: -----------    HW: 454 002 704 16
   Serial number: 3586U000000C28CCE91-
   Subsystem 5 - Part No SW: -----------    HW: 454 802 204 16
   Serial number: 3516RFC935F0A000000P
   Subsystem 6 - Part No SW: -----------    HW: 454 802 204 16
   Serial number: 3526R9215790A0000000
   Subsystem 7 - Part No SW: -----------    HW: 454 802 304 16
   Serial number: 3556VACB4870A000000Q
   Part No SW: 3Q0 953 521 EK    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0225
   Revision: FF034034    Serial number: 20160420501066 Dataset Number: 3G0094V____ 0001
   Coding: 0C10
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001009
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: FDAC178EBD7CD3B2E4D-80A8
291088 - Temperature Sensor for Heated Steering Wheel
          B1455 11 [009] - Short to Ground
                    Reset counter: 46
                    Mileage: 64684 km
                    Date: 2023.07.15
                    Time: 15:52:13
                    Ubat 30 Voltage: 12.90 V
                    Internal error state: 0
                    LIN_Temp: 255
                    Isense: 0
                    Max.Leistung: 110
                    PWM: 0
                    Offset: 249
                    Slope: 135
                    kp: 13
                    OUT: 50
                    Temperatur Statisch: 30
                    p_t_soll_0: 39.00 °C
                    p_t_soll_1: 43.00 °C
                    p_t_soll_2: 47.00 °C
291104 - Temperature Sensor for Heated Steering Wheel
          B1455 01 [008] - Electrical Failure
                    Reset counter: 86
                    Mileage: 64684 km
                    Date: 2023.07.15
                    Time: 15:52:53
                    Ubat 30 Voltage: 12.80 V
                    LIN_Temp: 254
                    Isense: 0
                    Max.Leistung: 110
                    PWM: 0
                    Offset: 249
                    Slope: 135
                    kp: 13
                    OUT: 50
   Part No SW: 3G0 920 791 B    HW: 3G0 920 791 B
   Component: KOMBI         404 2153
   Coding: 03AD189BFE8C00080B887B2F7003000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 H    HW: 5Q0 963 272 H
   Component: STH-MQB       008 0075
   Coding: 9309
   VCID: BB28D996E3E81D829A9-80EE
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0401
   Serial number: 00000000000000057123
   Serial number: 14012011600227 Dataset Number: SET_FPA_MOD 0001
   Coding: 0B0300345F015800DB0222DE9E0F00010001070000000000000000000000
   GVL: 01DC3C0808000600C0DC90000006CC0010040000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: EE8E20C2E01AB82A6D7-80BA
   Generator:
   Component: 1-01-03-01-04
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29160000995370066204
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
   Serial number: 5815200104
   Inverter for electrical outlet:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: WECHSELRICHTE  H55 0033
   Serial number: 0237610
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
   Serial number: HA1-00015.04.16 Dataset Number: v1260x015G0 0000
   Coding: 0301
   VCID: CAC68C52BC32B40A11F-809E
   Serial number: 16000104871018
   Coding: 0800000000000000
   Shop #: WSC 05311 115 00064
   ROD: EV_ELVMarquMQBB_VW41.rod
   VCID: F1B43BBEF124A7D2705-80A4
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 3Q0 959 760 B    HW: 3Q0 959 760 B
   Component: Sitzmemory    H04 0020
   Serial number: Y0006PEQ15416
   Coding: 001000020000050081C480808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   VCID: BA26DC92ECD2248A81F-80EE
   Part No SW: 3Q0 907 566 G    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0530
   Revision: --------
   Coding: 14C002
   ROD: EV_RearRadarS1BoschVW48X_VW37.rod
   Serial number: 060516EE200814 Dataset Number: V03935241MX 0001
   Coding: 001F1B20D200028000001000
   VCID: C3D8A1769B186542D29-8096
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000806963 Dataset Number: 3G0074V____ 0241
   Coding: 01010011005001
   Shop #: WSC 00015 115 00301
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_008_VW48.rod
   VCID: BD2CD78EFDFC13B2A4D-80E8
Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
   Part No SW: 3Q0 035 466 C    HW: 3Q0 035 466 C
   Component: MIB2_amp_P_VW H45 0210
   Revision: 00000001    Serial number: VWZ8Z1GAT00MGG- Dataset Number: V03935221ZB 0001
   Coding: 1284020001AA0A2AAA0000000000
   ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
   ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
   VCID: AF30FDC62790F122261-80FA
   Serial number: 290416EDS23656 Dataset Number: V03935238YR 0001
   Coding: 001F1120DE00028200001000
   VCID: C2D6A47284026C4AD9F-8096
   Component: AFS-ECU       H01 0120
   Coding: 03A202004F210200
   Shop #: WSC 05311 000 08193
   ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
   VCID: BFD0AD86F7F001A2B61-80EA
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0003
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
   Part No SW: 5NA 035 020 F    HW: 5NA 035 020
   Component: MU-H-ND-EU    H55 1367
   Serial number: A845A0LP008831 Dataset Number: V03935299LU 0001
   Coding: 028402010000000051110102008808001F0108E401208000D6
   VCID: B43AF2AACEB6D2FA5B3-80E0
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H61 9214
   Serial number: VWZ6ZJX0273831
   Subsystem 2 - Part No SW: V03 959 809 PD    HW: -----------
   Component: ECE 2023/2024  --- 0330
   Serial number: 30000000019991 Dataset Number: V03935239RW 0001
   ROD: EV_RDKBERU30_006_VW37.rod
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anhaenger     H21 0203
   Revision: 8A001003    Serial number: 0400114511 Dataset Number: 0G0124v____ 0016
   Coding: 0100000202000000
   Part No SW: 5Q0 907 556     HW: 5Q0 907 556
   Component: Areaview 2    H11 0329
   Serial number: C854706JG015141 Dataset Number: V03935230LZ 0001
   Coding: 01840201E70F200000204814
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 003013
   ROD: EV_CamSysRVAV2ARCE2MQBAB_003_VW37.rod
   VCID: F6BE08A2984A80EAA57-80A2
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30671343700000 Dataset Number: V03935230GZ 0001
   Coding: 0288
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 3G0 919 608     HW: 3G0 919 608
   Component: HeadupDisplay 040 0152
   Coding: 474060
   ASAM Dataset: EV_HeadUpDisplContiVW481 001010
   ROD: EV_HeadUpDisplContiVW481.rod
   VCID: EB8829D6D3084D024A9-80BE
   Part No SW: 3Q0 980 653 F    HW: 3Q0 980 653
   Component: MQB_B_MFK     H10 0171
   Serial number: 30041611P10303 Dataset Number: V08154711FU 0001
   Coding: 00040802040004010022235FC0568500980096300040
   Serial number: 110316EC811739 Dataset Number: V03935238KV 0001
   Coding: 000E11200100028000001000
   VCID: C5DCBF6E952C5B72FCD-8090
   Serial number: 110316EC811736 Dataset Number: V03935238KX 0001
   Part No SW: 4M0 907 594 D    HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Dataset Number: V03935237NH 0001
   Coding: 208040748202
   VCID: B720C5A6DFC039E27E1-80E2
   Part No SW: 3Q0 907 590 G    HW: 3Q0 907 590
   Revision: --------
   Coding: 14C002
   ROD: EV_RearRadarS2BoschVW48X_VW37.rod
End----------(Elapsed Time: 02:50, VBatt start/end: 12.2V/12.2V)-----------
siLc
Tallinn, Estonia
C?ID=330192
There is probably coding to do in module 16 also.
downtime
Finland
C?ID=280813
Remove steering heating from can gateway adaptations under multi function steering group. If not already done.
sers77
Norway
C?ID=26140
Will have another look when I get back on shore..
Thank you..
sers77
Norway
C?ID=26140
Nope, everything is off..
sers77
Norway
C?ID=26140
Do I have to pull a fuse?
Tried one (that was supposed to be for steering heater) but it was for right driving light :facepalm:
sers77
Norway
C?ID=26140
Is that the only way?
sers77
Norway
C?ID=26140
Cannot find that file..
Guessing that it is not official..
sers77
Norway
C?ID=26140
Aaah, 265.. That one I have :)
Thank you..
Supposed to fix the error in the steering wheel heating unit 16.
sers77
Norway
C?ID=26140
Yes, got rid of
But still have
sers77
Norway
C?ID=26140
So, with this wheel from a Golf R it's impossible to get it straight (without alignment).. It's just a little off, but...
Also, with the cluster updated to D the option for the "VIEW" button is available.. Don't really know what it does..
The only mfsw that I can find (in good condition) is from a 2019 T-Roc with chrome, VIEW and red stitching, but will it fit and work in a Passat (is it smaller)?
