A6 C7 issue
macapple
Verified VCDS-User
malaysia
C?ID=363509
Hi all ,
I'm experiencing a problem with the A6 C7 model, and I'm unsure about any customizations made by the previous owner. The car's screen doesn't have a camera, yet I'm encountering an error message appearing on the instrument cluster.
"Main beam assist : currently unavailable. no camera view"
how do i disable ?
Monday,10,July,2023,22:56:20:63906
VCDS Version: 23.3.1.0 (x64)  HEX-NET CB: 0.4631.4
VIN: WAUZZZ4GXHN119047   License Plate: ERRORA6
Mileage: 50656km-31476mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 36 3B 42 44 46 52 53 55
          5F 62 6C 6D 72 47
VIN: WAUZZZ4GXHN119047   Mileage: 50656km-31476miles
20-High Beam Assist. -- Status: Malfunction 0010
Address 01: Engine (J623-CYGA)       Labels:. 06L-906-264-CJE.clb
   Part No SW: 4G0 906 264     HW: 8T2 907 115
   Component: 1.8l R4 TFSI  H13 0004
   Revision: --H13---    CVN: B26A69BA
   Coding: 0A2500322425010B2000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM18TFS0204G0906264 001005
   ROD: EV_ECM18TFS020_AU57.rod
   VCID: 6680BED2999E6FA351-8032
   VINID: 9D196AAAA117A187810490041C340CF1F0
   Part No SW: 4G0 927 153 R    HW: 0CJ 927 156
   Component: 0CK 18TFSIRdW H03 0004
   Revision: --H03---    Serial number: 0000002052 CVN: 744B746E
   Coding: 100001
   ASAM Dataset: EV_TCMDL382021 002024
   ROD: EV_TCMDL382021_AU57.rod
   VCID: 383C20AA83AA295333-806C
   MTF pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  002 0572
   Serial number: 75117071170068001456
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 08A28E41104571829B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41CA4D4ED070689B84-8014
   Part No SW: 4H0 907 064 HP    HW: 4H0 907 064 HP
   Component: BCM2 2.0      H61 0825
   Coding: 05B86F0E000000000000
   VCID: 7EB0F6B2E90ED763B9-802A
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 4G0 820 043 BK    HW: 4G0 820 043 BK
   Serial number: 20031700041319
   Coding: 64217078A10000
   VCID: 699AB5EE888040DB7C-803C
   Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0368
   Revision: 1502003S    Serial number: 00001629647302
   Coding: 0105C01540349FE04101408080001800CF9DC3082F08020100000894E101140200400034030000
   VCID: 74A4D49AD7428D33DF-8020
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 150905  H38 0080
   Serial number:         150922211900
   Coding: 0045F7
   Serial number: 20172045X81A955547A0
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 20 03 2017  00000640
   Subsystem 4 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: 7E48889800PAG0MUFU03
02988 - Left-Hand/Right-Hand Traffic Switchover Active
                    Reset counter: 21
                    Mileage: 50656 km
                    Date: 2023.07.10
                    Time: 22:50:44
03455 - Function Restriction due to Faults in Other Modules
                    Reset counter: 61
                    Mileage: 50622 km
                    Date: 2023.07.10
                    Time: 06:31:15
   Component: Airbag10.43   H82 0092
   Revision: --------    Serial number: 003P100D8B2K Dataset Number: 4G0909602M  0003
   Coding: 30333130313630323937554A305234473053
   VCID: 3B363FA6B29C024BDE-806E
   Serial number: 3575HRB405V468HIFP5+
   Serial number: 3585HRB405B4D4QG3H6D
   Serial number: 3515JRB401659FHCLA87
   Serial number: 3525JRB401I59FHCP0V.
   Serial number: 3554VRB400M59GF8K9H$
   Serial number: 3564VRB400O59GF88PVH
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 91560QCV0003H
   Coding: 000034
   VCID: 3B363FA6BA9C024BDE-806E
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Serial number: 12 11 2017  C0020338
   Part No SW: 4G8 920 934 P    HW: 4G8 920 934 P
   Component: TBenRdw       H15 0225
   Revision: 15001309    Serial number: 658280317596008
   Coding: 33AF08000B410008010000
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K_AU57.rod
   VCID: 3E3036B2A18E1763F9-806A
   Part No SW: 4G8 907 468 H    HW: 4G8 907 468
   Revision: --------    Serial number: 00000002568635 Dataset Number: 4G0909515N  0025
   Coding: C0CD072918
   GVL: FD81C948DC21600100040800
   VCID: 3D3231BEAC880C7BE0-8068
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 5809573404
   Voltage stabilizer:
   Serial number: 170114000000000003FC
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04028264747464545425363E00
   VCID: 679EB3D6969476AB6A-8032
03576 - Contol Module for High Beam Assistant: Visibility Limited
                    Reset counter: 61
                    Mileage: 50622 km
                    Date: 2023.07.10
                    Time: 06:29:21
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0113
   Serial number: 27031700040494
   Coding: 22
   Revision: AA000000    Serial number: 00000246385439
   Coding: 00781B0000006001000001010101102030303232203232
   VCID: 77BEE396C634E62BFA-8022
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720W4XTF Dataset Number: 4G0909573C  0006
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 332617869ACCCA0B06-8066
   Component: TSG FA        H03 0511
   Coding: 011F17015E01620002080002
   VCID: 47DE5356F65456AB4A-8012
   Component: RCevo         H54 0202
   Revision: 00000002    Serial number: 0000698797 Dataset Number: 4G0909852L  0038
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A383AA2BDA63B43C5-806E
   Revision: 00002001    Serial number: 0437267572
   Coding: 01040E3A00B93081C330088400030E470000000000000000000000000000
   Subsystem 1 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00031970937
   Subsystem 2 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 6600307;
   Component: TSG BF        H03 0511
   VCID: 46C05E52F15E4FA3B1-8012
   Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
   Component: EPB-4         H01 0018
   Revision: --------    Serial number: 00000002151344 Dataset Number: 4G0909522G  0001
   ASAM Dataset: EV_ParkiBrake 001033
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 3228128265D6C3030D-8066
   Revision: --------    Serial number: -------------- Dataset Number: 4G0909865D  0019
   Coding: 04FE02102A600200
   VCID: 3424149A9FC2CD331F-8060
   Coding: E01E00
   Coding: E01E00
5275648 - Left/Right Driving Switch-Over Active
          C1080 00 [009] - -
                    Reset counter: 19
                    Mileage: 50605 km
                    Date: 2023.07.09
                    Time: 15:28:37
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 046 G    HW: 4G1 035 046 D
   Component: MU-H-LN-RW    053 0910
   Serial number: A737B0H7513169 Dataset Number: 4G1909545G  0040
   Coding: 01750107FF0A000013110001000A00102F0006E6F17001005E
   VCID: 2502F9DE2418A4BB98-8070
   Subsystem 1 - Part No SW: V03 959 803 BP    HW: -----------
   Component: ROW 2023/2024  --- 0333
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9HY807GH2
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349QCL0012I
   Compact disc data bank:
   Component: Gracenote2  --- 4011
   Component: TSG HL        H03 0511
   Coding: 010F15004001620002080002
   VCID: 49DA556EE040A0DB5C-801C
Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
   Part No SW: 4S0 980 556     HW: 4M0 980 556
   Component: RVC Compact   H08 0140
   Dataset Number: 4G0909460D  0013
   Coding: 0275000102002003000040
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
   ROD: EV_CamSysRVRVCPANAAU57X_001.rod
   VCID: 78BCE0AAC32AE953F3-802C
   Part No SW: 4G5 959 107 C    HW: 4G5 959 107 A
   Component: HDSG-Modul    H02 0049
   Revision: 13002001    Serial number: 056700320 Dataset Number: 4G1909541C  0003
   Coding: 111104C020
   ASAM Dataset: EV_HDSGAu571 001022
   ROD: EV_HDSGAu571.rod
   Component: TSG HR        H03 0511
End----------(Elapsed Time: 01:56, VBatt start/end: 12.3V/12.3V)-----------
It has a dedicated 'camera' for the high-beam assist:
Revision: AA001002
Reset counter: 61
Mileage: 50622 km
Date: 2023.07.10
Time: 06:29:21
One possibility is that the windshield has been replaced with an incorrect type?
