Coding of the air suspension
Zeuemr
C?ID=232197
Hi all,
guess this is my first thread here in this forum. I live in Germany, have a Q7, built in 2006, 8 zylinder gasoline engine.
Aplogies if my English is not the best....
I tried to do a training here in Germany for the VCDS, but they rescheduled a couple of times, eventually I got my money back. I own VCDS for a long time, hlped me so solve a lot of problems, but....
My cars problem: The air suspension is always at maximum height, no chance to fix that.
I am not familiar with the VCDS expressions, so please keep calm.
With VDCS (latest software update, of course) I can connect to the air suspension controller, but generally that's it.
Controller said my car is at about 195mm height at each side (which is smaller than the tire radius), indeed it was 540 / 580 mm. I have access to the actuator testing, which works from a software point of view (no errors) but the car is not willing to come down or react in some way.
I tried a "basic setting", and here is where my problem starts. There's a second button with "Adaption" (all translated from German). And I don't know which one to use.
With the 5 digit code I do have access to "basic setting", but I don't see the possibility here to set the real heigth of the car for each wheel.
There's a different code given in the software for "Adaption", but this code does not work, I can't get access to this section. (Tried it about 50 times over a longer period of time)
What I did so far, because I had some more problems with the air suspension before:
Replaced the compressor some time ago, and also the little valves for the rest pressure. Since then, everything worked fine for a year or two, when the car finally started to get to maximum height. So I replaced the control valve unit, which did not help at all. All replaced parts have been brandnew.
A car work shop in town could not help either, they had the same problem: No access to the "Adaption" section.
Today I unplugged the controller, had the hope to do a kind or reset, but that did not help as well.
Is this a faulty controller? I can't affort a new one, does it matter which version I buy? My one is a "B" version, I found some on Ebay with "C" or "F". Would they also work? Would this be a good or a bad idea to buy a newer one?
I tried to get help in the German Forum called MotorTalk, those guys couldn't help at all.
Does someone have, or can guide me to, a step by step manual how to do the basic setting / adaption? Or any other idea? Can't drive my car since months.... Obviously IT IS rocket sience.
BTW, the hood and the car door were closed, ignition on, motor runnig.
Thanks in advance,
Ansgar
Westbury, UK
Since not all Q7's are built the same we need you to post an Auto-Scan so we can see how your Q7 is equipped and configured.
Zeuemr
C?ID=232197
Sure.
The first one is after I removed the controller an put it back again, the second is before.
Samstag,08,Juli,2023,12:39:02:57342
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 8.1 x64
VCDS Version: DRV 23.3.1.0
Datenstand: 20230627 DS346.2
www.Ross-Tech.de
Händler-/Werkstattname: Ansgar Zeumer
Fahrzeug-Ident.-Nr.: WAUZZZ4L47D060689   KFZ-Kennzeichen:
Fahrzeugtyp: 4L (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 13 15 16 17 18 19 28 34 36 37
          3C 42 46 47 4F 52 55 56 57 61 62 65 69 6C 6D 6F 72 76 77
Fahrzeug-Ident.-Nr.: WAUZZZ4L47D060689   Kilometerstand: 158660km
00-Lenkwinkelsensor -- Status: i.O. 0000
01-Motorelektronik -- Status: Fehler 0010
02-Getriebe -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
05-Zugangs-/Startber. -- Status: Fehler 0010
06-Sitzverst. Beifah. -- Status: Fehler 0010
07-Anz./Bedieneinh. -- Status: Fehler 0010
08-Klima-/Heizungsel. -- Status: Fehler 0010
09-Zentralelektrik -- Status: i.O. 0000
0E-Media Player 1 -- Status: i.O. 0000
0F-Radio-Tuner (dig.) -- Status: i.O. 0000
13-Distanzregelung -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
16-Lenkradelektronik -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
18-Standheizung -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
28-Heizung/Klima hi. -- Status: Fehler 0010
34-Niveauregelung -- Status: Fehler 0010
36-Sitzverst. Fahr. -- Status: i.O. 0000
37-Navigation -- Status: Fehler 0010
3C-Spurwechsel -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
46-Komfortsystem -- Status: i.O. 0000
47-Soundsystem -- Status: i.O. 0000
4F-Zentralelektrik II -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: i.O. 0000
55-Leuchtweitenreg. -- Status: i.O. 0000
56-Radio -- Status: Fehler 0010
57-TV Tuner -- Status: Fehler 0010
61-Batterieregelung -- Status: Fehler 0010
62-Türelektr. hi. li. -- Status: i.O. 0000
65-Reifendruck -- Status: i.O. 0000
69-Anhänger -- Status: i.O. 0000
6C-Rückfahrkamera -- Status: i.O. 0000
6D-Heckklappe -- Status: Fehler 0010
6F-Komfortsystem II -- Status: i.O. 0000
72-Türelektr. hi. re. -- Status: i.O. 0000
76-Einparkhilfe -- Status: i.O. 0000
77-Telefon -- Status: i.O. 0000
Adresse 01: Motorelektronik        Labeldatei:. DRV\079-907-560-BAR.clb
   Teilenummer SW: 4L0 910 560 B    HW: 4L0 907 560 A
   Bauteil: 4.2l V8/4V FSI      0070
   Revision: 71H16---    Seriennummer:
   Codierung: 01210003190F0E60
   Betriebsnr.: WSC 61581 142 87136
   VCID: 275A7D469632EAABAA-8072
   VINID: 9D196AAAA11C10750018018824EEE05561
1 Fehler gefunden:
001057 - Vorkatalysator; Bank 1
               P0421 - 002 - Wirkung zu gering - Sporadisch
             Umgebungsbedingungen:
                    Fehlerstatus: 00100010
                    Fehlerpriorität: 0
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 255
                    Kilometerstand: 158623 km
                    Zeitangabe: 0
                    Datum: 2023.04.18
                    Zeit: 05:19:59
                    Drehzahl: 1724 /min
                    Last: 13.7 %
                    Geschwindigkeit: 79.0 km/h
                    Temperatur: 76.0°C
                    Temperatur: 13.0°C
                    Druck: 990.0 mbar
                    Spannung: 13.970 V
Adresse 02: Getriebe        Labeldatei: DRV\09D-927-750.clb
   Teilenummer SW: 09D 927 750 FR    HW: 09D 927 750 FR
   Bauteil: AL 750 6A           0998
   Revision: 00H64000    Seriennummer:
   Codierung: 0000504
   Betriebsnr.: WSC 31414 790 00001
   VCID: 030209D642CAE68BD6-8056
Kein(e) Fehlercode(s) gefunden.
Adresse 03: Bremsenelektronik        Labeldatei:. DRV\4L0-910-517-V1.clb
   Teilenummer SW: 4L0 910 517 A    HW: 4L0 614 517 A
   Bauteil: ESP ALLRAD MK25E1   0130
   Revision: 00H22001
   Codierung: 0545825
   VCID: 28587E7A9B2CE5D3A3-807C
Adresse 05: Zugangs-/Startber.        Labeldatei:. 4F0-910-852.clb
   Teilenummer SW: 4F0 910 852     HW: 4F0 905 852 B
   Bauteil: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Seriennummer: 10601100580039
   Codierung: 0000135
   Betriebsnr.: WSC 03654 128 66303
   VCID: 63C22956A28A468BB6-8036
   Subsystem 1 - Teilenummer: 4F0 910 131 G
   Bauteil: FBSAUDIC6 EZS   H45 0080
   Subsystem 2 - Teilenummer: 4F0 910 335
   Bauteil: FBSAUDIC6 KSG   H27 0080
1 Fehler gefunden:
00191 - Sensor für Türaußengriffberührung Beifahrerseite (G416)
            007 - Kurzschluss nach Masse
                    Fehlerstatus: 01110111
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 100
                    Kilometerstand: 158616 km
                    Zeitangabe: 0
                    Datum: 2023.04.15
                    Zeit: 13:45:25
Adresse 06: Sitzverst. Beifah.        Labeldatei: Keine
   Teilenummer SW: 4F0 910 760     HW: 4L0 959 760
   Bauteil: Sitzmemory BFS  H01 0100
   Revision: 00000000    Seriennummer: 00000000896401
   Codierung: 0070752
   VCID: 61CE235EB896549BA4-8034
1 Fehler gefunden:
01720 - Geber für Lehnenverstellung; Beifahrersitz (G279)
            005 - keine oder falsche Grundeinstellung/Adaption
                    Fehlerstatus: 01100101
                    Fehlerpriorität: 4
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 107
                    Kilometerstand: 156868 km
                    Zeitangabe: 0
                    Datum: 2022.03.26
                    Zeit: 09:52:01
Adresse 07: Anz./Bedieneinh.        Labeldatei: DRV\4L0-910-7xx-07-H.clb
   Teilenummer SW: 4L0 910 731 L    HW: 4E0 035 729 A
   Bauteil: Interfacebox    H43 4220
   Revision: 00000000    Seriennummer: 387J+067528445
   Codierung: 0002001
   Betriebsnr.: WSC 31916 037 52109
   VCID: 316E931EA8F6A41B74-8064
   Subsystem 1 - Teilenummer: 4L0 910 609
   Bauteil: E0380 BedienteilH01 0060
   Subsystem 2 - Seriennummer: 00000000566192
   Subsystem 3 - Seriennummer: 0127.10.060000000100010079ÿ
   Subsystem 4 - Seriennummer: 010079ÿ
1 Fehler gefunden:
02849 - Steuergerät für Spurwechselassistent (J769)
            004 - kein Signal/Kommunikation - Sporadisch
                    Fehlerstatus: 00100100
                    Fehlerpriorität: 5
                    Fehlerhäufigkeit: 2
                    Verlernzähler: 145
                    Zeitangabe: 0
                    Datum: 2023.04.15
                    Zeit: 15:04:49
Adresse 08: Klima-/Heizungsel.        Labeldatei: 4L0-910-043.clb
   Teilenummer SW: 4L0 910 043     HW: 4L0 820 043 F
   Bauteil: KLIMABETAETIGUNGH05 0060
   Revision: 00---012    Seriennummer: 00000000080957
   Codierung: 0788488
2 Fehlercodes gefunden:
01592 - Sensor für Luftgüte (G238)
            014 - defekt - Sporadisch
                    Fehlerstatus: 00101110
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 132
                    Verlernzähler: 146
                    Kilometerstand: 157132 km
                    Zeitangabe: 0
                    Datum: 2022.11.27
                    Zeit: 10:50:35
                    Temperatur: 14.0°C
02508 - Geber für Kältemitteltemperatur (G454)
            010 - Unterbrechung/Kurzschluss nach Plus - Sporadisch
                    Fehlerstatus: 00101010
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 16
                    Verlernzähler: 146
                    Kilometerstand: 158379 km
                    Zeitangabe: 0
                    Datum: 2023.03.16
                    Zeit: 14:45:12
Adresse 09: Zentralelektrik        Labeldatei: DRV\4F0-910-279.lbl
   Teilenummer SW: 4F0 910 279 J    HW: 4F0 907 279 A
   Bauteil: ILM Fahrer      H17 0240
   Revision: 00000000    Seriennummer: 4F0907279
   Codierung: 0113121
   VCID: 3068961AA3FCAD137B-8064
   Subsystem 1 - Teilenummer: 4L1 910 113   Labeldatei: DRV\1KX-955-119.CLB
   Bauteil: Wischer AU716   H12 0080
   Codierung: 00064792
   Subsystem 2 - Teilenummer: 4E0 910 557 A  Labeldatei: DRV\8K0-955-559.CLB
   Bauteil: REGENLICHTSENSORH13 0090
   Codierung: 00150059
Adresse 0E: Media Player 1        Labeldatei: DRV\4E0-910-111.lbl
   Teilenummer SW: 4L0 910 110 A    HW: 4L0 035 110
   Bauteil: MP3-Changer     H43 0350
   Revision: 00043000    Seriennummer: AUZ5ZBF1012140
   Betriebsnr.: WSC 00000 000 00000
   VCID: 1D365FAEC46E307BC0-8048
Adresse 0F: Radio-Tuner (dig.)        Labeldatei: DRV\4E0-910-563.lbl
   Teilenummer SW: 4E0 910 563 C    HW: 4E0 035 563
   Bauteil: DAB-Tuner       H41 0830
   Revision: 00000001    Seriennummer: KE1276U7800236
   Codierung: 0000001
   VCID: 24406A4AE70401B38F-8070
Adresse 13: Distanzregelung        Labeldatei: DRV\4L0-910-561.clb
   Teilenummer SW: 4L0 910 561     HW: 4L0 907 561
   Bauteil: ABSTANDSREGELUNGH05 0120
   Revision: --------    Seriennummer: 00000000000000
   Codierung: 0011161
   VCID: 66C4304251B833A351-8032
Adresse 15: Airbag        Labeldatei: DRV\4L0-910-655.clb
   Teilenummer SW: 4L0 910 655 B    HW: 4L0 959 655
   Bauteil: 30 AIRBAG AUDI8RH38 0120
   Revision: 05H38000    Seriennummer: 0037GD06XJS$
   Codierung: 0013104
   VCID: 2C50826A8FD4C9F347-8078
   Subsystem 1 - Seriennummer: 6332QSME176F1753K
   Subsystem 2 - Seriennummer: 6342QSME186C440BM
   Subsystem 3 - Seriennummer: 6352QSME180824639
   Subsystem 4 - Seriennummer: 6362QSME176F0C5F$
   Subsystem 5 - Seriennummer: 63734SME15061601L
   Subsystem 6 - Seriennummer: 63834SME15032E45-
Adresse 16: Lenkradelektronik        Labeldatei: DRV\4F0-910-549.lbl
   Teilenummer SW: 4F0 910 549     HW: 4F0 953 549 A
   Bauteil: Lenksäulenmodul H08 0230
   Revision: 00H08000    Seriennummer: 90055063010087
   Codierung: 0012052
   Subsystem 1 - Teilenummer: XXXXXXXXXXX
   Bauteil: Lenkradmodul    H07 0090
Adresse 17: Schalttafeleinsatz        Labeldatei: DRV\4L0-910-xxx-17.lbl
   Teilenummer SW: 4F0 910 930 C    HW: 4L0 920 930 A
   Bauteil: KOMBIINSTR. M73 H17 0170
   Revision: 00700000    Seriennummer: 5HE587RA6
   Codierung: 2801048
   Betriebsnr.: WSC 00011 888 96745
   VCID: 23426956E20A068BF6-8076
Adresse 18: Standheizung        Labeldatei: DRV\4L0-910-105.clb
   Teilenummer SW: 4L0 910 105     HW: 4L0 265 105 F
   Bauteil: Heizgeraet      H07 0060
   Revision: 0000000E    Seriennummer: 00000009011043
   Codierung: 0000101
   VCID: 60C8265AB39C5D93AB-8034
Adresse 19: Diagnoseinterface        Labeldatei:. DRV\4L0-910-468.clb
   Teilenummer SW: 4L0 910 468     HW: 4L0 907 468 A
   Bauteil: J533__Gateway   H06 0040
   Revision: 00H06000    Seriennummer: 0800D06A088175
   Codierung: F7FFFF7F353E02
   VCID: 6CD0426A4F5409F307-8038
Adresse 28: Heizung/Klima hi.        Labeldatei: Keine
   Teilenummer SW: 4L0 910 158     HW: 4L0 919 158 D
   Revision: 00---009    Seriennummer: 00000030010844
   Codierung: 0000006
   VCID: 68D83E7A5BAC25D363-803C
1 Fehler gefunden:
01320 - Steuergerät für Climatronic (J255)
            013 - bitte Fehlerspeicher auslesen
                    Fehlerstatus: 01101101
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 100
                    Zeitangabe: 0
                    Datum: 2023.04.01
                    Zeit: 21:20:22
                        ein
Adresse 34: Niveauregelung        Labeldatei: DRV\4L0-910-553.lbl
   Teilenummer SW: 4L0 910 553 B    HW: 4L0 907 553
   Bauteil: LUFTFDR.-CDC    H03 7550
   Revision: --H03001    Seriennummer: 15.1528-0095.2
   Codierung: 0015520
   VCID: 295E7B7E8026DCDBBC-807C
7 Fehlercodes gefunden:
01437 - Regellage nicht gelernt
                    Fehlerstatus: 11100101
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 105
                    Kilometerstand: 158665 km
                    Zeitangabe: 0
                    Datum: 2023.07.06
                    Zeit: 15:13:51
                    Fehlercode: 6
01400 - Niveauregelung
            001 - oberer Grenzwert überschritten - Sporadisch
                    Fehlerstatus: 00100001
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 146
                    Zeitangabe: 0
                    Datum: 2023.07.06
                    Zeit: 15:17:14
                    Fehlercode: 66
01772 - Signalleitung von Druckgeber Niveauregelung (G291)
            009 - Unterbrechung/Kurzschluss nach Masse - Sporadisch
                    Fehlerstatus: 00101001
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 168
                    Kilometerstand: 0 km
                    Zeitangabe: 0
                    Fehlercode: 77
00774 - Geber für Fahrzeugniveau hinten links (G76)
            012 - elektrischer Fehler im Stromkreis - Sporadisch
                    Fehlerstatus: 00101100
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 168
                    Zeitangabe: 0
                    Fehlercode: 17
00775 - Geber für Fahrzeugniveau hinten rechts (G77)
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 168
                    Zeitangabe: 0
                    Fehlercode: 20
00776 - Geber für Fahrzeugniveau vorn links (G78)
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 168
                    Zeitangabe: 0
                    Fehlercode: 23
01769 - Geber für Fahrzeugniveau vorn rechts (G289)
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 168
                    Zeitangabe: 0
                    Fehlercode: 26
Adresse 36: Sitzverst. Fahr.        Labeldatei: Keine
   Bauteil: Sitzmemory FS   H01 0100
   Codierung: 0066666
Adresse 37: Navigation        Labeldatei: DRV\4E0-910-88x-37.lbl
   Teilenummer SW: 4E0 910 888 P    HW: 4E0 919 887 L
   Bauteil: MNS ECE         H48 1060
   Revision: 00000000    Seriennummer: 399J/067545622
   Betriebsnr.: WSC 00493 128 21413
   VCID: 3B72B1367ABA5E4BDE-806E
Adresse 3C: Spurwechsel        Labeldatei: DRV\4L0-910-566.clb
   Teilenummer SW: 4L0 910 566 B    HW: 4L0 907 566 A
   Bauteil: J0769_SWA_MasterH10 0130
   Revision: 00H10000    Seriennummer: 6PZ 009 014-00
   Codierung: 0010101
   Betriebsnr.: WSC 67393 141 178006
   VCID: 2D568F6EB4CEC0FB50-8078
   Subsystem 1 - Teilenummer: 4L0 910 568 A
   Bauteil: J0770_SWA_Slave_H05 0060
   Subsystem 2 - Seriennummer: 6PZ 009 014-20
   Subsystem 3 - Seriennummer: 3F24.10.0600H0500000010083ÿ
   Subsystem 4 - Seriennummer: 010083ÿ
Adresse 42: Türelektr. Fahrer        Labeldatei: DRV\4L0-910-793-42.lbl
   Teilenummer SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Bauteil: TSG FA          H12 0130
   Revision: 00-00000
   Codierung: 0019147
   VCID: 2F6A9566BEC2B2EB62-807A
Adresse 46: Komfortsystem        Labeldatei: DRV\4L0-910-289.lbl
   Teilenummer SW: 4L0 910 289 D    HW: 4L0 907 289 A
   Bauteil: Komfortgeraet   H05 0020
   Revision: 0020 ---    Seriennummer: 01021999370000
   Codierung: 7610609
   Subsystem 1 - Teilenummer: 1K0 951 605 C
   Bauteil: LIN BACKUP HORN H03 1301
   Subsystem 2 - Teilenummer: 4F0 910 177
   Bauteil: Innenraumueberw.H01 0020
Adresse 47: Soundsystem        Labeldatei: DRV\4L0-910-223-BO.lbl
   Teilenummer SW: 4L0 910 223 G    HW: 4L0 035 223 D
   Bauteil: DSP-High AU716  H03 0150
   Revision: PROD_01     Seriennummer: 00000000000955
   Codierung: 0000016
Adresse 4F: Zentralelektrik II        Labeldatei: DRV\4F0-910-280.lbl
   Teilenummer SW: 4F0 910 280     HW: 4F0 907 280 E
   Bauteil: ILM Beifahrer   H10 0080
   Revision:             Seriennummer: 00000000016747
   Codierung: 0011101
   VCID: 5EB418A289E86B6399-800A
Adresse 52: Türelektr. Beifahr.        Labeldatei: DRV\4L0-910-793-52.lbl
   Teilenummer SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Bauteil: TSG BF          H12 0130
   Revision: 00-00000
   Codierung: 0019147
Adresse 55: Leuchtweitenreg.        Labeldatei: DRV\4F0-910-357.lbl
   Teilenummer SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Bauteil: AFS 1           H01 0020
   Codierung: 0000022
   Subsystem 1 - Teilenummer: 7L6 941 329 A
   Bauteil: AFS-Modul links H06 0002
   Subsystem 2 - Teilenummer: 7L6 941 329 A
   Bauteil: AFS-Modul rechtsH06 0002
Adresse 56: Radio        Labeldatei: DRV\4E0-910-541.lbl
   Teilenummer SW: 4E0 910 541 Q    HW: 4E0 035 541 P
   Bauteil: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Seriennummer: 388J.067565034
   Codierung: 0000001
   VCID: 2E548862B9C8BBE369-807A
1 Fehler gefunden:
00856 - Antenne; am Radio
            011 - Unterbrechung
                    Fehlerstatus: 01101011
                    Fehlerpriorität: 5
                    Fehlerhäufigkeit: 35
                    Verlernzähler: 45
                    Kilometerstand: 98261 km
                    Zeitangabe: 0
                    Datum: 2013.01.18
                    Zeit: 08:51:42
Adresse 57: TV Tuner        Labeldatei: DRV\4E0-910-148.clb
   Teilenummer SW: 4E0 910 148 C    HW: 4E0 919 148
   Bauteil: R0078 TVhybridTuner 0400
   Revision: R0H06000    Seriennummer: 76300800012202
   Codierung: 0000001
00863 - Antenne 1 für TV (R55)
                    Fehlerstatus: 01101010
                    Fehlerpriorität: 5
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 45
                    Kilometerstand: 156870 km
                    Zeitangabe: 0
                    Datum: 2022.03.26
                    Zeit: 09:52:04
02283 - Videoanbindung zum Endgerät
                    Fehlerpriorität: 5
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 137
                    Kilometerstand: 158580 km
                    Zeitangabe: 0
                    Datum: 2023.03.24
                    Zeit: 16:31:39
Adresse 61: Batterieregelung        Labeldatei: DRV\4F0-910-181.lbl
   Teilenummer SW: 4L0 910 181     HW: 4L0 915 181
   Bauteil: J0644 BEM       H12 0530
   Revision: --------    Seriennummer: 00000000057891
   VCID: 64C02A4AA78441B34F-8030
   Subsystem 1 - Teilenummer: 000 915 105 CE
   Bauteil: von JCB  360918I096
   Codierung: 30303039313531303543454A434233363039313849303936
   Betriebsnr.: WSC 67393 141 100997
1 Fehler gefunden:
03041 - Energiemanagement aktiv
            000 - - - Sporadisch
                    Fehlerstatus: 00100000
                    Fehlerpriorität: 7
                    Fehlerhäufigkeit: 2
                    Verlernzähler: 255
                    Kilometerstand: 158654 km
                    Zeitangabe: 0
                    Datum: 2023.04.21
                    Zeit: 13:46:16
Adresse 62: Türelektr. hi. li.        Labeldatei: DRV\4L0-910-795.lbl
   Teilenummer SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Bauteil: TSG HL          H21 0050
   Codierung: 0018442
Adresse 65: Reifendruck        Labeldatei: 4F0-910-273-HI.lbl
   Teilenummer SW: 4F0 910 273 C    HW: 4F0 907 273 A
   Bauteil: Reifendruck 3   H05 0100
   Revision: 00050100    Seriennummer: 00000900018420
   Codierung: 0222424
Adresse 69: Anhänger        Labeldatei: DRV\4E0-910-383.lbl
   Teilenummer SW: 4E0 910 383 C    HW: 4E0 907 383 C
   Bauteil: ANHAENGERELEKTR 004 0060
   Codierung: 0000001
Adresse 6C: Rückfahrkamera        Labeldatei: DRV\4L0-910-441.clb
   Teilenummer SW: 4L0 910 441 A    HW: 4L0 907 441 A
   Bauteil: J772__Rearview      0050
   Revision: --H12---    Seriennummer: 525PA8-J6X41BF
   Codierung: 1031001
Adresse 6D: Heckklappe        Labeldatei: DRV\4L0-910-945.clb
   Teilenummer SW: 4L0 910 945     HW: 4L0 827 851 B
   Bauteil: ValeoHeckdeckel H21 0280
   Revision: --H21001    Seriennummer: E5030000B
   Betriebsnr.: WSC 98765 666 38354
   Subsystem 1 - Teilenummer: 4L0 910 946
   Subsystem 2 - Seriennummer: E5030100B
   Subsystem 3 - Seriennummer: RD27.10.06--H21001001C0221ÿ
   Subsystem 4 - Seriennummer: 1C0221ÿ
1 Fehler gefunden:
00317 - Steuergerät für Heckklappe (J605)
            008 - unplausibles Signal - Sporadisch
                    Fehlerstatus: 00101000
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 146
                    Kilometerstand: 158667 km
                    Zeitangabe: 0
                    Datum: 2023.07.08
                    Zeit: 11:48:59
Adresse 6F: Komfortsystem II        Labeldatei: DRV\4L0-910-290.lbl
   Teilenummer SW: 4L0 910 290 A    HW: 4L0 907 290 A
   Bauteil: ILM HINTEN 2    H05 0060
   Revision: AAH05061    Seriennummer: 002123289-----
   Codierung: 0003587
   VCID: 264470429138F3A391-8072
   Subsystem 1 - Teilenummer: 4L0 910 591
   Bauteil: J_245_EE15_SKB09H10 0180
   Subsystem 2 - Teilenummer: 4L0 910 591
   Bauteil: J_394_EE15_SKB09H10 0180
   Subsystem 3 - Teilenummer: 4L0 910 591
   Bauteil: J_392_EE15_SKB09H10 0180
Adresse 72: Türelektr. hi. re.        Labeldatei: DRV\4L0-910-795.lbl
   Teilenummer SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Bauteil: TSG HR          H21 0050
   Codierung: 0018442
Adresse 76: Einparkhilfe        Labeldatei: DRV\4Fx-910-283.lbl
   Teilenummer SW: 4F0 910 283 G    HW: 4F0 919 283 G
   Bauteil: Parkhilfe 8-Kan H12 0060
   Revision: 00H12000    Seriennummer: 06330629200840
   Codierung: 0231146
Adresse 77: Telefon        Labeldatei: DRV\4F1-910-336.lbl
   Teilenummer SW: 4F1 910 336 D    HW: 4F1 862 335
   Bauteil: BTA             H11 1110
   Revision: 00H11000    Seriennummer: 00000007575401
   Codierung: 1070011
   Betriebsnr.: WSC 03654 128 28888
   VCID: 2546774EEC3EF8BB98-8070
Ende----------------------------(Dauer: 04:04)-----------------------------
Second one:
Samstag,15,April,2023,13:57:38:57342
VCDS Version: DRV 22.10.0.1
Datenstand: 20221224 DS344.0
www.Ross-Tech.de
Fahrzeug-Ident.-Nr.: WAUZZZ4L47D060689   Kilometerstand: 158610km
01-Motorelektronik -- Status: i.O. 0000
07-Anz./Bedieneinh. -- Status: i.O. 0000
34-Niveauregelung -- Status: i.O. 0000
61-Batterieregelung -- Status: i.O. 0000
6D-Heckklappe -- Status: i.O. 0000
   VCID: 275A7D469632EAB5E3-8072
Readiness: 0010 0001
   Codierung: 0000504
   VCID: 030209D642CAE6959F-8056
   Revision: 00H22001
   Codierung: 0545825
   VCID: 28587E7A9B2CE5CDEA-807C
   Codierung: 0000135
   VCID: 63C22956A28A4695FF-8036
1 Fehler gefunden:
                    Fehlerstatus: 01100111
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 100
                    Zeitangabe: 0
                    Datum: 2023.04.15
                    Zeit: 13:45:25
   Codierung: 0070752
   VCID: 61CE235EB8965485ED-8034
1 Fehler gefunden:
                    Fehlerpriorität: 4
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 100
                    Zeitangabe: 0
                    Datum: 2022.03.26
                    Zeit: 09:52:01
   Codierung: 0002001
   VCID: 316E931EA8F6A4053D-8064
   Codierung: 0788488
            014 - defekt
                    Fehlerstatus: 01101110
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 111
                    Verlernzähler: 100
                    Zeitangabe: 0
                    Datum: 2022.11.27
                    Zeit: 10:50:35
                    Temperatur: 14.0°C
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 14
                    Verlernzähler: 136
                    Zeitangabe: 0
                    Datum: 2023.03.16
                    Zeit: 14:45:12
   Codierung: 0113121
   VCID: 3068961AA3FCAD0D32-8064
   Codierung: 00064792
   Codierung: 00150059
   VCID: 1D365FAEC46E306589-8048
   Codierung: 0000001
   VCID: 24406A4AE70401ADC6-8070
   Codierung: 0011161
   VCID: 66C4304251B833BD18-8032
Adresse 15: Airbag        Labeldatei: DRV\4L0-910-655.lbl
   Codierung: 0013104
   VCID: 2C50826A8FD4C9ED0E-8078
   Codierung: 0012052
   Codierung: 2801048
   VCID: 23426956E20A0695BF-8076
   Codierung: 0000101
   VCID: 60C8265AB39C5D8DE2-8034
   VCID: 6CD0426A4F5409ED4E-8038
   Codierung: 0000006
   VCID: 68D83E7A5BAC25CD2A-803C
1 Fehler gefunden:
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 100
                    Zeitangabe: 0
                    Datum: 2023.04.01
                    Zeit: 21:20:22
                        ein
   Codierung: 0015520
   VCID: 295E7B7E8026DCC5F5-807C
1 Fehler gefunden:
01577 - Abschaltung durch Übertemperatur
                    Fehlerstatus: 11100001
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 100
                    Zeitangabe: 0
                    Datum: 2023.04.15
                    Zeit: 13:55:08
                    Fehlercode: 68
   Codierung: 0066666
   VCID: 3B72B1367ABA5E5597-806E
   Codierung: 0010101
   VCID: 2D568F6EB4CEC0E519-8078
   Revision: 00-00000
   Codierung: 0019147
   VCID: 2F6A9566BEC2B2F52B-807A
   Codierung: 7610609
   Codierung: 0000016
   Codierung: 0011101
   VCID: 5EB418A289E86B7DD0-800A
   Revision: 00-00000
   Codierung: 0019147
   Codierung: 0000022
   Codierung: 0000001
   VCID: 2E548862B9C8BBFD20-807A
1 Fehler gefunden:
            011 - Unterbrechung
                    Fehlerpriorität: 5
                    Verlernzähler: 45
                    Zeitangabe: 0
                    Datum: 2013.01.18
                    Zeit: 08:51:42
   Codierung: 0000001
                    Fehlerpriorität: 5
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 45
                    Zeitangabe: 0
                    Datum: 2022.03.26
                    Zeit: 09:52:04
                    Fehlerpriorität: 5
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 137
                    Zeitangabe: 0
                    Datum: 2023.03.24
                    Zeit: 16:31:39
   VCID: 64C02A4AA78441AD06-8030
   Codierung: 0018442
   Codierung: 0222424
   Codierung: 0000001
   Codierung: 1031001
   Codierung: 0003587
   VCID: 264470429138F3BDD8-8072
   Codierung: 0018442
   Codierung: 0231146
   Codierung: 1070011
   VCID: 2546774EEC3EF8A5D1-8070
Ende----------------------------(Dauer: 03:48)-----------------------------
Hope this helps.
Best regards,
Ansgar
Sure, it's here:
Ignore the fact that the screen-shots are really old; your suspension should work just like that.
Clear the faults in the module first.
Also, do a reality check of the height sensors in the Measuring Blocks of the module. Get someone to rock each corner up and down while you observe the values.
Reactions: TTT
