- Feb 25, 2014
- 2,564
- 4,146
- Cincinnati, OH
- C?ID=25607
I own this car and usually have good access to it, but it happens to be waiting for some engine work at my dealer. Starting Wednesday morning it's going to be in pieces for a couple weeks. I could run another quick test tomorrow if needed, but anything that can't be run by tomorrow would have to wait a while.
All of my testing was done with Beta 14.4.2/CB 4100. The car was parked with the engine running at idle. You will see a ton of no-communications DTCs because the dealer let the left-side battery go flat a couple times during diagnostics. My experience seems to line up with invisiblewave on his separate Auto-Scan thread.
Things I noticed:
When I have more time with the car, I will try out HEX-NET ECU turbo and address 31 support, as well as Generic OBD2 which I didn't have a chance to try at all today.
Baseline scan with HEX-USB+CAN:
Scan with HEX-NET using VCDS Desktop/USB:
Scan with HEX-NET using VCDS Desktop/Wifi:
Scan with HEX-NET using VCDS Mobile - Aborted:
Things I noticed:
- Address 01/11/31: Engine ECUs, Turbo Mode: I only had time to test this on HEX-USB+CAN, but huge progress in Beta 14.4.2! This was almost completely unusable before via any address. It looks like I can reliably switch to Turbo Mode on Address 01 (Engine 1) and Address 31 (Other/Combined). Curiously, I cannot shift to Turbo Mode on Address 11 (Engine 2). Since the car is technically in the dealer's custody right now I only had a little time and I couldn't drive it around and do extensive logging.
- Address 31: Engine Other, MVB flipping: Looks like this is fixed in Beta 14.4.2! However, as with Turbo Mode above, I was only able to bang on it for a few minutes with my HEX-USB+CAN.
- Address 07: Control Head: HEX-NET breaks down trying to talk to this device in any mode. It is the driver-facing "radio" in the Phaeton, and as many VW radios do, there's an indication on the screen when a diag session is up. This diag indicator was stuck-on indefinitely after the HEX-NET comms failures. I'm not sure whether Desktop or Mobile first triggered it. It only went away when I manually opened and closed a diag session with my HEX-USB+CAN interface. This module has always had some unique behavior in VCDS and it is very slow to respond to certain requests.
- Address 37: Navigation: Same deal as address 07, except there is no diag session-in-progress indicator to see. The infotainment and navigation computers are separate physical devices, but made by the same company and share some of the same firmware. A change that fixes address 07 communication seems quite likely to fix address 37 as well.
- Address 03: ABS Brakes: It looks like HEX-NET in VCDS Mobile mode ran into trouble. Desktop USB and Wifi were okay. I didn't notice that problem until after I got home, so I wasn't able to try replicating it or connecting to that module manually.
- VCDS Mobile might have given my Phaeton a wedgie: [edit: VCDS Mobile got hung up on address 07 and could not move on, but the other strangeness I experienced was probably unrelated to VCDS Mobile]
Monday,21,April,2014,17:21:51:05280
VCDS Version: 14.4.2.0 (x64)
Data version: 20140411
VIN: WVWAK03D868005728 License Plate: 2006PHAETON
Mileage: 120650km-74968mi Repair Order: HEX-USB+CAN
Chassis Type: 3D (3D - VW Phaeton (2002 > 2006))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 27 28 29 2E
34 36 37 38 39 46 47 55 56 57 65 66 68 69 71 75 76 77
VIN: WVWAK03D868005728 Mileage: 120650km-74968miles
Address 01: Engine Labels: 07C-906-018-BAP1.lbl
Part No SW: 07C 906 018 AJ HW: 000 000 000 00
Component: D1-6.0L-AT-LEV2 G ª6722
Revision: --H01--- Serial number: VWZ3Z0F7470400
Coding: 0000173
Shop #: WSC 01065 000 00000
VCID: 6DDBB2F477855E538C-5120
Readiness: 0110 1001
Address 02: Auto Trans Labels: 3D0-927-156.lbl
Part No: 3D0 927 156 AB
Component: AG5 01L 6.0lW12 USA 1010
Coding: 0000002
VCID: 68D5C3E058677B7BFF-513C
Address 03: ABS Brakes Labels: 3D0-614-517.lbl
Part No: 3D0 614 517 AK
Component: ESP 5.7 allrad H33 0047
Coding: 0008397
VCID: 6BDFBCEC4991506392-5120
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 C HW: 5WK 484 97
Component: G1 Kessy 6700
Revision: 67006015 Serial number: VWZ3Z0F7470400
Coding: 0213228
VCID: 275780DC95F9B40336-5120
Component: ELV XXXX
00087 - Terminal 30 for Starting Relevant Consumers
Address 06: Seat Mem. Pass Labels: 3D0-959-759.lbl
Part No: 3D0 959 759 CA
Component: Sitzmemory D1 BF 1720
Coding: 0000003
VCID: 77F7909C05D9E48366-5120
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3D0 035 008 Q
Component: ZAB COCKPIT 0253
Coding: 0500345
VCID: 285583E098E7BB7B3F-5120
Address 08: Auto HVAC Labels: 3D0-907-040.lbl
Part No: 3D0 907 040 J
Component: Climatronic D1 2031
Coding: 0000002
VCID: 254B8AD4EFF5A61304-5120
Address 09: Cent. Elect. Labels: 3D0-937-049-V1.clb
Part No: 3D0 937 049 H
Component: STG.Bordnetz 5101
Coding: 0000003
Shop #: WSC 02605 444 64790
VCID: 2F6768FCBD09EC43FE-5120
Address 11: Engine II Labels: 07C-906-018-BAP2.lbl
Coding: 0000173
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 H
Component: 04 Airbag 8.4E++H01 0554
Revision: BB38727 Serial number: 0006635<
Coding: 0012340
Subsystem 1 - Part No: 3D0 959 339
Component: BF-Gewichtsens. 006 0005
Date: 2064.00.00
Address 16: Steering wheel Labels: 3D0-953-549.lbl
Part No: 3D0 953 549 E
Component: Lenksäulenmodul 3401
Coding: 0000232
Address 17: Instruments Labels: 3D0-920-xxx-17.lbl
Part No: 3D0 920 982 B
Component: KOMBIINSTRUMENT RB8 0521
Coding: 0005221
01336 - Data Bus for Comfort System
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70E5AB8060B7B3BBA7-5120
Address 28: HVAC, Rear Labels: 3D0-919-158.lbl
Part No: 3D0 919 158 F
Component: Klima-Bedienteil D1 0117
VCID: 2E5975F8BA03E54BF5-5120
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) 0001
Coding: 0000001
VCID: 66C9CDD852736D0BCD-5102
Address 34: Level Control Labels: 3D0-907-553-V2.clb
Part No: 3D0 907 553 C
Component: LUFTFDR.-CDC- 3C3V0 1122
Coding: 0005531
Shop #: WSC 53212 053 999999
013 - Check DTC Memory
Address 36: Seat Mem. Drvr Labels: 3D0-959-760.lbl
Part No: 3D0 959 760 CA
Component: Sitzmemory D1 F 1720
Coding: 0000004
VCID: 6FE7A8FC7D89AC43BE-5120
Address 37: Navigation Labels: 3D0-919-887.lbl
Part No: 3D0 919 887 F
Component: NAVIGATION 0188
Coding: 0400000
VCID: 3777509C45592483A6-5120
Address 38: Roof Electronics Labels: 3D0-907-135.lbl
Part No: 3D0 907 135 C
Component: Dachmodul 0708
Coding: 0000015
VCID: 234F94CCE1C158236A-5120
00220 - Connection to Sunroof
00926 - Terminal 30
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
Coding: 0000001
VCID: 67D7C0DC55797403F6-5102
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 3D0 959 933 F
Component: X3 HSG 0102
Coding: 0000040
Shop #: WSC 03325 444 13946
VCID: 336F648C5121C8A39A-4AE6
Subsystem 1 - Part No: 3D1 959 701 L
Component: Tuersteuergeraet FS 6001
Subsystem 2 - Part No: 3D1 959 702 L
Component: Tuersteuergeraet BF 6001
Subsystem 3 - Part No: 3D0 959 703 K
Component: Tuersteuergeraet HL 6001
Subsystem 4 - Part No: 3D0 959 704 K
Component: Tuersteuergeraet HR 6001
Subsystem 5 - Part No: 3D0 909 610 C
Component: 3L HDSG 2330
Subsystem 6 - Part No: 7L0 907 719 A
Component: Neigungssensor 0020
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3D0 035 466 A
Component: 12K-AUDIOVERST 0118
VCID: 20459BC0F0D7433B77-5120
Address 65: Tire Pressure Labels: None
Part No: 3D0 907 273 D
Component: Reifendruckueberw. 0025
Coding: 0411224
00003 - Control Module
014 - Defective - MIL ON
Address 68: Wiper Electr. Labels: 3D1-955-119.lbl
Part No: 3D1 955 119 A
Component: Front Wiper 2005
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 D
Component: Batteriemanagement 2800
VCID: 244D97D0E4CF5F1B13-5120
Address 76: Park Assist Labels: 3D0-919-283.lbl
Part No: 3D0 919 283 D
Component: 03 Einparkhilfe 0907
VCID: 2B5F7CEC89119063D2-5120
00434 - Left Front Inner Parking Aid Sensor (G332)
006 - Short to Plus - Intermittent
End ---------------------------------------------------------------------
Monday,21,April,2014,17:41:10:21122
Mileage: 120650km-74968mi Repair Order: HEX-NET-USB
Coding: 0000173
VCID: 6D9208DC77C37C538C-5184
Readiness: 0110 0001
Coding: 0000002
VCID: 689C79C85821597BFF-5184
Coding: 0008397
VCID: 6B9606C449D7726392-5184
Coding: 0213228
VCID: 271E3AF495BF960336-5184
Component: ELV XXXX
Coding: 0000003
VCID: 77BE2AB4059FC68366-5184
Address 07: Control Head Labels: None
VCID: 55E2403CBF53D49354-5184
No Faults Found
Coding: 0000002
VCID: 250230FCEFB3841304-5184
Coding: 0000003
VCID: 2F2ED2D4BD4FCE43FE-5184
Coding: 0000173
Coding: 0012340
VCID: 281C39C898A1997B3F-5184
Date: 2064.00.00
Coding: 0000232
Coding: 0005221
Coding: 0000006
VCID: 70AC11A860F191BBA7-5184
VCID: 2E10CFD0BA45C74BF5-5184
Coding: 0000001
VCID: 668077F052354F0BCD-5160
Coding: 0005531
Coding: 0000004
VCID: 6FAE12D47DCF8E43BE-5184
Address 37: Navigation Labels: None
No Faults Found
Coding: 0000015
VCID: 23062EE4E1877A236A-5184
00926 - Terminal 30
Coding: 0000001
VCID: 679E7AF4553F5603F6-5160
Coding: 0000040
VCID: 3326DEA45167EAA39A-4B3C
VCID: 200C21E8F091613B77-5184
Coding: 0411224
VCID: 24042DF8E4897D1B13-5184
No Faults Found
VCID: 2B16C6C48957B263D2-5184
Monday,21,April,2014,18:04:11:21122
Mileage: 120650km-74968mi Repair Order: HEX-NET-Wifi
Coding: 0000173
VCID: ED9288DCF7C3FC530C-5184
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Fault Status: 01101000
Mileage: 120658 km
RPM: 372 /min
Load: 69.8 %
Temperature: 103.0°C
Temperature: 48.0°C
Absolute Pres.: 980.0 mbar
Voltage: 11.938 V
Readiness: 0010 0001
Coding: 0000002
VCID: E89CF9C8D821D97B7F-5184
Coding: 0008397
VCID: EB9686C4C9D7F26312-5184
Coding: 0213228
VCID: A71EBAF415BF1603B6-5184
Component: ELV XXXX
Coding: 0000003
VCID: F7BEAAB4859F4683E6-5184
VCID: D5E2C03C3F535493D4-5184
No Faults Found
Coding: 0000002
VCID: A502B0FC6FB3041384-5184
Coding: 0000003
VCID: AF2E52D43D4F4E437E-5184
Coding: 0000173
049408 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 - 004 - - Intermittent
Mileage: 120658 km
RPM: 561 /min
Load: 17.2 %
Temperature: 104.0°C
Temperature: 51.0°C
Voltage: 13.208 V
Coding: 0012340
VCID: A81CB9C818A1197BBF-5184
Date: 2064.00.00
Coding: 0000232
Coding: 0005221
Coding: 0000006
VCID: F0AC91A8E0F111BB27-5184
VCID: AE104FD03A45474B75-5184
Coding: 0000001
VCID: E680F7F0D235CF0B4D-5160
Coding: 0005531
Coding: 0000004
VCID: EFAE92D4FDCF0E433E-5184
No Faults Found
Coding: 0000015
VCID: A306AEE46187FA23EA-5184
00926 - Terminal 30
Coding: 0000001
VCID: E79EFAF4D53FD60376-5184
Coding: 0000040
VCID: B3265EA4D1676AA31A-4B3C
VCID: A00CA1E87091E13BF7-5184
Coding: 0411224
VCID: A404ADF86489FD1B93-5184
No Faults Found
VCID: AB1646C40957326352-5184
VCDS Mobile 0.41.0.4
Chassis Type:3D
Scan:
Address 01: Engine Labels:07C-906-018-BAP1.lbl
Part Number SW: 07C-906-018-AJ HW: 00000000000
Revision: --H01--- Serial Number: VWZ3Z0F7470400
Coding: 0000173
VCID: 6D9D5AB724BAEFBAC06C-5184
No fault codes found.
Address 02: Auto Trans Labels:3D0-927-156.lbl
Part Number SW: 3D0-927-156-AB
Coding: 0000002
VCID: 68932BA30B58CA92B33A-5184
Address 03: ABS Brakes Labels:None
Part Number SW:
Component:
Shop #: WSC 00000 000
VCID: 55ED1257AC2AC77A187C-5184
Address 05: Acc/Start Auth. Labels:3D0-909-13x-05.lbl
Part Number SW: 3D0-909-137-C HW: 5WK48497ÿ’
Revision: 67006015 Serial Number: VWZ3Z0F7470400
Coding: 0213228
VCID: 2711689FC6C605EA7AA0-5184
Subsystem 1 - Part Number: XXX-XXX-XXX-XX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels:3D0-959-759.lbl
Part Number SW: 3D0-959-759-CA
Coding: 0000003
VCID: 77B178DF56E6556A2A80-5184
Address 07: Control Head Labels:None
Part Number SW:
Component:
