VW SHARAN 2007 A/C Problem
andreistefan
Buzau, Romania
C?ID=435804
Hi,
I am working to repair an A/C on a 2007 Vw Sharan Diesel engine. Car came with Condenser and A/C Compressor damaged. All was changed with new parts(Condenser, compressor, A/C refrigerant sensor), all pipes/hoses proper cleaned. On idle all is working fine, but if you hit the gas pedal, on 2200-2300rpm, A/C compressor shuts down and is going back On only on idle.
All wiring is checked from A/C sensor, all fuses are ok, evaporator sensors seems ok, I removed them from the body of the vents, because I could not find replacement ones and I wanted to be sure they do not read a too low temperature. Installation is having 2 x evaporators, so 1050grams of R134 gas was added.
For 2 days, only errors were on Engine Ecu 001330 - A/C Refrigerant Pressure Sensor (G65) P0532 - 000 - Short to GND - Intermittent, from today it appear on HVAC module 1 Fault Found: 01086 - Speedometer Sensor (G22) 35-00 - -.
you can find below full reading.
Any help will be appreciated.
Thanks!
Monday,03,July,2023,18:24:41:48877
VCDS Version: 23.3.1.0 (x64)  HEX-NET2 CB: 0.4631.5
Dealer/Shop Name: Retrofit Buzau
VIN: WVWZZZ7MZ7V016531   License Plate: BE22BYL03072023
Mileage: 208330km-129450mi   Repair Order:
Chassis Type: 7M (7M - VW Sharan (1996 > 2010))
Scan: 25 01 02 03 08 09 15 16 17 18 19 22 29 35 36 37 39 45 55 56
          76
VIN: WVWZZZ7MZ7V016531   Mileage: 208330km-129450miles
Address 25: Immobilizer        Labels: 7M3-953-257.lbl
   Part No: 7M3 953 257
   Component: IMMO                0008
   Coding: 00003
   VCID: F6BE0CE111DC536AA57-4B00
   WVWZZZ7MZ7V016531     VWZ1Z0F2892783
   Part No SW: 03G 906 016 JP    HW: 03G 906 016 JP
   Component: R4 2,0L EDC G000SG  9771
   Revision: --H02---    Serial number: VWZ1Z0F2892783
   Coding: 0000072
   Shop #: WSC 04049 202 180626
   VCID: FAA618D120C4370AC1F-51A8
   VINID: 9E69EAAAA1DDA8798004614304E8D57EB2
                    Fault Frequency: 15
                    Mileage: 208331 km
                    Voltage: 12.31 V
                    Bin. Bits: 11001100
                    Temperature: 71.1°C
                    (no units): 16.0
005705 - Powertrain Data Bus
               P1649 - 000 - Missing Message from ABS Controller - Intermittent
                    Mileage: 208331 km
                    Voltage: 11.93 V
                    Bin. Bits: 11001100
                    Torque: 0.0 Nm
                    Bin. Bits: 00000000
Address 03: ABS Brakes        Labels: 7M3-907-37x-ESP-F.clb
   Part No: 7M3 907 379 E
   Component: ESP FRONT MK25      0102
   Coding: 0006154
   Shop #: WSC 00020 000 00000
   VCID: BFD0A9C57B66D222B61-513C
Address 08: Auto HVAC        Labels: 7M3-907-040.clb
   Part No: 7M3 907 040 J
   Component: CLIMATRONIC MPV GP  0007
   Coding: 00031
   Shop #: WSC 00020
   VCID: B53CCBED4C5A18726CD-2596
            35-00 - -
Address 09: Cent. Elect.        Labels: 7M3-962-258.lbl
   Part No: 7M3 962 258 BB
   Component:    Multifunkt.Einh  0004
   Coding: 04121
   Shop #: WSC 00020
   VCID: FBA81DD52AFE0E02DA9-508A
            49-00 - No Communications
01148 - Activation of Safety/Deadbolt Locks in Doors
01149 - Deactivation of Safety/Deadbolt Locks in Doors
            28-10 - Short to Plus - Intermittent
   Part No: 1C0 909 605 F
   Component: 2G AIRBAG VW61 0Q0M 0003
   Coding: 12871
   Shop #: WSC 00020
   VCID: A70011A586F67AE2EE1-50F4
   Part No: 1J0 907 487 D
   Component: Lenkradelektronik   0002
   Coding: 00008
   Shop #: WSC 00020
   VCID: B236F0F1BD340F4A49F-5160
Address 17: Instruments        Labels: 7Mx-920-xxx-17.lbl
   Part No: 7M3 920 840 T
   Component: KOMBIINSTRUMENT VDO V66
   Coding: 29111
   Shop #: WSC 00006
   VCID: C2D6A0310D94BFCAD9F-50F4
            30-00 - Open or Short to Plus
Address 18: Aux. Heat        Labels: 7M3-815-071.clb
   Part No: 7M3 815 071 G
   Component: HEIZG. B/D5W       0001
   VCID: B43AF6E94720017A5B3-513C
01409 - Repeated Flame-Out
            35-00 - -
            35-00 - -
            00-00 - -
            35-00 - -
            00-00 - -
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00020
   VCID: F0B23AF973B87D5A7FB-50F4
Address 29: Left Light        Labels: 7M3-907-391-29.lbl
   Part No: 7M3 907 391
   Component: EVG GDL + AutoLWR   0003
   Coding: 00005
   Shop #: WSC 00020
   VCID: F4BA36E907A0417A9B3-4B9A
Address 37: Navigation        Labels: 3B0-919-887.lbl
   Part No: 3B0 919 887 E
   Component: Navigation     BNO 0304
   Coding: 00002
   Shop #: WSC 00020
   VCID: B43AF6E94720017A5B3-4AE0
Address 39: Right Light        Labels: 7M3-907-391-39.lbl
   Coding: 00005
   VCID: F4BA36E907A0417A9B3-4B7A
Address 56: Radio        Labels: 3B0-035-186.lbl
   Part No: 3B0 035 186 D
   Component: Radio          BNO 0304
   Coding: 08407
   Shop #: WSC 00020
   VCID: A0120AB9E3D88DDAAFB-4AE0
00852 - Loudspeaker(s); Front
            36-00 - Open Circuit
00853 - Loudspeaker(s); Rear
            36-10 - Open Circuit - Intermittent
Address 76: Park Assist        Labels: 7M3-919-283.clb
   Part No: 7M3 919 283
   Component: Parkingsyst. SH RDW D02
   Coding: 00117
   Shop #: WSC 00020
   VCID: F7A001E516D62A62BE1-513C
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
            37-00 - Faulty
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
            37-00 - Faulty
01548 - Sensor for Parking Aid; Rear Right (G206)
            37-00 - Faulty
End----(Elapsed Time: 03:45, VBatt start/end: 12.4V/12.4V. VIgn 0.0V)------
TTT
C?ID=547002
Well, obvious you should focus on the pressure sensor. How many wires it has. Identify which ones are the supply, ground and signal and start measuring.
Dr Sheldon
Windsor UK
C?ID=334979
You come across as a dangerous !!
So you added 1050g of R134
And removed sensors
What you have done is wrong and Dangerous !!
I'm by no means an A/C expert, but wouldn't one do that by checking measuring blocks in the module and comparing the readings with a thermometer?
