- Aug 21, 2020
- 45
- 0
- Sweden
- C?ID=161058 (NRRT)
Sent the DPf for professional cleaning. Was not much soot but the flow was restricted by "Eolys/Cerium" . the diagnose is due the colour of waste that was brownish/redisch , not black.
Before cleaning pressure/flow was 120 mbar / 94 m3/h and after cleaning 35/498 so the status of the DPF was good.
Installed DPF in car and reseted the learned DPF values and dif. pres. offset . All values went to zero.
All fault codes was reseted. and symboles in dash went away.
Drove 6 km , checked dif.pressure values . Idle about near zero and att 2000r/m just below 40
Then tried to start an manual regeneration . "Cant start regereneration due safety reasons"
Falult codes now comes back instant and "glow" symbol flashing
Soot values and dif.pres. at idle has increased a lot .
What is making soot values increase so quick ? and wy cant the the manuel reset start , and wy is now fault codes and "glow" symbol back ?
Wednesday,14,August,2024,10:19:44:38398
VCDS Version: 24.7.0.0 (x64)
VIN: WAUZZZ4G7JN070847 License Plate: ZBH510
Address 01: Engine Labels: 059-907-401-V2.clb
Control Module Part Number: 4G0 907 589 F HW: 4G0 907 589 B
Component and/or Version: 3.0BTD EDC17 H23 0008
Software Coding: 322A403A25760B030000
Work Shop Code: WSC 40616 001 1048576
ASAM Dataset: EV_ECM30BTD0114G0907589F 001008 (AU57)
ROD: EV_ECM30BTD0114G0907589F_001.rod
VCID: 374513578ED87A2E32-8062
5188 - Particle Filter
P2463 00 [10101111] - Excessive Soot Accumulation
Mileage: 126748 km
Date: 2024.08.14
Time: 10:08:31
Engine RPM: 1368.00 /min
Normed load value: 26.3 %
Coolant temperature: 76 °C
Intake air temperature: 27 °C
Voltage terminal 30: 14.400 V
P Flt Ld fac Ash Cor: 1.0000
Particul.filter diff.pressure: 13 hPa
Exh t Adap T Oxi Cat Ds: 203.6 °C
Exh t Adap TP Flt Ds: 193.2 °C
Current operating mode_2-Bits 0-7: 0
Current operating mode_2-Bits 0-7: 142
5189 - Particulate Trap Bank 1
P2002 00 [10101111] - Efficiency Below Threshold
Mileage: 126748 km
Date: 2024.08.14
Time: 10:08:31
Ambient temperature: 20.5 °C
DPF: offset for differential pressure: -2 hPa
Particle filter: soot mass measured: 2.25 g
Particle filter: soot mass calculated: 26.10 g
Particle filter: kilometers since last regeneration: 5898 m
Particle filter field regeneration: cancel conditions-Bits 0-7: 0
Readiness: 1 2 0 0 1
Address 01: DTCs cleared
Address 01: Engine (4G0 907 589 F)
10:21:58
IDE00427 Particle filter: difference pressure 13 hPa
IDE00433 Particle filter: oil ash volume 0.00 l
IDE00434 Particle filter: soot mass calculated 26.17 g
IDE00435 Particle filter: soot mass measured 2.33 g
