- Feb 25, 2014
- 2,780
- 4,490
- Cincinnati, OH
- C?ID=25607
I do not own this car. It's a loaner from my dealer while my Phaeton is being worked on. I expect to have access to it for about two more weeks if follow-up testing is needed.
All of my testing was done with Beta 14.4.2/CB 4100. The car was parked with the engine running at idle.
Things I noticed:
Baseline scan with HEX-USB+CAN:
Scan with HEX-NET using VCDS Desktop/USB:
Scan with HEX-NET using VCDS Desktop/Wifi:
Scan with HEX-NET using VCDS Mobile:
Things I noticed:
- Address B8: Elect. Roof 2 (J256): HEX-NET seems uninterested in talking to this module in any mode. It's seen in the gateway installation list, but does not appear in the Auto-Scan, even to note the failure (except on VCDS Mobile). I tried to connect to it manually with VCDS Desktop and was immediately rejected. Unfortunately I forgot to make note of the error message.
- Address B9: Aux. Display (J285): Same deal as address B8 above.
Monday,21,April,2014,13:23:29:05280
VCDS Version: 14.4.2.0 (x64)
Data version: 20140411
VIN: 3VW7T7AT2DM833144 License Plate: 2014BEETLE
Mileage: 610km-379mi Repair Order: HEX-USB+CAN
Chassis Type: AT (6R0)
Scan: 01 02 03 05 08 09 15 17 19 25 26 2B 2E 44 47 56 77 B8 B9
VIN: 3VW7T7AT2DM833144 Mileage: 610km-379miles
B8-Elect. Roof 2 -- Status: OK 0000
B9-Aux. Display -- Status: OK 0000
Address 01: Engine (J623-CPPA) Labels: None
Part No SW: 06K 906 070 C HW: 06K 907 425
Component: Simos12.2 H09 5790
Revision: --H09--- Serial number: 00000000000000
Coding: 001D0012242400171000
Shop #: WSC 00066 000 00070
ASAM Dataset: EV_ECM20TFS02006K906070C 001008
ROD: EV_ECM20TFS02006K906070C.rod
VCID: 2A5179E84DEB896B29-807F
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 058 G HW: 02E 927 770 AL
Component: GSG DSG AG6 521 3508
Revision: 05652104 Serial number: 00001304300301
Shop #: WSC 00066 000 00000
VCID: 1E39A538C9A375CB45-804B
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5C0 907 379 C HW: 5C0 907 379 C
Component: ESP MK60EC1 H31 0156
Revision: 00H31001
Coding: F14B6016492500FD8F0C06E8921D0041A71800
VCID: 2E5975F87903E54BF5-807B
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Revision: 00086000 Serial number: 0193329970
Coding: 030C0C
ASAM Dataset: EV_KESSYPQ35G A02715
ROD: EV_KESSYPQ35G.rod
VCID: 346D67909F2FCF9B83-8061
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 BC HW: 5C0 820 047 BC
Component: J301 Klimaanlage 0204
Revision: 2001111S Serial number: 00000001635446
VCID: 62C1D1C8BD5B112B21-8037
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 088 G HW: 6R0 937 088 A
Component: BCM PQ25 Re3 H50 0353
Revision: BT050001 Serial number: 04551162130171
Coding: 3BBC6918088B080000F83930640984C5ADC2620F60844C51B2A004000000
VCID: 42813148DD9B712B01-8017
Subsystem 1 - Part No SW: 6R0 959 801 AP HW: 6R0 959 801 AP Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 1070
Coding: 8CBC30
Subsystem 2 - Part No SW: 6R0 959 802 BC HW: 6R0 959 802 BC Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 1070
Coding: 8CBC30
Subsystem 3 - Part No SW: 5C0 959 442 C HW: 5C0 959 442 C
Component: E221__MFL-YVJ H02 0103
Coding: E30000
Subsystem 4 - Part No SW: 5C3 959 811 B HW: 5C3 959 811 B
Component: J388__TSG_HL 006 1046
Coding: 800000
Subsystem 5 - Part No SW: 5C3 959 812 B HW: 5C3 959 812 B
Component: J389__TSG_HR 006 1046
Coding: 800000
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 P HW: 5C0 959 655 P
Component: AirbagVW10 302 0931
Serial number: 003LJD00XV4
Coding: 00004E45
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3F8738BCA6691CC36E-806A
Serial number: 6940000Y130000UNFR0N
Coding: 30304C
Serial number: 3572MSME35340479ZZZS
Serial number: 3582MSME30391379ZZZT
Subsystem 4 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME48215523ZZZO
Crash sensor for front airbag; passenger side:
Subsystem 5 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME351A5523ZZZT
Part No SW: 5C5 920 970 F HW: 5C5 920 970 F
Component: KOMBI H24 0103
Revision: X0024005 Serial number:
Coding: 251E01
Shop #: WSC 00066 000 00126
ASAM Dataset: EV_KombiUDSMM9RM10 A04712
ROD: EV_KombiUDSMM9RM10_SE12.rod
VCID: 2E5975F87103E54BF5-807B
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6R0 907 530 F HW: 1K0 907 951
Component: J533 Gateway H39 0042
Revision: H39 Serial number: 15061303300689
Coding: 255080
VCID: 36695D988153DD8BBD-8063
Part No SW: 5K0 953 234 HW: 5C5 920 970 F
Component: IMMO H24 0103
Coding: 000007
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
ROD: EV_ImmoUDSMM9RM10_SE36.rod
VCID: 6AD1B9E88D6B496BE9-803F
Address 26: Auto Roof (J256) Labels: None
Part No SW: 5C3 871 601 HW: 5C3 871 601
Component: VSG-MASTER 015 0344
ASAM Dataset: EV_VSGWEBASVW36X 005002
ROD: EV_VSGWEBASVW36X.rod
VCID: 62C1D1C8755B112B21-8037
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 13000052868002
Coding: 4900000000000000
Shop #: WSC 00066 790 50316
ROD: EV_ELVMarquMPVW36X.rod
VCID: 30656B806B37F3BBE7-8065
Address 2E: Media Player 3 (J650) Labels: None
Part No SW: 5C3 035 342 HW: 5C3 035 342
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664520274
Coding: 010100
VCID: 5CBDEF305F3F27DB6B-8009
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 3777509C46592483A6-8062
Address 47: Sound System (R12) Labels: 3T0-035-456.clb
Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
Component: KonzernAmp10K H07 6813
Revision: -------- Serial number: EAA098A0051977
ROD: EV_AudioVerst10KanalSTT3.rod
VCID: 26498DD859F3AD0B0D-8073
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AF HW: 1K0 035 180 AF
Component: Radio Prem-8 H05 0008
Revision: -----09S Serial number: VWZ4Z7N3472883
Coding: 01020000010003
VCID: 64CDD7D0674F1F1BD3-8031
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664737408
Coding: 0A10040000010110
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3A7149A8BD4B39EB59-806F
Address B8: Elect. Roof 2 (J256) Labels: None
Component: VSG-SLAVE 015 0344
ASAM Dataset: EV_VSG2WEBASVW36X 005002
ROD: EV_VSG2WEBASVW36X.rod
Address B9: Aux. Display (J285) Labels: 5C5-919-527.clb
Part No SW: 5C5 919 527 D HW: 5C5 919 527 D
Component: ZUSATZANZEIGE H13 0014
Coding: 05
ASAM Dataset: EV_Auxi_Disp_Unit_UDS_VDD 001007
ROD: EV_Auxi_Disp_Unit_UDS_VDD.rod
VCID: 32616188653BC1AB91-8067
End ---------------------------------------------------------------------
Monday,21,April,2014,14:05:35:21122
Mileage: 610km-379mi Repair Order: HEX-NET
VCID: 2A18C3C04DADAB6B29-807F
VCID: 1E701F10C9E557CB45-804B
Revision: 00H31001
VCID: 2E10CFD07945C74BF5-807B
Coding: 030C0C
VCID: 3424DDB89F69ED9B83-8061
VCID: 62886BE0BD1D332B21-8037
VCID: 42C88B60DDDD532B01-8017
Coding: 8CBC30
Coding: 8CBC30
Coding: E30000
Coding: 800000
Coding: 800000
Coding: 00004E45
VCID: 3FCE8294A62F3EC36E-806A
Coding: 30304C
Coding: 251E01
VCID: 2E10CFD07145C74BF5-807B
Coding: 255080
VCID: 3620E7B08115FF8BBD-8063
Coding: 000007
VCID: 6A9803C08D2D6B6BE9-803F
VCID: 62886BE0751D332B21-8037
VCID: 302CD1A86B71D1BBE7-8065
Coding: 010100
VCID: 5CF455185F7905DB6B-8009
Revision: 00H22000
VCID: 373EEAB4461F0683A6-8062
VCID: 260037F059B58F0B0D-8073
VCID: 64846DF867093D1BD3-8031
ROD: EV_UHVNA.rod
VCID: 3A38F380BD0D1BEB59-806F
Monday,21,April,2014,20:42:44:21122
Mileage: 660km-410mi Repair Order: HEX-NET-Wifi
VIN: 3VW7T7AT2DM833144 Mileage: 660km-410miles
VCID: AA1843C0CDAD2B6BA9-80FF
VCID: 9E709F1049E5D7CBC5-80CB
Revision: 00H31001
VCID: AE104FD0F945474B75-80FB
Coding: 030C0C
VCID: B4245DB81F696D9B03-80E1
VCID: E288EBE03D1DB32BA1-80B7
VCID: C2C80B605DDDD32B81-8097
Coding: 8CBC30
Coding: 8CBC30
Coding: E30000
Coding: 800000
Coding: 800000
Coding: 00004E45
VCID: BFCE0294262FBEC3EE-80EA
Coding: 30304C
Coding: 251E01
VCID: AE104FD0F145474B75-80FB
Coding: 255080
VCID: B62067B001157F8B3D-80E3
Coding: 000007
VCID: EA9883C00D2DEB6B69-80BF
VCID: E288EBE0F51DB32BA1-80B7
VCID: B02C51A8EB7151BB67-80E5
Coding: 010100
VCID: DCF4D518DF7985DBEB-8089
03138 - Input AUX IN
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 38
Revision: 00H22000
VCID: B73E6AB4C61F868326-80E2
VCID: A600B7F0D9B50F0B8D-80F3
VCID: E484EDF8E709BD1B53-80B1
ROD: EV_UHVNA.rod
VCID: BA3873803D0D9BEBD9-80EF
VCDS Mobile 0.41.0.4
Gateway Installation list:
B9- -- Status: OK 0000
Address 01: Engine (CPPA J623) Labels:06-01.lbl
Part Number SW: 06K-906-070-C HW: 06K-907-425
Revision: --H09---
VCID: 2A1791ABD5D4A182658E-807F
No fault codes found.
Address 02: Auto Trans Labels:02E-300-0xx.lbl
Part Number SW: 02E-300-058-G HW: 02E927770AL
Revision: 05652104 Serial Number: 00001304300301
VCID: 1E7F4D7B999CC5220906-804B
Address 03: ABS Brakes (J104) Labels:None
Part Number SW: 5C0-907-379-C HW: 5C0-907-379-C
Revision: 00H31001
VCID: 2E1F9DBBE93CD5A2B9E6-807B
Address 05: Acc/Start Auth. (J518) Labels:5K0-959-434.clb
Part Number SW: 5K0-959-434-B HW: 5K0-959-434
Revision: 00086000
Coding: 030C0C
VCID: 342B8FD30710E772CF22-8061
Address 08: Auto HVAC Labels:5C0-820-047.clb
Part Number SW: 5C0-820-047-BC HW: 5C0820047BC
Revision: 2001111S Serial Number: 00000001635446
VCID: 6287398BED64A1C26DFE-8037
Address 09: Cent. Elect. (J519) Labels:6R0-937-08x-09.clb
Part Number SW: 6R0-937-088-G HW: 6R0-937-088-A
Revision: BT050001
VCID: 42C7D90B4DA441C24DBE-8017
Subsystem 1 - Part Number: 6R0-959-801-AP‘>8 Labels:6R-09-01.lbl
Coding: 8CBC30
Subsystem 2 - Part Number: 6R0-959-802-BC‘>8 Labels:6R-09-02.lbl
Coding: 8CBC30
Subsystem 3 - Part Number: 5C0-959-442-C
Component: E221__MFL-YVJH02 0103
Coding: E30000
Subsystem 4 - Part Number: 5C3-959-811-B
Coding: 800000
Subsystem 5 - Part Number: 5C3-959-812-B
Coding: 800000
Address 15: Airbags (J234) Labels:5K0-959-655.clb
Part Number SW: 5C0-959-655-P HW: 5C0-959-655-P
VCID: 3FC1D0FF3E56342A2250-806A
Subsystem 1 - Part Number: 5C6-959-339-B
Component: BF-Gewichtss.H10 0046
Serial Number: 6940000Y130000UNFR0N
Coding: 30304C
Subsystem 2 - Part Number: 5K0-959-354
Component: S.Sens.Fahr.VH02 ----
Serial Number: 3572MSME35340479ZZZS
Subsystem 3 - Part Number: 5K0-959-354
Component: S.Sens.Beif.VH02 ----
Serial Number: 3582MSME30391379ZZZT
Subsystem 4 - Part Number: 5K0-959-659-A
Serial Number: 3556LSME48215523ZZZO
Subsystem 5 - Part Number: 5K0-959-659-A
Serial Number: 3566LSME351A5523ZZZT
Address 17: Instruments (J285) Labels:5K0-920-xxx-17.clb
Part Number SW: 5C5-920-970-F HW: 5C5-920-970-F
Revision: X0024005
Coding: 251E01
VCID: 2E1F9DBBE93CCDA2B9E6-807B
Address 19: CAN Gateway (J533) Labels:6R-19.lbl
Part Number SW: 6R0-907-530-F HW: 1K0-907-951
Revision: H39
Coding: 255080
VCID: 362FB5DB116CED62F136-8063
Address 25: Immobilizer (J334) Labels:5K0-920-xxx-25.clb
Part Number SW: 5K0-953-234 HW: 5C5-920-970-F
Revision: X0024005
Coding: 000007
VCID: EA97D1AB9554E182250E-80BF
Address 26: Auto Roof (J256) Labels:None
Part Number SW: 5C3-871-601 HW: 5C3-871-601
VCID: E287B98B6D64B9C2EDFE-80B7
Address 2B: Steer. Col. Lock (J764) Labels:5K0-905-861.clb
Part Number SW: 5K0-905-861-C HW: 5K0-905-861-C
Revision: 00000000
VCID: 302383C3F308DB52ABCA-8065
Address 2E: Media Player 3 (J650) Labels:None
Part Number SW: 5C3-035-342 HW: 5C3-035-342
Revision: A1001003
Coding: 010100
VCID: DCFB87734F009732A7B2-8089
Address 44: Steering Assist Labels:1Kx-909-14x-44.clb
Part Number SW: 1K0-909-144-P
Revision: 00H22000
VCID: 3731B8DF1666946AEA00-8062
Address 47: Sound System (R12) Labels:None
Part Number SW: 5C6-035-456-A HW: 5C6-035-456-A
Revision: --------
Shop #: WSC 00000 000
VCID: 260F659BC1CC85E24156-8073
Address 56: Radio (J503) Labels:1K-56.lbl
Part Number SW: 1K0-035-180-AF HW: 1K0-035-180-AF
Revision: -----09S
VCID: 648B3F93F7702FF29FC2-8031
Address 77: Telephone (J412) Labels:7P6-035-730.clb
Part Number SW: 7P6-035-730-K HW: 7P6-035-730-K
Revision: 1B001001
ROD: EV_UHVNA.rod
VCID: 3A37A1EB25741102156E-806F
Address B8: Failed to respond
Address B9: Failed to respond
