Q7 2018 adaptation of clutch kissing point
Lodarski
Seattle, USA
C?ID=510697
Hi,
So I'm having an issue with the vehicle experiencing a slight hesitation when transitioning from no load ( i.e. coasting ) to an acceleration. I changed the supercharger clutch and it did not fix the issue. I would like to reset some basic settings in the engine and transmission and I have massage VCDS finished-Time out/Cancel.
It happens in many settings and adaptations. Here is an example.
IDE02298 - Adaptation of clutch kiss points.
message - Finished-Timeout / Cancel
IDE00752-Oxygen sensor control test
Can VCDS work with my car to make the adaptation correctly?
Here is the code.
Thank you,
Monday,03,April,2023,20:44:45:05427
VCDS Version: 23.3.0.0 (x64)  HEX-V2 CB: 0.4631.4
VIN: WA1LAAF70JD028079   License Plate:
Mileage: 67040km-41656mi   Repair Order:
Chassis Type: F7-AU73 (8W8)
Scan: 01 02 03 08 09 13 15 16 17 19 28 29 36 39 3C 42 44 46 47 50
          52 5F 69 6C 6D 81 8B A5 BB BC CA CF D6 D7
VIN: WA1LAAF70JD028079   Mileage: 67040km-41656miles
50-Seat Adj. 3rd row -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CREC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4M0 907 551 A    HW: 06E 907 425
   Component: 3.0l V6 TFSI  H10 0005
   Revision: --H10---    CVN: 08BDF7A0
   Coding: 2A2A00320576010D74280000000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TFS0214M0907551A 001007
   ROD: EV_ECM30TFS021_AU73.rod
   VCID: 2D0707A41D906D52945-8078
   VINID: 9D105C45158701A50008800724E28DA3D5
Address 02: Auto Trans        Labels:| 0BK-927-156.clb
   Part No SW: 4M0 927 158 L    HW: 0D5 927 156 H
   Component: 0D5  30TSIUSA H05 1006
   Revision: --H05---    CVN: 228D7428
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011_AU49.rod
   VCID: 3D2737E4CDF0FDD2245-8068
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
   Part No SW: 4M0 907 379 Q    HW: 4M0 907 379 N
   Component: ESP9 Premium  H09 0657
   Dataset Number: 4M0909504M  0003 CVN: ACFBEF4F
   Coding: 28AA149C30A40A9E919E5898008652A2E6269A14280C50891A004A45676459
   ASAM Dataset: EV_ESP9BOSCHAU536K 012013
   ROD: EV_ESP9BOSCHAU536K.rod
   VCID: 45D75F04A520B5127C5-8010
   Part No SW: 4M0 820 043 AB    HW: 4M0 820 043 AB
   Component: Klima Zone 4  H52 0112
   Coding: 6608090C5548001110680180800000000000000000000000000000000000
   Shop #: WSC 60371 004 1048576
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 6597BF8405E095129C5-8030
   Subsystem 1 - Part No SW: 4M1 820 021 B    HW: 4M1 820 021 B
   Component: J126 FLuftV  H09 0003
   Serial number: 00000000000002036565
   Humidity sensor: exterior:
   Serial number: 2E2150E800PAG0MUFU02
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Dataset Number: 4M0909514AA 0055
   Coding: 07500363E0691CCD050F8715583E1CB911033D01900000000000000020001A010863012B025709
   VCID: 025D8418F48E422A197-8056
   Subsystem 1 - Part No SW: 4M8 955 119     HW: 4N1 955 119
   Component: J400FRWISCH  052 0995
   Serial number: 904753F0301731700365
   Coding: 7DC727
   Serial number: 21104366X81A955547A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AG    HW: 4M0 941 531 AG
   Component: E1 - LDS  H06 0008
   Serial number: 11 11 2017  01176639
   Subsystem 4 - Part No SW: 4N0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H10 0100
   Serial number: 0000009600350Z00EM02
   Coding: 350000
   Garage door opener control head:
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20171117110039 00441
   Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE127091723610053
   Coding: 030000
   Interior Light Module:
   Subsystem 7 - Part No SW: 4M0 947 135 CT    HW: 4M0 947 135
   Component: J528-Dachele  H14 0140
   Serial number: Q00513280
   Subsystem 8 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0080
   Serial number: WA130218000042199814
   Coding: 0A0100
   Subsystem 9 - Part No SW: 4M0 925 301 K    HW: 4M0 925 301 K
   Component: SL-Q7NF/AU736  H10 0013
   Serial number: 00000000000000166719
   Subsystem 10 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V512 LLR1SLvL  H03 0012
   Serial number: L14DH30400221
   Subsystem 11 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V514 LLR1SKvL  H03 0012
   Serial number: L14DH30001690
   Subsystem 12 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V516 LLR1SLvR  H03 0012
   Serial number: L14DH30400211
   Subsystem 13 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V518 LLR1SKvR  H03 0012
   Serial number: L14DH30001691
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 4M0 907 561 G    HW: 4M0 907 561
   Component: LRR4          H10 0340
   Dataset Number: 4M0909863P  0001
   Coding: B4779FFA58FFEC09959A81A1
   ASAM Dataset: EV_ACCBOSCHAU736 003022
   ROD: EV_ACCBOSCHAU49X_AU73.rod
   VCID: 343112C0FEBA3C9ADBB-8060
   Part No SW: 4M0 959 655 F    HW: 4M0 959 655 F
   Component: Airbag10.44   H02 0107
   Serial number: 003UM001KZUC Dataset Number: 4M0909602AK 0001
   Coding: AECCFCC000800000A0F00033D24C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006016
   ROD: EV_AirbaAU10BPAAU736_006.rod
   VCID: 3E2530E8C0F6E6CA3DF-806A
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 4M0857705K0340R00574
   Coding: 88001B
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 4M0857706K0339R00723
   Coding: 88001B
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J170008FCNR0T
   Subsystem 4 - Part No SW: -----------    HW: 442 062 211 17
   Serial number: 3577Y00C125A1C6371A/
   Subsystem 5 - Part No SW: -----------    HW: 442 062 211 17
   Serial number: 3587Y00C125A1C60B390
   Subsystem 6 - Part No SW: -----------    HW: 442 0B1 511 17
   Serial number: 3517700B327DA97172BK
   Subsystem 7 - Part No SW: -----------    HW: 442 0B1 511 17
   Serial number: 3527700BF289218382FM
   Subsystem 8 - Part No SW: -----------    HW: 442 0C1 710 17
   Serial number: 3557500BD27F01B3924H
   Subsystem 9 - Part No SW: -----------    HW: 442 0C1 710 17
   Serial number: 3567500BD27F01B2135B
   Part No SW: 4M0 907 129 LS    HW: 4M0 907 129 LS
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 0C41AA20C6CA045A63B-8058
   Part No SW: 4M0 920 890 C    HW: 4M0 920 890 C
   Component: FBenUSA       H18 0370
   Coding: 09C600C16C88CF0502A369601800600008000000
   ROD: EV_DashBoardAU736_AU73.rod
   VCID: 30391ED00AA200BABF3-8064
   Part No SW: 8W8 907 468 F    HW: 8W8 907 468 E
   Component: Gateway       H42 0123
   Revision: 7D000001    Serial number: 0187D759117C08 Dataset Number: 4M0909515N  0087
   Coding: 030100010000064054070000005900325C1A0007100000000150000000000000
   GVL: 01503C0408000000C0DCC8000002C800100C2000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 003111
   VCID: 4FFB7D2C775C7F42C69-801A
   Subsystem 1 - Part No SW: 4M0 951 523 A    HW: 4M0 951 523 A
   Component: J453 MFL  H06 0002
   Serial number: 20171208074711 00680
   Serial number: 7745276004
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 4M0 919 158 D    HW: 4M0 919 158 D
   Component: Klima Zone 2  H52 0103
   Coding: 000000000000000100800080000000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
   ROD: EV_AirCondiFondBHTCAU736.rod
   VCID: 363528C8E8C62E8AE5F-8062
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0024
   VCID: 78A9E6F0A25218FA373-802C
   Component: MEM-FS        009 0042
   Serial number: 00000293115615 Dataset Number: 4M0909856D  0022
   Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
   VCID: 79AFE3F4995801F248D-802C
   Part No SW: 4M0 907 566 D    HW: 4M0 907 566
   Component: MRR1Rear      H18 0410
   Revision: --------    Dataset Number: 4M0909535L  0016
   Coding: 1EC002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   Part No SW: 4M0 959 793 H    HW: 4M0 959 793 F
   Component: TSG FS        005 0129
   Serial number: 0000293964235  Dataset Number: 4M0909872G  0032
   Coding: 005F9B005E001080000120B0
   VCID: 43D3411CAB148B22521-8016
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H22 0005
   Serial number: 0000306289 Dataset Number: 4M0909852P  0002
   Coding: B0000101000101
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   Part No SW: 8W0 907 064 ED    HW: 8W0 907 064 DD
   Component: BCM2 MLBevo   025 0387
   Dataset Number: 4M0909501K  0066
   Coding: 01341E00492100C0650B80006E01580003024000810000502F0400000F04803F001E0001000000
   ASAM Dataset: EV_BCM2HellaAU736 014014
   ROD: EV_BCM2HellaAU736_014_AU49.rod
   Subsystem 1 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Serial number: 00002856223972944301
   Subsystem 2 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
   Component: GEB.F.Heckoef  H16 0816
   Serial number: 94265462
65896 - Databus
          [Climatronic control module: Klima_03: no signal/communication]
                    Fault Frequency: 253
                    Reset counter: 25
                    Mileage: 66290 km
                    Date: 2023.03.16
                    Time: 19:50:19
                    Supply voltages-Terminal 30 power supply: 12.365 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.283 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.351 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 02 80
   Part No SW: 4M0 035 223 C    HW: 4M0 035 223
   Component: MIB2_amp_PD   H03 0440
   Serial number: 00000000069802 Dataset Number: 4M1909510E  0012
   Coding: 0135060A008AF53AAF0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
   VCID: 2313E19C4B54AB22321-8076
Address 50: Seat Adj. 3rd row (J857)       Labels:* None
   Part No SW: 4M1 959 760 G    HW: 4M1 959 760 G
   Component: MEM-SR3       008 0016
   Serial number: 00000293571039 Dataset Number: 4M0909467C  0015
   Coding: FF041020F1000000000F000000000900000021210900000000000000440000
   ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
   ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
   Part No SW: 4M0 959 792 H    HW: 4M0 959 792 F
   Component: TSG BFS       005 0129
   Serial number: 0000293710514  Dataset Number: 4M0909873G  0033
   VCID: 42DD4418B40E822A597-8016
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4M1 035 880 B    HW: 4M1 035 880
   Component: MU-P-LNS-US   034 1178
   Serial number: A724L0HB042326 Dataset Number: 4M0909545M  0045
   Coding: 013706020000000013220002041A00102F001BE501700904BE
   VCID: 2C010AA0268A645A83B-8078
   Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
   Component: NAR 2018  --- 0063
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9HJ405PTG
   Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 H
   Component: ControlUnit_P  H15 0209
   Serial number: 05121700000000000990
   Compact disc data bank:
   Component: Gracenote2  --- 3012
          B11CF 53 [009] - Deactivated
                    Reset counter: 195
                    Mileage: 66290 km
                    Date: 2023.03.17
                    Time: 06:42:13
                    Voltage terminal 30: 14.7 V
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
   Part No SW: 4M0 907 383 E    HW: 4M0 907 383
   Revision: 9C001003    Serial number: 0462507040 Dataset Number: 4M0909527C  0024
   Coding: 0210000200000000
   Part No SW: 4M0 907 428 F    HW: 4M0 907 428
   Component: Areaview 2    H13 0318
   Serial number: C854607JG060455 Dataset Number: 4M1909460H  0022
   Coding: 02350602BB0FA10038404004
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
   ROD: EV_CamSysRVAV2CE2MLBEv_005_AU49.rod
   VCID: 35372FC4F5C02592EC5-8060
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0163
   Revision: --------    Serial number: 31697279800000 Dataset Number: 4M0909541G  0025
   Coding: 00B0
   ASAM Dataset: EV_DeckLidCONTIAU736 001015
   ROD: EV_DeckLidCONTIAU736_AU37.rod
   VCID: 48C956309232A87A873-801C
   Part No SW: 4M1 713 041 E    HW: 4M1 713 041 F
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 17120745158992
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 270BF58C3F6C47026E9-8072
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 4M0 907 541 G    HW: 4M0 907 541
   Dataset Number: 4M0909885K  0001
   ASAM Dataset: EV_ACC2BOSCHAU736 003022
   ROD: EV_ACC2BOSCHAU49X_AU73.rod
   VCID: 323D14D804AE32AAC97-8066
   Part No SW: 4M0 907 217 E    HW: 4M0 907 217 E
   Component: BVS           H16 0050
   Dataset Number: 4M0909466M  0044
   Coding: 0407030600000201022023A7A50000B4B0F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
   Part No SW: 4M0 959 795 H    HW: 4M0 959 795 F
   Component: TSG HFS       005 0129
   Serial number: 0000293691449  Dataset Number: 4M0909897G  0032
   Coding: 004F9B0000001080400020A0
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   Component: TSG HBFS      005 0129
   Serial number: 0000293691574  Dataset Number: 4M0909896G  0032
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
   Part No SW: 4M0 907 594 G    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Dataset Number: 4M0909469G  0015
   Coding: 2A8000053602
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3A2D3CF8DCDECAEA017-806E
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 4M0 907 590 D    HW: 4M0 907 590
   Revision: --------
   Coding: 1EC002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   VCID: 333311DCFBB43BA2C21-8066
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   Dataset Number: 4M0909471D  0012
   ROD: EV_LEDModLeftMELCOAU736_AU73.rod
   VCID: 1675C8488806CE8AC5F-8042
   Component: LED1R         H09 0003
   Dataset Number: 4M0909472D  0012
End----------(Elapsed Time: 02:33, VBatt start/end: 13.0V/13.0V)-----------
In all likelihood, yes, if you follow the correct procedure. However, I don't recall seeing a detailed procedure for either of those.
Lodarski
Seattle, USA
C?ID=510697
Hi Owe,
Is there a place I can look for the procedures (self-educating)? Today I tried other options and there is the same result.
Could you check in your system if is there a procedure for the:
IDE02293-Engaagment point adaptation
IDE02294-Main pressure valve calibration
IDE02295-Calibration of clutch valve
IDE02296-Calibration of distance sensors
IDE02297-cooling oil valve calibration
All give me the same message - Finished-Timeout / Cancel
Let me know if you need more information from my end.
Thank you for the help.
Lodarski
Seattle, USA
C?ID=510697
Hi,
Can someone help me find a manual for UDS protocol and learn how to use the VCDS special functions?
Thank you,
