2018 VW GTI. 267-sensor for automatic distance regulation- incorrectly positioned
gazaflash
North Bay, ON, Canada
C?ID=241260
I need some help doing a calibration of the ACC unit.
Checked with VCDS to see if it could be cleared. Nope!
Checked to make sure unit is seated and clipped in properly.
How do I go though step by step a calibration of the unit please
Please post an Auto-Scan so people can see exactly what ACC sensor this car has and the faults that are in it.
AINils
Germany (AIB)
C?ID=56975
After you upload Auto-Scan can give you a manual
gazaflash
C?ID=241260
Hi guys,
See upload of auto scan. Sorry, I should have done this right in the beginning!
....! What the hey? I cannot seem to paste or upload the scan!
gazaflash
C?ID=241260
Do you have to have a minimum number of messages before you are allowed to upload anything????
I think this website looks the same as Club Touareg!
gazaflash
C?ID=241260
Lets try again...!
Log-GTI-3VW547AU8JM282596-112040km-69618mi.txt
gazaflash
C?ID=241260
yeesh! I'm not getting to grips with this
Friday,16,June,2023,17:42:56:34708
VCDS Version: 23.3.1.0 (x64)
VIN: 3VW547AU8JM282596   License Plate: GTI
Mileage: 112040km-69618mi   Repair Order:
Chassis Type  AU-VW37 (3Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 32 3C 42 44 47 4B 52 5F
          A5 A9
VIN: 3VW547AU8JM282596   Mileage: 112040km-69618miles
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CXCB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 L    HW: 06K 907 425 B
   Revision: --H13---    CVN: 4DE8E76C
   Coding: 091900322444002F1000
   Shop #: WSC 00066 790 00072
   ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
   ROD: EV_ECM20TFS0205G0906259L_VW37.rod
   VCID: 377D166C8ECA102B3A-8062
   VINID: 0E69C510746521A74220214918A199E7A0
Readiness: 1010 0101
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 CP    HW: 5Q0 614 517 AB
   Component: ESC           H25 0323
   Revision: 00000000    Serial number: 60578000000570
   Coding: 01FA6BA15428096E407C020960C96880D62A90024006163634435051C0A9430B00000012121212B835351919323200
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009
   ROD: EV_Brake1UDSContiMK100ESP_037_VW37.rod
   VCID: 0109B8B4908E9E9BC4-8054
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0470596057 Dataset Number: V03935252QE 0001
   Coding: 032C0C
   VCID: 3C770940B7EC3373D7-8068
   Part No SW: 5GM 907 044 G    HW: 5GM 907 044 G
   Component: Climatronic   H04 2001
   Revision: 00001K05    Dataset Number: 0000
   Coding: 0002001420011801010400000010140E
   VCID: 489F6590F3346FD343-801C
   Part No SW: 5Q0 937 087 AR    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 034 0246
   Revision: --------    Serial number: C86414041801D3 Dataset Number: V03935274HK 0001
   Shop #: WSC 00066 790 00395
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0B159A9CA2C2C4CBAE-805E
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    180105  043 0551
   Serial number: 97022066180113090318
   Component: RLHS  047 0105
   Serial number: SBY18M04D09H18M21S55
   Coding: 00A8DD
   Sunroof control module:
   Subsystem 3 - Part No SW: 5GD 959 591 A    HW: 5GD 959 591 A
   Component: J245 PS60.006  H07 0170
   Serial number: 03691608030405171500
   Coding: 181803
   Humidity sensor: interior:
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0045
   Serial number: 000116644R18095 Dataset Number: V03935256PT 0001
   Coding: 0271167801
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   VCID: 50AF4DF00B64A7131B-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Dataset Number: V03935266FC 0205
   Coding: 2D0000C141FFC728949C810510400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E730348A1F02163F9-806A
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
                    Reset counter: 222
                    Mileage: 112023 km
                    Date: 2023.06.15
                    Time: 18:10:28
                    Control Module temperature: 35 ∞C
                    Voltage terminal 15: 11.7 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
                    Reset counter: 222
                    Mileage: 112023 km
                    Date: 2023.06.15
                    Time: 18:10:28
0836 - Databus
                    Reset counter: 10
                    Mileage: 112028 km
                    Date: 2023.06.16
                    Time: 07:41:49
                    Control Module temperature: 19 ∞C
                    Voltage terminal 15: 14.4 V
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Component: AirbagVW20    011 0830
   Serial number: 003MHM04BMY6 Dataset Number: V03935263HR 0001
   VCID: 51A948F4006EAE1B14-8004
   Serial number: IBH000000000008VUXL/
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 000 903 18
   Serial number: 35700000000DB50D7C2Z
   Subsystem 3 - Part No SW: -----------    HW: 480 000 903 18
   Serial number: 35800000000581013D26
   Subsystem 4 - Part No SW: -----------    HW: 480 401 003 18
   Serial number: 3510001BB29485A57725
   Subsystem 5 - Part No SW: -----------    HW: 480 402 803 18
   Serial number: 3520001B7297CD541253
   Subsystem 6 - Part No SW: -----------    HW: 480 400 302 18
   Serial number: 3550001BB2909F057322
   Subsystem 7 - Part No SW: -----------    HW: 480 400 302 18
   Component: FrontSensor_P  000 6149
   Serial number: 3560001C92843FB34224
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 13021820241156
   Coding: 0C00
   VCID: 0919A094A8BED6DB9C-805C
   Part No SW: 5G1 920 756 C    HW: 5G1 920 756 C
   Component: KOMBI         342 0310
   Coding: 0BAD0912ED88880902886B0B5001000080000000
   VCID: 2D5134047C96AAFB50-8078
   Component: GW MQB High   518 5323
   Serial number: 24031800842007 Dataset Number: V03935272LR 0001
   Coding: 0101000830085900FB00023B080F00000001070000000000000000000000
   Shop #: WSC 00066 790 07027
   GVL: 01563C500000060040CC80000000480000000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 387F155083D41F5333-806C
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Serial number: 29170002193490057394
   Coding: 34FFFF
   Revision: 00000000    Serial number: 18000057781010
   Coding: 5500000000000000
   VCID: 346721609FBCFB331F-8060
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H52 8043
   Serial number: HA1-00023.10.17 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52AB47F80568D5032D-8006
   Component: HRE_Master    H12 0080
   Serial number: 0470436043 Dataset Number: V03935270GQ 0001
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D710444ACF63A7BE0-8068
   Component: HRE_Slave  H12 0080
   Serial number: 0471147089
   Coding: 020111
   Serial number: 5038810101215  Dataset Number: V03935265HB 0001
   Coding: 003E13200000020000000000
   VCID: 479D66ACFE2A60AB4A-8012
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000000295500
   Coding: 011000
   Part No SW: 5QN 909 144 A    HW: 5QN 909 144 A
   Component: EPS_MQB_ZFLS  507 5081
   Dataset Number: V03935265SY 0001
   Coding: 930A0000
   ROD: EV_SteerAssisMQB_015.rod
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1HMD01UFP7 Dataset Number: V03935259L0001
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 2E5333087190D1E369-807A
Address 4B: Multifunc. Module
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
   Serial number: 6038806400612  Dataset Number: V03935265HC 0001
   VCID: 46836BA8F92079A3B1-8012
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000000288010
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    851 0867
   Serial number:                Dataset Number: V03935281LR 0001
   Coding: 027310020000000051220002001828009F0503F401200505C6
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 3365227C9AB2FC0B06-8066
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZJV0816174
   Subsystem 2 - Part No SW: 3G0 919 866 BP    HW: -----------
   Component: NAR 2018  --- 0715
          B11CF 53 [009] - Deactivated
                    Reset counter: 222
                    Mileage: 112023 km
                    Date: 2023.06.15
                    Time: 16:25:18
                    Voltage terminal 30: 12.1 V
                    SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 107 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 02
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 02
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 1272
   Serial number: 14011841K10937 Dataset Number: V03935269GN 0001
   Coding: 000307000002020100221354C150490084000E200120
   VCID: 081FA590B3B4AFD383-805C
   Part No SW: 5G0 907 159 G    HW: 4H0 907 159 A
   Serial number: 180221202454
   VCID: 326B277865A8F5030D-8066
End-------------------------(Elapsed Time: 05:32)--------------------------
AINils
Germany (AIB)
C?ID=56975
Use category 5Q0 907 572 - Dynamische Kalibrierung to calibrate your ACC (Dynamic)
AINils
Germany (AIB)
C?ID=56975
Use Google Chrome to translate
AINils
Germany (AIB)
C?ID=56975
Done first Version in english translation, but need some tweaks in formatting. But should work for most of you:
Maybe Ross-Tech will integrate this in RT Wiki
gazaflash
C?ID=241260
Hi there,
I have used Google translate and now have the directions in english. I just need to find some time to set all the parameters.
I have noticed that the module is under the VW badge. looking at some of the Youtube vids, the unit is behind the grill below the bumper. The unit is also has a dome and is mounted on 4 studs so the unit can be adjusted statically. The unit behind the VW badge on my GTI fits into a slot and clips into position. Does this mean that it does its own static adjustment?
AINils
Germany (AIB)
C?ID=56975
Don't fuck with screws, just use daynmic calibration. It's done in 5minutes and everthing ist working fine. Use it since years without any problems.
gazaflash
C?ID=241260
Hi again,
Sorry I haven't done it sooner. Was out of country.
ACC re-calibration, module 13​
5Q0 907 572 - Dynamic Calibration​
did the Access authorization: S23456
IDE11924-MAS13427-Correction angle-Horizontal correction angle dynamic
IDE11924-MAS13428-Correction angle-vertical correction angle dynamic
IDE11924-MAS13429-Correction angle-horizontal correction angle actual
IDE11924-MAS13430-Current correction angle-vertical correction angle
All the above said in the Stored value box "ERROR: Channel not available"
Only thing I could possibly change is,
IDE08936-Dejustment angle horizontal - 0.00 deg, which I changed to 0.00 again
IDE09906-Dejustment angle vertical - 0.00 deg, which I changed to 0.00 again
the measuring values were, prior to readjustment,
MAS13427-Correction angle-Horizontal correction angle dynamic, 0.000 deg
MAS13428-Correction angle-vertical correction angle dynamic, 0.000 deg
MAS13429-Correction angle-horizontal correction angle actual, -0.100 deg
MAS13430-Current correction angle-vertical correction angle, 9.080 deg
IDE08936-Misalignment angle: horizontal, 0.214 deg
IDE09906-Vertical readjustment, 9.091 deg
after changes to horizontal and vert de-adjustments,
all angles read 0.000 deg... I thought, I must be on the right track...!
took the car for a drive behind some cars and presto, no exclamation mark on dash, ACC is working as it should.
Thank you AINils for your information and sending me in the right direction. Could not have done it without you
AINils
Germany (AIB)
C?ID=56975
Yes now dynamic calibration is started, it will take around 20km to finish this process. But from first start car will working fine
