Code 001592 p0638 Throttle Body Actuator Bank 1 (J338)
Daniel Bujold
Canada Nova Scotia Fall River
C?ID=245764
Hi I am getting this code 001592 with P0638 on my 2009 Jetta TDI. I took the throttle body off and cleaned it. Could not remove the cover there was restriction and I did not want to break it. After putting it back together I tried to calibrate the throttle body with the system, but I am not sure if it is working. I hate to buy a new one if it is not the problem. Anyone please help me. This is my first time on the Forum and using VAG Com. Thanks Daniel
Daniel Bujold
C?ID=245764
Hi Uwe!
Here is tonight Scan!
I ran the Throttle Valve Control Module (J338) Adaptation tonight with no luck. IT ran for 15 minutes with noting. no error no working no finish.
Does this mean my throttle valve is bad?
Thanks Daniel
Thursday,13,August,2015,20:15:58:56450
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
VIN: 3VWHL81K39M170997   License Plate: MAM JETTA AUG 13
Mileage: 117520km-73023mi   Repair Order:
Chassis Type: 1K (1K0)
VIN: 3VWHL81K39M170997   Mileage: 117520km-73023miles
Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 016 P    HW: 03L 906 022 J
   Component: R4 2,0L EDC G000AG  8681
   Revision: 12H01---    Serial number: VWX7Z0I424K11K
   Coding: 0350078
   Shop #: WSC 00066 000 00000
   VCID: 3F8D06F76EA13EC66F-806A
001592 - Throttle Body Actuator Bank 1 (J338)
               P0638 - 000 - Implausible Signal - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 117525 km
                    Time: 08:45:15
                    RPM: 828 /min
                    Voltage: 14.06 V
                    Lambda: 99.4 %
                    Bin. Bits: 00000000
               P0299 - 000 - Control Range Not Reached
                    Mileage: 117526 km
                    Time: 19:22:06
                    RPM: 2737 /min
                    Speed: 22.0 km/h
                    Load: 78.4 %
                    Absolute Pres.: 2458.2 mbar
                    Absolute Pres.: 1509.6 mbar
                    Lambda: 79.7 %
                    Lambda: 79.7 %
Readiness: 1 1 0 0 1
   Part No SW: 02E 300 052     HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1914
   Revision: 04844002    Serial number: 00000903250536
   VCID: 51A9304FC835B8B689-8004
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AF    HW: 1K0 907 379 AF
   Component: MABS MK70M          0104
   Revision: 00H32001
   Coding: 0016641
   VCID: 76E3A3D3011BBF8E7C-8022
   Part No SW: 1K0 820 047 JE    HW: 1K0 820 047 JE
   Component: Climatic PQ35   143 1313
   Revision: 00143033    Serial number: 00000000000000
   VCID: 70EF95CB637F91BEA6-8024
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000009285888
   Coding: 10018E234004150007140000001400000008730B5C000120000000000000
   VCID: 326B5FC3ADF3E3AE90-8066
   Component: Wischer 280509 021  0501
   Coding: 00038805
   Part No SW: 1K0 909 605 AD    HW: 1K0 909 605 AD
   Component: 08 AIRBAG VW8R  036 8900
   Revision: 06036000    Serial number: 003EVM0097ZZ
   Coding: 0012344
   VCID: 6ED38BB3794B874EB4-803A
   Subsystem 1 - Serial number: 6332MSME45624F5AM
   Subsystem 2 - Serial number: 6342MSME46547176C
   Subsystem 3 - Serial number: 6351HSME0007530E$
   Subsystem 4 - Serial number: 6361HSME00071B43.
   Subsystem 5 - Serial number: 63727SME1C3C45423
   Subsystem 6 - Serial number: 63827SME1C3C42612
   Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
   Component: J0527           053 0111
   Coding: 0001031
   VCID: 020BCF035DD3932E40-8056
   Part No SW: 1K0 920 854 DX    HW: 1K0 920 854 DX
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0005000    Serial number: VWX7Z0I424K11K
   Coding: 0023303
   Shop #: WSC 05977 002 1048576
   VCID: 0407C91B47C79D1E72-8050
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533  Gateway   H07 0071
   Revision:   H07 01    Serial number: 150409F1000715
   Coding: ED807F06000202001002
   VCID: 377D6ED746910686A7-8062
   Component: IMMO            3HL 1222
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000523398430
   Coding: 0001205
   VCID: 6FED96B77E418E46BF-803A
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 70     2501
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2C5741BB8FD7B55EDA-8078
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Coding: 1B900F880106281B0904058FB0880F0488FCA0
   Shop #: WSC 95866 999 58876
   VCID: 71E990CF687598B6A9-8024
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 09010600572303
   Coding: 0001204
   Part No SW: 1K0 035 180 M    HW: 1K0 035 180 M
   Component: Radio DE2       016 0020
   Revision: 00016000    Serial number: VWZ4Z7J3168376
   Coding: 0010400
   VCID: 2A5B47A38523AB6E28-807E
00003 - Control Module
            014 - Defective
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003931555
   Coding: 0001168
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000003923245
   Coding: 0001168
   VCID: 77FDAED70611C68667-8022
00935 - Electric Window Motor; Rear Right (V27)
                    Fault Status: 00100101
                    Reset counter: 113
                    Mileage: 117420 km
End-------------------------(Elapsed Time: 02:50)--------------------------
NostraJackAss
Daniel
Did you verify the TV can move backwards 5mm before it moves forward?
Lubricate real good and try that by massaging the butterfly in reverse direction just so slightly.
Then try to readapt.
Daniel Bujold
C?ID=245764
Hi Jack!
So I should remove it again and lubricate it and move it backwards 5 mm until it moves in both direction. last time it moved only in one direction and it was open a bit.
You mentioned TV is that the butterfly?
Thank you so much!!
Daniel
Daniel Bujold
C?ID=245764
Jack should I try to remove the electrical cover on it ? I tried last time but it would not come off. Is there a coiled spring or something in there that prevents it from coming off?
Thanks again!
Daniel
NostraJackAss
Hi Jack!
Thank you so much!!
Daniel
TV = Throttle valve.......Butterfly is the flap inside you must clean and verify.
Thanks again!
Daniel
nope
Daniel Bujold
C?ID=245764
Hi Jack! I will let you know the outcome. Thank you so much for your guidance it is greatly appreciated! Daniel
NostraJackAss
Use WD 40 on the butterfly flap........ seems to work well and doesn't damage anything.
Daniel Bujold
C?ID=245764
Jack that is what I put on it last time. After working on it to free it up, I should be able to run the Throttle Valve Control Module Adaptation just by hooking it in the wiring harness. This way if it does not work I wont have to take it back off? Then a new one? Thanks again!!
Daniel Bujold
C?ID=245764
Hi Jack !
When I run the Throttle Valve Control Module Adaptation, I am getting error Group 124 Not Available??
Thanks Daniel
NostraJackAss
Are you in basic settings or blocks and did you turn them on?
I show a fluctuation in that channel typically 1st field from 4.7% to 96% when running that basic setting.
It will do it about 4 times before completing here if testing this channel.
FYI:
ADP should be done in adaption 10 channel 124 after a login of 12233 security access in 0x01-16-12233
Daniel Bujold
C?ID=245764
Hi Jack!
I took the valve to VW with a print out of the scan. The electronic department guy told me to change the valve. At the parts department the guy said the valve was bad because it was partly closed. The new one was wide open with a revision change $421.00 plus tax. Old Part number 03G 128 063D The new one got a different last letter from D to ??. I ran the Throttle Valve Control Module Adaptation on the new one and the valve opened and closed about 4 times. All Good now!!!!
Thanks Jack it was nice to have your support. Daniel
NostraJackAss
Hmmm I wonder if slipped on the gear internally on servo or if return spring broke?
Take the side cover off to find out what happened.........
Take pictures and upload please.
Daniel Bujold
C?ID=245764
Hi Jack! I finely took my old throttle Valve apart and fixed it . It was the shaft that was seized . It only needed some WD40 and motor oil into the casting hole that leads to the shaft. With light tapping on the disk with a piece of wood. The restriction on the cover was due to the electrical connection and two plastic alignment pins. No issues to re-assembling it. I took some pictures of it when it was apart and a video of the TV adaptation routine with VCDS. It opened and closed freely 2 or 3 times. I am not too sure how to post the pictures and video. I will try to get it posted. Too bad I did not try to fix it before buying a new one! Now I have a Throttle Valve for sale.
Thanks Daniel
NostraJackAss
Danielson........ The TV and pedal sensor POTS are pretty rugged from what I have observed.
They can be damaged or impaired usually from some type of FOD.
You can now sand the floor, paint the fence or WAX on WAX off as a treat.
My detail as a kid was the hated cleaning of diesel piston ring lands, in a bucket of kerosene with the old rings.
Then to be followed up by scrubbing cylinder bores with a toilet bowl brush after honing and then polishing cranks with old socks rapped around proper emery grades.
Daniel was evil and I agree according to Jef in the bar.
http://forums.ross-tech.com/showthread.php?1924-Random-Videos&p=38921&viewfull=1#post38921
