Resolved Multiple error codes and engine stalls (2018 Passat)
Resolved
Lieberkind
Denmark
C?ID=511675
Hi,
i have this issue that sometimes when i drive, the engine stalls (stops) and I get al lot of errors. after a moment I car start the car again and drive.
sometimes the car wont start also with at lot af errors.
can someone help me to figure out what the problem can be?
it happened today when I went home from work.
thanks.
VIN: WVWZZZ3CZJE130524   License Plate:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 42 44 52 5F 69 6C A5
VIN: WVWZZZ3CZJE130524   Mileage: 202307km-125707miles
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 KD    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 4798
   Revision: B4H25---    CVN: CFB81915B866C2ADB866C2AD
   Coding: 0125041203741D083000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM20TDI01104L906026KD 005005
   ROD: EV_ECM20TDI01104L906026KC.rod
   VCID: 76B5E8EE1843485A257-8022
   VINID: 9E69EAAAA0D3A9A5410C0142101018DF36
17158 - Implausible Data Received from ESP Control Module
          U0416 00 [036] - -
                    Fault Frequency: 13
                    Mileage: 197428 km
                    Date: 2023.04.09
                    Time: 12:34:58
                    Engine RPM: 0.00 /min
                    Coolant temperature: 95 °C
                    Intake air temperature: 64 °C
                    Voltage terminal 30: 11.880 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 5
                    Acceleration: 0.000 m/s²
   Part No SW: 0GC 300 042 H    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 1427
   Revision: 00H06V09    CVN: ED4B3409
   ROD: EV_TCMDQ381061.rod
   VCID: 2B03099A938145B28A9-807E
   No subsystems:
10679 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [168] - -
                    Fault Frequency: 8
                    Mileage: 199716 km
                    Date: 2023.04.28
                    Time: 06:10:25
                    Coolant temperature: 215 °C
                    Clutch: primary stat: New
                    selected gear: GANG_R
                    Driving position: P
                    Engine torque: 200 Nm
                    Control Module temperature: 78 °C
                    Accelerator pedal position: 100.0 %
                    DTC memory status: 66
   Part No SW: 5Q0 614 517 DA    HW: 5Q0 614 517 AH
   Component: ESC           H62 0753
   Revision: 00000000    Serial number: 63437000002806
   Coding: 0FEC6A8F34230B6C477C060260C749F0562CD0E2600692713862F078C222420B00000012121212B835351919323200
   Shop #: WSC 00015 115 08193
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 73B3D1FA0B315D72029-8026
10 Faults Found:
8246 - Databus
          [FCAN: Motor_Code_01 message is not received]
                    Reset counter: 197
                    Mileage: 202275 km
                    Date: 2023.06.01
                    Time: 14:33:15
8250 - Databus
          [FCAN: Motor_07 message is not received]
                    Reset counter: 197
                    Mileage: 202275 km
                    Date: 2023.06.01
                    Time: 14:33:15
8252 - Databus
          [FCAN: Motor_11 message is not received]
                    Fault Frequency: 16
                    Reset counter: 197
                    Mileage: 197428 km
                    Date: 2023.04.09
                    Time: 12:34:48
8254 - Databus
          [FCAN: Motor_12 message is not received]
                    Fault Frequency: 16
                    Reset counter: 197
                    Mileage: 197428 km
                    Date: 2023.04.09
                    Time: 12:34:48
8256 - Databus
          [FCAN: Motor_14 message is not received]
                    Fault Frequency: 14
                    Reset counter: 197
                    Mileage: 197428 km
                    Date: 2023.04.09
                    Time: 12:34:48
8258 - Databus
          [FCAN: Motor_20 message is not received]
                    Fault Frequency: 14
                    Reset counter: 197
                    Mileage: 197428 km
                    Date: 2023.04.09
                    Time: 12:34:47
8264 - Databus
          [FCAN: Tsk_06 message is not received]
                    Fault Frequency: 14
                    Reset counter: 197
                    Mileage: 197428 km
                    Date: 2023.04.09
                    Time: 12:34:47
8351 - Databus
          [FCAN: Motor_17_alt veraltet bit is set]
                    Fault Frequency: 14
                    Reset counter: 197
                    Mileage: 197428 km
                    Date: 2023.04.09
                    Time: 12:34:50
16409 - Display for Tire Pressure Monitoring
          C1146 02 [008] - Signal Failure
                    Reset counter: 197
                    Mileage: 202275 km
                    Date: 2023.06.01
                    Time: 14:33:20
16410 - Display for Tire Pressure Monitoring
                    Reset counter: 197
                    Mileage: 202275 km
                    Date: 2023.06.01
                    Time: 14:33:20
   Part No SW: 3Q0 959 435 F    HW: 3Q0 959 435 F
   Component: VWKESSYMQB    027 0907
   Revision: 00027000    Serial number: 0463688526 Dataset Number: V03935273SJ 0001
   Coding: 102F0F0723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3D2737C27DF5DB0224D-8068
12716804 - Databus
          [Message Motor_14 missing]
                    Reset counter: 197
                    Mileage: 199044 km
                    Date: 2023.04.21
                    Time: 14:34:41
                    Terminal_15_Kessy_specified_value: On
                    Terminal_15_Kessy_actual_value: On
                    Terminal_15_central electric_actual_value: On
                    Terminal_15red_Kessy_specified_value: On
                    Terminal_15red_Kessy_actual_value: On
                    Terminal_S_Kessy_specified_value: On
                    Terminal_S_Kessy_actual_value: On
                    Terminal_S_central electric_actual_value: On
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition met
                    Enabling immobilizer: Condition met
                    Control Module Voltage: 12.530 V
                    Vehicle speed: 0.0 km/h
                    Engine RPM: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: Not coded
                    Driver door: Open
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID-sensor 1 authentication: status: No response
                    ID-sensor 2 authentication: status: No response
                    ID-sensor 3 authentication: status: No response
                    ID-sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12718343 - Databus
          [Message Motor_07 missing]
                    Reset counter: 197
                    Mileage: 202275 km
                    Date: 2023.06.01
                    Time: 14:33:15
                    ZAT_pressed: OFF
                    Park selector lever position: Not engaged and not locked
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 12.496 V
                    Vehicle speed: 66.1 km/h
                    Engine RPM: 1438.5 /min
                    Status of vehicle locking: Vehicle locked internally
                    Driver door: closed
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12718344 - Databus
          [Message Motor_09 missing]
                    Reset counter: 197
                    Mileage: 202275 km
                    Date: 2023.06.01
                    Time: 14:33:14
                    ZAT_pressed: OFF
                    Control Module Voltage: 12.484 V
                    Vehicle speed: 66.0 km/h
                    Driver door: closed
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12718345 - Databus
          [Message Motor_code_01 missing]
                    Reset counter: 197
                    Mileage: 202275 km
                    Date: 2023.06.01
                    Time: 14:33:14
                    ZAT_pressed: OFF
                    Driver door: closed
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Part No SW: 5G0 907 044 DP    HW: 5G0 907 044 DP
   Component: Climatronic   H04 2001
   Revision: 00001K10
   Coding: 12020104202110011115100000101822
   VCID: 78A9E6D612573E2A37B-802C
   Air quality sensor:
   Humidity sensor: exterior:
328199 - Position Sensor for Right Temperature Flap Motor
          B1095 15 [008] - Open or Short to Plus
                    Reset counter: 193
                    Mileage: 202135 km
                    Date: 2023.05.31
                    Time: 05:38:58
                    Voltage terminal 30: 13.2 V
                    Outside temperature: 12.0 °C
                    Inside temperature: 12.8 °C
                    Right temperature flap: actual value: 0.0 %
                    Right temperature flap: actual value: 235
                    Temperature door right - Specified value: 235
459023 - Databus
          [Motorsteuergerät - kein Signal/Kommunikation]
                    Reset counter: 197
                    Mileage: 199044 km
                    Date: 2023.04.21
                    Time: 14:34:44
   Part No SW: 5Q0 937 086 BL    HW: 5Q0 937 086 BG
   Component: BCM PQ37BOSCH 034 0245
   Revision: --------    Serial number: 8658261117000X Dataset Number: V03935270TH 0001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 05579F2255A553C23CD-8050
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    171105  042 0607
   Serial number:         171116194235
   Component: RLHS  047 0105
   Serial number: S8Y17M12D07H23M45S43
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 31 07 2017  10000607
   Humidity sensor: interior:
7 Faults Found:
541973 - Databus
          [Motor_04 Datenbus fehlende Botschaft]
                    Reset counter: 197
                    Mileage: 199044 km
                    Date: 2023.04.21
                    Time: 14:34:43
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 12.5 V
                    Outside temperature: 20.0 °C
559125 - Databus
          [Motor_07 Datenbus fehlende Botschaft]
                    Reset counter: 197
                    Mileage: 202275 km
                    Date: 2023.06.01
                    Time: 14:33:15
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    last_wakeup: gültiges Funktelegramm
                    Voltage: 12.5 V
                    Outside temperature: 18.5 °C
555541 - Databus
          [Motor_12_alt aktiv]
                    Reset counter: 197
                    Mileage: 199044 km
                    Date: 2023.04.21
                    Time: 14:34:43
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.5 V
542229 - Databus
          [Motor_14 Datenbus fehlende Botschaft]
                    Reset counter: 197
                    Mileage: 199044 km
                    Date: 2023.04.21
                    Time: 14:34:44
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.5 V
542485 - Databus
          [Motor_18 Datenbus fehlende Botschaft]
                    Reset counter: 197
                    Mileage: 202275 km
                    Date: 2023.06.01
                    Time: 14:33:15
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.5 V
66314 - Positioning Motors for Headlight Range
          B1528 F1 [008] - Control Voltage Implausible
          B1263 01 [009] - Electrical Failure
                    Reset counter: 151
                    Mileage: 196399 km
                    Date: 2023.03.28
                    Time: 16:34:01
                    Terminal 15 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 11.8 V
                    Outside temperature: 12.5 °C
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418917340 Dataset Number: V03935258CH 0001
   Coding: 0471151911
   Shop #: WSC 14059 003 1048576
   VCID: 4BC3691A334165B2AA9-801E
12648465 - Databus
          [Motorsteuergerät - Motor_12 - kein Signal/keine Kommunikation]
                    Reset counter: 197
                    Mileage: 199044 km
                    Date: 2023.04.21
                    Time: 14:34:41
13637426 - Databus
                    Fault Frequency: 12
                    Reset counter: 197
                    Mileage: 199044 km
                    Date: 2023.04.21
                    Time: 14:34:42
12648468 - Databus
          [Motorsteuergerät - Motor_20 - kein Signal/keine Kommunikation]
                    Reset counter: 197
                    Mileage: 199044 km
                    Date: 2023.04.21
                    Time: 14:34:41
   Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
   Component: ACC BOSCH MQB H04 0195
   Dataset Number: V03935243QB 0001
   Coding: 3218776A5DFFCC28949C804D
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 35372FE245C50342ECD-8060
10 Faults Found:
0795 - Databus
          [FAULT_APS_RELEVANT_ERROR]
                    Reset counter: 197
                    Mileage: 199044 km
                    Date: 2023.04.21
                    Time: 14:34:43
                    Control Module temperature: 30 °C
                    Voltage terminal 15: 12.4 V
                    Status_ACC_System: ACC_Init
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Fault Frequency: 17
                    Reset counter: 197
                    Mileage: 197428 km
                    Date: 2023.04.09
                    Time: 12:34:48
                    Control Module temperature: 20 °C
                    Voltage terminal 15: 11.8 V
                    Longitudinal_acceleration_vehicle_reference: -0.00 m/s²
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Fault Frequency: 16
                    Reset counter: 197
                    Mileage: 197428 km
                    Date: 2023.04.09
                    Time: 12:34:48
                    Voltage terminal 15: 11.6 V
0933 - Databus
          [FAULT_MOTOR_AGED_DATA]
                    Reset counter: 197
                    Mileage: 202275 km
                    Date: 2023.06.01
                    Time: 14:33:10
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 13.3 V
                    Velocity_vehicle_reference: 19.55 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.21 m/s²
1064 - Databus
          [FAULT_TIMEOUT_MOTOR_14]
                    Reset counter: 197
                    Mileage: 202275 km
                    Date: 2023.06.01
                    Time: 14:33:10
                    Voltage terminal 15: 12.9 V
                    Velocity_vehicle_reference: 19.46 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.23 m/s²
1067 - Databus
          [FAULT_TIMEOUT_MOTOR_20]
                    Fault Frequency: 19
                    Reset counter: 197
                    Mileage: 197428 km
                    Date: 2023.04.09
                    Time: 12:34:48
                    Voltage terminal 15: 11.7 V
1088 - Databus
          [FAULT_TIMEOUT_TSK_06]
                    Fault Frequency: 19
                    Reset counter: 197
                    Mileage: 197428 km
                    Date: 2023.04.09
                    Time: 12:34:48
1085 - Databus
          [FAULT_TIMEOUT_TSK_08]
                    Reset counter: 197
                    Mileage: 202275 km
                    Date: 2023.06.01
                    Time: 14:33:10
1139 - Databus
          [FAULT_TIMEOUT_TSK_Ausrollkurve_01]
                    Reset counter: 197
                    Mileage: 202275 km
                    Date: 2023.06.01
                    Time: 14:33:10
                    Velocity_vehicle_reference: 19.51 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.24 m/s²
2065 - Databus
          [FAULT_TSK_HANDSHAKE]
                    Reset counter: 188
                    Mileage: 199244 km
                    Date: 2023.04.25
                    Time: 14:18:27
                    Control Module temperature: 11 °C
                    Voltage terminal 15: 11.5 V
   Part No SW: 3Q0 959 655 BK    HW: 3Q0 959 655 BK
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W6PQTY1YI Dataset Number: V03935274VB 0001
   Coding: 88CCC000000000005C5400CF000800000065
   Shop #: WSC 05311 000 08193
   VCID: 0849961662B74EAA47B-805C
   Left seat belt tensioner:
   Serial number: 3G1857705G0332R00762
   Coding: 80000D
   Right seat belt tensioner:
   Serial number: 3G1857706G0335R01113
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 002 211 17
   Serial number: 3570000000042B38DA2P
   Subsystem 4 - Part No SW: -----------    HW: 454 002 711 17
   Serial number: 35800000000C358D5A2V
   Subsystem 5 - Part No SW: -----------    HW: 454 802 411 17
   Serial number: 35100678A9612000000F
   Subsystem 6 - Part No SW: -----------    HW: 454 802 611 17
   Serial number: 352009EA84512000000K
   Subsystem 7 - Part No SW: -----------    HW: 454 801 711 17
   Serial number: 3550060015B12000000$
1053952 - Databus
          [NWD: 0x121 Motor_20 Timeout]
                    Fault Frequency: 14
                    Reset counter: 197
                    Mileage: 197428 km
                    Date: 2023.04.09
                    Time: 12:34:48
1056000 - Databus
          [NWD: 0x3BE Motor_14 Timeout]
                    Fault Frequency: 14
                    Reset counter: 197
                    Mileage: 197428 km
                    Date: 2023.04.09
                    Time: 12:34:49
1057792 - Databus
          [NWD: 0x0A8 Motor_12 Timeout]
                    Fault Frequency: 14
                    Reset counter: 197
                    Mileage: 197428 km
                    Date: 2023.04.09
                    Time: 12:34:48
   Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20171201100668
   Coding: 0C10
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   Part No SW: 3G0 920 791 C    HW: 3G0 920 791 C
   Component: KOMBI         407 3195
   Coding: 07A409086784000801887B031001000000000000
   VCID: 290FF392997D57A2785-807C
16776971 - Databus
          [Motor_04 keine Kommunikation]
                    Fault Frequency: 14
                    Reset counter: 197
                    Mileage: 197428 km
                    Date: 2023.04.09
                    Time: 12:34:48
16776988 - Databus
          [TSK_07 keine Kommunikation]
                    Fault Frequency: 15
                    Reset counter: 197
                    Mileage: 197428 km
                    Date: 2023.04.09
                    Time: 12:34:48
   Component: GW MQB High   518 5323
   Serial number: 25111710521013 Dataset Number: V03935261BG 0001
   Coding: 030300345F087300FB00025C1C0F00010001070000000000000000000000
   GVL: 01543C0000000400C08C80000002C80000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 382926D652D7FE2AF7B-806C
   Generator:
   Component: E221__MFL-DC1  H17 0040
   Serial number: 29170002477000097435
   Coding: 2DFFFF
   Serial number: 75886000001711270040
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
          [Timeout Knoten 0x76 / 01 - Motorsteuergerät]
                    Reset counter: 197
                    Mileage: 198641 km
                    Date: 2023.04.18
                    Time: 15:13:58
                    Terminal 30 power supply: 12.1 V
                    Terminal 15: OFF
   Serial number: 280917EIR27906 Dataset Number: V03935272KC 0001
   Coding: 00350B20D000028000001000
   VCID: 43D3413A1B11ADF2529-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000007689901
458803 - Databus
                    Reset counter: 197
                    Mileage: 199044 km
                    Date: 2023.04.21
                    Time: 14:34:41
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 760001 00  Dataset Number: V03935281HT 0001
   Coding: 0100001100400010
   Shop #: WSC 131071 102 209715
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2_002_VW48.rod
3161888 - Databus
                    Fault Frequency: 8
                    Reset counter: 197
                    Mileage: 199044 km
                    Date: 2023.04.21
                    Time: 14:34:41
                    Write only channel
3158274 - Databus
                    Fault Frequency: 8
                    Reset counter: 197
                    Mileage: 199044 km
                    Date: 2023.04.21
                    Time: 14:34:41
                    Write only channel
3161984 - Databus
                    Fault Frequency: 8
                    Reset counter: 197
                    Mileage: 199044 km
                    Date: 2023.04.21
                    Time: 14:34:41
                    Write only channel
3161920 - Databus
                    Fault Frequency: 8
                    Reset counter: 197
                    Mileage: 199044 km
                    Date: 2023.04.21
                    Time: 14:34:41
                    Write only channel
3161872 - Databus
                    Reset counter: 197
                    Mileage: 202275 km
                    Date: 2023.06.01
                    Time: 14:33:15
                    Write only channel
   Serial number: 031117EK324327 Dataset Number: V03935268PR 0001
   Coding: 00350120DE00028000001000
   VCID: 42DD443E040BA4FA59F-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000007696675
   Coding: 090000
458803 - Databus
                    Reset counter: 197
                    Mileage: 199044 km
                    Date: 2023.04.21
                    Time: 14:34:41
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    851 0867
   Serial number:                Dataset Number: V03935264UK 0001
   Coding: 02840201FF0000005111010100880A001F0100E4012000008F
   Shop #: WSC 05311 115 00061
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 323D14FEB4AB147AC9F-8066
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZHT3402210
   Subsystem 2 - Part No SW: 5NA 919 866 CK    HW: -----------
   Component: ECE AS 2023  --- 1910
6708 - Databus
          [Engine: no communication]
                    Reset counter: 197
                    Mileage: 202275 km
                    Date: 2023.06.01
                    Time: 14:33:14
                    Voltage terminal 30: 12.5 V
                    Network diagnosis-Status: Enabled
   Part No SW: 5Q0 907 383 J    HW: 5Q0 907 383 B
   Component: Anhaenger     H21 0204
   Revision: 8C001003    Serial number: 0444534779
   Coding: 0100000202000000
   VCID: 3E2530CE70F3C01A3D7-806A
336388 - Databus
          [Engine electronics - no signal/communication]
                    Fault Frequency: 8
                    Reset counter: 197
                    Mileage: 199044 km
                    Date: 2023.04.21
                    Time: 14:34:42
656650 - Bulb for Right Turn Signal on Trailer
          C10F6 15 [008] - Open or Short to Plus
                    Reset counter: 173
                    Mileage: 198795 km
                    Date: 2023.04.20
                    Time: 05:34:44
656906 - Bulb for Left Turn Signal on Trailer
          C10F7 15 [009] - Open or Short to Plus
                    Fault Frequency: 31
                    Reset counter: 151
                    Mileage: 197883 km
                    Date: 2023.04.12
                    Time: 17:01:51
   Dataset Number: V03935230RV 0001
   Coding: 0184020163002017000040
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW48.rod
   VCID: 392F23D269DDE722085-806C
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 27111712K20540 Dataset Number: V08154711FU 0001
   Coding: 0004080200000401002213458140A90098000E000020
   VCID: 3C213AC666EFD20A133-8068
1123173 - Databus
          [ESP_21_ESP_Systemstatus]
                    Reset counter: 197
                    Control Module temperature: -258 °C
                    Outside temperature: 77.5 °C
                    Vehicle speed: 655.35 km/h
                    System run time: 0.0 s
                    Voltage terminal 15: 11.2 V
                    mid: 02 E0
                    Status of camera: Initialization
                    Engine_Running_Info: 255
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1122628 - Databus
          [Timeout_Motor_14]
                    Reset counter: 197
                    mid: 01 E5
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1122629 - Databus
          [TIMEOUT_Motor_20]
                    Reset counter: 197
                    mid: 01 E9
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1122679 - Databus
          [Timeout_TSK_06]
                    Reset counter: 197
                    mid: 02 12
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1275 - Front Sensors for Driver Assist
          B182E F0 [008] - Function Restriction due to Environmental Influences
                    Reset counter: 146
                    Mileage: 199608 km
                    Date: 2023.04.27
                    Time: 14:40:10
                    Control Module temperature: 45 °C
                    Outside temperature: 11.5 °C
                    Vehicle speed: 38.56 km/h
                    System run time: 1769.7 s
                    Voltage terminal 15: 14.8 V
                    mid: 01 63
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
End----(Elapsed Time: 02:10, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Looks like the ECU is dropping off-line. That will indeed cause the engine to stall. Power problem to the ECU?
Lieberkind
Denmark
C?ID=511675
Thanks.
will look after wire problems or connectors.
Lieberkind
Denmark
C?ID=511675
UPDATE
Foundation out that 1 relay in engine compartment had a faulty socket.
This is fixed now.
Thank you for your help.
