p047a sensor adaptation code
mikeme
Alexandria/fairfax county VA
C?ID=99408
fella from another site stopped by and I ran this scan for him
he had replaced an exhaust pressure sensor to repair a P047A code, and was following up on adaptation of that sensor.
he had a basic OBD tool reset errors after replacing the sensor, and the MIL did not come back on over a 2000 mile trip back to VA from ND.
I ran the scan and was going to run the adaptation for the pressure sensor.
VCDS wanted a code to run the exhaust sensor adaptation, where is this code to be found? Thanks.
( I would guess after 2000 miles or so, it adapted itself. if you think otherwise, he will be back in a couple weeks.)
also, based on this scan, and evidence of a moderate amount of soot on his tailpipe, we discussed the issues related to repair/replacement of the DPF and EGR filter sooner or later for the P0401 code. in the mean time, as you can see in the scan it is still an intermittent code.
Tuesday,11,August,2015,16:39:08:51928
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
VIN: 3VWTL81K49M......   License Plate:
Mileage: 377520km-234580mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 56 62 65
          72
VIN: 3VWTL81K49M......   Mileage: 377520km-234580miles
Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 016 P    HW: 03L 906 022 J
   Component: R4 2,0L EDC G000AG  8681
   Revision: 12H01---    Serial number: VWX7Z0I324O0NT
   Coding: 0050078
   Shop #: WSC 09110 444 177425
   VCID: 3FA390536EB764C66F-806A
001025 - EGR System
               P0401 - 000 - Insufficient Flow - Intermittent
                    Fault Frequency: 28
                    Mileage: 376181 km
                    Time: 13:26:41
                    RPM: 1633 /min
                    Speed: 34.0 km/h
                    Voltage: 13.83 V
                    Load: 95.7 %
                    Load: 100.0 %
                    Mass Air / Rev.: 370.0 mg/str
                    Mass Air / Rev.: 405.0 mg/str
Readiness: 0 1 0 0 0
   Part No SW: 02E 300 052     HW: 02E 927 770 AJ
   Component: GSG DSG AG6     431 1953
   Revision: 04843012    Serial number: 00000809061226
   Shop #: WSC 00066 000 00000
   VCID: 5187A6EBC823E2B689-8004
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AE    HW: 1K0 907 379 AE
   Component: ESP MK60EC1   H35 0106
   Revision: 00H35001
   Coding: 113B600D492600FF881406EA921C0042B100
   VCID: 75CF327BDC0BEE9675-8020
   Part No SW: 1K0 820 047 JJ    HW: 1K0 820 047 JJ
   Component: Climatic PQ35   143 1313
   Revision: 00143033    Serial number: 00000000000000
   VCID: 75CF327B1C0BEE9675-8020
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000009430066
   Coding: 14898F2340041500070000001C000000000873075C000120000000000000
   VCID: 3245C967ADE5B9AE90-8066
   Component: Wischer 290409 021  0501
   Coding: 00038805
   Part No SW: 1K0 909 605 AD    HW: 1K0 909 605 AD
   Component: 02 AIRBAG VW8R  036 8900
   Revision: 06036000    Serial number: 003EVM002JEJ
   Coding: 0012338
   VCID: 6EFD1D17795DDD4EB4-803A
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME447454278
   Subsystem 3 - Serial number: 6342MSME452510290
   Subsystem 4 - Serial number: 6351HSME1C4F4F0DV
   Subsystem 5 - Serial number: 6361HSME1C4E4207C
   Subsystem 6 - Serial number: 63727SME1C1E482DF
   Subsystem 7 - Serial number: 63827SME1C1F4F64J
   Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
   Component: J0527           053 0111
   Coding: 0001034
   VCID: 022559A75DC5C92E40-8056
   Part No SW: 1K0 920 974 N    HW: 1K0 920 974 N
   Component: KOMBIINSTRUMENT 3HL 2418
   Revision: V0005000    Serial number: VWX7Z0I324O0NT
   Coding: 0007203
   VCID: 3957FE4B70934AF651-806C
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 T    HW: 1K0 907 951
   Component: J533  Gateway   H06 0071
   Revision:   H06 01    Serial number: 170309F2002027
   Coding: ED807F07400213002002
   VCID: 3851FB4F4B9953FEAE-806C
   Component: IMMO            3HL 2418
   Shop #: WSC 09432 444 05560
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Component: SG EXT.PLAYER H13 0084
   Revision: A1001003    Serial number: 7667365130
   VCID: 266D2537512DD50E0C-8072
   Part No SW: 3C0 035 684 A    HW: 3C0 035 684 A
   Component: RNS-MID       H01 0380
   Revision: AB001001    Serial number: VWZ6Z7J9071114
   Coding: 040004000400000600
   VCID: 2167362B3803323679-8074
            000 -  -
                    Reset counter: 21
                    Mileage: 336960 km
                    Reset counter: 61
                    Mileage: 336966 km
                    Time: 14:21:31
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000776398205
   Coding: 0001205
   VCID: 6FC300137E57D446BF-803A
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 70     2501
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2C79D71F8FC1EF5EDA-8078
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 DA    HW: 1K0 959 433 DA
   Component:    KSG PQ35 RDK 052 0225
   Coding: 139007885283281B0904058FB0880F0488DC00
   VCID: 72C509676D65F9AE50-8026
Address 4F: Centr. Electr. II (J533)       Labels: 1K0-907-532.clb
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Coding: 050B0500
   VCID: 66ED653791AD150ECC-8032
   Component: J245EE19SKB12  H01 0220
   Component: J394EE19SKB12  H01 0220
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 08121600053003
   Coding: 0001204
   VCID: 70C1036F6369CBBEA6-8024
            000 -  -
                    Reset counter: 21
                    Mileage: 336960 km
                    Reset counter: 61
                    Mileage: 336966 km
                    Time: 14:21:31
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003892377
   Coding: 0001168
   VCID: 76CD3577010DE58E7C-8022
   Component:    RDK              0453
   Coding: 0100101
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000003890538
   Coding: 0001168
   VCID: 77D3387306079C8667-8022
End-------------------------(Elapsed Time: 01:40)--------------------------
mikeme
C?ID=99408
Never mind about the adaptation code.
I looked this morning with the VCDS hooked up to my car and the value is suggested in a window available on the screen asking for the information.
would still be interested in an opinion as to if such adaptation is needed, especially after a couple thousand miles have passed since installing the differential pressure sensor
Gone But Not Forgotten
This is usually due to a internal filter pipe plugged to the EGR or dirty/faulty EGR.
