Boost pressure control valve (n249) fault - leon fr 1pz
adfow_uk
C?ID=136053
HI ALL,
KEEP GETTING FOLLOWING FAULT IN ENGINE MANAGEMENT SYSTEM, HAVE REPLACED N249 SOLENOID BUT FAULT RE-APPEARS. HAVE ALSO CHECKED WASTEGATE, PIPES AND HOSES FOR OPERATION/CONDITION - ALL OK.
MANY THANKS FOR YOUR HELP
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ1PZ7R008061   Mileage: 131310km-81592miles
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1P0 907 115     HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0040
   Revision: --H14---    Serial number: SEZ7Z0F3505878
   Coding: 0303000318070160
   Shop #: WSC 64018 476 92338
   VCID: 68D5B6C75BAB5E7EFE-803C
008801 - Boost Pressure Control Valve (N249)
               P2261 - 008 - Mechanical Malfunction
                    Fault Status: 01101000
                    Mileage: 131308 km
                    Time: 19:02:45
                    RPM: 2737 /min
                    Load: 12.2 %
                    Speed: 86.0 km/h
                    Temperature: 90.0°C
                    Temperature: 42.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.970 V
Readiness: 0010 0001
   Revision: 00H11001
   Coding: 0004738
   Shop #: WSC 06441 785 00200
   VCID: 73EFD1AB126DADA65B-8026
   Part No: 1P0 907 044
   Component: ClimatronicPQ35 009 0402
   VCID: 69D3B3C340A16776E1-803C
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Revision: 00H37000    Serial number: 00000004162570
   Coding: 818C0F2F00041000001D00000000000000007F075C
   VCID: 2B5F09CB8ADDB566D3-807E
   Subsystem 1 - Part No: 1P0 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SE350  012  0403
   Coding: 00056272
   Shop #: WSC 06441
   Part No SW: 3C0 909 605 H    HW: 3C0 909 605 H
   Component: R5 AIRBAG VW8   027 2521
   Revision: 09027000    Serial number: 003A1PANTR21
   Coding: 0021045
   Subsystem 1 - Serial number: 6332MSME0E1A1A7F
   Subsystem 2 - Serial number: 6342MSME0F133413
   Subsystem 3 - Serial number: 6351HTS6QLLM0PB3
   Subsystem 4 - Serial number: 6361HTS6QLLILAH2
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           634 0070
   Coding: 0002042
   VCID: 77F7E5BB0615C18667-8022
   Component: E0221           005 0060
   Part No: 1P0 920 925 B
   Component: KOMBIINSTRUMENT VO3 0422
   Coding: 0002401
   Shop #: WSC 00999 444 64523
   VCID: 2E5900DFB9CFC04EF4-807A
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 31001065158587
   Coding: 3D3F034007000203
   VCID: 2C5D0AD78FD3B25EDA-8078
   Component: IMMO            VO3 0422
   Part No SW: 1T0 959 701 G    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1124
   Revision: 11006001    Serial number: 00000504768523
   Coding: 0000688
   VCID: 3B7F398B7ABD25E643-806E
00914 - Window Regulator Switch; Rear Left; Driver (E53)
                    Reset counter: 132
                    Mileage: 131249 km
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.142 H07 1806
   VCID: 356B2FB35C99F396B5-8060
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Component:    KSG PQ35 G2  020 0202
   Coding: 198000005283CC7F0006050560085F86107C80
   VCID: 030F816B42CD9D264B-8056
   Subsystem 5 - Part No: 1P0 951 171
   Component: Innenraumueberw.010 4971
   Coding: 00000000
   Shop #: WSC 06441
   Subsystem 6 - Part No: 1K0 951 605 C
   Subsystem 7 - Component:       NGS n.mounted
   Part No SW: 1T0 959 702 G    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1124
   Revision: 11006001    Serial number: 00000509968527
   Coding: 0000688
   VCID: 3C7D3A977FB322DE4A-8068
   Part No: 1P2 035 186 A
   Component: Radio BVX           0006
   Coding: 0042424
   Shop #: WSC 04941 785 00200
00871 - Bass Speaker Front Right (R23)
   Part No SW: 1K0 959 703 N    HW: 1K0 959 795 H
   Component: J388   TUER-SG HL   1103
   Revision: 11004001    Serial number: 00000000098919
   Coding: 0000144
   Part No SW: 1K0 959 704 N    HW: 1K0 959 794 H
   Component: J389   TUER-SG HR   1103
   Revision: 11004001    Serial number: 00000000104092
   Coding: 0000144
End-------------------------(Elapsed Time: 01:56)--------------------------
elkm36a
C?ID=5916
Trying to understand this better:
Are these all the same?
Parts store: Turbocharger Cut Off Bypass Valve
Repair manual: Turbocharger Recirculating Valve N249
Vag-Com: Boost Pressure Control Valve N249
Forums: DV (Turbo diverter valve)
Any more names?
(neme used by parts store ?
It's unbelievable to
I'm reasonably confident they're all referring to the same thing.
Any more names?
Ricers like to call it the "blow off valve". :rolleyes:
NostraJackAss
Also "Secondary boost control valve" or "emergency boost control valve".............
"Turbo boost pulse protection valve"
DrPeter
16.4905° S, 151.7375° W
Some others...
- Pop-off valve
- "Blow-off valve" - (Like Uwe said) (I hear that a lot, I call it the diverter valve).
- Just to clarify:
The diverter valve is the actual part that is doing the diverting of boost pressure back into the intake stream when you let off the throttle,
this way you do not 'stall the turbo' with backed up boost pressure after the throttle plate closes, because the turbo is still spinning and
you want this so you do not have to re-spool the turbo each time the throttle closes, like when you are shifting gears.. etc.
The N249, is an electrical solenoid that the ECM controls to regulate the vacuum to the above diverter valve.
The ECM can watch the boost pressure with the G31 pressure sensor and when the throttle plate closes,
the boost pressure should not increase, because the diverter valve is commanded open. If the pressure does increase,
the ECM suspects the diverter valve has not opened and sets the fault.
Hope this helps,
drpeter
