Audi 8K _ footwell light dimming
pronet
Romania
C?ID=157414
I try to reactivate the foot lights dimming on an A4 8K platformm and it's not reconigzed by the MMI - I also activated on 5F and 09 Centr.Electr. It appears on MMI menu but not working. Any ideeas? Scan listed below:
Monday,21,April,2014,19:31:08:56830
VCDS Version: 14.4.0.3
Data version: 20140411
Workshop Code: 823 02391 056573
VIN: WAUZZZ8K6AA184103   License Plate:
Mileage: 72210km-44869mi   Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 20 3C 42 46 52 53 55 56
          5F 62 6D 72
VIN: WAUZZZ8K6AA184103   Mileage: 72210km-44869miles
Address 01: Engine (J623-CAGA)       Labels: 03L-906-022-CAG.clb
   Part No SW: 03L 906 022 MK    HW: 03L 906 022 B
   Component: R4 2,0L EDC   H04 8441
   Revision: 11H04---
   Coding: 0104002C02172018
   Shop #: WSC 20771 142 93681
   ASAM Dataset: EV_ECM20TDI03L906022MK A01009
   ROD: EV_ECM20TDI03L906022C.rod
   VCID: 7AF007C1FD02A7EB0E-802F
5182 - Particulate Trap Bank 1
          P2002 00 [096] - Efficiency Below Threshold
5231 - Fuel Rail/System Pressure
          P0087 00 [096] - Too Low
Address 02: Auto Trans (J217)       Labels: 0AW-927-156.clb
   Part No SW: 8K0 927 155 AF    HW: 0AW 927 156 H
   Component: 0AW 20TDI RdW H05 0009
   Revision: --H05---    Serial number: 0000000068
   Coding: 000002
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMVL381 A02017
   ROD: EV_TCMVL381.rod
   VCID: 77F61EF5CE10BA8371-8022
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
   Part No SW: 8K0 907 379 BD    HW: 8K0 907 379 BD
   Component: ESP8 front    H04 0030
   Coding: 174508
   VCID: 7CFC01D9FF3699DB1C-8029
   Part No SW: 8K0 907 064 DQ    HW: 8K0 907 064 DQ
   Component: BCM2 1.1      H02 0328
   Coding: 010200
   VCID: 02007F219DD2EF2B56-8057
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H50 0070
   Revision: C1000000    Serial number: 01170520101881
   Coding: 34180000
   VCID: 0004752993DEFD3B40-8055
   Component: BCM1 1.0      H29 0380
   Revision: 10029001    Serial number: 00000000669267
   Coding: 260050914074AF010001000300001D0D0F1C470802010141000000
   Shop #: WSC 61904 000 1048576
   VCID: 3C7CC1D9BFB659DB5C-8069
   Component: WWS 150510  H06 0070
   Coding: 00FD11
   Component: RLS  H04 0003
   Coding: 025028
   Component: E1 - LDS  H08 0090
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 R    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0070
   Revision: 11001001    Serial number: 50941013003266
   Coding: 100103
   VCID: 4894AD09FB6E057BC8-801D
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 J    HW: 8K0 959 655 J
   Component: AirbagVW-AU10 H41 0610
   Serial number: 003GKD0GCAFJ
   Coding: 30343435363030303030554A304C384B3053
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 448CB939CF46211B24-8011
   Serial number: 6334MSME53162D66F
   Serial number: 6344MSME53356B018
   Serial number: 6352QSME225D02067
   Serial number: 6362QSME70611E029
   Serial number: 63732SME60611A04R
   Crash sensor for front airbag; passenger side:
   Serial number: 63832SME3C5F4816B
   Revision: --------    Serial number: 90315JEJ000EG
   Coding: 000013
   VCID: 3D7ACCDDA4AC50D36B-8068
   Component: E221 - MFL  H02 0010
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 930 D    HW: 8K0 920 930 D
   Component: KOMBIINSTR.   H21 0255
   Revision: 00000000    Serial number: CIY58LD5A
   Coding: 0F06100002000008000000
   VCID: 2E58FB9179CABB4BE2-807B
Address 18: Aux. Heat (J364)       Labels: 8R0-265-105.clb
   Part No SW: 4H0 265 105 A    HW: 4H0 265 105 A
   Component: Standheizung  H20 0230
   Revision: 34003004    Serial number: 20100422102634
   Coding: 5D2000
   VCID: 204415A9331E1D3B60-8075
   Part No SW: 8T0 907 468 AE    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0117
   Revision: FC100058    Serial number: 5800F105020163
   Coding: 00C303
   VCID: 040C793987C6E11B64-8051
   Component: J367-BDM  H07 0170
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
   Component: FLA           H04 0004
   Revision: AA001002
   Coding: 02019164747464545425363E
   VCID: 336EEAE592E896A38D-8066
   Part No SW: 8K0 907 566 H    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0030
   Revision: 00H01000    Serial number: 6PZ 009 014-82
   Coding: 0000102
   VCID: 3C7CC1D97FB659DB5C-8069
   Subsystem 1 - Part No: 8K0 907 568 H
   Component: J0770_SWA_Slave_H01 0030
   Subsystem 2 - Serial number: 6PZ 009 014-92
   Subsystem 3 - Serial number: 5F19.05.1000H010003C322037ÿ
   Subsystem 4 - Serial number: 322037ÿ
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000010674403
   Coding: 011C02205000410001
   VCID: 458AA43DCC7C181333-8010
   Revision: 00002001    Serial number: 0130130245
   Coding: 01000620203934800120023280000000
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000010644337
   VCID: 448CB939C746211B24-8011
   Revision: 00000003    Serial number: 10000000520016
   VCID: 346CE9F997E6919B94-8061
   Part No: 8K5 907 357
   Coding: 0000004
   Shop #: WSC 06334 000 00000
   VCID: 77F61EF50610BA8371-8022
   Part No SW: 4F0 035 056 B    HW: 4F0 035 056
   Component: Radio U STD   H45 0020
   Revision: AB001007    Serial number: 342E60A7809989
   Coding: 010003020100000001
   VCID: 1F4616550E6022C359-804A
   Part No SW: 8T1 035 666 E    HW: 8T1 035 666 E
   Component: H-BN-EU       H47 0047
   Revision: --------    Serial number: 483E10A7626495
   Coding: 01010001010683ED11000B1E000000030001
   Subsystem 1 - Part No: 8R0 060 884 J
   Component: EUR 2010  1005
   Component: DU7 High  H43 0306
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Component:   CD-Database  1293
                    Fault Frequency: 11
                    Reset counter: 134
                    Mileage: 72147 km
                    Date: 2014.04.19
                    Time: 21:20:23
                    Bin. Bits: 10110110 00001010
                    Bin. Bits: 00000100 00001110
                    Bin. Bits: 00000000 00000000
                    Reset counter: 134
                    Mileage: 72147 km
                    Date: 2014.04.19
                    Time: 21:20:23
                    Bin. Bits: 00100001 00010000
                    Bin. Bits: 00000000 00001010
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000104585539
   Coding: 010C02204000210001
   VCID: 4280BF21DD522F2B16-8017
   Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
   Component: J605  Master  H50 0330
   Revision: --------    Serial number: 8K9827851A
   Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
   Component: J756  Slave  H50 0330
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Revision:             Serial number: 0000104585540
pronet
Romania
C?ID=157414
Sorry for the late replay. Thanks for the link Dana. The dimming works fine until the friend's wife try to stop them. After that operation the dimming won't to come back to the original settings. Now I departured form the Germany where my friend live. I will suggest him to check if the green/hidden menu is activated as listed in the link provided. Thanks you a lot again. Cheers.
