Any help for a fault code on a Skoda Superb 2011 2.0 TDI CR. Ive done a search and there seems to be very little about this fault code. Customer complaints are first start in the morning engine and glow plug light are on (Non start), after many key on/off's the glow plug light will go out (now the car will start)
Here the autoscan:
Quick inspection show quite new VAG part stickers on slam pannel and most off the front end (customer has owned for 8 months and said not been in a crash in there time)
I have checked the wiring diagram and there a 5v feed that does 5 items (D141) - G28 crank sensor - G427 Fuel Pressure - G581 Wastegate postion - G212 EGR - G69 Throttle valve control
Does the 5v feed A relate to this feed? Or has anyone come accross this before and can give me a heads up where to start?
Cheers Toby
Here the autoscan:
VCDS Version: Release 15.7.0 Running on Windows XP x86
Data version: 20150729
DG Motor Services
Tuesday,11,August,2015,08:30:58:62916
Chassis Type: 3T (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBBE73T7B903#### Mileage: 202510km-125833miles
Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 JB HW: 03L 906 018 BR
Component: R4 2,0L EDC H23 7128
Revision: 42H23--- Serial number:
Coding: 00190012042500080000
Shop #: WSC 35110 377 09999
ASAM Dataset: EV_ECM20TDI01103L906018JB 003001
ROD: EV_ECM20TDI01103L906018JB.rod
VCID: 73EFB0B5DA40ECA65B-8026
4123 - Sensor Reference Voltage A
P0641 00 [040] - Open Circuit
Fault Frequency: 8
Mileage: 201527 km
Time: 00:00:00
Readiness: 0 1 0 0 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BD HW: 1K0 907 379 BD
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 863D601609250000611306E790220082300000
Shop #: WSC 33361 790 00079
VCID: 75EB8EADDC34F29675-8020
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 BD HW: 3T0 907 044 BD
Component: Climatronic H16 0402
Revision: 00005001
Coding: 0000000002
ROD: EV_ClimaAutoBasis_SK12.rod
VCID: 75EB8EADD434F29675-8020
Part No SW: 1K0 937 087 K HW: 1K0 937 087 K
Component: BCM PQ35 H+ 103 0615
Revision: 00103 AD
Coding: 48990AB8A05BF1C040080080310081E4437000AE532081605C8040000040
VCID: 3973429DB0AC56F651-806C
Subsystem 1 - Part No: 3T2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 06111 26 0602
Coding: 00D7B7
Component: RLS 181110 05 54 0403
Coding: 2730ED
Fault Status: 00101010
Fault Frequency: 8
Reset counter: 254
Mileage: 193005 km
Date: 2015.07.06
Time: 12:42:52
Term 15 On
Voltage: 13.75 V
Term 50 Off
Reset counter: 250
Mileage: 197003 km
Date: 2015.07.22
Time: 09:01:41
Term 15 On
Voltage: 12.40 V
Term 50 Off
Address 10: Park/Steer Assist (J446) Labels: 5J0-919-475.clb
Part No SW: 5J0 919 475 A HW: 5J0 919 475 A
Component: PARKHILFE 4K H11 0005
Revision: --H11--- Serial number: 32991031613024
Coding: 108011
ASAM Dataset: EV_EPHVA14SKxxx0000 001001
ROD: EV_EPHVA14SKxxx0000.rod
VCID: 336F70B59AC0ACA69B-8066
Part No SW: 3T0 959 655 C HW: 3T0 959 655 C
Component: J234__LAU VW10 HI 1918
Revision: 20014000 Serial number: 003K2PNU07BZ
Coding: 0016725
VCID: 41832A7D187C0E3619-8014
Subsystem 1 - Serial number: 6332MTS659083070
Subsystem 2 - Serial number: 6342MTS659493070
Subsystem 3 - Serial number: 6351HTS64E12G6KJ
Subsystem 4 - Serial number: 6361HTS61RS1G6KR
Subsystem 5 - Serial number: 63727TS6EHKVF6KR
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 1K5 953 521 AK HW: 5K0 953 569 B
Component: LENKS.MODUL 009 0136
Revision: FF010039 Serial number: 20101117301720
Coding: 0082140000
Shop #: WSC 33361 790 00999
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 76E989A1C932F98E7C-8022
Subsystem 1 - Part No SW: 3T0 959 537 HW: 3T0 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0012
Coding: 800000
Part No SW: 3T2 920 941 H HW: 3T2 920 941 H
Component: KOMBI H20 0420
Coding: 410B00
VCID: 3A715D91BDAA5DEE58-806E
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 201110F2001836
Coding: 353303
VCID: 30657FB963D697BEE6-8064
Fault Status: 00101011
Reset counter: 10
Mileage: 201032 km
Date: 2015.08.05
Time: 05:13:19
Component: IMMO H20 0420
VCID: 6AD1ADD18D8A2D6EE8-803E
Address 42: Door Elect, Driver (J386) Labels: 8X0-959-793.clb
Part No SW: 8X0 959 793 C HW: 8X0 959 793 C
Component: TSG FA H09 0409
Coding: 011D0220D001001000
VCID: 4D9B064D1424DA56ED-8018
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 195 3001
Revision: 00H17000
VCID: 31637ABDA8DC9EB6E9-8064
Address 52: Door Elect, Pass. (J387) Labels: 8X0-959-792.clb
Part No SW: 8X0 959 792 C HW: 8X0 959 792 C
Component: TSG BF H09 0409
VCID: 4C9D0B49EF3ED35EFA-8018
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 3T0 035 156 C HW: 3T0 035 156 C
Component: BOLERO 015 0029
Revision: -----29S Serial number: SKZ4Z3K1131549
Coding: 0D0004000004
VCID: 2E5961C179E2814EF4-807A
Part No SW: 8X0 959 795 B HW: 8X0 959 795 B
Component: TSG HL H06 0409
Coding: 010C00200001001000
VCID: 4E9901411922E14E94-801A
Component: TSG HR H06 0409
End-------------------------(Elapsed Time: 03:04)--------------------------
Cheers Toby
