Hi all,
I was wondering if any guru's were willing to lend an ear and offer insight. I've been in the process of trying to install the trailer control module from Westfalia on my car with no success.
The only step that I was able to complete successfully as per the write up here in the forums, was activating the module via VCDS.
So several issues:
1) The install manual that came with the Westfalia Trailer Module, show's the more advance 3 plug Body Control Module (BCM), that the rest of the world uses on the Jetta. Ours only comes with 2. This is a problem, as the wiring numeration is completely different. For instance they will say connect wire 52 etc to the module and wire 52 being Orange and green, but on my plug wire 52 is something completely different. So in essence, I can't even say with 100 percent certainty that I have the correct wires plugged in on the BCM plug.
Specifically for those of you who'm could provide guidance in this issue my wire's are all plugged into the white Plug on the BCM with the following numeration: The Can L (Orange and Green) is in slot #20. Can H ( Orange and Brown) Slot #21. Stop wire (black and red) Slot #50
I do have pictures of the wires in the slot's where I installed it and can also provide a scan of the page on the install manual, showing their diagram/description.
2) I also completed a scan, which pulled several errors. Two of them are explainable: Telematics my subscription ran out and the other being the dimmer switch as I had it disconnected when I did the scan. The others are not:
A) I am getting an error now for my AC/HVAC system that wasn't there before.
B) There is a Tire Pressure Monitor Error displayed and when I look, it doesn't show up as installed on my VCDS, despite my car having this feature.
Here is the scan:
Thank you all
So several issues:
Here is the scan:
Sunday,09,August,2015,13:24:29:60588
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
VIN: 3VW3L7AJ3EM361115 License Plate: TRAILER INSTALL
Mileage: 106890km-66418mi Repair Order: Rosstech info needed
Chassis Type: AJ (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 44 47 56 69 75 77
VIN: 3VW3L7AJ3EM361115 Mileage: 106890km-66418miles
Part No SW: 03L 906 019 KD HW: 03L 907 309 AA
Component: R4 2,0L EDC G000SG 5680
Revision: 12H16--- Serial number:
Coding: 0050072
Shop #: WSC 00066 000 00000
VCID: 77FDC14F0621E88667-8022
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: A14B400C492800FB850C02E5921E0042A71000
Shop #: WSC 00066 123 12345
VCID: 7DF1D367E41DC2D63D-8028
Reset counter: 62
Mileage: 105929 km
Date: 2015.08.06
Time: 00:02:50
Count: 2
Count: 2
Count: 20480
Count: 16390
Count: 45056
Count: 1
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 BA HW: 5C0 820 047 BA
Component: J301 Klimaanlage 0204
Revision: 2001012S Serial number: 00000001670793
VCID: 60CF8A13B3AF0F3E36-8034
00457 - Control Module for Network (J519)
Fault Status: 00101101
Fault Frequency: 9
Reset counter: 67
Mileage: 106110 km
Date: 2015.08.06
Time: 04:45:33
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 J HW: 5C0 937 087 A
Component: BCM25 JLB H3 H34 0411
Revision: B2034001 Serial number: 08018182140178
Coding: 7B994B9A08AB0B0008382000240884C50082502E6000000030 0050002000
Shop #: WSC 65171 001 1048576
VCID: 3467364397D7C39E82-8060
Subsystem 1 - Part No SW: 6R0 959 801 AN HW: 6R0 959 801 AN Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 5461
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AS HW: 6R0 959 802 AS Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 5461
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H10 0007
Coding: 180000
Subsystem 4 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0037
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Coding: 800000
Fault Frequency: 12
Reset counter: 67
Mileage: 106110 km
Date: 2015.08.06
Time: 04:45:35
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 AD HW: 5C0 959 655 AD
Component: AirbagVW10 102 0912
Serial number: 003MVD00CLY7
Coding: 00004138
ROD: EV_AirbaVW10SMEVW360_SE36.rod
VCID: 74E7F643DF57839E42-8020
Serial number: 6940000Y130000W2FA0U
Coding: 303036
Serial number: 3572MSME6A61037CZZZ
Serial number: 3582MSME2120707AZZZN
Serial number: 3516KSME1A494324ZZZQ
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME1D0C6625ZZZZ
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME59617B24ZZZ$
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME3B597B24ZZZ4
Part No SW: 5C6 920 953 A HW: 5C6 920 953 A
Component: KOMBI H04 0809
Coding: 270A01
Shop #: WSC 00066 000 00199
VCID: 2B552D3F42E99C66D3-807E
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H34 0411
Revision: B2034001
Coding: 102200
VCID: 70EFFA53A34FBFBEA6-8024
Fault Status: 00101011
Fault Frequency: 8
Reset counter: 64
Mileage: 106287 km
Date: 2015.08.07
Time: 02:32:48
Reset counter: 28
Mileage: 106896 km
Date: 2015.08.09
Time: 13:12:53
Component: IMMO H04 0809
VCID: 6ADBE83B8D93456EE8-803E
Address 2E: Media Player 3
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 70 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 3979077770B53EF651-806C
Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
Component: KonzernAmp10K H08 6815
Revision: -------- Serial number: EAA098A0167369
ROD: EV_AudioVerst10KanalSTT3.rod
VCID: 2643DC0B590BA10E0C-8072
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 188 F HW: 1K0 035 188 F
Component: Radio Prem-8 H07 0009
Revision: -----12S Serial number: VWZ4Z7P3557198
Coding: 01020040010006
VCID: 2B552D3F4AE99C66D3-807E
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008200692892
Coding: 0200000100000000
VCID: 306F3A5363CFFFBEE6-8064
Fault Status: 01101000
Reset counter: 22
Mileage: 105929 km
Date: 2015.08.06
Time: 00:56:52
Address 75: Telematics (J949) Labels: None
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0086
Serial number: 000003554140503
Coding: 02630102C2163A007F1606000000
ROD: EV_OCULow.rod
VCID: 53A555DF3A19E4A6BB-8006
12670464 - Databus
Reset counter: 63
Mileage: 106260 km
Date: 2015.08.07
Time: 01:03:15
0035 - Databus
Reset counter: 63
Mileage: 106260 km
Date: 2015.08.07
Time: 01:00:51
2103041 - Control Module
Fault Priority: 8
Reset counter: 28
Mileage: 106896 km
Date: 2015.08.09
Time: 13:23:03
Address 77: Telephone (J412) Labels: 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0315
Revision: 1B001001 Serial number: 00007664949522
Coding: 0A10030080010110
Shop #: WSC 01383 790 50316
ROD: EV_UHVUMI.rod
VCID: 2E53242B71FBE94EF4-807A
End-------------------------(Elapsed Time: 03:04)--------------------------
Thank you all
