Toolbox opens, but can't see/find it on the screen?
Zlatko Ilievski
Macedonia
C?ID=429748
Hello does anybody have problem with vcds toolbox after update to 23.3.1?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Can you elaborate what sort of problems you are experiencing?
Zlatko Ilievski
Macedonia
C?ID=429748
When you press on vcds toolbox it opens window but actualy there is no window if i go to task manager and click on and press maximize window only black screen apear i check od another pc it is the same i can post a pic later
Try deleting the file vcdsscan.ini.
Zlatko Ilievski
Macedonia
C?ID=429748
Thanks Uwe i try it but without success
I tried opening it on the latest version, and it opens.. somewhere.. Can't see it, though.
Since it appears both of you are having the same problem, I've merged these threads.
For laughs, try editing the vcdsscan.ini file. You must have the VCDSScan application closed while doing this -- use Task Manager to verify that it's not running and kill it first if it is running.
Two lines it in specify the screen position:
Screen-x=200
Screen-y=320
200 and 320 appear to be the defaults. Try setting both to 0, or to a very small value such as 10, and then start VCDSScan.
Zlatko Ilievski
Macedonia
C?ID=429748
Hi i see now about the solution that worked for me too but now some buttons are missed like long coding helper ……
Hedges-Mobile
Oxfordshire, UK
C?ID=531292
Screen-x=200
Screen-y=320
This solution worked for me also
JC_49
C?ID=571473
Bumping with my 2 cents. I had this same issue but just with the long coding helper. I was able to fix this by using the graphics driver reset shortcut Win + Ctrl + Shift + B
Once I pressed that combination, the screen flashed and the Long Coding helper appeared in the center of my screen.
brundozg
Baden-Württemberg, Germany
C?ID=427444
Additional thing which sometimes helps is Shift + Right mouse click on the icon in taskbar, then you get options Restore, Move, Size, Minimize and Maximize.
I did not have issues with VCDS, but often with other programs when switching from docking station with 3 screens (1 vertical, 2 horizontal) to single screen.
davisev5225
Democratic People's Republic of Commifornia, USA
C?ID=263265
Windows + Shift + Arrow (left or right)
This key combination will move your currently-active window between monitors. If you only have one monitor, it'll reset the window onto that single monitor.
