hex net does not work well enough to trust. have to use hex can cable
   #21
zach fowler
C?ID=40426
hi, yeah i understand ap is wireless. for several reasons it would be helpful to have a repeater in the building. my building is quite small and the router is less than 100 feet from the hex net. however, my building is all metal. for testing purposes it would be easier to set up the laptop as a repeater. that way i could use the hex net in wireless (not ap) mode at all times and still have a good signal. normally the hex net gets a good signal, but not at all times. ill look into what i can do to improve the signal. maybe move the router as well. thanks
   #22
zach fowler
C?ID=40426
how do I prevent vcds from updating or changing my autoscan files, or diesel graphs? every time I modify or correct those files. during updates my modifications are lost. how do I prevent that?
   #23
Put custom Auto-Scan entries in the MyAutoScan.txt file please.
What "correction" are you making to the TDIGraph.cfg? If there's something you think is amiss in there, let us know please.
zach fowler
C?ID=40426
hi, thanks, I don't think its amiss at all. its a personal pref for set up. I change the autoscan file to suit the cars I see and to only scan the modules on the car, some scan extra modules. the tdi graph, I only use the alh graph. I delete the other one, or save that file under a diff name and use a file with just alh. when vcds updates it changes those files again. I am finding it harder to change the files back. often times windows wont let me, says files are in use so I can not change them.
thanks
   #25
zach fowler
C?ID=40426
hello- I just (as in minutes ago) uploaded a debug file for the hex net. please disregard that file. the problem continues with the hex can cable also, suspect this is a car problem. thanks for the help
   #26
zach fowler
C?ID=40426
uhm, trying to scan a 2010 tdi sport wagon. unable to check dtc in engine ecu. unable to upload debug file, file is too large. vcds will not create another debug file after deleting the existing file, debug is set to 1024. what should I do when I check dtc and it says too many errors or not supported by ecu?
thanks
   #27
Any problem accessing any of the other systems in the car?
What happens when you try with a HEX+CAN?
There are no known issues scanning those cars with the HEX-NET. I just scanned one two days ago.
zach fowler
C?ID=40426
hello, there are no other problems scanning the car or other modules. I have tried to hex net several times today at different times, the hex net will not check dtc on this car. the hex can works perfectly. thanks
   #29
Mind posting an Auto-Scan made with a HEX+CAN? Perhaps there's something there that might provide a clue?
zach fowler
C?ID=40426
sure, I can send a hex can and hex net scan. how should I upload?
   #31
zach fowler
C?ID=40426
HEX CAN
Tuesday,29,September,2015,15:21:29:22738
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
Workshop Code: 123 23001 000000
VIN: WVWNM7AJ4AW323914   License Plate:
Mileage: 136840km-85028mi   Repair Order:
Chassis Type: AJ (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 65 72 77
VIN: WVWNM7AJ4AW323914   Mileage: 136840km-85028miles
   Part No SW: 03L 906 019 CL    HW: 03L 906 022 TS
   Component: R4 2,0L EDC G000SG  7966
   Revision: 12H03---    Serial number:
   Coding: 0050072
   Shop #: WSC 83980 036 673543
   VCID: 77F65A920695968667-8022
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 114B400C492400FD881402E5921D0042300000
   VCID: 78F459AECB8B99FE6E-802C
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Revision: 00009001
   Coding: 0000001002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 75EA509AD499E49675-8020
Address 09: Cent. Elect.
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   021 0706
   Serial number: 003C4D0AJLNJ
   Coding: 00003031
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
   ROD: EV_AirbaVW10SMEVW360_SE36.rod
   VCID: 39729CAAB80140F651-806C
   Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
   Component: BF-Gewichtss.  007 0002
   Serial number: ---0000R--0005255900
   Serial number: 3572MSME4566444FZZZ+
   Serial number: 3582MSME2F660350ZZZV
   Serial number: 3512QSME20054D71ZZZN
   Serial number: 3522QSME1C284D31ZZZ-
   Serial number: 35527SME22401B20ZZZ+
   Serial number: 35627SME656F3520ZZZJ
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Coding: 0000532
   VCID: 78F459AE0B8B99FE6E-802C
   Subsystem 1 - Part No: 3C8 959 537 D
   Component: E221__MFL-TK6   H06 0022
   Coding: 00000226
   Part No SW: 5K0 920 970 Q    HW: 5K0 920 970 Q
   Component: KOMBI         H03 0305
   Coding: 270F00
   VCID: 3C7C85BEB73375DE4A-8068
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 110210F2001826
   Coding: E9807F07001612000002
   VCID: 69D20CEA40213076E1-803C
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223T7A7C04
   Coding: 0000002
   VCID: 7EF84FB629AFA7CE24-802A
   Component: IMMO          H03 0305
   VCID: 6AD073E68D273B6EE8-803E
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667818362
   VCID: 264847D651BFDF0E0C-8072
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2113
   Coding: 0001204
   VCID: 3162A48AA87188B6E9-8064
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
Address 46: Central Conv.
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Coding: 0001204
   VCID: 3260AB86AD77B3AE90-8066
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H10 0035
   Revision: -----20S    Serial number: VWZ4Z7K1109169
   Coding: 0100040004
   VCID: 61C214CA7811783639-8034
            000 -  -
                    Reset counter: 143
                    Mileage: 136839 km
                    Date: 2015.09.29
                    Time: 10:47:45
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: 346CAD9E5763BD9E82-8060
Address 65: Tire Pressure (J502)       Labels: 1K0-937-08x-65.clb
   Part No SW: 1K0 937 087 G    HW: 1K0 937 087 G
   Component: RDK           103 0521
   Coding: 018705
   VCID: 356A909A9C19A496B5-8060
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0001168
   VCID: 356A909A5C19A496B5-8060
Address 77: Telephone (J738)       Labels: 1K8-035-730.clb
   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
   Component: Telefon       H08 6900
   Revision: 00008000    Serial number: 00000330039913
   Coding: 412100
   VCID: 2A50B3E645A7FB6E28-807E
            000 -  -  - Intermittent
                    Reset counter: 183
                    Mileage: 136839 km
                    Date: 2015.09.29
                    Time: 10:51:26
End-------------------------(Elapsed Time: 02:10)--------------------------
zach fowler
C?ID=40426
HEX NET
Tuesday,29,September,2015,15:31:53:04186
   Coding: 0050072
   VCID: F7BEA11E86DD9E86E7-80A2
No Faults Found
   Revision: 00H30001
   VCID: F8BCA2224BC391FEEE-80AC
   Revision: 00009001
   Coding: 0000001002
   VCID: F5A2AB1654D1EC96F5-80A0
   Coding: 00003031
   VCID: B93A6726384948F6D1-80EC
   Coding: 0000532
   VCID: F8BCA2228BC391FEEE-80AC
   Coding: 00000226
   Coding: 270F00
   VCID: BC347E32377B7DDECA-80E8
   VCID: E99AF766C069387661-80BC
   Coding: 0000002
   VCID: FEB0B43AA9E7AFCEA4-80AA
   VCID: EA98886A0D6F336E68-80BE
   VCID: A600BC5AD1F7D70E8C-80F2
   Coding: 0001204
   VCID: B12A5F06283980B669-80E4
   Revision: 00H17000
   Coding: 0001204
   VCID: B228500A2D3FBBAE10-80E6
   Coding: 0100040004
   VCID: E18AEF46F8597036B9-80B4
            000 -  -
                    Reset counter: 143
                    Mileage: 136839 km
                    Date: 2015.09.29
                    Time: 10:47:45
   Coding: 0001168
   VCID: B4245612D72BB59E02-80E0
   Coding: 018705
   VCID: B5226B161C51AC9635-80E0
   Coding: 0001168
   VCID: B5226B16DC51AC9635-80E0
   Coding: 412100
   VCID: AA18486AC5EFF36EA8-80FE
                    Reset counter: 183
                    Mileage: 136839 km
                    Date: 2015.09.29
                    Time: 10:51:26
End-------------------------(Elapsed Time: 01:43)--------------------------
OK, I can clearly see a big difference there, but nothing that stands out as an obvious reason for it.
Now for the sake of completeness, I have to ask: Does the HEX-NET still "balk" if you run it via USB instead of WiFi? And when you're running it via WiFi, is it in infrastructure or AP mode?
zach fowler
C?ID=40426
I do not use the usb cable with the hex net. I use it in wireless mode, I have changed my router, and added a repeater. I am 40 feet from the router and 15 feet form the repeater. I have not used the AP mode. my laptop is wireless, also when using the AP mode it is very slow to connect to the pc, sometimes will not
note: that car is also now gone. this problem does happen with other cars. I have noticed it seems very hard to scan diesels with the hex net.
   #35
Trying the HEX-NET with the supplied USB cable would narrow things down some. It would tell us whether the problem you are experiencing is with firmware that in the HEX-NET that interacts with the car or on the WiFi end of things. My guess is the latter.
zach fowler
C?ID=40426
hello, that sport wagon has been delivered to the customer. however, I have another tdi sport wagon in the building today and I am having the same trouble with this car. i will try the hex net with the usb cable and let you now how it goes. thanks
zach fowler
C?ID=40426
hex net with usb cable
VCDS Version: Release 15.7.0 (x64) Running on Windows 7 x64
Monday,05,October,2015,11:49:00:04186
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 65 72 77
VIN: 3VWPL7AJ7AM616036   Mileage: 107770km-66965miles
   Part No SW: 03L 906 019 CM    HW: 03L 906 022 TS
   Component: R4 2,0L EDC G000AG  9971
   Revision: 12H02---    Serial number:
   Coding: 0050078
   Shop #: WSC 23073 444 53552
   VCID: 78BC22220BC311FE6E-802C
No Faults Found
   Part No SW: 02E 300 052     HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1920
   Revision: 04844002    Serial number: 00000906290708
   Shop #: WSC 02069 000 90108
   VCID: 51EABF86C8F960B689-8004
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 114B600C49230000880B06E7921F0042B100
   Shop #: WSC 00066 000 00000
   VCID: 004C4AC29313593E56-8054
   Part No SW: 3C8 907 336 N    HW: 3C8 907 336 N
   Component: Climatic      H13 0203
   Revision: 00006001
   Coding: 0000000000
   Shop #: WSC 00066 000 00186
   ASAM Dataset: EV_Climatic A01001
   VCID: 383CE2228343D1FEAE-806C
   Part No SW: 5K0 937 085 C    HW: 5K0 937 085 C
   Component: BCM PQ35 B++  008 0019
   Revision: BI008001
   Coding: 6D380E1A902F3EC480080001400000C001000086535D8560648020000000
   VCID: 3326D50E922532A69B-8066
   Component: Wischer 09090  21  0501
   Coding: 009795
                    Reset counter: 120
                    Mileage: 106929 km
                    Date: 2010.01.11
                    Time: 09:36:08
                        Term 15 Off
                    Voltage: 11.85 V
   Component: AirbagVW10G   019 0706
   Serial number: 003C4D07A2Z0
   Coding: 00003044
   VCID: 393AE726B849C8F651-806C
   Subsystem 1 - Part No SW: 1KM 959 339     HW: 1KM 959 339
   Component: BF-Gewichtss.  007 0001
   Serial number: ---0000R--0004JSD600
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME16475249ZZZV
   Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME37635349ZZZY
   Serial number: 3511HSME4619241DZZZL
   Serial number: 3521HSME2745221DZZZI
   Serial number: 35527SME191C1400ZZZ4
   Serial number: 35627SME0B231400ZZZ+
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Coding: 0001532
   VCID: 76A02C1A01D7678E7C-8022
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
   Part No SW: 5K0 920 970 L    HW: 5K0 920 970 L
   Component: KOMBI         H08 0021
   Revision: V0008011    Serial number:
   Coding: 270F00
   Shop #: WSC 00066 000 00150
   ASAM Dataset: EV_KombiUDSMM9RM10 A04010
   ROD: EV_KombiUDSMM9RM10_VW36.rod
   VCID: 373EE11E8E5DDE86A7-8062
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H07 0081
   Revision:   H07 01    Serial number: 210709F1000078
   Coding: ED807F07001602002002
   VCID: 66807C5A5177970ECC-8032
   Revision: 00001000    Serial number: 1225223T5XSF04
   Coding: 0000002
   VCID: 7EB0343A29E72FCE24-802A
   Component: IMMO          H08 0021
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01010
   ROD: EV_ImmoUDSMM9RM10_SE25.rod
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000758998820
   Coding: 0001205
   VCID: 6FAE197E7E8D5646BF-803A
00109 - Left Mirror Turn Signal Lamp (L131)
                    Fault Status: 00101100
                    Reset counter: 159
                    Mileage: 104900 km
                    Date: 2015.04.27
                    Time: 09:34:23
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 70     2901
   Revision: 00H17000
   VCID: 2F2ED97EBE0D1646FF-807A
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 09052400011001
   Coding: 0001204
   VCID: 70AC1A0263B349BEA6-8024
Address 56: Radio
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000004233650
   Coding: 0001168
   Component: RDK           008 0817
   Coding: 018705
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000004231766
   Coding: 0001168
   VCID: 77BE211E06DD1E8667-8022
00938 - Switch for Electric Window; Rear Right (E54)
                    Reset counter: 122
   Part No SW: 1K8 035 730 C    HW: 1K8 035 730 C
   Component: Telefon       H08 6600
   Revision: 00008000    Serial number: 20389520172059
   Coding: 412100
   VCID: 291A376640E9787621-807C
End-------------------------(Elapsed Time: 01:40)--------------------------
zach fowler
C?ID=40426
working on 06 beetle convertible 5cyl. same problem trying to scan 01......any fixes yet?
   #39
Santos
Hi Zach, the debug files you sent shows the HEX-NET codeblock is at .4215. The current version is .4222. Please update and try again.
   #40
zach fowler
C?ID=40426
hi, thanks for the reply. software is updated. working on 06 beetle 2.5 auto today. software is buggy. sorry to sound disappointed, but I am
