VCDS & STATUS OK
senna1
C?ID=231631
Why does VCDS Report status ok when there are faults, here is a scan on test work on the bench with locksmith type harness to deliberately cause faults
all the moduels report Staus Ok, can you explain why. the status says ok.
Tuesday,16,May,2023,19:55:02:51242
VCDS Version: 23.3.1.0 (x64)  HEX-NET2 CB: 0.4631.5
VIN: WVWZZZ3CZHE032909   License Plate: PASSAT BENCH
Mileage: 211458km-131393mi   Repair Order:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F
VIN: WVWZZZ3CZHE032909   Mileage: 211458km-131393miles
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ES    HW: 04L 907 309 R
   Component: R4 2.0l TDI   H23 1989
   Revision: B5H23---    CVN: 7FCF0AFE
   Coding: 0119001203451D083000
   Shop #: WSC 44058 002 1048576
   ASAM Dataset: EV_ECM20TDI01104L906026ES 002002
   ROD: EV_ECM20TDI01104L906026ES_002_VW48.rod
   VCID: 7F506C16C771FE52761-802A
   VINID: 9E69EAAAA0D3A985400C2240242C86176B
35 Faults Found:
4527 - Coolant Fan Control Circuit 1
          P0480 00 [035] - Electrical Malfunction
21469 - Neutral Position Sensor 1
          P086E 00 [035] - Intermittent/Erratic
26468 - Ignition Switch; ON Position
          P2532 00 [035] - Short to Plus
23813 - Engine Oil Temp. Sensor (G8)
          P0197 00 [035] - Signal too Low
14627 - Fuel Pump Control Module
          P025A 00 [167] - Electrical Fault
                    Engine RPM: 0.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: 10 °C
                    Intake air temperature: -40 °C
                    Voltage terminal 30: 13.040 V
                    Engine status: COENG_READY
5270 - Output for Starter Relay
          P0615 00 [035] - Open Circuit
5457 - Starter Relay 2
          P26E4 00 [035] - Electrical Malfunction
13865 - Coolant Pump for Intercooler
          P023A 00 [039] - Open Circuit
                    Voltage terminal 30: 13.020 V
                    Air mass at air mass meter 1: 0.0 kg/h
                    EGR temp. sensor 2: B1: raw value: 2222.0 °C
                    Outside temperature sensor 1: B1: raw value: -0.0 °C
                    Intake air temperature before throttle valve: calculated: 0.0 K
                    Charge air cooler output: temp. sensor 1: B1: raw value: -40.0 °C
                    Heater supp.pump 1 bank 1 charg.air cool.circuit: activat.: 10.00 %
                    Turbocharger 1 charger output: temp. sensor 1: B1: raw value: -40.0 °C
4978 - Glow Plug Module 1; Glow Plug Circuit
          P0670 00 [035] - Electrical Malfunction
5132 - Valve for Fuel Metering (N290)
          P0090 00 [167] - Open Circuit
5177 - Fuel Pressure Regulator Valve (N276)
          P2294 00 [167] - Open Circuit
5244 - Fuel Pressure Sensor (G247)
          P0193 00 [167] - Short to Plus
28388 - Coolant Pump 3
          P26F4 00 [039] - Electrical Malfunction / Open Circuit
                    Heater support pump 1 bank 1 second.circuit: activat.: 47.64 %
                    Shut-off timer: last engine shut-off time: 3 s
2813 - Accelerator Position Sensor (G79)
          P2122 00 [167] - Signal too Low
                    Accelerator pedal travel: raw value: 0.00 %
                    Accelerator pedal: sensor voltage 1: 0.0 mV
                    Accelerator pedal: sensor voltage 2: 0.0 mV
                    Accelerator pedal: switch positions-Bits 0-7: 8
                    Starter control: Interlock- or P/N-signal-Bits 0-7: 65
                    Limitation: torque: 1000.0 Nm
                    Control Module temperature: 17.8 °C
2815 - Accelerator Position Sensor 2 (G185)
          P2127 00 [167] - Signal too Low
10382 - Coolant Circulation Valve (N214)
          P1257 00 [035] - Open Circuit
10065 - Mass Air Flow Sensor (G70)
          P0104 00 [167] - Intermittent
                    Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
                    Standardized airflow ratio: filtered: 3.9999
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 0.00 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
                    Charge air pressure: specified value: 0 hPa
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 4131.2 hPa
                    Mean injection quantity: 0.00 mg/stroke
4820 - Engine Coolant Temp. Sensor (G62)
          P0118 00 [035] - Signal too High
5951 - Exhaust Gas Recirculation Sensor 2
          P0486 00 [039] - Electrical Malfunction
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Specified value: 0.00 %
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Actual value: 0.00 %
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Offset closed: 0.02 %
                    Exhaust recirculation valve 2 bank 1: monitoring - status-Bits 0-7: 7
                    Exhaust recirculation valve 2 bank 1: monitoring - status-Bits 0-7: 0
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Raw voltage: 0.0 mV
4900 - EGR Sensor 1
          P0405 00 [039] - Signal too Low
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Specified value: 0.00 %
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Offset closed: 2.60 %
                    Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7: 7
                    Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7: 0
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Raw voltage: 0.8 mV
5927 - Sensor for Exhaust Flap
          P048B 00 [039] - Electrical Malfunction
          [Exhaust Pressure Control Valve "A"Position Sensor/Switch Circuit/Open]
                    Particulate filter output: temp. sensor 1: bank 1: raw value: -0.0 °C
                    Exh.recircul.valve 1 bank 1: pos.feedback - Specified value: 0.00 %
                    Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 0.00 %
                    Exh.recircul.valve 1 bank 1: pos.feedback - Offset closed: 2.10 %
                    Exhaust recirculation valve 1 bank 1: monitoring - status-Bits 0-7: 16
                    Exh.recircul.valve 1 bank 1: pos.feedback - Raw voltage: 1.8 mV
4967 - Fuel Temp. Sensor A (G81)
          P0183 00 [035] - Open or Short to Plus
9491 - Engine Oil Pressure Regulation
          P06DA 00 [035] - Electrical Malfunction
5169 - Manifold Pressure / Boost Sensor (G31)
          P0238 00 [167] - Signal too High
9764 - Exhaust Pressure Sensor 1
          P0470 00 [035] - Malfunction
5253 - Particulate Filter; Differential Pressure Sensor
          P2452 00 [039] - Elect. Malfunction
                    Particle filter: air pressure sensor 1 bank 1: raw value: 0 hPa
                    Particl.filt.: different.press.sensor 1 bank 1: adaptat. value: 0 hPa
                    Par.fil: diff.pr.sens.1 bank 1: offset: -1 hPa
                    Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 0 hPa
                    Particle filter: soot mass measured: 9.97 g
                    Particle filter: soot mass calculated: 6.45 g
5306 - Throttle Position Sensor (G69)
          P0122 00 [167] - Signal too Low
          [Throttle/Pedal Position Sensor/Switch "A"Circuit Low]
                    Throttl.valve adapt. 1 bank 1: posit feedback - Specified value: 0.00 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed: -0.26 %
                    Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7: 0
                    Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7: 7
                    Throttl.valve adapt. 1 bank 1: posit feedback - Raw voltage: 0.0 mV
5325 - Boost Pressure Control Valve/Solenoid (Bank 1)
          P0045 00 [167] - Open Circuit
                    Turbine actuator 1 bank 1: posit.feedback - Specified value: 0.00 %
                    Turbine actuator 1 bank 1: posit.feedback - Actual value: 100.00 %
                    Turbine actuator 1 bank 1: posit.feedback - Offset closed: -1.46 %
                    Turbine actuator 1 bank 1: monitoring - status-Bits 0-7: 0
                    Turbine actuator 1 bank 1: monitoring - status-Bits 0-7: 7
                    Turbine actuator 1 bank 1: posit.feedback - Raw voltage: 0.6 mV
5334 - Turbocharger Boost Control Position Sensor Circuit
          P2564 00 [167] - Signal too Low
                    Turbine actuator 1 bank 1: posit.feedback - Raw voltage: 0.4 mV
4451 - Powertrain Databus
          U0002 00 [167] - No Communications
          [High Speed CAN Communication BusPerformance]
                    Cruise Control System (CCS): status-Bits 0-7: 7
                    selected gear-Bits 0-7: 0
10092 - Neutral Position Sensor 1
          P086D 00 [035] - Short to Plus
18110 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
          P0030 00 [035] - Malfunction / Open Circuit
20001 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
          P0036 00 [035] - Malfunction / Open Circuit
8621 - Sensor 1 for Exhaust Temp Bank 1 (G235)
          P0544 00 [167] - Circuit Malfunction
                    Turbocharger 1 turbine input: temp. sensor 1: B1: raw value: 1000.0 °C
                    Turbocharger 1 turbine output: temp. sensor 1: B1: raw value: -100.0 °C
                    Particulate filter input: temp. sensor 1: bank 1: raw value: -100.0 °C
                    Shut-off timer: last engine shut-off time: 6 s
5260 - Sensor 1 for Exhaust Temp Bank 1 (G235)
          P0544 00 [039] - Circuit Malfunction
                    Shut-off timer: last engine shut-off time: 2 s
Address 03: ABS Brakes
   Part No SW: 3Q0 959 435 D    HW: 3Q0 959 435 D
   Component: VWKESSYMQB    026 0811
   Revision: 00026000    Serial number: 0408644099 Dataset Number: V03935243VL 0001
   Coding: 002F0F0E0F
   Shop #: WSC 05311 115 00307
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3B28580693E922721A9-806E
13 Faults Found:
1057547 - Antenna for Keyless Entry System; Interior Antenna 1
          B1172 13 [137] - Open Circuit
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:00:23
                    Terminal_15_Kessy_specified_value: OFF
                    Terminal_15_Kessy_actual_value: OFF
                    Terminal_15_central electric_actual_value: OFF
                    Terminal_15red_Kessy_specified_value: OFF
                    Terminal_15red_Kessy_actual_value: OFF
                    Terminal_S_Kessy_specified_value: OFF
                    Terminal_S_Kessy_actual_value: OFF
                    Terminal_S_central electric_actual_value: OFF
                    Terminal_50_Kessy_specified_value: On
                    Terminal_50_Kessy_actual_value: On
                    ZAT_pressed: On
                    Park selector lever position: Not engaged and not locked
                    Request active: Condition met
                    Enabling Steering Column Lock: Condition not met
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 11.787 V
                    Internal_key_position: Kessy_defect
                    Vehicle speed: Initialization
                    Engine RPM: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: Not coded
                    Driver door: closed
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID-sensor 1 authentication: status: No response
                    ID-sensor 2 authentication: status: No response
                    ID-sensor 3 authentication: status: No response
                    ID-sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
1058315 - Antenna for Keyless Entry System; Interior Antenna 2
          B1174 13 [137] - Open Circuit
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:00:23
                    ZAT_pressed: On
                    Driver door: closed
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12687616 - Databus
          U1121 00 [137] - Missing Message
          [Message TSG_FT_01 missing]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    Terminal_15_Kessy_actual_value: On
                    Terminal_15_central electric_actual_value: On
                    Terminal_15red_Kessy_actual_value: On
                    Terminal_S_central electric_actual_value: On
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Request active: Condition not met
                    Control Module Voltage: 12.894 V
                    Driver information key position copy workshop: active
                    Driver door: closed
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12713984 - Databus
          [Message TSG_BT_01 missing]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    ZAT_pressed: OFF
                    Driver door: closed
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12716804 - Databus
          [Message Motor_14 missing]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    ZAT_pressed: OFF
                    Driver door: closed
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12718084 - Databus
          [Message Airbag_02 missing]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    ZAT_pressed: OFF
                    Driver door: closed
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
1073670 - Terminal 15
          B1148 12 [137] - Short to Plus
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    ZAT_pressed: OFF
                    Driver door: closed
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
1073926 - Terminal 15 Redundancy
          B11D6 12 [137] - Short to Plus
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    ZAT_pressed: OFF
                    Driver door: closed
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12718085 - Databus
          [Message ESP_21 missing]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:04:40
                    ZAT_pressed: OFF
                    Control Module Voltage: 12.963 V
                    Driver door: closed
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12718343 - Databus
          [Message Motor_07 missing]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    ZAT_pressed: OFF
                    Driver door: closed
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12718344 - Databus
          [Message Motor_09 missing]
                    Reset counter: 114
Address 08: Auto HVAC
   Part No SW: 5Q0 937 086 BF    HW: 5Q0 937 086 BF
   Component: BCM PQ37BOSCH 032 0222
   Revision: --------    Serial number: 865817061600W9 Dataset Number: V03935241AB 0001
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
40 Faults Found:
558101 - Databus
          [Airbag_02 Datenbus fehlende Botschaft]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: operated
                    Voltage: 12.8 V
                    Outside temperature: 77.5 °C
554517 - Databus
          [ESP_05_alt aktiv]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.9 V
533269 - Databus
          [ESP_20 Datenbus fehlende Botschaft]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.8 V
539157 - Databus
          [Klima_12 Datenbus fehlende Botschaft]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.8 V
556053 - Databus
          [LH_EPS_02_alt aktiv]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.8 V
555285 - Databus
          [LWI_01_alt aktiv]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.9 V
559125 - Databus
          [Motor_07 Datenbus fehlende Botschaft]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.8 V
542229 - Databus
          [Motor_14 Datenbus fehlende Botschaft]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.8 V
542485 - Databus
          [Motor_18 Datenbus fehlende Botschaft]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.8 V
549141 - Databus
          [TSG_BT_01 Datenbus fehlende Botschaft]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:00:03
                    Terminal 15 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Low beam: Not operated
                    Voltage: 11.7 V
                    Outside temperature: 77.0 °C
550677 - Databus
          [TSG_HBFS_01 Datenbus fehlende Botschaft]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.8 V
551445 - Databus
          [TSG_HFS_01 Datenbus fehlende Botschaft]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.8 V
137217 - Outside temperature sensor
          B103F 1B [137] - Resistance Too High
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.8 V
6922 - Bulb for Low Beam Headlamp Right
          B1218 15 [009] - Open or Short to Plus
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:17
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.8 V
7434 - Bulb for High Beam Headlamp Right
          B121A 15 [009] - Open or Short to Plus
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:19:28
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 13.0 V
5386 - Bulb for Front Right Turn Signal
          B11EA 15 [009] - Open or Short to Plus
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:53
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.8 V
9738 - Bulb for Left Parking Lamp
          B12E8 15 [009] - Open or Short to Plus
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:20
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.8 V
11274 - Bulb for Center Brake Light
          B12C6 15 [009] - Open or Short to Plus
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:36:08
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.8 V
10762 - Bulb for Right Tail Light
          B12BF 15 [009] - Open or Short to Plus
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:18
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.8 V
12298 - License Plate Light
          B12CA 15 [009] - Open or Short to Plus
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:18
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.8 V
5642 - Bulb for Rear Left Turn Signal
          B11E9 15 [009] - Open or Short to Plus
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:53
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.8 V
11018 - Bulb for Left Brake Light
          B12C2 15 [009] - Open or Short to Plus
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:36:08
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.8 V
13578 - Bulb for Left Tail Light 2
          B12C0 15 [009] - Open or Short to Plus
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:18
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.8 V
460041 - Heated Rear Window
          B1265 14 [009] - Open or Short to Ground
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.8 V
395273 - Control Circuit for Signal Horn
          B1344 14 [009] - Open or Short to Ground
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.8 V
263442 - Siren / Alarm Horn for Anti-Theft Alarm System
          B131D F7 [009] - No Release by Immobilizer
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:04:42
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.9 V
934148 - No Communications with Rain/Light Sensor
          U10F6 00 [009] - -
          [Sensor für Regen- und Lichterkennung->kein Signal/ Kommunikation]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:15
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 12.9 V
135432 - Terminal S
          B11A5 11 [009] - Short to Ground
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:35:18
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
Address 10: Park/Steer Assist
Address 13: Auto Dist. Reg
Address 15: Airbags
   Part No SW: 3Q0 953 521 DJ    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20160412500584
   Coding: 0400
   Shop #: WSC 00015 115 00001
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 7BA89806D369E2725A9-802E
   Part No SW: 3G0 920 941 B    HW: 3G0 920 941 B
   Component: KOMBI         202 9630
   Coding: 27A409102780260001886B011000000000000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009007
   ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
   VCID: 251C9E7E056D84825CD-8070
17 Faults Found:
9453074 - Fuel Level Sensor 1
          B103E 1B [009] - Resistance Too High
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:20:23
9459994 - Covering for fuel level indicator sensor 1
          B1059 1A [008] - Resistance Too Low
          [Geber 1 für Kraftstoffvorratsanzeige: Übergangswiderstand zu klein]
                    Reset counter: 154
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:20:15
13639936 - Databus
          [Steuergerät für BCM / Bordnetz / el. ZE: bitte Fehlerspeicher auslesen]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:20:03
16776960 - Databus
          [ACC_02 keine Kommunikation]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:20:03
16776961 - Databus
          [ACC_04 keine Kommunikation]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:20:03
16776962 - Databus
          [Airbag_01 keine Kommunikation]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:20:03
16776967 - Databus
          [EPB_02 keine Kommunikation]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:20:03
16776968 - Databus
          [ESP_24 keine Kommunikation]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:20:03
16776971 - Databus
          [Motor_04 keine Kommunikation]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:20:03
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:20:03
16776978 - Databus
          [LH_EPS_01 keine Kommunikation]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:20:03
16776984 - Databus
          [ELV_01 keine Kommunikation]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:20:03
16776988 - Databus
          [TSK_07 keine Kommunikation]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:20:03
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:20:06
          U1110 00 [009] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:20:06
16777022 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_NAV SD_0x32 keine Kommunikation]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:20:06
16777028 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_AWV_0x1B keine Kommunikation]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:20:06
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 26061610801902 Dataset Number: V03935241FS 0001
   Coding: 030300045F087300FB00005C080F00010001070000000000000000000000
   GVL: 01543C0000000600400C80000000480000000000000000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 7CAA9B1AD667E54A533-8028
16 Faults Found:
131594 - Parallel Parking Assistance Control Module
          U104E 00 [009] - No communication
          [Timeout Knoten 0x0A / 76 - Steuergerät für Parklenkassistent]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:00:02
                    Terminal 30 power supply: 11.7 V
                    Terminal 15: On
131602 - Power Steering Control Module
          U101D 00 [009] - No Communication
          [Timeout Knoten 0x12 / 44 - Steuergerät für Lenkhilfe]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:00:02
                    Terminal 15: On
131603 - No Communication with ABS Brake Control Module
          U0121 00 [009] - -
          [Timeout Knoten 0x13 / 03 - Steuergerät für ABS Bremse]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:00:02
                    Terminal 15: On
131605 - No Communications with Airbag Control Module
          U0151 00 [009] - -
          [Timeout Knoten 0x15 / 15 - Steuergerät für Airbag]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:00:02
                    Terminal 15: On
131633 - Control Module for Electronic Steering Column Lock
          U10A4 00 [009] - No Communications
          [Timeout Knoten 0x31 / 2B - Steuergerät für elektronische Lenksäulenverriegelung]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:00:02
                    Terminal 15: On
131654 - No Communications with HVAC Control Module (J301)
          U0164 00 [009] - -
          [Timeout Knoten 0x46 / 08 - Steuergerät für Klima]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:00:02
                    Terminal 15: On
131658 - Door Control Module - Driver's Door
          U0199 00 [009] - No Communications
          [Timeout Knoten 0x4A / 42 - Türsteuergerät Fahrerseite]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:00:02
                    Terminal 15: On
131659 - Door Control Module - Passenger's Door
          U0200 00 [009] - No Communications
          [Timeout Knoten 0x4B / 52 - Türsteuergerät Beifahrerseite]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:00:02
                    Terminal 15: On
131671 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [009] - -
          [Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:00:02
                    Terminal 15: On
131699 - Control unit for information electronics 1
          U1054 00 [009] - No Communication
          [Timeout Knoten 0x73 / 5F - Steuergerät für Informationselektronik 1]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:00:02
                    Terminal 15: On
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [009] - -
          [Timeout Knoten 0x76 / 01 - Motorsteuergerät]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:00:02
                    Terminal 15: On
0513 - Terminal 15
          U1405 00 [008] - Implausible signal
          [HW KL_15 unplausibles Signal]
                    Reset counter: 154
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:00:01
                    Terminal 15: On
197149 - Generator
          U1052 00 [009] - No Communication
          [Generator (LIN#1) Timeout]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:00:02
                    Terminal 15: On
197175 - Control unit for battery monitoring
          U1050 00 [009] - No Communication
          [BDM (LIN#1) Timeout]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:00:02
                    Terminal 15: On
197169 - Controls in Steering Wheel
          U108E 00 [009] - No Communications
          [MFL (LIN#2) Timeout]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:00:02
                    Terminal 15: On
197234 - Analog Clock
          U1096 00 [009] - No Communications
          [Analoguhr (LIN#2) Timeout]
                    Reset counter: 114
                    Mileage: 211458 km
                    Date: 2021.02.01
                    Time: 00:00:02
                    Terminal 15: On
Address 2B: Steer. Col. Lock
Address 44: Steering Assist
Address 52: Door Elect, Pass.
End----------(Elapsed Time: 00:40, VBatt start/end: 13.1V/13.1V)-----------
Westbury, UK
VCDS reports what the modules report - sometimes the gateway and the modules get out of sync, that's not a VCDS thing.
  • Agree
No, the Gateway reports them as OK. The modules themselves report the faults when queried directly. As for why the Gateway is out of synch with the modules, you'd have to ask the people who wrote the software in the modules and the Gateway.
senna1
C?ID=231631
:thumbs: JUST CURIOUS
senna1
C?ID=231631
Thats right it could be misleading ok once you know why
Westbury, UK
I'm curious why you insert code tags into your replies even when you're just typing?
Code tags are for wrapping an Auto-Scan or similar large block of data, not to just insert into every reply.
