Volkswagen Virtus india support needed.
vrpram
India
C?ID=550004
I’m using a Volkswagen virtus GT 2022 in India. Recently purchased the Ross tech VCDS Hex V2 device to perform some mods. But the car is not available on auto scan auto detect. Kindly add the vehicle and update the software. I’m here to offer you guys all support needed to do that. Just tell me what needs to be done?
PS: the Virtus GT is similar in every way to Skoda Slavia added during MY2021.
Hello, I would start by posting a complete and unedited Auto-Scan.
(you may have to enter the Chassis code or vehicle type manually)
Try this video: (~ time 1:43)
I'd be surprised if Auto-Detect didn't work on a 2022 model car. So just go to the Auto-Scan screen, leave all the defaults alone and just click [Start]. (Make sure the car's ignition is on. Engine doesn't need to be running, but can be.)
Once you post an Auto-Scan, we can see what the car is made of, and whether anything is missing from VCDS.
vrpram
India
C?ID=550004
Did the full auto scan today. Posting the results here:
Two fault codes(P0106 and U1054) popped up and both happened only once in the months of March and April. Is this a cause for concern or just a freak incident that can be ignored?
I haven't faced any issues while driving and the instrument cluster has not lit up with any warnings. Help would be appreciated.
Monday,15,May,2023,20:31:53:43458
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
VIN: MEXH22D28NT010227   License Plate:
Chassis Type: D2-VW27 (2Q0)
Scan: 01 02 03 05 08 09 15 17 19 2B 44 5F
VIN: MEXH22D28NT010227   Mileage: 10164km-6315miles
Address 01: Engine (J623-DUMA)       Labels: None
   Part No SW: 05E 906 018 DM    HW: 05E 907 309 BC
   Component: R4 1.5l TFS   H80 2082
   Revision: 8EH80000    CVN: 8DFF2BC3
   Coding: 012500122324090810000000000000000000000000000000
   Shop #: WSC 00793 648 00200
   ASAM Dataset: EV_ECM15TFS01105E906018DM 004003
   ROD: EV_ECM15TFS01105E906018DL_VW27.rod
   VCID: 73B3CD963B3FB4B2029-8026
   VINID: 755A1808250221E9000400821CE72D8A06
34562 - Manifold / Barometric Pressure Sensor (G71) / (F96)
          P0106 00 [096] - Implausible Signal
                    Reset counter: 11
                    Mileage: 7398 km
                    Date: 2023.03.30
                    Time: 10:03:37
                    Engine RPM: 1995.50 /min
                    Normed load value: 27.1 %
                    Vehicle speed: 35 km/h
                    Coolant temperature: 75 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 12.720 V
                    Unlearning counter according OBD: 11
                    Charge air pressure: actual value: 968.05 hPa
                    Absolute intake pressure: 65 kPa abs
                    Overrun cut-off-Bits 0-7: 0
                    Throttle valve position: normed: 9.4 %
                    Particulate filter: loading stage: 0
                    Camshaft adjustment intake bank 1: actual value: -30.97 °
                    Camshaft adjustment: exhaust: bank 1: actual value: -18.58 °
   Part No SW: 0CW 300 020 L    HW: 0AM 927 769 N
   Component: GSG DQ200G2_M H07 2202
   Revision: 00007009    Serial number: CU502205125255 CVN: F001930C
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: 3B2325B653EF3CF21A9-806E
   Part No SW: 5QP 614 517     HW: 2Q0 614 517 L
   Component: ESC_base      H13 0201
   Serial number: 36901445220628
   Coding: 3A068B3F5B425CADD1FEDA1852E162A649D4D106336A262424541254454A4665922B8B60CC566424242A482AA231D6431F8C6BC2F84CE47032270E
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 005001
   ROD: EV_Brake1BOSCHESPMQBA0.rod
   VCID: 0E45BC6230DDF95A8D7-805A
   Part No SW: 3Q0 959 435 Q    HW: 3Q0 959 435 Q
   Component: VWKESSYMQB    037 1400
   Revision: 00037000    Serial number: 0597601346 Dataset Number: V03935342GU 0001
   Coding: 032C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004055
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 48C94A7A1239676A87B-801C
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 6JM 907 057 A    HW: 6JM 907 057 A
   Component: Climatronic   035 0207
   Coding: 212100000400003101000400024011050101350000000000000000000000
   ASAM Dataset: EV_ACClimaBHBMQBA0Touch 001003
   ROD: EV_ACClimaBHBMQBA0Touch_VW27.rod
   VCID: 4ACD70720C35957A91F-801E
   Part No SW: 2Q0 937 089 D    HW: 2Q0 937 089 C
   Component: BCM A0 Std    H12 0954
   Serial number: 014260622A0032 Dataset Number: V03935381DG 0001
   ASAM Dataset: EV_BCMA0 207001
   ROD: EV_BCMA0_207_VW27.rod
   Subsystem 1 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Component: RLS  054 0206
   Serial number: SBY22M06D23H10M13S48
   Coding: 00184D
   Driver door control module:
   Subsystem 2 - Part No SW: 5QR 959 801 A    HW: 5QR 959 801 A
   Component: FHSG_DRV  003 0010
   Serial number: AP0883RHNA2722073682
   Coding: 2D2203
   Part No SW: 2Q0 959 655 AP    HW: 2Q0 959 655 AP
   Component: VW22Airbag    020 0511
   Revision: --------    Dataset Number: V03935371KB 0001
   Coding: 88CCC000000000007C000000008800000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001036
   ROD: EV_AirbaVW22BPAVW27X_VW27.rod
   VCID: 0B43B57643CFCC726A9-805E
   Subsystem 1 - Part No SW: -----------    HW: 442 061 204 22
   Serial number: 3577Y50A508A6EE1B28L
   Subsystem 2 - Part No SW: -----------    HW: 442 061 204 22
   Serial number: 3587Y509B08DB2D5018E
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 904 22
   Serial number: 3517710AD0940044018Y
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 904 22
   Serial number: 3527710AB0940044205V
   Subsystem 5 - Part No SW: -----------    HW: 442 130 302 22
   Component: FrontSensor_D  290 118A
   Serial number: 355AG23C2C785F72D0A8
   Part No SW: 2GP 920 310 A    HW: 2GP 920 310 A
   Component: KOMBI         030 3092
   Coding: 252400182180000C02082A001000000000001407
   ASAM Dataset: EV_DashBoardJCIMQBAB 010005
   ROD: EV_DashBoardJCIMQBAB_010_VW27.rod
   VCID: 392F3FBE59D30EE2085-806C
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 2Q0 909 901 E    HW: 2Q0 937 089 C
   Component: GW MQB A0     H12 0954
   Serial number: 014260622A0032 Dataset Number: V03935352Y0001
   Coding: 030100042F00570000000000000F00010001070000000000000000000000
   GVL: 01403C0000000600400000000000C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewA0 013026
   ROD: EV_GatewA0_VW27.rod
   VCID: 34310E8A7EB1F38ADB3-8060
   Generator:
   Component: 4-00-12-00-04
   Subsystem 2 - Part No SW: 3G0 959 442 AH    HW: 3G0 959 442 AH  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H50 0500
   Serial number: PR6-0440071019220470
   Coding: 290C00
   Subsystem 3 - Part No SW: 2Q0 915 181 B    HW: 2Q0 915 181 B
   Component: J367-BDMBOSCH  H02 2012
   Serial number: 101A854B
131699 - Control unit for information electronics 1
          U1054 00 [008] - No Communication
          [Timeout Knoten 0x73 / 5F - Steuergerät für Informationselektronik 1]
                    Reset counter: 157
                    Mileage: 8841 km
                    Date: 2023.04.25
                    Time: 18:14:46
                    Terminal 30 power supply: 12.3 V
                    Terminal 15: OFF
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H10 0021
   Serial number: 22000044558002
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 313F079E81A3C6A2B05-8064
Address 44: Steering Assist (J500)       Labels: None
   Part No SW: 5QR 909 144 C    HW: 5QR 909 144 A
   Component: EPS_ECU       430 4250
   Serial number: 000025.04.22000 Dataset Number: V03935368TX 0001
   Coding: 00000000000000000101020101000100000001010101
   ASAM Dataset: EV_SteerAssisNSKGEN3MQB 004008
   ROD: EV_SteerAssisNSKGEN3MQB.rod
   VCID: 56F59402C88DC19A057-8002
   Part No SW: 6JR 035 180     HW: 6JR 035 180
   Component: MU-R--R2      H04 0576
   Serial number: VWZ7Z2A7300975  Dataset Number: V03935382F  0001
   Coding: 22711608000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUREGIO 001010
   ROD: EV_MUREGIO.rod
   VCID: 03539D566B9F8432129-8056
End----------(Elapsed Time: 10:14, VBatt start/end: 13.8V/13.7V)-----------
Since VCDS has ASAM data in the form of a .ROD file for every module in this car, I would call it "Well supported".
The P0106 bothers me a bit. However, you probably won't get any satisfaction from your dealer unless/until whatever is causing that sets a Check Engine light.
The U1054, not so much. Your infotainment system was slow to wake up one morning, or woke up on the wrong side of the bed.
vrpram
India
C?ID=550004
Yes, most dealers here are like “don’t fix it unless it breaks.” Would love to see a day in the future when dealers fix issues proactively.
Anyway coming to fault codes. Cleared the DTC and did a re-scan. The errors did not pop up again. Will keep scanning once a week to keep track of it.
Cheers!
