How to actively monitor boost PSI
abishoff
C?ID=248712
I have a HEX-NET. How do i setup active monitoring for boost psi, egt, engine temp, etc...?
Couldn't begin to tell you until you tell us what kind of car you have. The preferred method would be for you to post an Auto-Scan so we can see exactly what ECU your car has.
abishoff
C?ID=248712
I have a 2015 VW Passat. I'm looking to use VCDS/VCDS Mobile as a boost gauge.
Friday,10,July,2015,14:44:37:49139
VCDS Version: 14.10.2.0
Data version: 20150311
VIN: 1VWCV7A37FC009301   License Plate: ADB8823
Mileage: 34630km-21518mi   Repair Order: 07102015
Chassis Type: A3 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
          52 56 62 72 75 77
VIN: 1VWCV7A37FC009301   Mileage: 34630km-21518miles
Address 01: Engine (J623-CVCA)       Labels: None
   Part No SW: 04L 906 016 AF    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 8417
   Revision: 8AH20---
   Coding: 011D0012032410089000
   Shop #: WSC 41657 001 1048576
   ASAM Dataset: EV_ECM20TDI01104L906016AF 001014
   ROD: EV_ECM20TDI01104L906016AE.rod
   VCID: ED9289163C2E8D49359-80B8
   Part No SW: 02E 300 061 T    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 4509
   Revision: 05652104    Serial number: 00001404052843
   Shop #: WSC 09003 957 00200
   VCID: A502B1366C5E7509BD9-80F0
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: C54BC0F549220003A30E03E4921A0042A1100012
   VCID: FEB0BE5A694806D19C3-80AB
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0332322625
   Coding: 130C0C
   ROD: EV_KESSYPQ35G_AU21.rod
   VCID: B73E6B7E0EF2F7991F5-80E2
   Part No SW: 561 907 044 AP    HW: 561 907 044 AP
   Component: Climatronic   H03 0707
   Revision: 00001K01
   Coding: 0010019012
   VCID: E582F136E4DEB5097D9-80B0
   Part No SW: 5K0 937 087 AE    HW: 5K0 937 087 AE
   Component: BCM PQ35 H+   122 0174
   Revision: BL122001
   Coding: EF200E3B982B08D4098802013600854800F1A08645A005B064806000BC70
   VCID: F8BCA8424B6C38E1D6F-80AD
   Component: RLS 290514 05  54  0403
   Coding: 02300A
   Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
   Component: AirbagVW10    500 0975
   Serial number: 003LZD018ST9
   Coding: 00004D32
   ASAM Dataset: EV_AirbaVW10SMEVW360 001030
   ROD: EV_AirbaVW10SMEVW360_SK35.rod
   VCID: F2A89A6A251052B1E8B-80A7
   Serial number: 6940000Y1400016MTW0J
   Coding: 303047
   Serial number: 3572MSME6E6B6A44ZZZB
   Serial number: 3582MSME312C6A44ZZZ-
   Serial number: 3516KSME7B12782EZZZ+
   Serial number: 3526KSME050D572DZZZZ
   Serial number: 3556LSME0703372EZZZU
   Serial number: 3566LSME1D6B352EZZZ7
   Part No SW: 1K5 953 521 BR    HW: 5K0 953 569 AH
   Revision: FF010042    Serial number: 20140530200383
   Coding: 000A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: FEB0BE5A614806D19C3-80AB
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
   Coding: E20000
   Part No SW: 561 920 970 G    HW: 561 920 970 G
   Component: KOMBI         H04 0813
   Coding: 231C01
   VCID: 9E709EDA8108A6D1FC3-80CB
   Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1653
   Revision:   H55       Serial number: 28061403000506
   Coding: 461000
   VCID: 804CC0A213BC7021EEF-80D5
   Component: IMMO          H04 0813
   Coding: 000007
   VCID: EA98820A0DC09A7150B-80BF
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Revision: 00000000    Serial number: 14000125876005
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: B02C5062EB9C20A15EF-80E5
Address 2E: Media Player 3
   Part No SW: 561 959 760 B    HW: 561 959 760 B
   Component: MEM-FS        H04 0182
   Revision: AA000000    Serial number: 00000105342645
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: A208AA2ABD708231D8B-80F7
   Part No SW: 3C0 035 684 N    HW: 3C0 035 684 N
   Component: RNS-MID       H26 5378
   Revision: AB001001    Serial number: VWZ6Z7P3158088
   Coding: 04090042010000A4000B
   VCID: AE104E1AF9A836514C3-80FB
   Subsystem 1 - Part No: 7L6 919 859
   Component: NAR V8  8112
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Revision: 12110009    Serial number: 0008552180
   Coding: 0405FD
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 9C7494D29714B4C1127-80C9
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B
   Component: J388__TSG_HL  006 5470
   Serial number: 14102630140613191023
   Coding: 800000
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 215    3501
   Revision: 00H22000
   VCID: B93A6D46F0E6E1E9E91-80EC
   Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
   Component: KonzernAmp10K H08 6815
   Revision: --------    Serial number: EAA098A0144697
   ROD: EV_AudioVerst10KanalSTT3.rod
   VCID: A600B63AD9587E11B43-80F3
   Component: EZE_2         H55 1653
   Coding: 01030108
   VCID: EFAE931E3E227F59075-80BA
   Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
   Component: J245 P05 9BA3  H08 0005
   Coding: 181100
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Revision: 14110009    Serial number: 0008587165
   Coding: 0405FC
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 9D7299D68C0EBDC9E59-80C8
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B
   Component: J389__TSG_HR  006 5470
   Serial number: 14102631140627144210
   Coding: 800000
Address 75: Telematics (J949)       Labels: None
   Part No SW: 561 035 285     HW: 561 035 285
   Component: OCULowUSA     014 0102
   Serial number: 000003554140523
   Coding: 02140102C2423A007F1606000000
   ROD: EV_OCULow_SE12.rod
   VCID: D3E63FEEBA4A3BB903D-8086
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 159
                    Mileage: 34633 km
                    Date: 2015.07.10
                    Time: 14:41:40
Address 77: Telephone (J412)       Labels: 5N0-035-729.clb
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0592
   Revision: 1B001001    Serial number: 00007666170901
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: AE104E1AF1A836514C3-80FB
End-------------------------(Elapsed Time: 02:38)--------------------------
[Select]
[Installed]
[01-Engine]
[Functions]
[Live Data HUD]
[Create New]
Click on the Gauge gadget.
On it's configuration pop-up, click [Set Measuring value]
- For "boost" on your engine, try "Intake manifold pressure"
Jef
HQ
Your Engine Control Module (ECM) is the UDS type. To that end, click on the [Adv. Meas. Values] button and you will get a list of live data that can be viewed... all 883 of them. :eek:
Note that boost pressure PSI will not be in a PSI scale since this VW/Audi uses the metric system.
Locations 070 to 084 look to show boost information.
Location 300 is "Exhaust gas recirculation temperature"
Location 104 is "Coolant temperature".
When you go into [Adv. Meas. Values], there is a search box at the top of the list so you can search for key words.
abishoff
C?ID=248712
Using Uwes method, and selecting gauges, and set the measure value, and set the type as PSI. you can get virtual gauges using VCDS mobile via Web interface or VCDS app. The gauge will convert to PSI I think. It's very handy! I was boosting max about 23 PSI at a WOT pull.
abishoff
C?ID=248712
          52 56 62 72 75 77
   Revision: 8AH20---
   Revision: 00H46001
   Coding: 130C0C
   Revision: 00001K01
   Coding: 0010019012
   Revision: BL122001
   Coding: 02300A
   Coding: 00004D32
   Coding: 303047
   Coding: 000A140000
   Coding: E20000
   Coding: 231C01
   Coding: 461000
   Coding: 000007
   Coding: 0405FD
   Slave Driver:
   Coding: 800000
   Revision: 00H22000
   Coding: 01030108
   Coding: 181100
   Coding: 0405FC
   Slave Passenger:
   Coding: 800000
                    Fault Priority: 8
                    Reset counter: 159
                    Mileage: 34633 km
                    Date: 2015.07.10
                    Time: 14:41:40
   ROD: EV_UHVUMI.rod
[Select]
[Installed]
[01-Engine]
[Functions]
[Live Data HUD]
[Create New]
Uwe what is used for o2 lamda, air intake temp, and Exhaust temp?
Please browse through the list or try typing in keywords.
abishoff
C?ID=248712
Can you please explain the difference between these values?
Intake manifold press. sensor; act. value calculated [loc 40066]
Intake manifold pressure; act. value calculated [loc 43297]
Nope, I don't have more detailed info than what's in VCDS.
BJAsayHEY
C?ID=185589
I am also looking to monitor/check boost on my 2015 Golf R. I have logged intake manifold pressure but the readings I am getting peak out at about 2.5 bar. I know my car is not boosting 37 psi. Do I have to subtract atmospheric pressure from that reading to figure my actual boost pressure?
Yes.
