B5 Audi S4 Instrument cluster lighting
crazyquik22023
C?ID=206258
Is there a way to turn off the instrument cluster lighting when the headlights are not turned on in a b5 s4? I know in my 2001 a4 the cluster lights only turn on with the headlights. In the s4 the lights are always on? Would like them to be only on with the headlights. Tried adaption channel 19 like in the b6/b7's but the channel is not accessible in the b5. Anybody know of a way to do this? Thanks.
crazyquik22023
C?ID=206258
Anyone? Also having problems changing the service interval. I swapped this gauge cluster from a 2000 s4 into my 2001 a4. Everything seems to be working ok except I can't change the service interval. With my 2001 cluster I am able to change settings in groups 40, 42 & 43 to get the service reminder to say what I want. With this s4 cluster no matter what I change the numbers to in those fields I get no change in the displayed service reminder. It says service in 8100 miles at all times. Any info would be helpful.
Wednesday,12,August,2015,22:00:10:42504
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
Mileage:    Repair Order: B5
Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2001)
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine        Labels: 06B-906-018-AWM.clb
   Part No: 4B0 906 018 CH
   Component: 1.8L R4/5VT     G   0001
   Coding: 16201
   Shop #: WSC 87119
   VCID: 69D99DB813DFEA76E1-5140
Readiness: 0010 0000
Address 03: ABS Brakes        Labels: 8E0-614-111-EDS.lbl
   Part No: 8E0 614 111 A
   Component: ABS/EDS 5.3 QUATTRO D10
   Shop #: BB 24334
   VCID: 1C37F46C8C0DCFDEAA-5124
Address 08: Auto HVAC        Labels: 8D0-820-043-1D.lbl
   Part No: 8D0 820 043 P
   Component: A4     KLIMAAUTOMAT D58
   Coding: 00140
   Shop #: WSC 63351
   VCID: 2D5129A8E7B73656CD-2592
9 Faults Found:
00787 - Temperature Sensor in Fresh Air intake duct (G89)
            30-00 - Open or Short to Plus
00602 - Potentiometer On Positioning Motor for Footwell/Defroster Flap (G114)
00601 - Potentiometer On Positioning Motor for Central Flap (G112)
00600 - Potentiometer On Positioning Motor for Temperature Flap (G92)
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
00797 - Sunlight Photo Sensor (G107)
01297 - Sensor for Vent Temperature; Footwell (G192)
01296 - Sensor for Vent Temperature; Center (G191)
Address 15: Airbags        Labels: 8D0-959-655-AI8.lbl
   Part No: 8D0 959 655 K
   Component: Airbag Front+Seite 0002
   Coding: 00104
   Shop #: WSC 06335
   VCID: 3E731EE43AD1BDCE64-517C
Address 17: Instruments        Labels: 8D0-920-xxx-17.lbl
   Part No: 8D0 920 980 D
   Component: B5-KOMBIINSTR. VDO D07
   Coding: 00244
   VCID: 2C5724ACDCAD3F5EDA-5140
Address 35: Centr. Locks        Labels: 8D0-862-257.lbl
   Part No: 8L0 862 257 N
   Component: CV-Pump             D11
   Coding: 15176
   Shop #: WSC 06435
   VCID: 408F601C4025CB3E16-4EEA
01366 - Opened Due to Crash Signal
            35-00 -  -
00955 - Key 1
            09-00 - Adaptation Limit Surpassed
Address 37: Navigation        Labels: 4B0-035-192-RNSD-37.lbl
   Part No: 4B0 035 192 K
   Component: RNS 4.2 H06    BNO 0140
   VCID: 2541D188BF470E1605-4ACE
            49-00 - No Communications
Address 45: Inter. Monitor        Labels: 4B0-951-173.lbl
   Part No: 4B0 951 173
   Component: Innenraumueberw.    D03
   Coding: 00101
   Shop #: WSC 06435
   VCID: 60CF809CE0E5AB3E36-4B32
Address 56: Radio        Labels: 4B0-035-192-RNSD-56.lbl
   Component: Radio          BNO 0001
   Coding: 01320
   Shop #: WSC 02325
   VCID: 2541D188BF470E1605-4AE8
End-------------------------(Elapsed Time: 03:58)--------------------------
I'm not aware of any way to tweak the lighting in B5 clusters.
For your service reminder question, post the stored values in channels 40-48. The easiest way to do that is to click [SRI Reset], wait for VCDS to read the channels, then click [Save to logfile] and post the contents.
crazyquik22023
C?ID=206258
With these setting my display reads 8100 miles until serivce
Thursday,13,August,2015,14:31:23:42504
VCDS Release 15.7.0: SRI Reset
Control Module Part Number: 8D0 920 980 D Labels: 8D0-920-xxx-17.lbl
Component:B5-KOMBIINSTR. VDO D07 , Coding:00244
Channel Description Unit Current val. New val.
02 Service Reminder Status 0 ---
40 Mileage since Service miles x100 3 ---
41 Time since Service Days 1 ---
42 Min Mileage to Service miles x1000 4 ---
43 Max Mileage to Service miles x1000 4 ---
44 Max Time to Service Days 365 ---
45 Oil Quality --- --- ---
47 Soot Quantity --- --- ---
48 Thermal Load --- --- ---
OK, it makes no sense to me why that cluster is showing 8100 miles to service. If you drive it for a few hundred miles, is does the 8100 decrease?
crazyquik22023
C?ID=206258
Haven't driven it more than 50 or so miles yet. I'll post back when i drive a few hundred miles and see if there is any change.
crazyquik22023
C?ID=206258
I've driven approx. 300 miles since making changes and the display is still reading "service in 8100 miles"
40 Mileage since Service miles x100 5 ---
41 Time since Service Days 4 ---
I'm stumped. I think at this point I would try a cold boot of the cluster, (remove all power from it) and/or a general Adaptation reset (Channel 0, [Read] -> [Save]).
crazyquik22023
C?ID=206258
I'll give that a try Uwe. Thanks
crazyquik22023
C?ID=206258
Tried doing a general reset and value still will not change no matter what numbers I put in channels 40-46.
