How to change the number of blinks on a 2015 RS5
siberian
C?ID=76852
On the T2 series Touaregs I was able to change the number of blinks when overtaking by:
09 Central Electrics -> Adaptations -> Channel 1 -> change value -> test and save
On the RS any other channel than reset to factory (0?) gives a "Security Code required"
Thanx for any tips:
siberian
Sunday,09,August,2015,10:35:19:17415
VCDS Version: 15.7.0.1
Data version: 20150729
VIN: WUAC6AFR4FA901899   License Plate: WARP10
Mileage: 930km-577mi   Repair Order:
Chassis Type: FR (8R0)
Scan: 01 02 03 05 06 08 09 13 15 16 17 19 1B 22 36 3C 42 44 46 47
          52 53 56 5F 6C
VIN: WUAC6AFR4FA901899   Mileage: 930km-577miles
Address 01: Engine (------CFSA)       Labels: None
   Part No SW: 8T2 907 560 F    HW: 8T1 907 560
   Component: 4.2l V8HDZ /  H05 0003
   Revision: NAH05---
   Coding: 1A25003225C6080D3000
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM42FSI0118T2907560F 001002
   ROD: EV_ECM42FSI0118T2907560F.rod
   VCID: 3F86A159A639BBC66F-806A
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 8T0 927 156 H    HW: 0B5 927 156 K
   Component: 0B5 42 FSINAR H03 0005
   Revision: --H03---
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
   VCID: 4280A8ADD5CBD62E00-8016
   Part No SW: 8T0 907 379 G    HW: 8T0 907 379 G
   Component: ESP8 quattro  H09 0010
   Coding: 2C2D1A
   VCID: 4688B4BDF1E3EA0E2C-8012
   Part No SW: 8K0 907 064 KM    HW: 8K0 907 064 KM
   Component: BCM2 2.0      H15 0711
   Coding: 0D804040000000000000
   VCID: 050A73B18C65211665-8050
   Subsystem 1 - Part No SW: 8K0 959 754 CB    HW: 8K0 959 754 CB
Address 06: Seat Mem. Pass (J521)       Labels: 8T0-959-760.clb
   Part No SW: 8T0 959 760 F    HW: 8T0 959 760 F
   Component: MEM-BFS       H10 0077
   Revision: AA000000    Serial number: 00000136338084
   Coding: C80370250F2400001000
   Part No SW: 8K1 820 043 AR    HW: 8K1 820 043 AR
   Revision: C3000000    Serial number: 01240420150771
   Coding: 4802200600
   VCID: 78F40A45CB974CFE6E-802C
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00001043342801
   Coding: 06400091043C9FF2350148C0000039090F9CD388A2090221000008004000010200040034000000
   VCID: 7AF0104DF59B5EEE18-802E
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 150415  H15 0080
   Coding: 00FD11
   Coding: 02005D
   Subsystem 3 - Part No SW: 8K0 941 531 AQ    HW: 8K0 941 531 AQ
   Component: E1 - LDS  H03 0031
   Component: USHL4.2  H30 0030
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561 C    HW: 8K0 907 561 C
   Component: ACC3          H11 0110
   Coding: 00333E
   Shop #: WSC 06192 000 00000
   VCID: 3260F86D6D6B66AE90-8066
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 Q    HW: 8K0 959 655 Q
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NDD1363WB
   Coding: 303343334830383131304A55304C38543053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 4B9E8589E2811766F3-801E
   Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
   Component: BF-Gewichtss.  H02 0060
   Serial number: 5810000R150000Q28J
   Serial number: 6334MSME507A3338C
   Serial number: 6344MSME507A1845E
   Serial number: 6352QSME03562D56H
   Serial number: 6362QSME08563B4AP
   Serial number: 63732SME40584D5E9
   Serial number: 63832SME4358164C0
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372ODN00085
   Coding: 00003E
   VCID: 448CAEB5C7DFD81E32-8010
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8T0 920 984 H    HW: 8T0 920 984 H
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 5XW34HP4G
   Coding: 83BF0100AF03D705020000
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z154150BAF
   Coding: 80E3031600
   VCID: 4C9C8695EF8F105EFA-8018
   Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
   Component: DYNAMIKLENK.  H06 0730
   Revision: 52001005    Serial number: --------------
   Coding: 030000
   VCID: 3972CF41B01D95F651-806C
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H15 0100
   Serial number: 000703150001019
   VCID: 2F66F11976594B46FF-807A
Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
   Component: MEM-FS        H10 0077
   Revision: AA000000    Serial number: 00000139859400
   Coding: C81B7B250F2400001000
Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0365222736
   Coding: 010211
   Lane Change Assistant 2:
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H10 0305
   Coding: 011C13224E00120102
   VCID: 56A864FD21435A8E5C-8002
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Part No SW: 8K0 909 144 P    HW: 8K0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0006486396
   Coding: 010000010001
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X.rod
   VCID: 3E78DC5DA133B2CE64-806A
   Revision: 00002001    Serial number: 0366507033
   Coding: 0106029A00FAC00583B0003200000000
   Component: GTO BF  H01 0080
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H05 0220
   Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
                    Fault Status: 00101001
                    Reset counter: 66
                    Mileage: 939 km
                    Date: 2015.08.06
                    Time: 14:47:45
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Revision: 00005001    Serial number: 94813043464506
   VCID: 2D5AEB1174553956CD-8078
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H10 0305
   VCID: 55AA63F13C45519655-8000
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 20000000619482
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A70D04DBD1B9EEE58-806E
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156D10F8258653
   Coding: 020007010000000001
   VCID: 244C0E35279FF81E12-8070
   Part No SW: 8R1 035 746 G    HW: 8R1 035 746 G
   Component: H-BNT-NA      H42 0901
   Revision: --------    Serial number: 523EV0F7541431
   Coding: 150200020306E9EF75028B5E00000403140000000000000000
   VCID: 3B7ED549BA21A7E643-806E
   Subsystem 1 - Part No: 8R0 060 884 CJ
   Component: NAR 2015  1102
   Component: DU7 High  H42 0104
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Component: CD-Database  5950
            000 -  -  - Intermittent
                    Reset counter: 61
                    Mileage: 743 km
                    Date: 2015.07.28
                    Time: 13:47:58
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00010000
   Revision: --H09---    Serial number: 525PA8-JA291BX
   Coding: 1021008
   VCID: 3874CA454B178CFEAE-806C
End-------------------------(Elapsed Time: 04:30)--------------------------
Keithuk
Stoke on Trent, England
C?ID=122432
On my Golf I used 09-Cent. Elect., Adaptation - 10, Select Comfort Turn Signals (Cycle) from the combobox.
That will show Channel 31 and the Stored value (default) is 3. You can change the number of blinks from 1 to 5 using the up and down buttons enter the New value. Click Save when done and then click Done, Go Back.
siberian
C?ID=76852
Thanx Keith. I don't believe I saw a pull down menu at the top, but then again I was focused on the "slam dunk" doing it the Touareg way and just kept getting the above mentioned (error) warning. I did go up past (I bleieve) channel 31 by repeatedly selecting Channel Up. I'll give it a whirl... Cheers
siberian
I am not aware of a way to tweak the number of comfort turn signals in a B8+ (i.e. BCM1 and BCM2) vehicle.
siberian
C?ID=76852
Thanx Dana, was hoping there was a way to do that.
siberian
mikeholroyd
C?ID=98585
Be aware that on some models, including the Octavia 2 FL, altering the number in the adaptations isn't in itself enough to change the settings. What is also required is a factory reset of the maxidot/MFD display on the dashpod as well.
Doing a factory reset will not lose any settings stored, (though the data will be reset) the only difference it will make is that if the time clock is set to daylight saving, it will revert to normal and will need the DST reactivating.
Mike
