Trying to do DPF regen 2012 Skoda Fabia 1.6 unable to select Meas Blocks -08 on 01 Engine
wandango75
C?ID=495194
Hi,
I'm lookin for assistance to select the Meas Blocks button on my laptop. the button is not lit up like all the others and when i click on it i am greeted with a popup "VCDS ERROR:Function not available"
16848 - Diesel Particulate Filter
P2458 00 [172] - Regeneration Duration
Mileage: 274594 km
Date: 2023.05.03
Time: 16:20:27
Has anyone got any ideas as to why i can't access this please? Thanks in advance
Wednesday,03,May,2023,18:44:51:37903
VCDS Version: 22.10.0.1 (x64)  HEX-NET2 CB: 0.4623.4
VIN: TMBFL65J7D3071917   License Plate: PUD AFTER
Mileage: 274680km-170678mi   Repair Order:
Chassis Type: 5J-SK25 (6N0)
Scan: 01 03 08 09 15 17 19 25 44 56
VIN: TMBFL65J7D3071917   Mileage: 274680km-170678miles
   Part No SW: 03L 906 023 LN    HW: 03L 906 023 LK
   Component: R4 1.6l TDI   H33 9978
   Revision: --H33---    Serial number:                CVN: F02527F4
   Coding: 00114016002500080000
   Shop #: WSC 13765 031 00047
   ASAM Dataset: EV_ECM16TDI02103L906023LN 003012
   ROD: EV_ECM16TDI02103L906023LL.rod
   VCID: 7DAC91F4BD782E13804-8028
   VINID: 91D49670615A1D40C01C12411CD53C6E84
                    Mileage: 274594 km
                    Date: 2023.05.03
                    Time: 16:20:27
                    Engine RPM: 780.25 /min
                    Normed load value: 10.6 %
                    Coolant temperature: 70 °C
                    Intake air temperature: 38 °C
                    Voltage terminal 30: 14.118 V
                    Particle filter: soot mass measured-MASS_SOOT_PHY_PF: 11.95 g
                    Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 0.88 g
                    Particle filter kilometers since last regeneration_1-DIST_RGN_ENVD_H: 442 km
                    Counter for regeneration time of particulate filter-T_INT_RGN_ACT_INI_PF_ENVD_H: 12596.0189 s
                    Particle filter: difference pressure-DIP_PF: 0.00 hPa
                    DPF: offset for differential pressure-DIP_PF_AD[0]: 2.49 hPa
                    Service regeneration: Release conditions 3-FRF_STATE_RGN: 1
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6R0 907 379 AR    HW: 6R0 907 379 AQ
   Component: ABS9.0 front  H01 0001
   Serial number: --------------
   Coding: 40DC447D412A00C1021D226A825800020000
   ASAM Dataset: EV_Brake1ABS90BOSCH 003017
   ROD: EV_Brake1ABS90BOSCH_VW25.rod
   VCID: 0E4EC63880DE258B69E-805A
Address 08: Auto HVAC (J255)       Labels: 6Q0-907-044.lbl
   Part No SW: 5J0 907 044 C    HW: 5J0 907 044 C
   Component: Climatronic   H09 0103
   Revision: K0000000
   VCID: 2A066AA81CF669AB956-807E
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 221
                    Mileage: 268608 km
                    Date: 2017.06.26
                    Time: 08:00:49
   Part No SW: 6R7 937 087 M    HW: 6R7 937 087 M
   Component: PQ25 BCM      H28 0555
   Revision: -1------    Serial number: --------------
   Coding: 24980B3808C92400922008002C2B08C00080400F60000000020000000000
   Shop #: WSC 13765 790 00047
   VCID: 4ECE063840DE658B29E-801A
   Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 3211
   Coding: 030000
   Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 3211
   Coding: 020000
   Subsystem 3 - Part No: 5J0 951 172
   Component: DWA-Sensor      H03  H03 1211
   Component: LIN BACKUP HORN H05  H05 1501
   Subsystem 5 - Part No: 5J0 951 172
   Part No SW: 6R0 959 655 L    HW: 6R0 959 655 L
   Component: VW10AirbagT2C H10 0020
   Revision: --------    Serial number: 003GY007U6T$
   Coding: 003243
   ROD: EV_AirbaVW10BPAVW250_VW25.rod
   VCID: 4BC80F2CB34C50A34E0-801E
   Serial number: 3495RRB401E4UON69P2D
   Serial number: 3505RRB401E4UON678O8
   Serial number: 3515RRB40631M1UC2OU%
   Serial number: 3525RRB401E4UON6Q8NS
   Part No SW: 5J0 920 941 D    HW: 5J0 920 941 D
   Component: KOMBI         H05 0306
   Coding: 420A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK25.rod
   VCID: 2C0A6CB01682779B67A-8078
   Part No SW: 6N0 909 901     HW: 6R7 937 087 M
   Component: GW-K-CAN TP20 H28 0555
   Revision: -1------
   Coding: 032300
   VCID: 70B2B8C0FAAA537B1B2-8024
   Component: IMMO          H05 0306
   VCID: 6A86AAA8DCF6A9AB556-803E
   Part No: 6R0 423 156 C
   Component: LenkhilfeTRW        V278
   Coding: 10110
   Shop #: WSC 13765
   VCID: 303278C0336A137B5B2-8064
   Part No SW: 5J0 035 161 D    HW: 5J0 035 161 D
   Component: Radio-SWING   004 0003
   Revision: -----07S    Serial number: SKZ4Z2M1382470
   Coding: 050004000006
   VCID: 2318878C7BDCB8E3D60-8076
End----------(Elapsed Time: 00:58, VBatt start/end: 12.4V/12.3V)-----------
                    Mileage: 274594 km
                    Date: 2023.05.03
                    Time: 16:20:27
   Revision: K0000000
                    Reset counter: 221
                    Mileage: 268608 km
                    Date: 2017.06.26
                    Time: 08:00:49
   Coding: 030000
   Coding: 020000
   Coding: 003243
   Coding: 420A00
   Revision: -1------
   Coding: 032300
   Coding: 10110
   Shop #: WSC 13765
End----------(Elapsed Time: 00:54, VBatt start/end: 12.4V/12.3V)-----------
Address 01: DTCs cleared
Address 17,5J0 920 941 D,recoded (Long Coding),from,420A00,to,120A00,(13765/031/00047),
Address 17,5J0 920 941 D,recoded (Long Coding),from,120A00,to,420A00,(13765/031/00047),
Your ECU uses the newer UDS protocol. You need to use [Adv Meas Values] instead.
See:
JMR
Romania
C?ID=432218
However, at that mileage the dpf might be cracked / non functioning anymore... Most of the time when i see this error the dpf unit is done and cooked
wandango75
C?ID=495194
I want the give it a try before I bite the bullet and replace it
wandango75
C?ID=495194
I want the give it a try before I bite the bullet and replace it, where do I go from there? I’m not 100% clued up on these things, I just want to try and regen the dpf to see if the fault clears
