Looking for some CAN bus data of PQ and MQB platform cars
   #61
Ronaldo
Brazil
C?ID=357813
In my MQB workbench I use the message WBA_03 (0x394) to control the gear position displayed on the cluster and it seems to work perfectly so I'm surprised that another CAN bus message could also work, even partially. Did you try to send a corresponding WBA_03 after the 0xAF to see if the selected gear stops flashing? (maybe the cluster also responds directly to the gear selector but needs some kind of confirmation from the mechatronics, but that's just a guess). I have no idea about what message would be expected to release the gear lever lock solenoid, but probably it's something from the gearbox (the mechatronics module controls the variables related to "gear lever lock" and changes the values as active/not active, for example, when you press the break pedal when the car is stopped). Since you probably won't include a real gearbox in setting (even though your "weird shit" seems very impressive) maybe the easiest way to work it around would be opening the gear selector and finding a way to disable the lock permanently.
   #62
roli
Slovenia
Yeah, it's not 0x394 - I was fully expecting it to be at the start, but apparently not.
I did some more experiments and figured it out though. With the help of our friend opendbc. They now have a MQB DBC.
The CAN address that does the magic is 0x128. Three bytes in length, but only byte 0 is important. Bit 0 is locked/unlocked (1 being unlocked) then bits 4-7 are the highlighted gear.
Bit 1 is supposed to control something about the backlight, but doesn't seem to do anything for me - though I did wire the dimming/backlight terminal directly to 12V, so that might be the reason.
   #63
NordicAlex
Oslo, Norway
i have some GB of data from my skoda octavia VRS, PQ35 2010. its sniffed from motor can.
I can upload it if you want to exploit it.
   #64
roli
Slovenia
Hi! Yes if you can that would be nice. I am still looking for some information for my Superb 2 cluster, and Octavia probably shares a lot with that.
   #65
NordicAlex
Oslo, Norway
uploading now, Can send u link tomorrow
   #66
NordicAlex
Oslo, Norway
Here is some. i made new yesturday to the dashboard. can send u that also in a few days
   #67
roli
Slovenia
Thank you! Yeah, the convenience can for the cluster is probably even better source since it has some information not present on the drivetrain one.
   #68
CanCoder
TBD
Dear NordicAlex,
Can you upload again the logs from your car?
Thanks in advance.
   #71
Alex640
Russia
Hi !
Does anyone know a formula to extract RPM from a message? ID 0x107.
0x107 0x01 0x00 0xfe 0x8e 0x81 0x33 0x76 0x93
   #72
CanCoder
TBD
From the bytes 3 and 4 you got 0x8e 0x81, mask it with 0xff 0x0f and swap the bytes and you get 0x01 0x8e which is 398, multiply it by 3 and you get 1194 RPM.
See the attached photo from the "official" DBC file.
   #75
Alex640
Russia
Very thanks to all, I'll check tomorrow at different RPM's.
   #76
TTT
C?ID=547002
What do you mean? Decoding method is just above your post.
   #77
Alex640
Russia
This is correct !
1224 RPM 0x107 0x00 0x00 0xfe 0x97 0x01 0x35 0x49 0x0f
1947 RPM 0x107 0x07 0x00 0xfe 0x89 0x82 0x35 0x02 0x78
Tnank you very much !
   #78
TTT
C?ID=547002
Go figure. He said its the official dbc file. Why wouldn’t be correct?
   #79
CanCoder
TBD
Can you post some example for the vehicle speed reading?
Or can you post a whole CAN bus sniff when the car is moving?
I will try to search the CAN bus ID for the vehicle speed.
   #80
Alex640
Russia
I think in CAN-K ID's is
0xFD // speed/distance
0x31B // speed on kombi
I can make a log file from my car.
