Bretterson
Sorry, I'm confused about your logic/math in the second part, can you clarify? The way I see it... if I spend $199 on a new cable then I need to get $150 (I think that's what I paid) for the one I have now for things to be a wash. If I only get $50 for the cable I have and go buy a new one for $199 then I'd be out $299 ($199 + ($150-$50)).If you can get more than $50 for it, then that is a reasonable assumption; otherwise, you're right back at square one since a 3-VIN HEX-V2 costs $199 and (assuming I read correctly) you spent $150 on your used cable + $99 to re-register it = $250. Here's the math as I understand it:
150 [used cable]
+ 99 [registration fee]
=249 [total cost before SFD access]
vs $199 for a 3-VIN cable outright with no extra registration cost (before SFD access). That means, to come out on top, you need to recover at least $50 from your used cable to make purchasing a new 3-VIN cable worth your while.
249 [used cable & re-registration fee]
- 50 [minimum margin for sale of used cable]
=199 [new 3-VIN cable cost]
All the ones with two VINs remaining that have sold recently on eBay went for least $150, so I should have no problem recovering what I spent. (No need to mention fees since I probably won't use eBay, it was just for reference.)
That was actually an honest question because I found a line in the instructions unclear: the SFD beta thread states, "You must be a Verified User in this forum. If you're not, then please Get Verified first!"That's a bit like buying 2 cars from a used-car dealer, several years apart.
"I bought a service plan on the first car, so I don't need to buy another one for the newer car do I?"
"But you want the service done on the new car, not the old one, sir...."
Since it just says you have to be a verified user, not that the cable needs to be registered to you I figured it might mean as long as you were verified in general (potentially from a previous cable) then you were set. Personally, I think it would be clearer to say, "You must be using a cable that is registered to you. If it isn't, then please Get Verified first!"
Yes.Really ?
mmm old software that will not update ???
