Help with 2013 Audi Q5 3.0 TFSI Codes!
pmac619
28277, 92103, 91602, 94949, 92101, 22045, +
C?ID=250378
Hello!
I am having some issues working on my 2013 Q5 3.0. I have found most vag com upgrades work, except for a few key ones that I would like to do. I have not found a list updated with the codes that work with my MMI 3 2013 Q5, does anyone have a newly updated list by chance? It's odd that some of the codes from pre-facelift work, and some from the facelift list work with my car, is it because it was built at end of one, and very start of the other perhaps?
For example:
When I follow all directions for aux circulation, it blacks out my normal ac screen, and sometimes enables aux, and sometimes does not. I have done it several times with same result.
I have since turned off Aux Air, it's out of MMI now, and still working on getting AC MMI tab to be live. It is there, just not active, so I can't properly operate AC.
My daytime running lights are not working when set to "ON," although in MMI it says they are set to on? Coding from another upgrade must have changed this?
I can't turn off "lights on" annoying dinging, none of the posted code lists have seemed to work yet, any suggestions?
Does anyone have the codes, or new upgrade lists, used on a 2013 Q5 3.0TFSI, or similar MMI?
Anyone know how go fix these, or run into same on similar, that can help?
Thank you for any help, below is the last Auto-Scan:
VCDS Version: Release 15.7.0 Running on Windows 8.1 x86
Data version: 20150729
Thursday,06,August,2015,16:36:22:41105
Chassis Type: FP (8R0)
Scan: 01 02 03 05 08 09 14 15 16 17 19 36 42 44 46 47 52 53 56 5F
          62 6C 6D 72
VIN: WA1DGAFP9DA037579   Mileage: 135010km-83891miles
Address 01: Engine (J623-CTUC)       Labels: None
   Part No SW: 8R0 907 551 A    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0001
   Revision: --H07---
   Coding: 2A2A0034052601060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218R0907551A 001002
   ROD: EV_ECM30TFS0218R0907551A.rod
   VCID: 3620EC0489E7EC8EBC-8062
6322 - Air Intake System
          P307A 00 [032] - Flow too Low
                    Mileage: 134974 km
                    Date: 2015.08.06
                    Time: 13:12:11
6307 - MAP/MAF <-> Throttle Position Correlation
          P0068 00 [096] - -
                    Mileage: 134974 km
                    Date: 2015.08.06
                    Time: 13:12:12
Readiness: 0000 0100
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 8R0 927 158 AM    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H16 1003
   Revision: --H16---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002020
   ROD: EV_TCMAL551211_AU48.rod
   VCID: 085C52FCB393AA7E1E-805C
   Part No SW: 8R0 907 379 AK    HW: 8R0 907 379 AK
   Component: ESP8 quattro  H09 0080
   Coding: 191D1C
   Shop #: WSC 06335 000 00000
   VCID: 095A57F8A099D37601-805C
            000 -  -
                    Fault Frequency: 32
                    Reset counter: 61
                    Mileage: 134804 km
                    Date: 2015.08.03
                    Time: 18:04:28
                    Hex Value: 0x00C0
                    Hex Value: 0x07A2
                    Hex Value: 0x0015
                    Hex Value: 0x1094
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
   Component: BCM2 2.0      H11 0621
   Coding: 0DA54040000000000000
   VCID: 044446CC87BB8E1E72-8050
   Subsystem 1 - Part No SW: 8K0 959 754 B    HW: 8K0 959 754 B
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01011120121276
   Coding: 66183A8080
   Shop #: WSC 06335 123 12345
   VCID: 393AE738B0F903F651-806C
                    Reset counter: 60
                    Mileage: 134804 km
                    Date: 2015.08.03
                    Time: 18:02:53
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000502516202
   Coding: 2600000181388FE01F00408300003D0D4F9CC748A6090221000008004000070100000034000000
   Shop #: WSC 52140 001 104857
   VCID: 78BC223CCB73DAFE6E-802C
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 121023  H11 0050
   Coding: 01D513
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Component: USHL4.2  H30 0030
03110 - Active Steering Control Module (J792)
                    Reset counter: 59
                    Mileage: 134853 km
                    Date: 2015.08.04
                    Time: 14:38:10
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8R0 907 364 C    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H09 0054
   Revision: 00000000    Serial number: 16101201280001
   Coding: 010181
   VCID: 3A38F834B5FF08EE58-806E
00457 - Control Module for Network (J519)
                    Reset counter: 100
                    Mileage: 134853 km
                    Date: 2015.08.04
                    Time: 14:31:21
                    Bin. Bits: 00000000 00000010
                    Bin. Bits: 00000000 00000000
Address 15: Airbags (J234)       Labels: 8R0-959-655.clb
   Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
   Serial number: 003GPD90YDUE
   Coding: 303634313432303030304A55304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 47DE91C0FE0D6506D7-8012
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R120000BAGZ
   Serial number: 6334MSME73204C001
   Serial number: 6344MSME7320447FG
   Serial number: 6352QSME6221304A5
   Serial number: 6362QSME30233E76G
   Serial number: 63732SME47241758.
   Serial number: 63832SME49245350W
   Part No SW: 8K0 953 568 L    HW: 8K0 953 568 L
   Revision: --------    Serial number: 90372LJQ000H8
   Coding: 000037
   VCID: 43C685D0C23549260B-8016
Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 980 T    HW: 8R0 920 980 T
   Component: KOMBIINSTR.   H35 0556
   Revision: 00000000    Serial number: UWH5AAZAD
   Coding: 035D22001301D705020001
   VCID: 4AD8A8F4E51F986EC8-801E
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0055
   Revision: 1Y060027    Serial number: 2741Y12A220261
   Coding: 80CF07FF00
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0141
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0076
   Revision: AA000000    Serial number: 00000038219943
   Coding: 01581B00000000000000
   VCID: 42C880D4DD2F402E00-8016
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 P    HW: 8K0 959 793 P
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000043523668
   Coding: 011D13205E00440004
   VCID: 4DD2A3E814718F56ED-8018
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Part No SW: 8R0 909 144 P    HW: 8R0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0014514699
   Coding: 000000000000
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X.rod
   VCID: 45C29BC8C401771625-8010
   Revision: 00002001    Serial number: 0186866330
   Coding: 01261E3A20FA70958730053600040007
   Shop #: WSC 45202 123 104857
   Component: GTO BF  H01 0080
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H04 0220
   Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J394EE20SKB13  H04 0220
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Revision: 00005001    Serial number: 94813007565802
   VCID: 2D12C36874B1AF56CD-8078
   Part No SW: 8K0 959 792 P    HW: 8K0 959 792 P
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000043760237
   VCID: 4CD4AEECEF6B865EFA-8018
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 10000000123198
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 383CE23C83F31AFEAE-806C
   Revision: AB001007    Serial number: 156KC0C7662995
   Coding: 020007010000000001
   VCID: 2404264C277B6E1E12-8070
   Part No SW: 8R1 035 746 G    HW: 8R1 035 746 B
   Component: H-BNT-NA      H44 0901
   Revision: --------    Serial number: 204JR0C7540151
   Coding: 1A0200060205E3FF47029F5E0B000403140000000100000000
   VCID: 3B36FD30BAC531E643-806E
   Subsystem 1 - Part No: 8R0 060 884 BA
   Component: NAR 2013  0703
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Component: CD-Database  4949
            000 -  -
                    Reset counter: 61
                    Mileage: 135019 km
                    Date: 2015.08.06
                    Time: 16:27:12
                    Bin. Bits: 00000000 00001010
                    Bin. Bits: 00000000 00000001
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000043649578
   Coding: 010C13204000240004
   VCID: 46C09CC4F1077C0E2C-8012
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H07---    Serial number: 525PA8-J2XA4EL
   Coding: 1020010
   VCID: 3424D60C579BFE9E82-8060
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8R0827851B
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H52 0330
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000071759842
   Shop #: WSC 45202 000 1048576
End-------------------------(Elapsed Time: 02:59)----------------
m_bolc
San José, Costa Rica
C?ID=230356
pmac619
C?ID=250378
Active steering and aux heating have been taken off, see middle of my post.
I have done 90% of the posted upgrades that have been online, most all worked, except for the above.
thanks for your help!
m_bolc
C?ID=230356
For me, there is no way of knowing right now what went wrong. Can you please post the file located in your debug folder? Or better yet, session logs showing what you changed.
Always always keep a baseline of your car, and make changes one at a time. If something doesn't work, you can quickly trace back your steps. We need to retrace your steps to get your ABS module recoded, you AC screen, and your DRLs back. That's why I have asked for your session logs, or the file in the debug folder. You were told the same thing in another thread.
pmac619
C?ID=250378
I realize and will do so, ABS code is normal and caused by the ECU upgrade on the car, per my Audi Tech.
I have not had access to the computer those are stored on, so have not been able to post the requested above.
I did what you suggested as well, each mod down the list of mods, one after another, and checking to make sure working, the ones I mentoned in first post are the ones that would not work correctly after following the steps in several forums.
I was looking for a master list, specifically for a 2013+ Q5 3.0 with the coding specs to see if someone had been updating a list and could post. If I had a list for my car specifically, I could figure it out quickly from the Byte and bit numbers and match them to mine, but I get what you are saying and will post the other info and maybe you can see from that what is going on.
I appreciate it and will look now for that on other computer.
pmac619
C?ID=250378
Here is from the Debug folder:
ddress 09:8K0 907 063 DH recoded (Long Coding) from 26000011C13CAFE01F00488300003D0D4F9CC748A6090221000008004000070100000034000000 to 26000011C13CAFE01700488300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Saturday,01,August,2015,23:46:10:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000011C13CAFE01700488300003D0D4F9CC748A6090221000008004000070100000034000000 to 26000011813CAFE01700488300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Saturday,01,August,2015,23:52:49:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000011813CAFE01700488300003D0D4F9CC748A6090221000008004000070100000034000000 to 26000011813CAFE01700488300003D0D4F1CC748A6090221000008004000070100000034000000  (52140/001/104857)  Sunday,02,August,2015,00:18:07:41105
Address 08:8K1 820 043 T recoded (Long Coding) from 6618228080 to 7E18228080  (06335/123/12345)  Sunday,02,August,2015,00:42:15:41105
Address 08:8K1 820 043 T recoded (Long Coding) from 6618228080 to 7E18228080  (06335/123/12345)  Sunday,02,August,2015,00:42:38:41105
Address 08:8K1 820 043 T recoded (Long Coding) from 6618228080 to 7E18228080  (06335/123/12345)  Sunday,02,August,2015,00:42:44:41105
Address 08:8K1 820 043 T recoded (Long Coding) from 6618228080 to 7E18228080  (06335/123/12345)  Sunday,02,August,2015,00:43:03:41105
Address 44:8R0 909 144 P recoded (Long Coding) from 000000000000 to 000000010000  (00000/000/00000)  Sunday,02,August,2015,00:47:11:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000011813CAFE01700488300003D0D4F1CC748A6090221000008004000070100000034000000 to 26000011813CAFE01700488300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Sunday,02,August,2015,01:01:59:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000011813CAFE01700488300003D0D4F9CC748A6090221000008004000070100000034000000 to 26000011813CAFE01700408300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Monday,03,August,2015,15:38:54:41105
Address 17:8R0 920 980 T recoded (Long Coding) from 837D22001301D705020001 to 835D22003301D705020001  (52140/001/104857)  Monday,03,August,2015,15:45:00:41105
Address 5F:8R1 035 746 G recoded (Long Coding) from 1A0200060205F3FF47029F5E09000403140000000100000000 to 1B0200060205F1FF47029F5E09000403140000000100000000  (45202/123/104857)  Monday,03,August,2015,15:46:42:41105
Address 17:8R0 920 980 T recoded (Long Coding) from 835D22003301D705020001 to 835D22000301D705020001  (52140/001/104857)  Monday,03,August,2015,15:47:50:41105
Address 17:8R0 920 980 T recoded (Long Coding) from 835D22000301D705020001 to 835D22001301D705020001  (52140/001/104857)  Monday,03,August,2015,15:48:21:41105
Address 5F:8R1 035 746 G recoded (Long Coding) from 1B0200060205F1FF47029F5E09000403140000000100000000 to 1B0200060205E1FF47029F5E09000403140000000100000000  (45202/123/104857)  Monday,03,August,2015,15:49:49:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000011813CAFE01700408300003D0D4F9CC748A6090221000008004000070100000034000000 to 26000011813CAFE01F00408300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Monday,03,August,2015,16:52:20:41105
Address 5F:8R1 035 746 G recoded (Long Coding) from 1B0200060205E3FF47029F5E09000403140000000100000000 to 1B0200060205E2FF47029F5E09000403140000000100000000  (45202/123/104857)  Monday,03,August,2015,17:19:55:41105
Address 5F:8R1 035 746 G recoded (Long Coding) from 1B0200060205E2FF47029F5E09000403140000000100000000 to 1B0200060205E3FF47029F5E09000403140000000100000000  (45202/123/104857)  Monday,03,August,2015,17:22:26:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000011813CAFE01F00408300003D0D4F9CC748A6090221000008004000070100000034000000 to 26001011813CAFE01F00408300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Monday,03,August,2015,17:29:39:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000011813CAFE01F00408300003D0D4F9CC748A6090221000008004000070100000034000000 to 26000011813CAFE01F01408300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Monday,03,August,2015,17:30:24:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000011813CAFE01F01408300003D0D4F9CC748A6090221000008004000070100000034000000 to 26000011813CAFE01F01418300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Monday,03,August,2015,17:31:45:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000011813CAFE01F01418300003D0D4F9CC748A6090221000008004000070100000034000000 to 26004011813CAFE01F01418300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Monday,03,August,2015,17:32:31:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26004011813CAFE01F01418300003D0D4F9CC748A6090221000008004000070100000034000000 to 26000011813CAFE01700418300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Tuesday,04,August,2015,14:31:17:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000011813CAFE01700418300003D0D4F9CC748A6090221000008004000070100000034000000 to 26001011813CAFE01700418300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Tuesday,04,August,2015,14:33:26:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000011813CAFE01700418300003D0D4F9CC748A6090221000008004000070100000034000000 to 26001011813CAFE01700418300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Tuesday,04,August,2015,14:33:32:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000011813CAFE01700418300003D0D4F9CC748A6090221000008004000070100000034000000 to 26000011813CAFE01700408300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Tuesday,04,August,2015,14:36:57:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000011813CAFE01700408300003D0D4F9CC748A6090221000008004000070100000034000000 to 26000011803CAFF01700408300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Tuesday,04,August,2015,14:38:19:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000011803CAFF01700408300003D0D4F9CC748A6090221000008004000070100000034000000 to 26000011803CAFF01F00408300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Tuesday,04,August,2015,14:38:48:41105
Address 5F:8R1 035 746 G recoded (Long Coding) from 0D0200060305E1FF47029F5E0B000403140000000100000000 to 0C0200060105E3FF47029F5E0B000403140000000100000000  (45202/123/104857)  Tuesday,04,August,2015,14:41:20:41105
Address 46:8K0 907 064 GP recoded (Long Coding) from 01261E3A20FA70958430053600040007 to 01261E3A20FA709584B0053600040007  (45202/123/104857)  Tuesday,04,August,2015,14:58:58:41105
Address 46:8K0 907 064 GP recoded (Long Coding) from 01261E3A20FA709584B0053600040007 to 01261E3A20FA70958430053600040007  (45202/123/104857)  Tuesday,04,August,2015,14:59:41:41105
Address 17:8R0 920 980 T recoded (Long Coding) from 835D22001301D705020001 to 035D22003301D705020001  (52140/001/104857)  Tuesday,04,August,2015,15:06:26:41105
Address 17:8R0 920 980 T recoded (Long Coding) from 035D22003301D705020001 to 035D22001301D705020001  (52140/001/104857)  Tuesday,04,August,2015,15:06:48:41105
Address 08:8K1 820 043 T recoded (Long Coding) from 6618228080 to 66183A8080  (06335/123/12345)  Tuesday,04,August,2015,15:13:25:41105
Address 08:8K1 820 043 T recoded (Long Coding) from 66183A8080 to 6618229880  (06335/123/12345)  Tuesday,04,August,2015,15:13:58:41105
Address 08:8K1 820 043 T recoded (Long Coding) from 66183A8080 to 7E183A8080  (06335/123/12345)  Tuesday,04,August,2015,15:14:12:41105
Address 08:8K1 820 043 T recoded (Long Coding) from 66183A8080 to 66003A8080  (06335/123/12345)  Tuesday,04,August,2015,15:15:52:41105
Address 08:8K1 820 043 T recoded (Long Coding) from 66003A8080 to 66183A8080  (06335/123/12345)  Tuesday,04,August,2015,15:16:58:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000011803CAFF01F00408300003D0D4F9CC748A6090221000008004000070100000034000000 to 26000001803CAFF01F00408300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Tuesday,04,August,2015,15:22:29:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000001803CAFF01F00408300003D0D4F9CC748A6090221000008004000070100000034000000 to 26001001803CAFF01F00408300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Tuesday,04,August,2015,15:24:11:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000001803CAFF01F00408300003D0D4F9CC748A6090221000008004000070100000034000000 to 26000001813CAFF01F00408300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Tuesday,04,August,2015,15:25:35:41105
Address 5F:8R1 035 746 G recoded (Long Coding) from 000200060105E3FF47029F5E0B000403140000000100000000 to 000200060205E3FF47029B5E0B000403140000000100000000  (45202/123/104857)  Tuesday,04,August,2015,15:35:44:41105
Address 5F:8R1 035 746 G recoded (Long Coding) from 000200060105E3FF47029F5E0B000403140000000100000000 to 000200060205E3FF47029B5E0B000403140000000100000000  (45202/123/104857)  Tuesday,04,August,2015,15:36:38:41105
Address 5F:8R1 035 746 G recoded (Long Coding) from 000200060105E3FF47029F5E0B000403140000000100000000 to 000200060105E3FF47029B5E0B000403140000000100000000  (45202/123/104857)  Tuesday,04,August,2015,15:37:58:41105
Address 5F:8R1 035 746 G recoded (Long Coding) from 000200060105E3FF47029F5E0B000403140000000100000000 to 000200060205E3FF47029F5E0B000403140000000100000000  (45202/123/104857)  Tuesday,04,August,2015,15:38:13:41105
Address 5F:8R1 035 746 G recoded (Long Coding) from 000200060105E3FF47029F5E0B000403140000000100000000 to 000200060205E3FF47029F5E0B000403140000000100000000  (45202/123/104857)  Tuesday,04,August,2015,15:38:34:41105
Address 5F:8R1 035 746 G recoded (Long Coding) from 000200060105E3FF47029F5E0B000403140000000100000000 to 000200060105E3FF47029B5E0B000403140000000100000000  (45202/123/104857)  Tuesday,04,August,2015,15:38:48:41105
Address 46:8K0 907 064 GP recoded (Long Coding) from 01261E3A20FA70958430053600040007 to 01261E3A20FA70958730053600040007  (45202/123/104857)  Wednesday,05,August,2015,15:19:29:41105
Address 08:8K1 820 043 T recoded (Long Coding) from 66183A8080 to 66003A8080  (06335/123/12345)  Wednesday,05,August,2015,15:24:49:41105
Address 08:8K1 820 043 T recoded (Long Coding) from 66003A8080 to 66183A8080  (06335/123/12345)  Wednesday,05,August,2015,15:25:24:41105
Address 44:8R0 909 144 P recoded (Long Coding) from 000000000000 to 000000010000  (00000/000/00000)  Wednesday,05,August,2015,15:28:22:41105
Address 44:8R0 909 144 P recoded (Long Coding) from 000000000000 to 000000010000  (12345/123/12345)  Wednesday,05,August,2015,15:28:28:41105
Address 44:8R0 909 144 P recoded (Long Coding) from 000000000000 to 000000010000  (12345/123/12345)  Wednesday,05,August,2015,15:28:32:41105
Address 08:8K1 820 043 T recoded (Long Coding) from 66183A8080 to 66083A8080  (06335/123/12345)  Wednesday,05,August,2015,15:32:35:41105
Address 08:8K1 820 043 T recoded (Long Coding) from 66083A8080 to 66003A8080  (06335/123/12345)  Wednesday,05,August,2015,15:33:38:41105
Address 08:8K1 820 043 T recoded (Long Coding) from 66003A8080 to 66183A8080  (06335/123/12345)  Wednesday,05,August,2015,15:34:03:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000001813CAFF01F00408300003D0D4F9CC748A6090221000008004000070100000034000000 to 26001001813CAFF01F00408300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Wednesday,05,August,2015,16:14:59:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000001813CAFF01F00408300003D0D4F9CC748A6090221000008004000070100000034000000 to 26000001813CAFE01F00408300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Wednesday,05,August,2015,16:20:18:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000001813CAFE01F00408300003D0D4F9CC748A6090221000008004000070100000034000000 to 26000001813CAFE00400408300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Wednesday,05,August,2015,16:21:51:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000001813CAFE00400408300003D0D4F9CC748A6090221000008004000070100000034000000 to 26000001813CAFE01F00408300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Wednesday,05,August,2015,16:22:33:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000001813CAFE01F00408300003D0D4F9CC748A6090221000008004000070100000034000000 to 26000001813C8FE01F00408300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Wednesday,05,August,2015,19:08:51:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000001813C8FE01F00408300003D0D4F9CC748A6090221000008004000070100000034000000 to 26000001811C8FE01F00408300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Wednesday,05,August,2015,19:17:50:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 26000001811C8FE01F00408300003D0D4F9CC748A6090221000008004000070100000034000000 to 2600000181188FE01F00408300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Wednesday,05,August,2015,19:19:25:41105
Address 09:8K0 907 063 DH recoded (Long Coding) from 2600000181188FE01F00408300003D0D4F9CC748A6090221000008004000070100000034000000 to 2600000181388FE01F00408300003D0D4F9CC748A6090221000008004000070100000034000000  (52140/001/104857)  Wednesday,05,August,2015,19:19:46:41105
pmac619
C?ID=250378
Here is another log I was able to find:
Thursday,06,August,2015,16:32:35:41105
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 15.7.0.1
VIN: WA1DGAFP9DA037579   License Plate:
          62 6C 6D 72
   Revision: --H07---
                    Mileage: 134974 km
                    Date: 2015.08.06
                    Time: 13:12:11
          P0068 00 [096] - -
                    Mileage: 134974 km
                    Date: 2015.08.06
                    Time: 13:12:12
   Revision: --H16---
   Coding: 000002
   Coding: 191D1C
            000 -  -
                    Fault Frequency: 32
                    Reset counter: 61
                    Mileage: 134804 km
                    Date: 2015.08.03
                    Time: 18:04:28
                    Hex Value: 0x00C0
                    Hex Value: 0x07A2
                    Hex Value: 0x0015
                    Hex Value: 0x1094
                    Hex Value: 0x0000
   Coding: 66183A8080
                    Reset counter: 60
                    Mileage: 134804 km
                    Date: 2015.08.03
                    Time: 18:02:53
   Coding: 01D513
   Coding: 02005C
                    Reset counter: 59
                    Mileage: 134853 km
                    Date: 2015.08.04
                    Time: 14:38:10
   Coding: 010181
                    Reset counter: 100
                    Mileage: 134853 km
                    Date: 2015.08.04
                    Time: 14:31:21
   Coding: 000037
   Coding: 80CF07FF00
            000 -  -
                    Reset counter: 61
                    Mileage: 135019 km
                    Date: 2015.08.06
                    Time: 16:27:12
   Coding: 1020010
End-------------------------(Elapsed Time: 02:59)--------------------------
pmac619
C?ID=250378
Uwe...
I see that you simply put a response to some of my posts by attaching the Reason as: "CODE Tags." What is this supposed to mean, and how can I find someone with the correct "CODES" to fix, and make the changes and upgrades available for my car?
"M_bolc" is trying to help by looking at past activity and since posted, I look forward to his review and response.
I am not sure what you mean when simply tagging my posts with a reason, and what I can do from that simple action in order to better use this BETA version of this product?
Thank you, I appreciate you looking into this and sending a response to help me fix the "Codes."
-PMM
m_bolc
C?ID=230356
Ok, that makes a world of difference.
To make sure we're looking at the correct fixes: we're looking to get the AC screen back on the MMI, and also fix the DRLs right?
PS: Uwe is wrapping your files in [ code][/code ] tags so that the post is easier to read (shows your file in that nice little sub window within the post, just remove the spaces between brackets)
m_bolc
C?ID=230356
Wooooow that's a lot of long coding changes!
Now, to piece back together your steps, the earliest date I see that you carried out changes was August 2nd. Was your car broken then, or was it after that session that things went wrong?
Also, another tip to help you in the future:
1. Always start a VCDS session with an auto scan, this will be critical because it gives you the full picture of a functional car and all its coding before you make any changes.
2. Save the session log (a screen will pop up where you punch in your license plate or work order number).
3. DO NOT close the session log, that way VCDS will automatically add each change line by line to the bottom of the log file. It even warns you if you are really done with the file.
4. Once you are finished tinkering, close the program. The auto scan file will not only contain your car's information when you started, but the information of how you left it after you made your changes.
Also, you won't find a "master" list of codes for any car. You may find coding for each module individually, but you would have to make sure that the reference car has the same equipment as yours. Coding varies not only from car to car, but each car may be equipped with different versions of each module, and then each module tailored to the extras the car has installed. With the amount of options and personalization possible in Audis/VW coding variations are vast.
pmac619
C?ID=250378
M_bolc -
Yes, the issues with some of the mods happened sometime during my process of doing most all of the mods available to me via the code lists available on Audi forums. I have done these mods a few times over and there are still just a few that I think have disrupted normal settings, as well as not being able to complete the mod.
the most important things I am trying to change back are: The AC menu is showing in my MMI, but it is light green and not accesible, you cant do anything wth it, I have since turned off Aux Air, it's out of MMI now, and I am still working on getting AC MMI tab to be live. It is there, just not active, so I can't properly operate AC.
Thanks for the help Uwe and M_bolc!
m_bolc
C?ID=230356
I'll go ahead and ASSume that your debug file contains all changes you have carried out. If you have used VCDS on more than one PC, please post the debug file from that PC as well. If not, try the following:
This is the earliest coding I found for your modules in your log. It will maybe revert a lot of the changes you want to implement, but let's get everything working first and then we can start tweaking your car.
Address 5F:
Address 08:
6618228080
Address 09:
Let me know how it goes. The changes to the MMI screen should be addressed by the reverted 5F coding, in conjunction with 08 coding (Information electronics and auto HVAC). Central Electronics (09) should take care of the DRLs.
pmac619
C?ID=250378
Thanks M_bolc, not sure I follow the coding suggestions above, I am use to the step by step with first selecting the area (5F for example) then going to long coding, a specific byte, then a bit under that to make the changes.
I will try to use the long codes you supplied to see if I can figure out from that as well.
Thanks again and I will see what I can find out.
I will also post the latest auto scan.
m_bolc
C?ID=230356
Just open each address, click on the coding button, and copy paste the above values in the blank box. Click Do It!, and you should be set.
m_bloc: Thought I would try to lend a hand - hope you don't mind
Pmac619: wow, you certainly have been a very busy-boy with your cable! Here's a more intuitive version of the debug report that you posted earlier. I've arranged the data by control module address, then by date. The highlighted codes in the table are those that were in your car before you made changes. Hopefully the story that the table tells makes more sense in this form.
Perhaps m_bloc can provide more information regarding the impact of the changes that have been made, but as he has suggested, it might be prudent to re-establish the original values
Cheers
PS: If you want the original spreadsheet for the data (for copy-and-paste purposes), click HERE
pmac619
C?ID=250378
DV52 - Although I appreciate your elaborate spreadsheet with time of modification, date, etc, I am looking for a resolution to the main 3 things listed on my original post:
1. Getting the AC in MMI to work properly.
2. Changing back my ability to have the DRLsame work as normal, and have them operable through MMI.
3. Ability to turn off the annoying "Lights on" warning.
4. A list that petrains to my car, listing modifications and steps to carry out mods. I had to use lists from both pre and post facelift which caused some of these issues.
Although I appreciate your fancy sheet you made from my data, I don't see steps to remedy my requested mods, and fixes?
I have yet to do what m_bolc has so kindly recommended, iwI'll hopefully complete today and will post accordingly.
m_bolc
C?ID=230356
pmac619, What I'm trying to do is to get your car to a factory functional state. That's why I suggested using the earliest codes available from where your car was still working appropriately.
As soon as you confirm that you are back to square one, I will help you with the tweaks. I don't want to explore further coding possibilities because we may end up bricking your module ($$$ repairs).
As I said before, you will not find a list for X brand and Y model. You can find possible tweaks for each module. When I find something online I look at what my car is displaying. Most of the time 80% of the tutorial applies to my application and I can infer the remaining 20%.
The coding possibilities are endless, but you really have to stop trying to anything you stumble upon so lightheartedly. You have some reversible issues with your car, I really wouldn't like to see you have permanent issues with it.
I'm not the most experienced user (less than a year), but I have tinkered carefully and learned a lot! Hopefully your experience will be somewhat similar.
Please report back if my prior coding suggestions returned to car to fully functional.
Regards,
Mauricio
pmac619
C?ID=250378
Mauricio- I am going to follow your lead when I have a moment to do so, that's what I sd in the earlier post. Once done I will respond back.
pmac619
C?ID=250378
Mauricio-
Here is what it is saying now...
Malfunctions:
01Engine 0010
6322- I get this from time to time due to tune and intake.
6307- 104 intermittent throttle position correlation
08 HVAC 0010
J255 Redirect Fail
01207 J364 No Signal
09Cent Elect 0010
03110 J792 no signal
01771 J431 no signal
14 Suspension Electric 0010
5F Information Elec0010
J393
m_bolc
C?ID=230356
Can you post the full auto scan?
Did your initial issues get resolved? (DRLs, A/C screen, etc).
