2009 Audi A4 Avant, getting fault codes that say
Kale
C?ID=254307
2 Faults Found: 005582 - ROD - Unknown faultcode 002822 - ROD - Unknown faultcode
Any ideas, on why it says Unknown faultcode, and also where I can find exactly what they mean?
Thanks for any help!
Keithuk
Stoke on Trent, England
C?ID=122432
Welcome to the forum.
When you have a problem/query you always post a full AutoScan of the vehicle in between CODE tags [CODE] Full AutoScan [/CODE] as it takes up less room. How to post an Auto-Scan
There are a few ROD error codes which should be fixed in the next versions.
2012 Passat SE TDI - Unknown Error Code
Zenerdiode
Newcastle, England
C?ID=24330
Also, I believe you're using a HEX-NET Kale? If you do an Auto-Scan in Infrastructure mode; it will go ahead and download any required ASAM data - including missing .rod files.
Kale
C?ID=254307
Thanks, I appreciate the info. I will scan the car again in infrastructure mode, it will download that date and include info on what it is instead of just unknown rod file correct?I will check into how to download a full scan, thanks Keithuk, and Zenerdiode. I need to figure out a better way on my Mac to download the scan to where it looks like it does on the computer, when I download it it just shoves everything together practically putting it into a blur, any ideas on that either?
Kale
C?ID=254307
VIN: WAUGF78K19A142132
Scan: 01 02 03 05 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 42 46 47
	 52 53 55 56 62 65 67 6C 72 77
10-Park/Steer Assist -- Status: Cannot be reached 1100
Address 01: Engine  (CAEB
 DL0MA)	Labels: 06H-907-115-CAB.clb
	Part No SW: 8K2 907 115 AL	HW: 8K2 907 115 D
	Component: 2.0l R4/4V TF H14 0001
	Revision: E1H14---
	Coding: 010C010A190F0160
	Shop #: WSC 50578 001 1048576
	ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
	ROD: EV_ECM20TFS0118K2907115AL.rod
	VCID: 79B57EE767D7DA651FAD48-802C
5582 - Oil Pressure Switch for reduced Oil Pressure
	P164D 00 [040] - Malfunction
Address 02: Auto Trans  (J217)	Labels: 8K-02.lbl
	Part No SW: 8K0 927 158 C	HW: 0B6 927 156
	Component: 0B6 20TFSIUSA H04 0050
	Revision: --H04---
	Coding: 001002
	Shop #: WSC 06335 000 00000
	ASAM Dataset: EV_TCMAL651 A01004
	ROD: EV_TCMAL651.rod
	VCID: 362FB5DB1649F51DB20F2B-8063
No fault codes found.
Address 03: ABS Brakes  (J104)	Labels: 8K0-907-379.clb
	Part No SW: 8K0 907 379 AB	HW: 8K0 907 379 AB
	Component: ESP8 quattro  H04 0060
	Revision: --------
	Coding: 150500
	VCID: 79B57EE767D7C2651FAD48-802C
Address 05: Acc/Start Auth.  (J393)	Labels: 8K0-907-064-05.clb
	Part No SW: 8K0 907 064 AG	HW: 8K0 907 064 AG
	Component: BCM2 1.1      H80 0143
	Coding: 090200
	VCID: 75AD72D74BCFA6057B8574-8020
	Subsystem 1 - 	Part No SW: 8T0-959-754-A
	Component: FBSAUDIB8 IDGH37 0060
	Subsystem 2 - 	Part No SW: 8K0-905-852-D
	Component: ELVAUDIB8    H36 0041
Address 07: Control Head	Labels: 8T0-035-7xx-07-H.clb
	Part No SW: 8T0 035 729 M	HW: 8T0919609A
	Component: Interfacebox    H43  4610
	Revision: 00000000	Serial Number: 340IP087512491
	Coding: 0001003
	VCID: 43C9DC0F559BC8B505B19A-8016
	Subsystem 1 - 	Part No SW: 8T0-919-609-A
	Component: E0380 BedienteilH08  0100
	Serial Number: 00000000153584
Address 08: Auto HVAC  (J255)	Labels: None
	Part No SW: 8T1 820 043 AC	HW: 8T1 820 043 AC
	Component: KLIMA 3 ZONEN H06 0140
	Revision: C1000000
	Coding: 64002000
	VCID: 72A749CB3AA1B13D5E6797-8027
Address 09: Cent. Elect.  (J519)	Labels: 8K0-907-063.clb
	Part No SW: 8K0 907 063 D	HW: 8K0 907 063 D
	Component: BCM1 1.0      H22 0253
	Revision: 05022001
	Coding: 260090950034AF010000000300003D0D0F1C460800010161000000
	Shop #: WSC 06335 123 12345
	VCID: 302383C3F42DC32DE8F36D-8065
	Subsystem 1 - 	Part No SW: 8K1-955-119-A	Labels: 1Kx-955-119.clb
	Component: WWS 300908   H06 0070
	Coding: 00F511
	Subsystem 2 - 	Part No SW: 8K0-955-559	Labels: 8K0-955-559.clb
	Component: RLS          H04 0003
	Coding: 025028
	Subsystem 3 - 	Part No SW: 8K0-941-531-G
	Component: E1 - LDS     H07 0070
	Subsystem 4 - 	Part No SW: 8K0-907-410-A
	Component: UGDO HL US   H04 0060
Address 0E: Media Player 1	Labels: 4E0-910-111.lbl
	Part No SW: 8T1 035 110 C	HW: 8T1035110C
	Component: MP3-Changer     H43  0390
	Revision: 00043003	Serial Number: AUZ5ZBH8607275
	VCID: 2A1791ABD2F139FD26B7AF-807F
Address 0F: Digital Radio	Labels: 4E0-910-593-SIR.lbl
	Part No SW: 4E0 910 593 M	HW: 4E0035593F
	Component: SDAR SIRIUS     H07  0160
	Revision: 00000000	Serial Number: AUZ4Z7H0413820
	Coding: 0000100
	VCID: 312586C7FF274A25E7FD60-8064
Address 10: Failed to respond
Address 15: Airbags  (J234)	Labels: 8K0-959-655.clb
	Part No SW: 8K0 959 655 F	HW: 8K0 959 655 F
	Component: AirbagVW-AU10 H27 0410
	Coding: 303836354230303030304A55304C384B3053
	ROD: EV_AirbaECUVWAUDI010_AU48.rod
	VCID: 40C3D303448D4BAD1893BD-8015
	Subsystem 1 - 	Part No SW: 8K0-959-339-B
	Component: BF-Gewichtss.H01 0030
	Serial Number: 5810000R0800001U5Eªª
	Subsystem 2 - 	Serial Number: 6334MSME41416A0DCEªª
	Subsystem 3 - 	Serial Number: 6344MSME41130504ZEªª
	Subsystem 4 - 	Serial Number: 6352QSME60070C0EGEªª
	Subsystem 5 - 	Serial Number: 6362QSME3B085410AEªª
	Subsystem 6 - 	Serial Number: 63732SME160E0E1A2Eªª
	Subsystem 7 - 	Serial Number: 63832SME160E0904YEªª
Address 16: Steering wheel  (J527)	Labels: 8K0-953-568.clb
	Part No SW: 8K0 953 568 F	HW: 8K0 953 568 F
	Component: Lenks.Modul   H13 0013
	Revision: --------
	Coding: 000017
	VCID: 3D3DAAF7337F3E457375DC-8068
	Subsystem 1 - 	Component: E221 - MFL   H02 0003
Address 17: Instruments  (J285)	Labels: 8T0-920-xxx-17.clb
	Part No SW: 8K0 920 980 A	HW: 8K0 920 980 A
	Component: KOMBIINSTR.   H17 0224
	Revision: 00100000
	Coding: 8B1611000300D705020000
	Shop #: WSC 39016 001 1048576
Address 19: CAN Gateway  (J533)	Labels: 8T0-907-468.clb
	Part No SW: 8T0 907 468 K	HW: 8T0 907 468 K
	Component: GW-BEM 4CAN-M H09 0094
	Revision: 4EB40045
	Coding: 000303
	VCID: 49D5CE2777B792E5CFCD58-801C
	Subsystem 1 - 	Part No SW: 8K0-915-181-B
	Component: J367-BDM     H04 0150
01327 - Control Module for Parking Aid (J446)
Address 1E: Media Player 2  (R199)	Labels: 4E0-035-785.lbl
	Part No SW: 4E0 035 785 F	HW: 4E0 035 785 C
	Component: SG ext.Player H15 0850
	Revision: 00000000
	Coding: 020000
	VCID: 2B1994AFDD0BA0F5DDA1A2-807E
Address 36: Seat Mem. Drvr  (J136)	Labels: 8T0-959-760.clb
	Part No SW: 8K0 959 760	HW: 8K0 959 760
	Component: MEM-FS        H05 0043
	Revision: AA000000
	Coding: 00581300000000000000
	VCID: F7B1F8DFD1C35415E9B9DE-80A2
Address 37: Navigation	Labels: 4E0-910-88x-37.lbl
	Part No SW: 4E0 910 888 M	HW: 4E0919887M
	Component: MNS US          H52  1100
	Revision: 00000000	Serial Number: 341I-087515588
	Shop #: WSC 08316 444 56725
	VCID: 3833BBE31C5D9B6DA02315-806D
Address 42: Door Elect, Driver  (J386)	Labels: 8K0-959-793.clb
	Part No SW: 8K0 959 793 B	HW: 8K0 959 793
	Component: TSG FA        H10 0170
	Revision:
	Coding: 011C03204E00410001
	VCID: 3FC1D0FF39732C556169C6-806A
Address 46: Central Conv.  (J393)	Labels: 8K0-907-064-46.clb
	Coding: 0126063A207A4414033002
	Subsystem 1 - 	Part No SW: 8K0-959-719
	Component: GTO BF       H06 0040
	Subsystem 2 - 	Part No SW: 1K0-951-605-C
	Component: LIN BACKUP HOH03 1301
	Subsystem 3 - 	Part No SW: 8K0-959-591
	Component: J245 PS127   H06 0037
	Subsystem 4 - 	Part No SW: 8K0-959-591
	Component: J394 PS222   H06 0037
02615 - Fuel Tank Cap; Lock
	009 - Open or Short to Ground
02616 - Fuel Tank Cap; Unlock
Address 47: Sound System  (J525)	Labels: 8T0-035-223-ASM.clb
	Part No SW: 8T0 035 223 AD	HW: 8T0 035 223 G
	Component: DSP STD       H08 0300
	Revision: S2600000
	Coding: 020101
	VCID: 70A343C334AD832DA873AD-8025
Address 52: Door Elect, Pass.  (J387)	Labels: 8K0-959-792.clb
	Part No SW: 8K0 959 792 B	HW: 8K0 959 792
	Component: TSG BF        H10 0170
	Revision:
	VCID: 3E3FADFB3E79255D6A7FD3-806B
Address 53: Parking Brake  (J540)	Labels: 8K0-907-801.clb
	Part No SW: 8K0 907 801 E	HW: 8K0 907 801 E
	Component: EPB Audi B8   H05 0060
	Revision: 00000003
	VCID: 312586C7FF27CA25E7FD60-8064
Address 55: Xenon Range	Labels: 8K0-907-357.clb
	Part No SW: 8K0 907 357 B
	Component: Dynamische LWR  H01  0030
	Revision: 00000001	Serial Number:
	Coding: 0000004
	Shop #: WSC 06334 000 00000
	VCID: 342B8FD300357F0D8C1B41-8061
Address 56: Radio	Labels: 4E0-910-541.lbl
	Part No SW: 4E0 910 541 T	HW: 4F0035541N
	Component: TUNER EU/US/RDW H42  0630
	Revision: 00000000	Serial Number: 357I1087509487
	Coding: 0000002
Address 62: Door, Rear Left  (J388)	Labels: 8K0-959-795.clb
	Part No SW: 8K0 959 795	HW: 8K0 959 795
	Component: TSG HL        H06 0170
	Revision:
	Coding: 010C03204000210001
	VCID: FF4110FFF9F36C55A1E986-80AA
Address 65: Tire Pressure  (J502)	Labels: 8K0-907-273.clb
	Part No SW: 8K0 907 273 A	HW: 8K0 907 273 A
	Component: J502-RDK      H03 0250
	Revision: 00001001
	Coding: 0CD154
Address 67: Voice Control	Labels: 4E0-910-75x-67.lbl
	Part No SW: 4E0 910 754 Q	HW: 4E0035753A
	Component: SDS 3501 US     H46  0630
	Revision: 00000000	Serial Number: 00000809020510
	Shop #: WSC 12336 024 394758
Address 6C: Back-up Cam.	Labels: 4L0-910-441.clb
	Part No SW: 8T0 907 441 B	HW: 4L0907441A
	Component: J772__Rearview       0070
	Revision: --H12---	Serial Number: 525PA8-J8990FO
	Coding: 1000007
	VCID: 3731B8DF11439415A9391E-8062
Address 72: Door, Rear Right  (J389)	Labels: 8K0-959-794.clb
	Part No SW: 8K0 959 794	HW: 8K0 959 795
	Component: TSG HR        H06 0170
	Revision:
	VCID: FEBFEDFBFEF9655DAAFF93-80AB
Address 77: Telephone	Labels: 4E0-910-336.lbl
	Part No SW: 4F0 910 336 H	HW: 4E0862335
	Component: Handyvorb2      H20  1130
	Revision: 00000000	Serial Number: 00000005061432
	Coding: 0010900
	VCID: 28136BA3CCFD0BED3083C5-807D
This is what I'm working with, at this point I've replaced:
Oil Pressure Regulating Valve
PCV valve unit (I had crankcase pressure which is now better)
Full oil change and filter 5w40 Full synthetic Castrol
Oil pump and pickup tube
Rod and Main bearings since I was down there
The Pressure Sending Unit
The Valve underneath the filter which has 2 O rings on it to restrict oil flow
Any ideas would be awesome, I just really want to drive this thing safely, I have put a oil pressure tester up to it where the pressure sending unit goes and its dropped to below 8 pounds which is where I shut it off. It only does it at idle, and also when I go above 4k RPMS it tells me to shut it off since its unsafe, the EPC I believe.
Let me know what you think!
Thanks-Kale
Gone But Not Forgotten
OEL PSI is insufficient and pump + check valves + regulation N248 etc........or bypass must be inspected for being stuck open at pump first, and then thereafter in filter/distribution or additional wear in other areas must be inspected to determine by measuring...... or good visual.
At 8 PSI ..........it should not be hard to find.
FYI........by design if the system happens to think its PSI is too high it will force the N248 to make a dump.......
Log the duty cycle in "advanced measuring blocks" ADVMB in VCDS or measure at N248 directly.
Kale
C?ID=254307
Sorry for not knowing the lingo but OEL stand for what? Also the pump is brand new I put that on trying to fix the car, check valves and regulation, I am going to take the cover off the cams in the front which has a check valve and screen in it and see what that looks like. Also which regulators are you speaking of as well as N248? Any ideas on where you would personally start with everything I have already replaced in mind?
Pressure regulating valve
Pressure sending unit
Main and rod bearings
Oil filter and oil
PCV valve
balance shaft chain tensioner
Oil cooler
I will go ahead and log that, at first glance what am I looking for, do you know the numbers it should be putting out?
Thanks!
OEL is Jack's pidgin German for "Öl" which means "oil" in English. ;)
Time to isolate .....force regulation to produce max psi with gage attached, to see if it is electronic verse actually a mechanical loss..... In old instrument clusters, vw would ref oil as oel. Kind of a silent test to see if you are awake.
