2014 Audi C7 A6 TDI fault 15474
xlr8tt
California, USA
C?ID=6901
I have been receiving fault 15474 on and off for the past several months. Sometimes it clears on its own or I clear codes and then it came back several weeks later. Now it seems to be stuck on all the time. Does that mean there is a bad sensor that needs to be replaced?
Saturday,22,April,2023,08:26:53:02582
VCDS Version: 23.3.0.0 (x64)  HEX-NET CB: 0.4631.4
VIN: WAUFMAFC9EN160102   License Plate:
Mileage: 203811km-126642mi   Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 3C 42 44 46 47 52
          53 55 56 5F 62 6C 72 8F 90 AC
VIN: WAUFMAFC9EN160102   Mileage: 203811km-126642miles
Address 01: Engine (J623-CPNB)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 401 N    HW: 4G0 907 401 E
   Component: 3.0TDI FSA    H14 0016
   Revision: 58H14---    CVN: 49F1DF85C2AAFDD538D3FF8238D3FF82827A968D
   Coding: 0A2A4012052601050000
   Shop #: WSC 63076 003 1048576
   ASAM Dataset: EV_ECM30TDI0114G0907401N 002016
   ROD: EV_ECM30TDI0114G0907401N_002.rod
   VCID: 2E10F7A1711D53E361-807A
   VINID: 9D195675159325578118004008E6DD51B4
15474 - Particulate Matter Sensor
          P24AE 00 [237] - Electrical Malfunction
                    Fault Frequency: 16
                    Mileage: 202384 km
                    Date: 2023.02.26
                    Time: 14:18:21
                    Engine RPM: 1605.00 /min
                    Normed load value: 68.2 %
                    Vehicle speed: 118 km/h
                    Coolant temperature: 73 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 14.420 V
                    Exh u PP Ds Batt Snsr Raw: 14.3 V
                    Com i PP Ds IDE Raw: 0.000 µA
                    Exh i PP Ds IDE Shnt Circ: 0.0 µA
                    Exh st PP Ds St Ma-Bits 0-7: 2
                    Particle sensor: surface temperature: 629.85 °C
                    Particle sensor: heat voltage: 7.13 V
Readiness: 1 1 0 0 0
   Part No SW: 4G0 927 158 Q    HW: 0BK 927 156 AM
   Component: 0BK 30 TDIUSA H18 1008
   Revision: --H18---    CVN: 13B31F1C
   VCID: 3C34CDE9B761B173DF-8068
   Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
   Component: ESP PREMIUM   H09 0450
   Coding: 27A79701E4E5E9805B00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004039
   VCID: 3A38CBF1BD558F43CD-806E
   Part No SW: 4H0 907 064 ER    HW: 4H0 907 064 ER
   Component: BCM2 2.0      H36 0521
   Coding: 0DA82046000000000000
   VCID: 7DB200EDE4FB787BA8-8028
   Serial number: 0214000081270015
   Part No SW: 4G0 820 043 AM    HW: 4G0 820 043 AM
   Component: KLIMA 4 ZONEN H14 0096
   Serial number: 06051400041700
   Coding: 368120B849
   ASAM Dataset: EV_AirCondiComfoUDS 004003
   ROD: EV_AirCondiComfoUDS_004.rod
   VCID: 6A983BB18D75FFC37D-803E
0386 - Functional Limitation due to Energy Management
          B10CD 00 [008] - -
                    Reset counter: 77
                    Mileage: 202795 km
                    Date: 2023.03.14
                    Time: 08:50:10
                    Voltage terminal 30: 11.28 V
                    Outside temperature: 17.5 °C
                    Energy management deactivation stage: 1
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001873489
   Coding: 0600E015473C8FE08100088380003908CF9CD208A6090221000008406000
   Shop #: WSC 65188 001 104857
   VCID: 6FAE2AA5BE971AEB2A-803A
   Component: WWS57X 140423  H37 0080
   Serial number:         140426005750
   Coding: 0045F7
   Serial number: 22581019
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
   Component: E1 - LDS  H07 0044
   Serial number: 28 04 2014  00001395
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555RBJGH03
   Serial number: 37D88827000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061412801348
   Coding: A8C305
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71AA2CDDA0A30C1B3C-8024
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H33 0033
   Revision: --------    Serial number: 003D80042CGF Dataset Number: 4G0909602E  0007
   Coding: 303234373131303030314A55304C34473053
   VCID: 3326E6D59A3F7E0B0E-8066
   Component: BF-Gewichtss.  H11 0046
   Serial number: 6940000Y1400014BUV06
   Serial number: 3575HRB400850PAS59MJ
   Serial number: 3585HRB40692L7IKH0V$
   Serial number: 3515JRB401E52JCIM253
   Serial number: 3525JRB4016510A0O8OQ
   Serial number: 3554VRB401I50VVKSGVD
   Serial number: 3564VRB401450VL0M9P.
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372NE500053
   Coding: 000434
   VCID: 383CD1F98B599D533B-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 04 03 2014  C0444099
   Part No SW: 4G8 920 984     HW: 4G8 920 984
   Component: TDieUsa   Nv  H58 0622
   Revision: 29460237    Serial number: 658230414596006
   Coding: 0BEF0A040B41CF05020000
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 73A626D5DABF3E0BCE-8026
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001379351 Dataset Number: 4G0909515H  0067
   Coding: 00CD077D00
   GVL: FDA1E84CFE62600F0000
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 72A823D1A5A53703C5-8026
   Serial number: 0144133303
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 140209000000000004E0
12290 - Quiescent Current
          U1406 00 [009] - Too High
                    Reset counter: 61
                    Mileage: 203803 km
                    Date: 2023.04.18
                    Time: 18:02:04
                    Voltage terminal 30: 12.2 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 27 °C
                    System status: LIN_active
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Reset counter: 77
                    Mileage: 202376 km
                    Date: 2023.02.25
                    Time: 16:04:55
                    Voltage terminal 30: 10.9 V
                    Voltage terminal 15: 11.0 V
                    Control Module temperature: 35 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 1
   Part No SW: 4G0 919 158 N    HW: 4G0 919 158 N
   Component: KLIMA FOND    H08 0096
   Serial number: 02051400040731
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
   Revision: AA000000    Serial number: 00000100505855
   VCID: 77BE12C5C6C7522BF2-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H03 0056
   Revision: --------    Serial number: EJ1BPA820769P8 Dataset Number: 4G0909573C  0006
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3620DFC1894D6B2329-8062
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH05 0060
   Revision: 00H05000    Serial number: 6PZ 010 287-03
   Coding: 0000001
   VCID: 302CE9D9A329451373-8064
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H05 0060
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F02.05.1400H05000AMS14381ÿ
   Subsystem 4 - Serial number: S14381ÿ
   Component: TSG FA        H03 0507
   Coding: 011F17005E00628002000012
   VCID: 47DEA205F6A7E2AB42-8012
   Component: RCEPS         H40 0010
   Revision: 00001000    Serial number: 0026528394 Dataset Number: 4G0909852K  0030
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 3228E3D16525770305-8066
   Revision: 00002001    Serial number: 0334261390
   Coding: 0107063A00FA418580A0080402070E470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000218297
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO29206575
   Coding: 101F00
   Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93228910
   Revision: CJ007001    Serial number: 00000000100611
   Coding: 030000
   VCID: 1D72206D04BBD87BC8-8048
   Component: TSG BF        H03 0507
   Coding: 011F17005E00628002000002
   VCID: 46C0AF01F1ADFBA3B9-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H03 0015
   Revision: --------    Serial number: 00000001050106 Dataset Number: 4G0909522D  0007
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D12F0AD7C1B28FB58-8078
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 140502-0002-171
   Coding: 1221A6101002A500
   ROD: EV_HeadlRegulBasic_AU21.rod
   Part No SW: 4G0 035 082 H    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0138
   Revision: AB001007    Serial number: 156EW0E8004733
   Coding: 020007010000000001
   VCID: 2502088D2CEB10BB90-8070
   Part No SW: 4G0 035 746 J    HW: 4G0 035 746 E
   Component: H-BNT-NA      H41 1038
   Revision: --------    Serial number: 194EX0E7610109
   Coding: 050200000303E1EF55128F1E00000003100001000100000000
   Shop #: WSC 33149 003 104857
   VCID: 2E10F7A1791D53E361-807A
   Subsystem 1 - Part No: 8R0 060 884 BL
   Component: NAR 2014  0902
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDED004ED6N
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349NE20007X
   Component: CD-Database  5571
   Component: TSG HL        H03 0507
   Coding: 010F17004000628002000002
   VCID: 49DAA43DE0B314DB54-801C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H08---    Serial number: 525 PA8J44G06O
   Coding: 1080004
   VCID: 26000F8191ED1BA399-8072
   Component: TSG HR        H03 0507
   Dataset Number: 4G0909614C  0001
   Coding: 0006E008031F0300070308014244CA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 312AECDD60234C1B7C-8064
   Dataset Number: 4G0909615C  0001
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0010
   Revision: 00000000    Serial number: 140920029 Dataset Number: 4G0909571F  0014
   ROD: EV_RDCMA00100.rod
   VCID: 2B16FEB5420F26CB46-807E
End----(Elapsed Time: 02:31, VBatt start/end: 11.1V/11.2V. VIgn 11.2V)-----
"Electrical Malfunction" could be a bad sensor, or it could be a problem with the wiring/connections between the sensor and the ECU.
proetto
Ardmore, PA, USA
C?ID=219098
                    Fault Frequency: 16
                    Mileage: 202384 km
                    Date: 2023.02.26
                    Time: 14:18:21
   Coding: 368120B849
          B10CD 00 [008] - -
                    Reset counter: 77
                    Mileage: 202795 km
                    Date: 2023.03.14
                    Time: 08:50:10
   Coding: 0045F7
   Coding: 02006D
   Coding: A8C305
   Coding: 000434
   Coding: 00CD077D00
   Voltage stabilizer:
                    Reset counter: 61
                    Mileage: 203803 km
                    Date: 2023.04.18
                    Time: 18:02:04
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
                    Reset counter: 77
                    Mileage: 202376 km
                    Date: 2023.02.25
                    Time: 16:04:55
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 1
   Coding: 20
   ROD: EV_SARA2.rod
   Coding: 0000001
   Coding: 101F00
   Coding: 030000
   Coding: 1080004
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
Did you get this fixed? What was the cause?
proetto
Ardmore, PA, USA
C?ID=219098
Do you know how I can find a part number for that sensor? I'm getting the same error
P24AE 00 [11101101] - Electrical Malfunction
2014 Audi A6 TDI
