Search with spaces?
Smac770
C?ID=256949
Is there a way to do searches for strings that include spaces? The control module part numbers are spaced in the autoscan logs, which I support. But it makes it impossible to search the known good scans forum for scans with a particular part number. I'm trying to find scans with 4G0 035 182, but I can't actually get an answer to that question from the search engine.
It's also annoying that the forum has no structure to the threads by make and model. If I want to look at threads for the SQ5, then I want to look at threads for the SQ5. Except I can't search on SQ5 because it's only three characters. Currently, I have to search by the engine code because it's at least 4 characters. CWGD (B9) or CTUD (B8). Unless I was trying to find if anyone had posted one from a B9.5 3.0 TDI, in which case I don't know the engine code offhand.
So that's an annoyance, but the inability to do searches for matching strings that include spaces is a real problem. I've tried using single quotes and double quotes as delimiters. Tried other things google searching turned up searching google with spaces, like %20, %22, +. None of that did anything either.
Thanks,
Scott
