B5 Passat Problems
AutoAL
C?ID=254324
Having a few problems and ran a scan. The was going to replace the o2 sensor. Not sure where to start on evap leak. Was going to check the check valve on the brake system to see if thats the problem. Not sure how to handle the airbag supply voltage to low. Nor how to handle the comm errors for the instruments, can gateway, seat mem. drvr.
Friday,07,August,2015,15:36:42:25268
VCDS Version: 15.7.0.1
Data version: 20150729
VIN: WVWWH63B72E088005   License Plate:
Mileage: 221980km-137931mi   Repair Order:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
VIN: WVWWH63B72E088005   Mileage: 221980km-137931miles
Address 01: Engine        Labels: 078-907-551-ATQ.lbl
   Part No: 3B0 907 551 CG
   Component: 2.8L V6/5V      G   0001
   Coding: 07551
   Shop #: WSC 05311
   VCID: 6AD5CCFE161D5D6EE8-5178
   WVWWH63B72E088005     VWZ7Z0A3811488
16826 - EVAP Emission Control Sys
            P0442 - 35-10 - Small Leak - Intermittent
16825 - EVAP Emission Control Sys
            P0441 - 35-10 - Incorrect Flow - Intermittent
16519 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit
            P0135 - 35-10 - Malfunction - Intermittent
17887 - Brake Boost Vacuum System
            P1479 - 35-10 - Mechanical Failure - Intermittent
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 3B0 927 156 AC
   Component: AG5 01V 2.8l5V  USA 3939
   Coding: 00104
   Shop #: WSC 05311
   VCID: 67D3B5CA050F6006F7-5178
Address 03: ABS Brakes        Labels: 8E0-614-111-ASR.lbl
   Part No: 3B0 614 111
   Component: ABS/ASR 5.3 FRONT   D00
   Coding: 00031
   Shop #: WSC 05314
   VCID: 53AB711AA197FCA6BB-515A
   Part No: 3B1 907 044 J
   Component: CLIMATRONIC B5GP    0003
   Coding: 17200
   Shop #: WSC 05311
   VCID: 2851F6F6C891AF7E3E-5178
   Part No: 6Q0 909 605 C
   Component: 09 AIRBAG VW6  04   0004
   Coding: 12345
   Shop #: WSC 05311
   VCID: 3773258A152F3086A7-513C
   Part No: 1J0 907 487 B
   Component: Lenkradelektronik   0002
   Coding: 00008
   Shop #: WSC 05314
   VCID: 30611E96F041E7BEE6-522A
Address 17: Instruments        Labels: 3B0-920-xx5-17.lbl
   Part No: 3B0 920 926 B
   Component: KOMBI+WEGFAHRSP VDO V01
   Coding: 07235
   Shop #: WSC 23345
   VCID: 234BE1DAB1B74C266B-513C
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 05314
   VCID: 70E1DE9630C1A7BEA6-513C
Address 36: Seat Mem. Drvr        Labels: 3B1-959-760.lbl
   Part No: 3B1 959 760 D
   Component: Sitzverstellung     0101
   VCID: 2E5D00EEBA75F14EF4-515A
   Part No: 1C0 959 799 C
   Component: 0Q Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 05311
   VCID: 3773258A152F3086A7-4B18
   Subsystem 1 - Part No: 1C0959801
   Component: 0Q Tõrsteuer.FS KLO 0003
   Subsystem 2 - Part No: 1C0959802A
   Component: 0Q Tõrsteuer.BF KLO 0002
   Subsystem 3 - Part No: 1C0959811
   Component: 0Q Tõrsteuer.HL KLO 0002
   Subsystem 4 - Part No: 1C0959812
   Component: 0Q Tõrsteuer.HR KLO 0002
End-------------------------(Elapsed Time: 04:10)--------------------------
NostraJackAss
Programming firmware update needed.
Possible bad N80
Heated OXS oxygen sensors are suspect for shorts and should be changed or fused before damage to ecu.
Check for broken or worn hoses on intake and to booster.
I would clear the codes because they are sporadic and see if they come back while observing learned trims.
AutoAL
C?ID=254324
Will having the firmware reflashed be expensive at the dealer?
NostraJackAss
All depends ........
We can do it through the mail for you if interested.
Just give us an email via the contact form at fixmyeuro.com
AutoAL
C?ID=254324
In looking at the coding for the different systems the Auto HVAC is coded for a W8 even though it's a V6. Would this cause the ac to function abnormaly?
NostraJackAss
AutoAL
C?ID=254324
I've replaced the N80 valve and the o2 sensor then reset all of the DTC's. I haven't had any of the codes come back yet. Would the brake boost vacuum errors stay in the system after the problem has been fixed? I only ask because I replaced the breather hoses on the engine because they were cracked. The reason i'm concerned about the hvac system is that it hasn't been cooling very well so I'm trying to find the issue with it. It didn't have any fault codes when I scanned it but, I found instructions online how to have it do an actuator test. After the test I get a fault code for 04f7 temperature flap servo.
United States
No, if this returned
that system isn't fixed but I'm glad to hear you resolved the other issues!
Try Basic Settings 008 with the Key on, Engine off. You may need to pump the pedal a few times to get it to Test On and provide results such as Sys OK or Sys nOK. The vacuum pump should run, which would mean the fuse/relay/wiring to it should be OK, and providing that happens the only other common issue would be faulty check valves and/or external leaks to/from the brake booster and vac. pump.
http://wiki.ross-tech.com/wiki/index.php/17887/P1479/005241
If the flap motor Basic Setting created a Auto HVAC DTC you may want to diagnose that. Post the scan with it shown if you need further assistance.
