Adapting Driver/Passenger seat module/memory
Ricxk916
C?ID=245516
I have replaced BOTH seat control modules as niether seat was operating when I bought the car.
When ONLY the driver's module is connected then everything works, including memory function - for the driver's seat only of course.
I found what looks like a solution at http://www.audi-portal.com/en/diagnostic/ecu_10115.html as below:
I Procedure if address word 36 in both control units.
J Ignition off
J Unplug all connectors between seat and vehicle body from both seats, except airbag.
J Ignition on, ignition off
J Connect only front passenger seat
J Ignition on
J Run program J136 - Seat memory control unit, adaption to DS/PS
J Connect driver seat
J Interrogate and if necessary erase both fault memories
J Check functioning of seats
The problem is I can't "Run program J136". Please can anyone tell me if this can be done using VCDS? (And, obviously, how?)
I don't see any adaptations for seat adjustment in http://wiki.ross-tech.com/wiki/index.php/Audi_A6/S6/RS6/allroad_(4F)
I do see that your can read the seat module assignment in MVB 130/131 as per http://www.audi-portal.com/en/diagnostic/ecu_10117.html#1 so I have logged all the MVBs below (just for driver's seat of course):
Friday,07,August,2015,15:04:57:27526
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
Dealer/Shop Name: RicDavies
VIN:    License Plate: S6VGT
Mileage: 74317-DrvSeatMVB   Repair Order:
                Address 36: Seat Mem. Drvr       Labels: NONE
Control Module Part Number: 4F0 910 760     HW: 4F0 959 760
  Component and/or Version: Sitzmemory FS   H04 0050
           Software Coding: 0082946
            Work Shop Code: WSC 02327 785 00200
                      VCID: 61C9E3C8B8222C3639-8034
                Address 36: Seat Mem. Drvr  (4F0 910 760 )
15:05:16 Group 001
  00000000  Bin. Bits
  11001000  Bin. Bits
  2  Count
  0  Count
15:05:16 Group 002
  Not Oper.
  8787  Count
  Not Oper.
  8000  Count
15:05:16 Group 003
  Not Oper.
  8014  Count
  Not Oper.
  8396  Count
15:05:31 Group 004
  8782  Count
  8000  Count
  8008  Count
  8396  Count
15:05:31 Group 005
  8651  Count
  8697  Count
  8145  Count
  8436  Count
15:05:31 Group 006
  65534  Count
  65534  Count
  65534  Count
  65534  Count
15:05:43 Group 007
  8190  Count
  8190  Count
  8190  Count
  8190  Count
15:05:43 Group 008
  65534  Count
  65534  Count
  65534  Count
  65534  Count
15:05:43 Group 009
  8865  Count
  8569  Count
  8567  Count
  8530  Count
15:05:57 Group 010
  65534  Count
  65534  Count
  65534  Count
  65534  Count
15:05:57 Group 011
  65534  Count
  65534  Count
  65534  Count
  65534  Count
15:05:57 Group 012
  Not Oper.
  65534  Count
  Not Oper.
  65534  Count
15:06:09 Group 013
  Not Oper.
  65534  Count
  Not Oper.
  65534  Count
15:06:09 Group 014
  65534  Count
  65534  Count
  65534  Count
  65534  Count
15:06:09 Group 015
  65534  Count
  65534  Count
  65534  Count
  65534  Count
15:06:20 Group 016
  65534  Count
  65534  Count
  65534  Count
  65534  Count
15:06:20 Group 017
  8190  Count
  8190  Count
  8190  Count
  8190  Count
15:06:20 Group 018
  65534  Count
  65534  Count
  65534  Count
  65534  Count
15:06:31 Group 019
  65534  Count
  65534  Count
  65534  Count
  65534  Count
15:06:31 Group 020
  65534  Count
  65534  Count
  65534  Count
  65534  Count
15:06:31 Group 021
  65534  Count
  65534  Count
  65534  Count
  65534  Count
15:06:49 Group 022
  Not Oper.
  65534  Count
  Not Oper.
  65534  Count
15:06:49 Group 023
  Continue
  N/A
  N/A
  N/A
15:06:49 Group 024
  65534  Count
  65534  Count
  N/A
  N/A
15:07:03 Group 025
  65534  Count
  65534  Count
  N/A
  N/A
15:07:03 Group 026
  65534  Count
  65534  Count
  N/A
  N/A
15:07:03 Group 027
  8190  Count
  8190  Count
  N/A
  N/A
15:07:16 Group 028
  65534  Count
  65534  Count
  N/A
  N/A
15:07:16 Group 029
  65534  Count
  65534  Count
  N/A
  N/A
15:07:16 Group 030
  65534  Count
  65534  Count
  N/A
  N/A
15:07:27 Group 031
  65534  Count
  65534  Count
  N/A
  N/A
15:07:27 Group 032
  65534  Count
  65534  Count
  65534  Count
  65534  Count
15:07:27 Group 033
  65534  Count
  65534  Count
  65534  Count
  65534  Count
15:07:40 Group 034
  65534  Count
  65534  Count
  N/A
  N/A
15:07:40 Group 035
     0      Bin. Bits
  600  Count
  0  Count
  65534  Count
15:08:06 Group 040
  Continue
  N/A
  N/A
  N/A
15:08:06 Group 041
    000000  Bin. Bits
     00000  Bin. Bits
         0  Bin. Bits
15:08:06 Group 042
  00000000  Bin. Bits
    000000  Bin. Bits
    000000  Bin. Bits
     00000  Bin. Bits
15:08:18 Group 043
  00000000  Bin. Bits
  N/A
  N/A
  N/A
15:08:18 Group 044
  14.080 V  Voltage
  N/A
  N/A
15:08:18 Group 045
  00000000  Bin. Bits
  N/A
  N/A
  N/A
15:08:29 Group 046
  Continue
  N/A
  N/A
  N/A
15:08:29 Group 047
  Continue
  N/A
  N/A
  N/A
15:08:29 Group 048
  0  Count
  0  Count
  0  Count
  N/A
15:08:42 Group 049
  26447  Count
       010  Bin. Bits
  N/A
  N/A
15:08:42 Group 050
     01111  Bin. Bits
     00000  Bin. Bits
  N/A
  N/A
15:08:42 Group 051
  1352  Count
  8000  Count
  9352  Count
  250  Count
15:08:55 Group 052
  2096  Count
  8000  Count
  10096  Count
  250  Count
15:08:55 Group 053
  806  Count
  8000  Count
  8806  Count
  250  Count
15:08:55 Group 054
  563  Count
  8000  Count
  8563  Count
  250  Count
15:09:07 Group 055
  65535  Count
  0  Count
  65535  Count
  250  Count
15:09:07 Group 056
  65535  Count
  0  Count
  65535  Count
  250  Count
15:09:07 Group 057
  65535  Count
  0  Count
  65535  Count
  250  Count
15:09:17 Group 058
  65535  Count
  0  Count
  65535  Count
  250  Count
15:09:17 Group 059
  65535  Count
  0  Count
  65535  Count
  250  Count
15:09:17 Group 060
  65535  Count
  0  Count
  65535  Count
  250  Count
15:11:04 Group 130
  2-Wire
  Dr. Door 1
  Central 1
  Gateway 1
15:11:04 Group 131
  E-Mgmnt 1
  Pas. Door 1
  Memory Pax 0
  Dr-Ident. 0
15:11:04 Group 132
  Cent Elec 1
  El.Ign.Lock 1
  N/A
  N/A
15:11:17 Group 133
  00000000  Bin. Bits
  00000000  Bin. Bits
  00000000  Bin. Bits
  00000000  Bin. Bits
15:11:17 Group 134
  11111111  Bin. Bits
  11111111  Bin. Bits
  00000111  Bin. Bits
   1000000  Bin. Bits
Thank you in advance.
Ricxk916
C?ID=245516
I have made a note of the current adaptations on the driver's seat module here:
Friday,07,August,2015,15:42:22:27526
Mileage: 74317-DrvrSeatAdapt   Repair Order:
Adaptation Channel 001:
Stored value 2
  N/A
  N/A
  N/A
  N/A
Adaptation Channel 002:
Stored value 0
  N/A
  N/A
  N/A
  N/A
Adaptation Channel 003:
Stored value 0
  N/A
  N/A
  N/A
  N/A
Adaptation Channel 004:
Stored value 1
  N/A
  N/A
  N/A
  N/A
Adaptation Channel 005:
Stored value 1
  N/A
  N/A
  N/A
  N/A
Adaptation Channel 006:
Stored value 1
  N/A
  N/A
  N/A
  N/A
Adaptation Channel 007:
Stored value 65535
  N/A
  N/A
  N/A
  N/A
Adaptation Channel 008:
Stored value 248
  N/A
  N/A
  N/A
  N/A
Adaptation Channel 009:
Stored value 600
  N/A
  N/A
  N/A
  N/A
Adaptation Channel 010:
Stored value 2096
  N/A
  N/A
  N/A
  N/A
Adaptation Channel 012:
Stored value 0
  N/A
  N/A
  N/A
  N/A
Ricxk916
C?ID=245516
I have put the passenger seat module back. Now, both seats have full movement except for the back adjustment and neither seat can SET memory, though the driver's seat will return to the positions previously set on buttons '1' and '2'. In summary, back adjustment and memory setting don't work.
Please post the complete Auto-Scan and if one of those controllers (06 or 36) are not communicating let us know what the part numbers from each control unit are. That should let us know if they should be plug and play with unique address words as opposed to needing identity configuration via Adaptation for each address (06 versus 36) so both will communicate.
One last note.
Stored value 2
  N/A
  N/A
  N/A
  N/A
Although I suspect this is a 4F0 controller I dug into B8/8T0 stuff and located Adaptation channel 001 (Reset Control Unit Address). If both of these modules have the identical part number I believe you would need to do the following:
Unplug the Passenger unit, connect to 36-Driver and change Adp channel 001 from 2 to the new value of 1 followed by testing/saving, exiting and make sure to cycle the ignition. Make sure 36 still communicates with VCDS before plugging the other controller back in!​
If the modules do not have identical part numbers ignore that suggestion.
Ricxk916
C?ID=245516
The original and *new* seat modules all look exactly the same to me, as shown in photos below:
Original seat module:
*New* seat module:
*New* seat module:
Autoscan with both modules installed:
Friday,07,August,2015,11:43:39:27526
VIN: WAUZZZ4F37N004960   License Plate: S6VGT
Mileage: 74284mi-ABSfixed+test   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 13 15 16 17 19 36 37 42
          46 47 4F 52 53 55 56 57 61 62 6D 72 76 77
VIN: WAUZZZ4F37N004960   Mileage: 119550km-74284miles
06-Seat Mem. Pass -- Status: Cannot be reached 1100
   Part No SW: 4F1 910 552 C    HW: 4F1 907 552
   Component: 5.2L V10/4V FSI    ª0060
   Revision: 59H09---    Serial number:
   Coding: 010D0003190F0260
   Shop #: WSC 00763 210 91830
   VCID: 2447AADCE7B0791E12-8070
000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
               P0030 - 004 - Malfunction / Open Circuit - MIL ON
                    Fault Status: 11100100
                    Fault Frequency: 41
                    Mileage: 119518 km
                    Date: 2015.08.06
                    Time: 17:26:06
                    RPM: 1123 /min
                    Load: 52.5 %
                    Temperature: 25.0°C
                    Temperature: 25.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.954 V
Readiness: 0010 1001
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4F2 910 156 M    HW: 09E 927 156 C
   Component: AG6 09E 5,2 FSI RdW 0010
   Revision: --H01---    Serial number:        0085607
   Coding: 0000001
   Shop #: WSC 02325 785 00200
   VCID: 2F6D55F0BE76CA46FF-807A
Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
   Part No SW: 4F0 910 517 P    HW: 4F0 614 517 P
   Component: ESP 8.0 quattro H05 0070
   Coding: 0020920
   VCID: 31695388A842DCB6E9-8064
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Serial number: 10601000434043
   Coding: 0000147
   Shop #: WSC 00976 210 82617
   VCID: 63C5E9C0A23E3E262B-8036
   Subsystem 1 - Part No: 4F0 910 131 E
   Component: FBSAUDIC6 EZS   H45 0080
   Subsystem 2 - Part No: 4F0 910 220 D
   Component: FBSAUDIC6 IDG   H01 0040
Address 06: Seat Mem. Pass
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
   Part No SW: 4F1 910 732 E    HW: 4E0 035 729 A
   Component: Interfacebox    H43 5570
   Revision: 00000000    Serial number: 351EN067518046
   Coding: 0011002
   Shop #: WSC 02335 785 00200
   VCID: 2643B0D4918C8B0E0C-8072
   Component: Bedienteil MMIC6H02 0060
   Subsystem 2 - Serial number: 00000000424828
   Subsystem 3 - Serial number: 0123.05.060000000100010533ÿ
   Subsystem 4 - Serial number: 010533ÿ
Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
   Part No SW: 4F0 910 043     HW: 4F2 820 043 N
   Component: KLIMABETAETIGUNGH20 0170
   Revision: 00000030    Serial number: 00000000266593
   Coding: 0525578
   VCID: 5BB5D1209A4E06E663-800E
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Component: ILM Fahrer      H17 0240
   Coding: 0015121
   Subsystem 1 - Part No: 4F2 910 113 A
   Component: Wischer AudiC6  H04 0190
   Coding: 00064784
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH12 0090
   Coding: 00146221
   Shop #: WSC 02335
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBF8113747
   VCID: 1C37923CDFC041DEAA-8048
Address 0F: Digital Radio        Labels: None
   Part No SW: 4E0 910 563 C    HW: 4E0 035 563
   Component: DAB-Tuner       H41 0830
   Revision: 00000001    Serial number: KE1276U7301399
   Coding: 0000001
   Shop #: WSC 02323 785 00200
Address 11: Engine II        Labels: Redir Fail!
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 4F0 910 561 B    HW: 4F0 907 561 A
   Component: ABSTANDSREGELUNGH05 0060
   Revision: --------    Serial number: 00000000000000
   Coding: 0041158
   VCID: 224BACC4FDA4772E60-8076
Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
   Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
   Component: 4E AIRBAG AUDI8RH29 0260
   Revision: 07H29000    Serial number: 0037LD0B36T7
   Coding: 0013381
   VCID: 2959BBE88092A47621-807C
   Subsystem 1 - Serial number: 6332CSME0F2E147CG
   Subsystem 2 - Serial number: 6342CSME11287E634
   Subsystem 3 - Serial number: 6352QSME0E27352FP
   Subsystem 4 - Serial number: 6362QSME10277665C
   Subsystem 5 - Serial number: 63734SME0C6E467BI
   Subsystem 6 - Serial number: 63834SME0E62532F6
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H07 0230
   Revision: 00H07000    Serial number: 90054061240139
   Coding: 0102152
   VCID: 66C3F0D4510C4B0ECC-8032
   Component: Lenkradmodul    H07 0090
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4F0 920 980 R
   Component: KOMBIINSTR. M73 H17 0070
   Revision: 00500000    Serial number: 59L370956
   Coding: 2177443
   Shop #: WSC 00282 067 57207
   VCID: 2345A9C0E2BE7E266B-8076
Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 E
   Component: Gateway         H11 0070
   Revision: 11          Serial number: 12009061288056
   Coding: EEFEF3DC1B3D06
   Shop #: WSC 00551 210 91539
   VCID: 275DBDD09686920637-8072
00461 - Control Module for Seat Memory; Passenger (J521)
                    Reset counter: 106
                    Mileage: 119518 km
                    Date: 2015.08.06
                    Time: 17:27:27
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0082946
   Shop #: WSC 02327 785 00200
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 D
   Component: MNS ECE         H47 1060
   Revision: 00000000    Serial number: 364EP067561262
   VCID: 3B7571A07A0E26E643-806E
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 793 E
   Component: TSG FA          H12 0120
   Revision: 00000000    Serial number: Uga
   Coding: 0003834
   VCID: 2C5742FC8F60B15EDA-8078
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 B    HW: 4F0 907 289 B
   Component: Komfortgeraet   H22 0170
   Revision: 01700022    Serial number: 01013198330000
   Coding: 3285755
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
   Component: DSP-High C6     H09 0240
   Revision: PROD_01     Serial number: 00000000000587
   Coding: 0000117
   VCID: 2541B7D8EC8A801605-8070
   Part No SW: 4F0 910 280     HW: 4F0 907 280 A
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000237286
   Coding: 0011104
   VCID: 5EB3D834895C13CE04-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 792 E
   Component: TSG BF          H12 0120
   Revision: 00000000    Serial number: &Eb
   Coding: 0003834
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 B    HW: 4F0 907 801 A
   Component: EPB  CB4C0060   H04 0060
   Revision: --H04---
   Coding: 0008021
   Shop #: WSC 02324 785 00200
   VCID: 1F4DA530CED65AC64F-804A
   Part No: 8P0 907 357 F
   Coding: 0000003
   VCID: 3D717FB8641A28D67D-8068
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 H
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 394EU067644253
   Coding: 0000001
Address 57: TV Tuner        Labels: None
   Part No SW: 4E0 910 148 E    HW: 4E0 919 148
   Component: R0078 TVhybridT     0470
   Revision: R0H05000    Serial number: 76300700297602
   Coding: 0000303
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: J0644 BEM       H12 0590
   Revision: 00000000    Serial number: 00000000035546
   Shop #: WSC 00976 210 67853
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  2605170495
   Coding: 344630393135313035442056413032363035313730343935
   Shop #: WSC 00000 384 00290
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
   Component: TSG HL          H21 0050
   Coding: 0003114
   VCID: 2E5348F4B97CC34EF4-807A
Address 6D: Trunk Elect.        Labels: Redir Fail!
   Part No SW: 4F9 910 591     HW: 4F9 827 851 D
   Component: ValeoHeckdeckel H20 0280
   Revision: --H20001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6CD782FC4FE0715E9A-8038
   Subsystem 1 - Part No: 4F9 910 592
   Subsystem 3 - Serial number: RD12.05.06--H20001001B0193ÿ
   Subsystem 4 - Serial number: 1B0193ÿ
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Component: TSG HR          H21 0050
   Coding: 0003114
                    Reset counter: 147
                    Mileage: 119518 km
                    Date: 2015.08.06
                    Time: 17:29:12
   Part No SW: 4F0 910 283 D    HW: 4F0 919 283 D
   Component: Parkhilfe 4-Kan H09 0040
   Revision: 00H09000    Serial number: 11720613103500
   Coding: 0001116
   Part No SW: 4E0 910 336 M    HW: 4E0 862 335
   Component: Handyvorb2      H10 1130
   Revision: 00000000    Serial number: 00000007549036
   Coding: 0010900
Gone But Not Forgotten
Maybe the production dates are not the same and maybe this used module is a dud?
Ricxk916
C?ID=245516
Thanks Dana, I decided to try out the "B8/8T0 stuff" you found - at my own risk of course! And.....whoops! The Component Protection that Audi had previously
removed (at great expense) has come back.
See Autoscan below with just the driver seat module connected and Adaptation 001 set to "1" , then Tested, then Saved, then ignition off/on/off, then seat all the way forwards+5 seconds, back+5 seconds, forward+5 seconds:
Friday,14,August,2015,17:58:01:27526
VIN:    License Plate: S6VGT Driver Seat Module Only
Stored value 1
  N/A
  N/A
  N/A
  N/A
Address 36: DTCs cleared
VIN: WAUZZZ4F37N004960   Mileage: 119940km-74527miles
36-Seat Mem. Drvr -- Status: Malfunction 1010
                    Mileage: 119518 km
                    Date: 2015.08.06
                    Time: 17:26:06
                    RPM: 1123 /min
                    Load: 52.5 %
                    Temperature: 25.0°C
                    Temperature: 25.0°C
                    Voltage: 12.954 V
   Coding: 0000001
   Coding: 0020920
   Coding: 0000147
   Coding: 0011002
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Reset counter: 160
                    Mileage: 119660 km
                    Date: 2015.08.10
                    Time: 20:34:27
   Coding: 0525578
   Coding: 0015121
   Coding: 00064784
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
   Coding: 0000001
   Coding: 0041158
   Coding: 0013381
   Coding: 0102152
   Coding: 2177443
                    Reset counter: 120
                    Mileage: 119518 km
                    Date: 2015.08.06
                    Time: 17:27:27
                    Reset counter: 161
                    Mileage: 119942 km
                    Date: 2015.08.13
                    Time: 16:07:53
   Coding: 0082946
01448 - Sensor for Driver Seat; Tilt Adjust (G232)
                    Fault Status: 01100101
                    Reset counter: 121
                    Mileage: 119940 km
                    Date: 2015.08.14
                    Time: 17:59:24
   Coding: 0003834
                    Reset counter: 161
                    Mileage: 119942 km
                    Date: 2015.08.13
                    Time: 16:51:22
   Coding: 3285755
   Coding: 0000117
   Coding: 0011104
   Coding: 0003834
                    Reset counter: 161
                    Mileage: 119942 km
                    Date: 2015.08.13
                    Time: 16:07:53
   Revision: --H04---
   Coding: 0008021
   Coding: 0000003
   Coding: 0000001
   Coding: 0000303
02272 - Quiescent Current Stage 1
            000 -  -  - Intermittent
                    Mileage: 119660 km
                    Date: 2015.08.10
                    Time: 19:47:00
02273 - Quiescent Current Stage 2
                    Mileage: 119660 km
                    Date: 2015.08.10
                    Time: 19:53:26
02276 - Quiescent Current Stage 5
                    Mileage: 119660 km
                    Date: 2015.08.10
                    Time: 19:53:36
02274 - Quiescent Current Stage 3
                    Mileage: 119660 km
                    Date: 2015.08.10
                    Time: 19:55:12
02277 - Quiescent Current Stage 6
                    Mileage: 119660 km
                    Date: 2015.08.10
                    Time: 19:55:22
   Coding: 0003114
   Coding: 0003114
   Coding: 0001116
   Coding: 0010900
End-------------------------(Elapsed Time: 03:34)--------------------------
I tested the driver seat memory and it worked fine.
Then I plugged the passenger seat module in. That module definitely still had Adaptation 001=2. Again I did the seat forward/back/forward+5 seconds, and the 'Set' button lit when I tried it, and I heard a 'beep' when I pressed '1' to store the position. Then I moved the seat and pressed (only) '1' to set it back to the memory position but nothing happened.
The driver's seat memory no longer worked either.
Below is the Autoscan with both seat modules installed (DrvrSeatAdp001=1, PassSeatAdp001=2):
Friday,14,August,2015,18:16:17:27526
VIN:    License Plate: ASCAN21
Stored value 2
  N/A
  N/A
  N/A
  N/A
Stored value 1
  N/A
  N/A
  N/A
  N/A
Address 06: DTCs cleared
06-Seat Mem. Pass -- Status: Malfunction 1010
                    Mileage: 119518 km
                    Date: 2015.08.06
                    Time: 17:26:06
                    RPM: 1123 /min
                    Load: 52.5 %
                    Temperature: 25.0°C
                    Temperature: 25.0°C
                    Voltage: 12.954 V
   Coding: 0000001
   Coding: 0020920
   Coding: 0000147
Address 06: Seat Mem. Pass        Labels: None
   Component: Sitzmemory BFS  H04 0050
   Coding: 0082946
02005 - Coding Pin
                    Fault Status: 01101000
                    Reset counter: 121
                    Mileage: 119940 km
                    Date: 2015.08.14
                    Time: 18:16:54
01722 - Sensor For Seat Front Height Adj. Pass. Seat (G281)
                    Reset counter: 121
                    Mileage: 119940 km
                    Date: 2015.08.14
                    Time: 18:16:54
   Coding: 0011002
                    Reset counter: 160
                    Mileage: 119660 km
                    Date: 2015.08.10
                    Time: 20:34:27
   Coding: 0525578
   Coding: 0015121
   Coding: 00064784
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
   Coding: 0000001
   Coding: 0041158
   Coding: 0013381
   Coding: 0102152
   Coding: 2177443
                    Reset counter: 160
                    Mileage: 119518 km
                    Date: 2015.08.06
                    Time: 17:27:27
                    Reset counter: 161
                    Mileage: 119942 km
                    Date: 2015.08.13
                    Time: 16:07:53
   Coding: 0082946
            000 -  -
                    Reset counter: 121
                    Mileage: 119940 km
                    Date: 2015.08.14
                    Time: 18:17:43
02005 - Coding Pin
                    Reset counter: 121
                    Mileage: 119940 km
                    Date: 2015.08.14
                    Time: 18:17:43
   Coding: 0003834
                    Reset counter: 161
                    Mileage: 119942 km
                    Date: 2015.08.13
                    Time: 16:51:22
   Coding: 3285755
   Coding: 0000117
   Coding: 0011104
   Coding: 0003834
                    Reset counter: 161
                    Mileage: 119942 km
                    Date: 2015.08.13
                    Time: 16:07:53
   Revision: --H04---
   Coding: 0008021
   Coding: 0000003
   Coding: 0000001
   Coding: 0000303
                    Mileage: 119660 km
                    Date: 2015.08.10
                    Time: 19:47:00
                    Mileage: 119660 km
                    Date: 2015.08.10
                    Time: 19:53:26
                    Mileage: 119660 km
                    Date: 2015.08.10
                    Time: 19:53:36
                    Mileage: 119660 km
                    Date: 2015.08.10
                    Time: 19:55:12
                    Mileage: 119660 km
                    Date: 2015.08.10
                    Time: 19:55:22
   Coding: 0003114
   Coding: 0003114
   Coding: 0001116
   Coding: 0010900
You will notice that both seats (36 and 06) now have a problem with an "implausible coding pin".
And the driver's seat (36) now has Component Protection Active which I previously had removed by Audi. Looks like another trip to the dealer for that. Whoops!
Both seats have forward and back, and rake, and lumbar movement on the buttons; but no backrest movement, and no memory; which isn't the end of the world, it would just be nice to get it all working.
Perhaps Jack is right, maybe one of the modules is duff!
And finally, I re-checked the Adaptation 001 settings: the driver's seat had reset to '2' and the passenger seat had set itself to '1'; though they were both '2' before I started.
Strange huh?
This is strange. The Component Protection is a bummer but that Adaptation tweak appears to have both controllers online and communicating at this point in time. The Coding bridges (or coding pins) however could be a possible wiring discrepancy ... or I provided wrong side of the pond adaptation values. If our left and rights are misconfigured it might not hurt to use my previous instructions (before another CP dealer trip!) and do the opposite:
DrvrSeatAdp001=2, PassSeatAdp001=1
Edit: If that resolves the coding pin DTCs I would say the right side of the car (regardless of steering wheel location) = 2. Feedback would be excellent either way!
Ricxk916
C?ID=245516
Thx Dana. As each module already has a different Adaptation number: "1" & "2", I just swapped the modules over, so now Driver (36, rhd) = "2" and passenger (06, left side) = "1", and now all seems well (apart from CP of course) Thx. Final Autoscan below for posterity:
Wednesday,26,August,2015,10:35:07:27526
Mileage: SeatAdaptChk03   Repair Order:
After seat modules swapped between seats.
Stored value 1
  N/A
  N/A
  N/A
  N/A
Stored value 2
  N/A
  N/A
  N/A
  N/A
VIN: WAUZZZ4F37N004960   Mileage: 120510km-74881miles
                    Mileage: 119518 km
                    Date: 2015.08.06
                    Time: 17:26:06
                    RPM: 1123 /min
                    Load: 52.5 %
                    Temperature: 25.0°C
                    Temperature: 25.0°C
                    Voltage: 12.954 V
   Coding: 0000001
   Coding: 0020920
   Coding: 0000147
   Coding: 0082946
   Coding: 0011002
   Coding: 0525578
   Coding: 0015121
   Coding: 00064784
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
   Coding: 0000001
   Coding: 0041158
   Coding: 0013381
   Coding: 0102152
   Coding: 2177443
   Coding: 0082946
            000 -  -
                    Reset counter: 139
                    Mileage: 120516 km
                    Date: 2015.08.25
                    Time: 20:53:35
   Coding: 0003834
   Coding: 3285755
01503 - Bulb for 3rd Brake Light (M25)
                    Fault Status: 00101001
                    Reset counter: 178
                    Mileage: 119946 km
                    Date: 2015.08.15
                    Time: 13:12:28
   Coding: 0000117
   Coding: 0011104
   Coding: 0003834
   Revision: --H04---
   Coding: 0008021
   Coding: 0000003
   Coding: 0000001
   Coding: 0000303
   Coding: 0003114
   Coding: 0003114
                    Reset counter: 174
                    Mileage: 120470 km
                    Date: 2015.08.22
                    Time: 18:36:25
   Coding: 0001116
   Coding: 0010900
End-------------------------(Elapsed Time: 03:33)--------------------------
Ricxk916
C?ID=245516
Backrest on both seats still don't work, though everything else does, including memory, which has been a godsend because everyone who ever works on the car moves the seat waaaay back and all I have to do to set it back is hold the "1" button. Lovely.
So...I took the passenger seat out.
I put power directly onto the backrest motor and it worked fine, in both directions; so the motor is good.
I put power through the 12-pin black block connector (pins 6 and 8) to the motor and it worked fine again.
I checked the switch for continuity; between pin 4 (power in) and pin 5 (backrest switch); and that was OK.
I think this means the problem is in the controller box? My reasoning is that the switch is working, which triggers a 'relay' in the seat controller to send 12V power to either of the cables to the backrest motor, which isn't being sent because if it was then the motor would move. In fact I hear a 'relay-type' click when the backrest switch is operated in one direction, but not the other.
I have searched everywhere to see if there is any kind of setting in the controller that 'enables/disables' the backrest. I can't imagine any need for such a setting.
I am stumped. Any ideas? Full Autoscan below:
Sunday,12,March,2017,17:13:18:27526
VCDS Version: 16.8.4.2 (x64)
Mileage: 144050km-89508mi   Repair Order: 1703121713
VIN: WAUZZZ4F37N004960   Mileage: 144050km-89508miles
   VCID: 2447AADCE7B079628D-8070
Readiness: 0110 1001
   Coding: 0000001
   VCID: 2F6D55F0BE76CA3A60-807A
   Coding: 0020920
   VCID: 31695388A842DCCA76-8064
   Coding: 0000147
   Shop #: WSC 57389 001 1048576
   VCID: 63C5E9C0A23E3E5AB4-8036
   Coding: 0082946
   VCID: 61C9E3C8B8222C4AA6-8034
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
   Coding: 0011002
   VCID: 2643B0D4918C8B7293-8072
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Coding: 0525578
   VCID: 5BB5D1209A4E069AFC-800E
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 63
                    Mileage: 144056 km
                    Date: 2017.03.12
                    Time: 17:15:44
                    Temperature: 12.0°C
   Coding: 0015121
   Coding: 00064784
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
   VCID: 1C37923CDFC041A235-8048
   Coding: 0000001
   Coding: 0041158
   VCID: 224BACC4FDA47752FF-8076
Address 15: Airbags        Labels: 4F0-910-655-8R.clb
   Coding: 0013381
   VCID: 2959BBE88092A40ABE-807C
   Coding: 0102152
   VCID: 66C3F0D4510C4B7253-8032
   Coding: 2177443
   VCID: 2345A9C0E2BE7E5AF4-8076
Address 19: CAN Gateway        Labels: 4F0-910-468.clb
   VCID: 275DBDD09686927AA8-8072
   Coding: 0074850
   Shop #: WSC 36594 001 1048576
   VCID: 3B7571A07A0E269ADC-806E
   Coding: 0003834
   VCID: 2C5742FC8F60B12245-8078
   Coding: 3285755
   Coding: 0000117
   VCID: 2541B7D8EC8A806A9A-8070
   Coding: 0011104
   VCID: 5EB3D834895C13B29B-800A
   Coding: 0003834
   Revision: --H04---
   Coding: 0008021
   VCID: 1F4DA530CED65ABAD0-804A
   Coding: 0000003
   VCID: 3D717FB8641A28AAE2-8068
   Coding: 0000001
   Coding: 0000303
   Coding: 0003114
   VCID: 2E5348F4B97CC3326B-807A
   VCID: 6CD782FC4FE0712205-8038
   Coding: 0003114
   Coding: 0201116
   Coding: 0010900
Ricxk916
C?ID=245516
This location provides Measure Value Blocks (MVB) information for the J136 (Driver's Seat Memory Controller):
So now I know that the controllers 'sees' the backrest button being operated 'forward' and 'back' because it says so in words "forward" and "back" in MVB 002 block 3.
Also, MVB 002 block 4 shows the current backrest position as "8000"; which I guess is OK as the other seat adjustments are also in the 8000 range. BUT the following was interesting:
Measured value block 052:
Maximum software travel, backrest angle adjustment: 2096
Stored value, software block front, backrest angle adjustment: 8000
Stored value, software block rear, backrest angle adjustment: 10960
Stored value, load change counter, backrest angle adjustment: 7
I think this means that the controller software thinks that 8000 is as far forward as the backrest should travel. If so, this might explain why the relay doesn't click when the backrest button is pushed forward, only when it is pushed back. It would be nice to know if that 8000 value can be altered somewhere to test this theory.
I also made a note of the Adaptation fields: 1=2; 2=1; 3=0; 4=1; 5=0; 6=1; 7=65535; 8=248; 9=600; 10=2096; 11=N/A; 12=0.
Though this doesn't currently mean anything to me; except I think that the '2' in field 1 means this is the right side seat (UK driver's seat).
lanasa1980
C?ID=363799
I am new to my Audi S5. I have having issue with my seats too. And advice??
Sunday,16,June,2019,13:10:57:15290
VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
VIN: WAURV78T29A027382   License Plate:
Mileage: 213290km-132532mi   Repair Order:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 36 42 46 47 52 53 55 56 65
          77
VIN: WAURV78T29A027382   Mileage: 213290km-132532miles
Address 01: Engine (J623-CAUB)       Labels:. 079-907-560-CAU.clb
   Part No SW: 8T0 907 560 N    HW: 8T0 907 560
   Component: 4.2l V8/4V    H10 0003
   Revision: 76H10---
   Coding: 01140009190F0120
   Shop #: WSC 44177 000 1048576
   VCID: 45D75034E5A25D8FB93-8010
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8K0 927 158 B    HW: 0B6 927 156
   Component: 0B6 42 FSIUSA H04 0040
   Revision: --H04---
   Coding: 001002
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMAL651 A01004
   ROD: EV_TCMAL651.rod
   VCID: 353720F4B5C2CD0F293-8060
   Part No SW: 8K0 907 379 AB    HW: 8K0 907 379 AB
   Component: ESP8 quattro  H04 0060
   Coding: 120500
   VCID: 79AFECC4D9DAE96F8DB-802C
   Part No SW: 8K0 907 064 F    HW: 8K0 907 064 F
   Component: BCM2 1.1      H80 0143
   Coding: 090000
   VCID: 33331EECBB36D33F077-8066
   Subsystem 1 - Part No SW: 8K0 959 754 AB    HW: 8K0 959 754 AB
   Serial number: 0816000082741003
   Component: ELVAUDIB8  H36 0041
   Serial number: 0208000074687009
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 B    HW: 8T0 959 760 B
   Component: MEM-BFS       H09 0043
   Revision: AA000000    Serial number: 00001001170436
   Coding: 00017025002C00000000
   VCID: 42DD4B28F48C6AB79C1-8016
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0150
   Revision: C1000000    Serial number: 01171020081343
   Coding: 48022000
   VCID: 72BDDBE884AC9A37CC1-8026
            001 - Upper Limit Exceeded
                    Fault Status: 01100001
                    Reset counter: 56
                    Mileage: 213293 km
                    Date: 2019.06.17
                    Time: 12:41:39
                    Temperature: 41.0°C
                    Temperature: 92.0°C
                    Load: 100.0 %
                    Absolute Pres.: 30.0 bar
                    RPM: 1280 /min
                    Speed: 39.0 km/h
                    Current: 0.470 A
                    Temperature: 19.0°C
                    Reset counter: 71
                    Mileage: 205655 km
                    Date: 2019.03.31
                    Time: 13:40:06
                    Temperature: 16.0°C
   Component: BCM1 1.0      H22 0253
   Revision: 05022001    Serial number: 00000000252864
   Coding: 26001091063CAF010000080300003D3D0F18538800010161000000
   Shop #: WSC 06325 123 12345
   VCID: 303911E04A20E8277A5-8064
   Subsystem 1 - Part No SW: 8T1 955 119 C    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 171008  H13 0040
   Serial number: SWF08100170198
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10297230
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 J    HW: 8K0 941 531 J
   Component: E1 - LDS  H07 0070
   Serial number: 00000000000910080719
   Subsystem 4 - Part No SW: 8K0 907 410 A    HW: 8K0 907 410 A
   Component: UGDO HL US  H04 0060
                    Reset counter: 71
                    Mileage: 205655 km
                    Date: 2019.03.31
                    Time: 13:40:00
   Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0039KD14B3V9
   Coding: 303333334330303030304A55304C38543053
   VCID: 40D94120FA0078A78A5-8014
   Subsystem 1 - Part No SW: 8K0 959 339     HW: 8K0 959 339
   Component: BF-Gewichtss.  H01 0050
   Serial number: 5810000R08000021S2
   Serial number: 6334MSME41442F238
   Serial number: 6344MSME414274769
   Serial number: 6352QSME4809511CH
   Serial number: 6362QSME680F452CU
   Serial number: 63732SME570D181C3
   Serial number: 63832SME570D1A14+
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90315HJG000D5
   Coding: 000036
   VCID: 3D2738D48D72154FE13-8068
   Part No SW: 8T0 920 981 E    HW: 8T0 920 981 E
   Component: KOMBIINSTR.   H31 0224
   Revision: 00100000    Serial number: 9D969WJA8
   Coding: 831701000300D705020000
   VCID: 3E253FD880740E57F89-806A
   Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0094
   Revision: 4GB20042    Serial number: 4200G08A07814B
   Coding: 000303
   VCID: 46D55738D8A45697B09-8012
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
   Serial number: 1804D255300908
   Component: MEM-FS        H09 0043
   Revision: AA000000    Serial number: 00001001169530
   Coding: 00D872E5002C41000000
   Shop #: WSC 39863 001 104857
03338 - Force Limit for Fore/Aft Seat Adjustment: Forwards
                    Reset counter: 118
                    Mileage: 207303 km
                    Date: 2019.04.14
                    Time: 14:32:05
03330 - Motor for Fore/Aft Adjustment
                    Reset counter: 118
                    Mileage: 207303 km
                    Date: 2019.04.14
                    Time: 14:32:06
03313 - Sensor for Fore/Aft Adjustment
                    Fault Frequency: 27
                    Reset counter: 56
                    Mileage: 207303 km
                    Date: 2019.04.14
                    Time: 14:32:18
03332 - Motor for Height Adjustment
                    Reset counter: 118
                    Mileage: 207303 km
                    Date: 2019.04.14
                    Time: 14:33:31
   Part No SW: 8K0 959 793     HW: 8K0 959 793
   Component: TSG FA        H09 0149
   Revision:             Serial number: YV•
   Coding: 011C03224E002201
   VCID: 7DA7F8D4CDF2D54FA13-8028
02123 - Door Warning Light / Entry Light
                    Fault Status: 00101100
                    Reset counter: 62
01705 - Selection Switch for Mirror-Adjust (E48)
                    Reset counter: 62
02111 - Motor for Window Regulator
                    Reset counter: 62
                    Mileage: 212502 km
                    Date: 2019.06.07
                    Time: 23:16:14
   Revision: 00002001    Serial number: 0115220032
   Coding: 0106069A007A440400B000
   Component: GTO BF  H06 0040
   Serial number: 00000000000000089545
   Subsystem 3 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB10  H01 0180
02615 - Fuel Tank Cap; Lock
                    Fault Status: 01101001
                    Reset counter: 173
                    Mileage: 208532 km
                    Date: 2019.05.01
                    Time: 21:07:08
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 173
                    Mileage: 208532 km
                    Date: 2019.05.01
                    Time: 21:09:04
Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
   Part No SW: 8T0 035 223 S    HW: 8T0 035 223 B
   Component: DSP Prem      H13 0210
   Revision: 00013001    Serial number: 34833002152405
   Coding: 0203010302
                    Fault Status: 00101011
                    Reset counter: 62
                    Mileage: 212502 km
                    Date: 2019.06.07
                    Time: 23:11:42
                    Voltage: 12.20 V
                    Temperature: 26.0°C
                    Temperature: 28.0°C
                    Bin. Bits: 00000100
00871 - Bass Speaker Front Right (R23)
                    Reset counter: 62
                    Mileage: 212502 km
                    Date: 2019.06.08
                    Time: 01:26:17
                    Voltage: 12.20 V
                    Temperature: 29.0°C
                    Temperature: 29.0°C
                    Bin. Bits: 00000100
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                    Reset counter: 71
                    Mileage: 212607 km
                    Date: 2019.06.09
                    Time: 16:26:23
                    Voltage: 12.20 V
                    Temperature: 31.0°C
                    Temperature: 33.0°C
                    Bin. Bits: 00000100
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
                    Reset counter: 65
                    Mileage: 212554 km
                    Date: 2019.06.08
                    Time: 18:11:05
                    Voltage: 12.30 V
                    Temperature: 24.0°C
                    Temperature: 26.0°C
                    Bin. Bits: 00000100
   Part No SW: 8K0 959 792     HW: 8K0 959 792
   Component: TSG BF        H09 0149
   Revision:             Serial number: E•
   VCID: 7CA1F5D0D6E8DC4796D-8028
                    Reset counter: 62
                    Mileage: 212502 km
                    Date: 2019.06.08
                    Time: 01:48:50
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 10000000120459
   VCID: 313F14E4412AE12F75B-8064
   Part No: 8K0 907 357 B
   Component: Dynamische LWR  H01 0030
   Coding: 0000002
   Shop #: WSC 06324 000 00000
   VCID: 34311DF0B238D4071ED-8060
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 195 L    HW: 8T1 035 195 L
   Component: Symph3 Sirius H02 0211
   Revision: 00000004    Serial number: AUZ5Z4H1055847
   Coding: 050300020104850343D9070801
   VCID: 40D94120FA8078A78A5-8014
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0250
   Revision: 00001001    Serial number: 13140782005448
   Coding: 0CD154
   Part No SW: 8T0 862 336 C    HW: 8T0 862 336 C
   Component: FSE_256x BT     H33 0550
   Revision: 00000000    Serial number: 00000005022762
   Coding: 0010370
   VCID: 3B2336CC9F661B7FDF7-806E
End----------(Elapsed Time: 01:42, VBatt start/end: 13.2V/13.3V)-----------
JudeA5Quattro
Ireland
C?ID=305421
Hi Guys, I am new to the forum and really hope that one of the members can help! - My 7 year old got behind the wheel of my my 2007 Audi A5 3.0TDI Quattro and played with the electric seat buttons - I`m not exactly sure what he did but think that he put the Backrest all the way forward - When I tried to re adjust the seat to the normal position I could only move the backrest in the reclining position with no forward movement available and now after several attempts to fix and recalibrate the seat module by moving the seat to its end limits, I have fully reclined the backrest and it will not move to the upright position - All other functions of the seat work! - I have switched the Seat Control Module with the fully functional Passenger Seat Control Module and have also switched the Seat Buttons/Switches and the problem stayed with the Driver Seat so I know that the problem is not the Seat Switch Modules or the Seat Control modules - Having put everything back as stock, I am now getting the errors:
I am hoping that it is possible for me to reprogram / Readapt the Seat Control Module - Any help or advise in solving this is greatly appreciated! - Thank you very Much in advance for any help provided!
Best regards,
JudeA5Quattro.
Full Scan Details as follows:
Wednesday,07,April,2021,13:40:42:21983
VIN: WAUZZZ8T38A005082   License Plate: 07D5675
Mileage:    Repair Order: all modules put back
Gateway Installation List:  8T0 907 468 D
Scan: 01 03 05 06 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 77
VIN: WAUZZZ8T38A005082   Mileage: 261050km-162208miles
Address 01: Engine (J623-CAPA)       Labels:| 059-907-401-V1.clb
   Part No SW: 8K0 907 401     HW: 8K0 907 401
   Component: 3.0TDI EDC17  H01 0008
   Revision: --H01---
   Coding: 01140023180F0118
   ASAM Dataset: EV_ECM30LTDIA5 A01009
   ROD: EV_ECM30LTDIA5_A01.rod
   VCID: 688AB13582F686BB273-803C
   Part No SW: 8K0 907 379 J    HW: 8K0 907 379 J
   Component: ESP8 quattro  H03 0190
   Coding: 1B0500
   VCID: 40DA4995CA869EFBCF3-8014
   Part No SW: 8K0 907 289 A    HW: 8K0 907 289 A
   Component: BCM2.01       H37 0253
   Coding: 031000
   VCID: 372822499F48D9437E9-8062
   Subsystem 1 - Part No SW: 8K0 959 754 D    HW: 8K0 959 754 D
   Serial number: 0813000162343005
   Subsystem 2 - Part No SW: 8K0 905 852 A    HW: 8K0 905 852 A
   Component: ELVAUDIB8  H34 0039
   Serial number: 0207000000064003
   Part No SW: 8T0 959 760     HW: 8T0 959 760
   Component: MEM-BFS       H08 0027
   Revision: AA000000    Serial number: 00001001010682
   Coding: 08217025002444441000
   VCID: 55F488C125040B538C5-8000
                    Reset counter: 236
                    Mileage: 261050 km
                    Date: 2007.01.30
                    Time: 01:40:00
   Part No SW: 8T2 820 043 F    HW: 8T2 820 043 F
   Component: KLIMA 1 ZONE  H04 0093
   Revision: B1000000    Serial number: 0131.05.070079
   Coding: 36060000
   VCID: 3534284185442B536C5-8060
   Part No SW: 8K0 907 063 D    HW: 8K0 907 279 D
   Component: BCM1 1.0      H19 0253
   Revision: 05019001    Serial number: 00000000021081
   Coding: 260050910014AF211709000300005D5D0099038800010101000000
   Shop #: WSC 00011 888 77253
   VCID: 303A19557A260E7B3F3-8064
   Subsystem 1 - Part No SW: 8T2 955 119 B    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 310507  H11 0040
   Serial number: SWFBIE 0000106
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8T0 955 559     HW: 4E0 955 559 B
   Component: RLS  H12 0001
   Serial number: 10006416
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Serial number: 00000000002905070665
03207 - Charisma Switch Module
                    Reset counter: 236
                    Mileage: 261050 km
                    Date: 2007.01.30
                    Time: 01:40:00
   Part No SW: 8K0 919 475     HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0003
   Revision: 11001001    Serial number: 46130634901104
   VCID: 76B6EF4DD8C2604BA5F-8022
   Part No SW: 8K0 959 655     HW: 8K0 959 655
   Component: AirbagVW-AU10 H21 0334
   Serial number: 0038GD0826R/
   Coding: 30323232333030303030554A305238543053
   ASAM Dataset: EV_AirbaECUVWAUDI010 A02001
   VCID: 7AAEFB7DEC5A042BC17-802E
   Serial number: 6334LSME18351305+
   Serial number: 6344LSME1A351B3EL
   Serial number: 6352QSME2D4B3D57Z
   Serial number: 6362QSME2F343953M
   Serial number: 63734SME2F222C1F9
   Serial number: 63834SME2B381C679
   Part No SW: 8K0 953 568 B    HW: 8K0 953 568 B
   Component: Lenks.Modul   H09 0011
   Revision: --------    Serial number: 90304GF10000H
   Coding: 000016
   VCID: 392C2471A95CCF3388D-806C
   Part No SW: 8T0 920 900 G    HW: 8T0 920 900 G
   Component: KOMBIINSTR.   H20 0136
   Revision: 00200000    Serial number: 6D6136R57
   Coding: 2305010002000008010000
   Part No SW: 8T0 907 468 D    HW: 8T0 907 468 D
   Component: GW-BEM 5CAN   H04 0084
   Revision: GA800029    Serial number: 2900G07428800C
   Coding: 000003
   Shop #: WSC 00280 209 71611
   VCID: 42DE439DC48A8CEBD97-8016
   Subsystem 1 - Part No SW: 8K0 915 181     HW: 8K0 915 181
   Component: J367-BDM  H06 0150
   Serial number: 17001799100507
                    Reset counter: 236
                    Mileage: 261050 km
                    Date: 2007.01.30
                    Time: 01:40:18
   Component: MEM-FS        H08 0027
   Revision: AA000000    Serial number: 00001001010706
   Coding: 08217005002444441000
   Revision:             Serial number: 0h`
   Coding: 0110022250012201
   VCID: 7DA4F061FDF43313E45-8028
   Revision: 00002001    Serial number: 0104776558
   Coding: 01000680003900C0012000
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223     HW: 8T0 035 223
   Component: DSP STD       H07 0200
   Revision: 15S00000
   Coding: 0203010102
   VCID: 6B80CE399380ADA34A1-803E
                    Reset counter: 236
                    Mileage: 261050 km
                    Date: 2007.01.30
                    Time: 01:40:17
                    Voltage: 14.50 V
                    Temperature: 15.0°C
                    Bin. Bits: 00000001
   Revision:             Serial number: 0•)`
   Coding: 011002225C012201
   VCID: 7CA2FD65E6EE3A1BD3B-8028
   Part No SW: 8K0 907 801 C    HW: 8K0 907 801 C
   Component: EPB Audi B8   H03 0030
   Revision: 00000001    Serial number: 00000000007280
   VCID: 2F381A2967181183269-807A
   Coding: 0000002
   VCID: 72BED35DB8AA7C6B897-8026
   Part No SW: 8T2 035 186     HW: 8T2 035 186
   Component: Concert3      H10 0050
   Revision: 00000508    Serial number: AUZ5Z6G1000356
   Coding: 0502008201048D0001DB070000
   VCID: 75B4E841C5C46B53AC5-8020
                    Reset counter: 236
                    Mileage: 261050 km
                    Date: 2007.01.30
                    Time: 01:40:17
02259 - Information Display and Control Head (Front) (J685)
                    Reset counter: 236
                    Mileage: 261050 km
                    Date: 2007.01.30
                    Time: 01:40:23
End----------(Elapsed Time: 01:13, VBatt start/end: 14.4V/14.4V)-----------
JudeA5Quattro
Ireland
C?ID=305421
..So I have made some progress - I took the back of the seat off and now know what wires power the Backrest Motor - There are 4 wires - 2 of which are larger gauge = 1 brown & yellow to pin 1 of the 12 pin port on the Module and 1 red & yellow to pin 6 of the 12 pin port on the module. The 2 lighter guage wires are 1 green & brown with the other being blue & brown - I am not sure of the pin numbers but these go to the smaller 10 pin port on the controls module. - I am planning on sending 12 volts to the backrest motor from an external battery to get it back in an upright position - I assume that the larger gauge wires are the power runs but the smaller wires are now confusing me - can I just apply the 12 volts to pin 1 and pin 6 altering the polarity by swapping the positive and negative from my external battery? - any ideas or advice before I proceed?
JudeA5Quattro
Ireland
C?ID=305421
...I tried to add some pics of my A5 seat module and seat with the back cover off with the backrest motor wires exposed but they did not up load!
Westbury, UK
You have to save the pictures to an image hosting website (I use imgur) then copy the direct link and paste that here using the forum image icon to create img tags.
JudeA5Quattro
Ireland
C?ID=305421
Thanks for that Petrol Dave - I will try to post som pics soon! - I got the seat buck up! - +12 Volts to pin1 netagtve terminal at Pin 6 - Car Battery was disconnected to be on the safe side!
JudeA5Quattro
Ireland
C?ID=305421
.....I am coming to the same conclusion that Rick916 came to - questioning if there is some control function of the seat control module which disables the 12V to the backrest motor if the for & Aft limits are reached/pushed - does any body know if it is possible to "unblock the module" if this is the case?
