09 Jetta TDI How to code for window up/down via remote?
alhersch
Central, IN
C?ID=253584
I have read up some on how to do long code to setup the remote to put the windows down and up but I don't seem to have that option on my car. Shouldn't there be a Bit 4 on byte 3 to enable this option???
Friday,31,July,2015,10:58:24:55727
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: 3VWRL71K59M073072   License Plate: NA
Mileage: 158560km-98524mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 65 72
VIN: 3VWRL71K59M073072   Mileage: 158560km-98524miles
Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 016 P    HW: 03L 906 022 J
   Component: R4 2,0L EDC G000AG  8681
   Revision: 12H01---    Serial number: VWX7Z0H924I0J9
   Coding: 0050078
   Shop #: WSC 00066 000 00000
   VCID: 3F8D11D96EA413D9575-806A
001151 - Exhaust Pressure Control Valve
               P047F - 000 - Stuck Open
                    Mileage: 158557 km
                    Time: 10:33:36
                    RPM: 1380 /min
                    Speed: 16.0 km/h
                    Load: 24.3 %
                    Load: 9.8 %
                    Lambda: 91.5 %
                    Temperature: 42.0°C
                    Temperature: 26.1°C
001162 - Exhaust Pressure Control Valve 1
               P048A - 000 - Stuck Closed - Intermittent
                    Mileage: 158513 km
                    Time: 13:42:04
                    RPM: 1173 /min
                    Speed: 51.0 km/h
                    Load: 11.4 %
                    Lambda: 53.7 %
                    Temperature: 120.0°C
                    Temperature: 40.5°C
008817 - Oxygen (Lambda) Sensor Signal B1 S2
               P2271 - 000 - too Rich - MIL ON
                    Fault Status: 11100000
                    Mileage: 158531 km
                    Time: 12:17:57
                    RPM: 2346 /min
                    Speed: 121.0 km/h
                    Lambda: 38.7 %
                    Mass Air / Rev.: 550.0 mg/str
                    Voltage: 0.525 V
                    (no units): 0.01
                    Voltage: 0.975 V
Readiness: 1 2 0 0 0
   Part No SW: 02E 300 051     HW: 02E 927 770 AJ
   Component: GSG DSG AG6     431 1814
   Revision: 04843012    Serial number: 00000807220488
   Shop #: WSC 02069 000 90108
   VCID: 50AF2265C33A9CA1BEF-8005
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AE    HW: 1K0 907 379 AE
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 113B400D492900FD880B02EB921B0042B100
   VCID: 75E1B3F1DC1899894D9-8020
   Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
   Component: Climatic PQ35   142 1212
   Revision: 00142032    Serial number: 00000000000000
   VCID: 78FFBAC50B0AE4E156F-802D
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000001101993
   Coding: 14018E234004150007140000001400000008730B5C000120000000000000
   VCID: 326B48EDADF6CEB1A8B-8067
   Component: Wischer 181008 021  0501
   Coding: 00038805
   Shop #: WSC 00066
                    Fault Status: 00101100
                    Reset counter: 209
                    Mileage: 157898 km
                    Voltage: 11.55 V
                    Reset counter: 209
                    Mileage: 157898 km
                    Voltage: 11.90 V
                    Fault Status: 00101010
                    Reset counter: 209
                    Mileage: 157898 km
                    Voltage: 11.90 V
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0447403
   Coding: 0000100
   VCID: 33654DE952ECC7B9A3D-8066
            000 -  -
                    Reset counter: 112
                    Mileage: 155460 km
                    Time: 09:59:13
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M07ATNP
   Coding: 0013889
   VCID: 6CD796954F525841A27-8039
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME3E142778H
   Subsystem 3 - Serial number: 6342MSME40256D215
   Subsystem 4 - Serial number: 6351HSME1819137EB
   Subsystem 5 - Serial number: 6361HSME181D713AC
   Subsystem 6 - Serial number: 63727SME1859475FE
   Subsystem 7 - Serial number: 63827SME185854271
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
   Part No SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
   Component: J0527           057 0101
   Coding: 0012021
   VCID: 0407DE3547C2B0014A7-8051
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
   Part No SW: 1K0 920 974 N    HW: 1K0 920 974 N
   Component: KOMBIINSTRUMENT 3HL 2418
   Revision: V0003000    Serial number: VWX7Z0H924I0J9
   Coding: 0023203
   VCID: 39797FC170803DE9691-806C
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 060908F1000955
   Coding: ED807F070013021002
   Shop #: WSC 22207 444 59412
   VCID: 356173F15C98D9898D9-8060
   Part No SW: 1K5 919 965 A    HW: 1K5 919 965 A
   Component: Kompass         005 0004
   Revision: 00005000    Serial number: 1293324T3E4Y04
   Coding: 0000003
   Component: IMMO            3HL 2418
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000630488929
   Coding: 0001205
   VCID: 6FED81997E44A359875-803A
                    Fault Status: 00100101
                    Reset counter: 218
00109 - Left Mirror Turn Signal Lamp (L131)
                    Fault Status: 01101100
                    Reset counter: 187
                    Mileage: 117104 km
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   VCID: 2A5B508D8526867110B-807F
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Coding: 13900F880186281B0904058FB0880F0488DC00
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 08091802230702
   Coding: 0001204
   VCID: 70EF82E5637ABCA19EF-8025
                    Reset counter: 215
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio DE2       016 0020
   Revision: 00016000    Serial number: VWZ4Z7H2244021
   Coding: 0040401
   VCID: 2959AF8180208D69191-807C
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003519033
   Coding: 0001168
   VCID: 76E3B4FD011E9291443-8023
   Coding: 0100101
00625 - Vehicle Speed Signal
                    Reset counter: 206
                    Mileage: 157814 km
                    Time: 10:24:31
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000003524930
   Coding: 0001168
   VCID: 77FDB9F90614EB995F5-8022
End-------------------------(Elapsed Time: 03:10)--------------------------
That's still an Mk.5. That means it's going to be in 46: Central Convenience, Byte 7 I believe.
alhersch
Central, IN
C?ID=253584
Thanks Uwe! Found it in 46. I couldn't find this info anywhere! Either i'm blind or can't read... LOL
Al
