VCDS Version: Release 15.7.0 Running on Windows 8.1 x86
Data version: 20150729
Thursday,06,August,2015,16:36:22:41105
Chassis Type: FP (8R0)
Scan: 01 02 03 05 08 09 14 15 16 17 19 36 42 44 46 47 52 53 56 5F
62 6C 6D 72
VIN: WA1DGAFP9DA037579 Mileage: 135010km-83891miles
Address 01: Engine (J623-CTUC) Labels: None
Part No SW: 8R0 907 551 A HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0001
Revision: --H07---
Coding: 2A2A0034052601060000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM30TFS0218R0907551A 001002
ROD: EV_ECM30TFS0218R0907551A.rod
VCID: 3620EC0489E7EC8EBC-8062
6322 - Air Intake System
P307A 00 [032] - Flow too Low
Mileage: 134974 km
Date: 2015.08.06
Time: 13:12:11
6307 - MAP/MAF <-> Throttle Position Correlation
P0068 00 [096] - -
Mileage: 134974 km
Date: 2015.08.06
Time: 13:12:12
Readiness: 0000 0100
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 8R0 927 158 AM HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H16 1003
Revision: --H16---
Coding: 000002
ASAM Dataset: EV_TCMAL551211 002020
ROD: EV_TCMAL551211_AU48.rod
VCID: 085C52FCB393AA7E1E-805C
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 8R0 907 379 AK HW: 8R0 907 379 AK
Component: ESP8 quattro H09 0080
Coding: 191D1C
Shop #: WSC 06335 000 00000
VCID: 095A57F8A099D37601-805C
Fault Frequency: 32
Reset counter: 61
Mileage: 134804 km
Date: 2015.08.03
Time: 18:04:28
Hex Value: 0x00C0
Hex Value: 0x07A2
Hex Value: 0x0015
Hex Value: 0x1094
Hex Value: 0x0000
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 GP HW: 8K0 907 064 FP
Component: BCM2 2.0 H11 0621
Coding: 0DA54040000000000000
VCID: 044446CC87BB8E1E72-8050
Subsystem 1 - Part No SW: 8K0 959 754 B HW: 8K0 959 754 B
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Revision: C1000000 Serial number: 01011120121276
Coding: 66183A8080
Shop #: WSC 06335 123 12345
VCID: 393AE738B0F903F651-806C
Reset counter: 60
Mileage: 134804 km
Date: 2015.08.03
Time: 18:02:53
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000502516202
Coding: 2600000181388FE01F00408300003D0D4F9CC748A6090221000008004000070100000034000000
Shop #: WSC 52140 001 104857
VCID: 78BC223CCB73DAFE6E-802C
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 121023 H11 0050
Coding: 01D513
Component: G397_RLFS H06 0002
Coding: 02005C
Component: E1 - LDS H03 0031
Component: USHL4.2 H30 0030
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
03110 - Active Steering Control Module (J792)
Reset counter: 59
Mileage: 134853 km
Date: 2015.08.04
Time: 14:38:10
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8R0 907 364 C HW: 8K0 907 364
Component: DAEMPFUNGS-SG H09 0054
Revision: 00000000 Serial number: 16101201280001
Coding: 010181
VCID: 3A38F834B5FF08EE58-806E
00457 - Control Module for Network (J519)
Reset counter: 100
Mileage: 134853 km
Date: 2015.08.04
Time: 14:31:21
Bin. Bits: 00000000 00000010
Bin. Bits: 00000000 00000000
Address 15: Airbags (J234) Labels: 8R0-959-655.clb
Part No SW: 8R0 959 655 F HW: 8R0 959 655 F
Serial number: 003GPD90YDUE
Coding: 303634313432303030304A55304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 47DE91C0FE0D6506D7-8012
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R120000BAGZ
Serial number: 6334MSME73204C001
Serial number: 6344MSME7320447FG
Serial number: 6352QSME6221304A5
Serial number: 6362QSME30233E76G
Serial number: 63732SME47241758.
Serial number: 63832SME49245350W
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 L HW: 8K0 953 568 L
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372LJQ000H8
Coding: 000037
VCID: 43C685D0C23549260B-8016
Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb
Part No SW: 8R0 920 980 T HW: 8R0 920 980 T
Component: KOMBIINSTR. H35 0556
Revision: 00000000 Serial number: UWH5AAZAD
Coding: 035D22001301D705020001
VCID: 4AD8A8F4E51F986EC8-801E
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0055
Revision: 1Y060027 Serial number: 2741Y12A220261
Coding: 80CF07FF00
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0141
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0076
Revision: AA000000 Serial number: 00000038219943
Coding: 01581B00000000000000
VCID: 42C880D4DD2F402E00-8016
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 P HW: 8K0 959 793 P
Component: TSG FA H02 0506
Revision: Serial number: 0000043523668
Coding: 011D13205E00440004
VCID: 4DD2A3E814718F56ED-8018
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 8R0 909 144 P HW: 8R0 909 144 B
Component: RCEPS H43 0510
Revision: 00001000 Serial number: 0014514699
Coding: 000000000000
ASAM Dataset: EV_RCEPSAU48X 008018
ROD: EV_RCEPSAU48X.rod
VCID: 45C29BC8C401771625-8010
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0186866330
Coding: 01261E3A20FA70958730053600040007
Shop #: WSC 45202 123 104857
Component: GTO BF H01 0080
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H04 0220
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H04 0220
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813007565802
VCID: 2D12C36874B1AF56CD-8078
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 P HW: 8K0 959 792 P
Component: TSG BF H02 0506
Revision: Serial number: 0000043760237
VCID: 4CD4AEECEF6B865EFA-8018
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 10000000123198
ROD: EV_ParkiBrake_AU48.rod
VCID: 383CE23C83F31AFEAE-806C
Revision: AB001007 Serial number: 156KC0C7662995
Coding: 020007010000000001
VCID: 2404264C277B6E1E12-8070
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8R1 035 746 G HW: 8R1 035 746 B
Component: H-BNT-NA H44 0901
Revision: -------- Serial number: 204JR0C7540151
Coding: 1A0200060205E3FF47029F5E0B000403140000000100000000
VCID: 3B36FD30BAC531E643-806E
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: CD-Database 4949
Reset counter: 61
Mileage: 135019 km
Date: 2015.08.06
Time: 16:27:12
Bin. Bits: 00000000 00001010
Bin. Bits: 00000000 00000001
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000043649578
Coding: 010C13204000240004
VCID: 46C09CC4F1077C0E2C-8012
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Revision: --H07--- Serial number: 525PA8-J2XA4EL
Coding: 1020010
VCID: 3424D60C579BFE9E82-8060
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H52 0330
Revision: -------- Serial number: 8R0827851B
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H52 0330
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000071759842
Shop #: WSC 45202 000 1048576
End-------------------------(Elapsed Time: 02:59)--------------------------
