- Apr 11, 2014
- 45
- 15
- Mackay Qld Australia
- C?ID=240542
Hi All
Looking to retrofit the above feature in my T Cross. I have managed to get an Autoscan of a R Line T Cross with the feature factory fitted and from my research I need to change my steering wheel to include the Travel Assist activation button instead of the short cut button to the Assistance System Menu. I have found what I think is a suitable replacement part number 3G0419089AJ but it also includes a heated steering wheel option which appears to not be an option in the Australian Market T Cross. The seller says it is suitable for the Golf 8 and Passat 3G
My first question will TA work with a straight replacement with the above steering wheel and coding the relevant ECU's using VCDS or will i have to change more parts and do more advanced coding or flashing of ECU's?
Secondly will it be possible to activate the heated steering wheel option as it is ( The button is already on the wheel) or will it require extra wiring?
If the latter is not possible will it throw an error code even though it is not activated power wise but is seen in the canbus network?
I have attached the Autscans of firstly mine and secondly the R Line with TA fitted from factory
Wednesday,09,November,2022,16:13:38:26570
VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
VIN: WVGZZZC1ZNY019566 License Plate:
Chassis Type: C1-VW27 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 3C 44 5F A5
VIN: WVGZZZC1ZNY019566 Mileage: 8828km-5485miles
Address 01: Engine (J623-DKJA) Labels:. 04E-907-309-V1.clb
Part No SW: 04C 906 025 G HW: 04C 907 309 BB
Component: R3 1.0l TFS H20 7716
Revision: D7H20000 CVN: 05443C2F
Coding: 01250032236415080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM10TFS01104C906025G 002005
ROD: EV_ECM10TFS01104C906025G_002.rod
VCID: 2411E163CE5D838BA3B-8070
VINID: 9E65EAAAA4C1A9EA400491461881A61547
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 051 D HW: 0AM 927 769 N
Component: GSG DQ200G2_M H07 1905
Revision: 00007009 Serial number: CU502108116330 CVN: AB2F8AB0
ROD: EV_TCMDQ200021_VW27.rod
VCID: 372B262F6FCBF813169-8062
Part No SW: 2Q0 614 517 AQ HW: 2Q0 614 517 M
Component: ESC_high_vFGS H34 0362
Serial number: 08505001210909
Coding: 92054C3E3D4249B63201BC1C12E011A649264D06226A244844546255454888659264B26044562412222A46AAA272964FFF4E69F2FF90AC90093509
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 005001
ROD: EV_Brake1BOSCHESPMQBA0_005.rod
VCID: 7DA7F4070D7712438C5-8028
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 2GN 820 045 B HW: 2GN 820 045 B
Component: SG_AC_Manuell H70 0601
Coding: 612100000800010001000800020000000000000000000000000000000000
ASAM Dataset: EV_ACManuePrehMQBA0 001013
ROD: EV_ACManuePrehMQBA0.rod
VCID: 3C21390356EDDB4BFBB-8068
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 2Q0 937 088 HW: 2Q0 937 088
Component: BCM A0 Std+ H12 0954
Serial number: 01102124400379
ASAM Dataset: EV_BCMA0 207001
ROD: EV_BCMA0_207_VW27.rod
VCID: 76B5EB2B2841411BCDF-8022
Subsystem 1 - Part No SW: 5Q0 955 559 C HW: 5Q0 955 559 C Labels: 5Q0-955-547.CLB
Component: RLS 054 0206
Serial number: S2Y21M07D01H07M47S56
Coding: 0018DD
Driver door control module:
Subsystem 2 - Part No SW: 2Q1 959 405 E HW: 2Q1 959 163 D
Component: FHSG_DRV 002 0003
Serial number: 00000000000053797623
Coding: 0F8003
Front passenger door control module:
Subsystem 3 - Part No SW: 2Q1 959 406 E HW: 2Q1 959 164 D
Component: FHSG_PSG 002 0003
Serial number: 00000000000053713015
Coding: 158003
Subsystem 4 - Part No SW: 5Q0 959 408 D HW: 5Q0 959 164 C
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000053887292
Coding: 1F0000
Subsystem 5 - Part No SW: 5Q0 959 407 D HW: 5Q0 959 163 C
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000053891645
Coding: 070000
Part No SW: 5QA 919 298 K HW: 5QA 919 298 A
Component: PLA 3.0 12K H08 0073
Serial number: 000150057321215
Coding: 8371167851
ASAM Dataset: EV_EPHVA2CAU3700000 009055
ROD: EV_EPHVA2CAU3700000.rod
VCID: 58E98593C295176BFF3-800C
Part No SW: 2Q0 907 572 T HW: 2Q0 907 572 B
Component: ACCCONTIMQB H07 0383
Coding: 3204670300FF8748949C810580508700000000000000000004
ASAM Dataset: EV_ACCMRRCONTIVW376 003018
ROD: EV_ACCMRRCONTIVW376_003.rod
VCID: 45D75CE725279A83945-8010
Part No SW: 2Q0 959 655 AS HW: 2Q0 959 655 AS
Component: VW22Airbag 020 0411
Revision: --------
Coding: 88CCC0C0000000035C540000008C00A80065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001036
ROD: EV_AirbaVW22BPAVW27X_VW27.rod
VCID: 0E45A3CB30D119DB65F-805A
Left seat belt tensioner:
Subsystem 1 - Part No SW: 654 980 945 A HW: 654 980 945 A
Component: BeltPretRevFL 005 0060
Serial number: 278A.001726082100144
Coding: 303630
Right seat belt tensioner:
Subsystem 2 - Part No SW: 654 980 946 A HW: 654 980 946 A
Component: BeltPretRevFR 005 0060
Serial number: 278A.000227082100192
Coding: 303630
Subsystem 3 - Part No SW: ----------- HW: 442 062 701 21
Serial number: 3577Y5399006DBE1B37J
Subsystem 4 - Part No SW: ----------- HW: 442 062 701 21
Serial number: 3587Y53AD00A2351F241
Subsystem 5 - Part No SW: ----------- HW: 442 0B2 408 21
Serial number: 3517786A906FD11362DU
Subsystem 6 - Part No SW: ----------- HW: 442 0B1 708 21
Serial number: 3527711A506CC5F5206I
Subsystem 7 - Part No SW: ----------- HW: 442 133 008 21
Component: FrontSensor_D 290 118A
Serial number: 355AG53B8C63F894C35E
Part No SW: 2G0 920 740 J HW: 2G0 920 740 J
Component: KOMBI 204 8400
Coding: 24A4110B658800080188220B5001000000000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001044
ROD: EV_DashBoardVDDMQBA0_001_VW27.rod
VCID: 290FF057A97F5EE390D-807C
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_Audio_0x31 keine Kommunikation]
Reset counter: 231
Mileage: 7727 km
Date: 2022.10.03
Time: 12:47:56
U1110 00 [008] - -
[BAP_TEL_0x28 keine Kommunikation]
Reset counter: 231
Mileage: 7727 km
Date: 2022.10.03
Time: 12:48:01
9456681 - Key
B104C 29 [008] - Implausible Signal
Mileage: 8257 km
Date: 2022.10.28
Time: 09:00:21
Part No SW: 3Q0 907 530 AL HW: 3Q0 907 530 E
Component: GW MQB High 524 5463
Serial number: 17082111602169
Coding: 030100346F0857002200005C1C0F00010001070000000000000000000000
GVL: 01443C000000000040C080000000C80000000000000000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 79AFE017195F2E63A0D-802C
Generator:
Component: 4-00-02-00-04
Subsystem 2 - Part No SW: 3G0 959 442 AB HW: 3G0 959 442 AB Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H07 0120
Serial number: PR6-0440066200212628
Coding: 2D2D00
Subsystem 3 - Part No SW: 2Q0 915 181 B HW: 2Q0 915 181 B
Component: J367-BDMBOSCH H02 2012
Serial number: 101EF2BA
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0150
Serial number: 14520010933662
Coding: 92954620
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
VCID: 392F201759DFEE63E0D-806C
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H06 0150
Serial number: 14520010939767
Address 44: Steering Assist (J792) Labels:* 2Qx-909-144-V1.clb
Part No SW: 2Q2 909 144 S HW: 2Q2 909 144 S
Component: TRW_G4L_MQBA0 622 6042
Serial number: 02671910CB4M249
Coding: 010001010100000001010201010001000000010101
ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
ROD: EV_SteerAssisTRWG4LMQBA0.rod
VCID: 43D342FF2B13A4B3BA1-8016
Part No SW: 3G9 035 832 A HW: 3G9 035 832 A
Component: MU-O-ND-R2 H22 0278
Serial number: VWZAZ2Y0816981
Coding: 22160008000000000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001001
ROD: EV_MUOIMQB_001_VW27.rod
Subsystem 1 - Part No SW: 5NN 919 605 A HW: 5NN 919 605 A
Component: ABT_Std-2 381 8304
Serial number: VWZ6ZHY2462095
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 2Q0 980 653 C HW: 2Q0 980 653
Component: MQB MFK 3.0 H16 1302
Serial number: E81904310212290
Coding: 00000C1001CAC020509E00000000000000018000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007042
VCID: 35372C2775C70A03045-8060
R Line
Monday,13,March,2023,10:13:47:26570
VCDS Version: 23.3.0.0 HEX-V2 CB: 0.4631.4
VIN: WVGZZZC1ZPY003809 License Plate:
Mileage: 854km-530mi Repair Order:
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 3C 44 47 55 5F A5 D6 D7
VIN: WVGZZZC1ZPY003809 Mileage: 854km-530miles
Coding: 0125003223641D081000
ROD: EV_ECM10TFS01104C906025G_002_VW27.rod
VCID: 2411E163CE5D838A4BB-8070
VINID: 9E65EAAAA4C1AA0A400032002476A96703
Revision: 00007009 Serial number: CU502206116418 CVN: AB2F8AB0
VCID: 372B262F6FCBF812FE9-8062
Serial number: 08503994220615 Dataset Number: V03935346JN 0001
Coding: 92054C3E3D4149B03204BC1612E311A649264D06226A244844546255454888659264B26044562412222A46AAA271964FFF8E69F2FF90AC90093509
ROD: EV_Brake1BOSCHESPMQBA0.rod
VCID: 7DA7F4070D771242645-8028
1272 - Tire Pressure Warning
C102D 00 [137] - -
Reset counter: 64
Mileage: 830 km
Date: 2023.03.08
Time: 12:34:26
Part No SW: 3Q0 959 435 Q HW: 3Q0 959 435 Q
Component: VWKESSYMQB 037 1400
Revision: 00037000 Serial number: 0598546792 Dataset Number: V03935330VN 0001
Coding: 132C0C0723
ASAM Dataset: EV_KessyHellaMQBAB 004055
ROD: EV_KessyHellaMQBAB.rod
VCID: 48C955D3123587EA873-801C
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: 2GN 907 044 HW: 2GN 907 044
Component: Climatronic H24 0106
Dataset Number: V03935349YY 0001
Coding: 612100002800010001100800024401150100000000000000000000000000
ASAM Dataset: EV_ACClimaBHBMQBA0Touch 001008
ROD: EV_ACClimaBHBMQBA0Touch_VW27.rod
VCID: 7F5B0E0F077B0052769-802A
Part No SW: 2Q0 937 090 E HW: 2Q0 937 090 C
Component: BCM A0 Std+ H12 0963
Serial number: 00102217301871 Dataset Number: V03935371HU 0001
ASAM Dataset: EV_BCMA0 208001
ROD: EV_BCMA0_207_VW37.rod
VCID: 343111237EBD130ADBB-8060
Subsystem 1 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 054 0206
Serial number: SAY22M06D21H09M20S57
Coding: 0018DD
Serial number: 00000000000061581332
Coding: 0F80F3
Serial number: 00000000000061309392
Coding: 1580F3
Serial number: 00000000000061305633
Coding: 1F0000
Serial number: 00000000000061232808
Coding: 070000
Serial number: 000150057322146 Dataset Number: V03935337KS 0001
Coding: 8371167851
ROD: EV_EPHVA2CAU3700000_VW27.rod
VCID: 58E98593C295176A173-800C
Address 13: Auto Dist. Reg (J428) Labels:| User\2Q0-907-572.lbl
Part No SW: 2Q0 907 572 AA HW: 2Q0 907 572 D
Component: ACCCONTIMQB H09 0396
Dataset Number: V03935361HM 0001
Coding: 3004674348FF8748949C810580508700000000000000000024
VCID: 73B3D23F3B335432021-8026
Revision: -------- Dataset Number: V03935351MW 0001
VCID: 0E45A3CB30D119DA8DF-805A
Serial number: 278A.001715062200517
Coding: 303630
Serial number: 278A.001715062200769
Coding: 303630
Subsystem 3 - Part No SW: ----------- HW: 442 060 706 22
Serial number: 3577Y50BD096FEA251EW
Subsystem 4 - Part No SW: ----------- HW: 442 060 706 22
Serial number: 3587Y50AF096FEB2D52Z
Subsystem 5 - Part No SW: ----------- HW: 442 0B2 406 22
Serial number: 3517736A7097934180DH
Subsystem 6 - Part No SW: ----------- HW: 442 0B2 506 22
Serial number: 3527731A5098C012B2FH
Subsystem 7 - Part No SW: ----------- HW: 442 131 606 22
Serial number: 355AG03AEC88EB82B97R
Part No SW: 2G0 920 320 B HW: 2G0 920 320 B
Component: KOMBI 524 6220
Dataset Number: V03935349WP 0001
Coding: 24A410186D8800080188624B5001000080000404
ASAM Dataset: EV_DashBoardVDDMQBA0 001048
VCID: 1B63DA9FF323BC72FA1-804E
16777022 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_NAV SD_0x32 keine Kommunikation]
Fault Frequency: 14
Reset counter: 97
Mileage: 300 km
Date: 2023.02.17
Time: 08:01:08
Part No SW: 3Q0 907 530 AR HW: 3Q0 907 530 E
Component: GW MQB High 524 5502
Serial number: 19062210522153 Dataset Number: V03935378NP 0001
Coding: 030900046F0857002200025C1C0F00010001070000000000000000000000
GVL: 01443C000000060040C090000080C80000000000000000000000000000000000
Generator:
Subsystem 2 - Part No SW: 3G0 959 442 AE HW: 3G0 959 442 AE Labels: 3C8-959-537.CLB
Serial number: PR6-0440071175220732
Coding: 2D2F00
Component: J367-BDMBOSCH H03 2012
Serial number: 10298365
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H10 0021
Serial number: 22000150377012 Dataset Number: V03935279SD 0001
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 313F183781AF2622B0D-8064
Address 3C: Lane Change (J1086) Labels:| User\2Q0-907-686.lbl
Serial number: 14520016347728 Dataset Number: V03935345YL 0001
Coding: 92954620
VCID: 392F201759DFEE6208D-806C
Serial number: 14520016306895
Part No SW: 2Q2 909 144 AB HW: 2Q2 909 144 AB
Component: TRW_G4L_MQBA0 623 6050
Serial number: 03145795CB4N175 Dataset Number: V03935378KS 0001
Part No SW: 2G0 035 456 HW: 2G0 035 456
Component: AMPeth8C H04 3131
Serial number: A1128A00098274 Dataset Number: V03935327NR 0001
Coding: 22000000000000000000000000000000000000000000000000
ASAM Dataset: EV_AMPEthMQB 001005
ROD: EV_AMPEthMQB_VW27.rod
VCID: 6099AD739AC5DFAA6F3-8034
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Revision: -------- Serial number: -------------- Dataset Number: V03935371SX 0001
Coding: 068E000001200003
ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
VCID: 41DF48F7310FB6A240D-8014
Address 5F: Information Electr. (J794) Labels:| User\3G9-035-832.lbl
Part No SW: 3G9 035 832 C HW: 3G9 035 832 C
Component: MU-O-ND-R2 H22 0306
Serial number: VWZAZ2A0738118 Dataset Number: V03935353WK 0001
VCID: 2B030A5FA3834CF28A1-807E
Subsystem 1 - Part No SW: 5NN 919 605 B HW: 5NN 919 605 B
Component: ABT_Std-2_Nav 381 8304
Serial number: VWZ6ZHA1802077
Subsystem 2 - Part No: V03 959 817 TC
Component: MRM 2022/23 7065
6720 - Rear View Camera
B1102 31 [008] - No Signal
Reset counter: 20
Mileage: 565 km
Date: 2023.02.23
Time: 08:10:11
Voltage terminal 30: 12.7 V
Address A5: Frt Sens. Drv. Assist (R242) Labels:| User\2Q0-980-653.lbl
Part No SW: 2Q0 980 653 D HW: 2Q0 980 653
Component: MQB MFK 3.0 H16 1401
Serial number: EA1567403221730 Dataset Number: V03935374AJ 0001
Coding: 00000C1011CEC020089E00000020002000418000000000000000000000000000
VCID: 36352B2B68C1011AE5F-8062
Part No SW: 992 941 571 AC HW: 992 941 571 A
Component: LED1L H08 9201
ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
VCID: 6393A27F8BD3C4B2721-8036
Component: LED1R H08 9201
